Skip Headers
Oracle® Enterprise Manager Cloud Control Upgrade Guide
12c Release 1 (12.1.0.1)
E22625-09
  Go To Table Of Contents
Contents
Go To Index
Index
Previous
Previous
Next
Next
24 Checking Agent Upgrade Status
Perform these steps in the Enterprise Manager Grid Control console of the earlier release.
To check the status of the agent upgrade operations, follow these steps:
  1. In Grid Control, click Deployments.
  2. On the Deployments page, in the Upgrade section, click Enterprise Manager 12c Upgrade Console.
  3. On the Upgrade Console page, do the following:
    • For macro-level details, in the Agent Upgrade Status section, view the count displayed against the following:
      • Successful, to identify the Management Agents that have been successfully upgraded.
      • Failed, to identify the Management Agents that failed to get upgraded.
      • In Progress, to identify the Management Agents that are currently being upgraded.
      • Not Started, to identify the Management Agents that are yet to be upgraded.
      • Not Supported, to identify the Management Agents that are not supported in the upgraded Enterprise Manager system because Oracle Management Agent 12c is not released for a particular platform.
        To drill down and view more information, click the count value. Enterprise Manager Grid Control displays the Agent Upgrade Status page that provides information.
    • For micro-level details, in the Other Links section, click Agent Upgrade Status.
      On the Agent Upgrade Status page, do the following:
      • To filter the list according to your needs and view only the upgrade operations that interest you, use the search functionlity.
        For example, to view only the deployment operations that have failed, select Deployment from the Operation Type list, and select Failed from the Operation Status list, and click Search.
        An Operation Type refers to a job submitted for a particular agent upgrade step such as Deployment, Configuration, Health Check, Upgrade, or Switch Over. An operation name refers to the operation name you specified while submitting any of these jobs. And each of these operations can have a status such as Not Started, In Progress, Success, Not Supported, Failed, or Pending Report Verification.
      • To deploy the agent software, select one or more Management Agent from the table, and click Deploy and Configure Agent.
        You cannot deploy and configure Oracle Management Agent 12c for problematic Management Agents. To identify problematic Management Agents, see Identifying Problematic Oracle Management Agents.
        Also, you can deploy and configure Oracle Management Agent 12c only on existing Management Agents that are either completely upgradable or upgradable with missing plug-ins. To identify the upgradability status of the Management Agents, see Checking the Upgradability Status of Oracle Management Agents.
      • To check the health and readiness of the deployed Management Agent, select one or more Management Agents, and click Check Agent Readiness.
      • To view the readiness check details, select one or more Management Agents, and click View and Verify Health Check Reports.
        On the Agent Readiness Check Details page, review the reports one by one. If you want to confirm that you have verified the report, then select the Management Agent and click Verify and Sign Off Report. If you want to view more details about the readiness check, then select the Management Agent and click View Detailed Report.
      • To switch over the agents, select one or more Management Agents, which have successfully been deployed, configured, and health-checked, and click Switch Agent.
