Skip Headers
Oracle® Enterprise Manager Cloud Control Upgrade Guide
12c Release 1 (12.1.0.1)
E22625-09
  Go To Table Of Contents
Contents
Go To Index
Index
Previous
Previous
Next
Next
F Setting Preferred Credentials Using EMCLI
When you provide the agent credentials, you can choose to enter the preferred credentials registered with the Enterprise Manager system. However, ensure that the credentials were registered using EMCLI.
To run these commands, you must have the EMCLI Client installed on the hosts. If you do not have EMCLI, install one following the instructions outlined in Oracle Enterprise Manager Command Line Interface Guide.
