| Oracle® Enterprise Manager Cloud Control Upgrade Guide 12c Release 1 (12.1.0.1) E22625-09 |
![]() Previous |
![]() Next |
Note: Perform these steps in the Enterprise Manager Grid Control console of the earlier release. |
To manage information about the location of the core Management Agent software and its associated plug-ins, follow these steps:
In Grid Control, click Deployments.
On the Deployments page, in the Upgrade section, click Enterprise Manager 12c Upgrade Console.
On the Upgrade Console page, in the Select Upgrade Type section, select one of the following. For information about these upgrade approaches, see "Understanding Upgrade Approaches".
To upgrade your Enterprise Manager system with downtime (even if you manually install Management Agents), select 1-System.
To upgrade your Enterprise Manager system with "near zero" downtime (even if you manually install Management Agents), select 2-System.
To upgrade your Enterprise Manager system with downtime on a different host, select 1-System on a Different Host.
Enterprise Manager Grid Control refreshes the page and displays a table with a list of tasks you need to perform for the upgrade approach you selected.
In the Preupgrade Steps section, from the table, click Manage Software.
On the Manage Software page, in the Agent Upgradability and Target Upgradability pie charts, click the hyperlinks in the respective legends and identify the Management Agents and targets that can be upgraded, and that cannot be upgraded due to unavailability of the Management Agent software or the plug-in software.
In the Provide Software Location section, enter the absolute path to the directory where the core Management Agent software and the plug-in software are present for the required platforms.
For example, /john/software/oracle/em/.
And then, click Validate to register that location with the Enterprise Manager system.
