Skip Headers
Oracle® Enterprise Manager Cloud Control Upgrade Guide
12c Release 1 (12.1.0.1)
E22625-09
  Go To Table Of Contents
Contents
Go To Index
Index
Previous
Previous
Next
Next
29 Viewing Inactive Targets in the Upgraded Enterprise Manager System
This chapter is applicable only for 2-System upgrade approach.
Targets available in the existing Enterprise Manager system are active (monitored) in the upgraded Enterprise Manager system only when the Oracle Management Agents that were monitoring those targets are switched over to the upgraded Enterprise Manager system using Oracle Management Agent 12c.
To view a list of targets that are currently inactive in the upgraded Enterprise Manager system, follow these steps:
  1. In Cloud Control, from the Setup menu, click Post Upgrade Tasks.
  2. On the Post Upgrade Console page, click the Targets with Pending Activation tab.
  3. In this tab, you can view a list of inactive targets.
    To search for targets of your choice, enter a keyword or a part of the target name (or target type) in the search text box placed right above the Target Name column (or Target Type column).
    Alternatively, you can click the links in the Refine Search pane to filter the table and list the targets of your choice.
To convert these inactive targets to active targets, switch over the Management Agents that are monitoring these targets in the existing Enterprise Manager system to the upgraded Enterprise Manager system. For information about switching over the Management Agents, see Chapter 14.
