| Oracle® Enterprise Manager Cloud Control Upgrade Guide 12c Release 1 (12.1.0.1) E22625-09 |
![]() Previous |
![]() Next |
To upgrade your existing Enterprise Manager system to Enterprise Manager Cloud Control with 2-System upgrade approach, follow these steps:
Table 5-1 Upgrading Enterprise Manager with 2-System Upgrade Approach
| Step No. | Step | Procedure |
Step 1 |
Prepare Yourself |
(a) |
Learn about the 2-System upgrade approach. |
(b) |
Review the important facts you need to know before you begin. |
Step 2 |
Perform Preupgrade Tasks |
(a) |
Apply the preupgrade console patch on your existing Enterprise Manager system to get access to the Enterprise Manager 12c Upgrade Console. |
(b) |
Provide information about the host where you plan to upgrade your existing OMS. |
(c) |
Manually download the following software, and stage them to an accessible location:
Installing Plug-Ins While Upgrading Oracle Management Agent |
(d) |
Provide information about the location of the software you manually downloaded and staged in Step 2 (c) |
(e) |
Analyze your environment to identify Oracle Management Agents (Management Agent) with valid and invalid inventory, check their upgradability status, and identify the problematic Management Agents. If a required software is missing, then repeat Step (c) and Step (d). |
(f) |
Meet the prerequisites for upgrading the Management Agents. |
Step 3 |
Upgrade Oracle Management Service and Oracle Management Repository Note: Optionally, you can choose to deploy and configure your Oracle Management Agents before upgrading the Oracle Management Service and Oracle Management Repository. In this case, perform Step 4 (a) before Step 3 (a) to Step 3 (l). |
(a) |
On the remote host where you plan to install Enterprise Manager Cloud Control, meet the following prerequisites:
(b) |
Stop all running and scheduled deployment procedures in your existing Enterprise Manager system before upgrading the system. |
(c) |
(Only if you have Application Dependency and Performance (ADP) or JVM Diagnostics (JVMD) installed)
(d) |
Copy the emkey from the existing OMS, either the Enterprise Manager 10g Grid Control Release 5 (10.2.0.5) or Enterprise Manager 11g Grid Control Release 1 (11.1.0.1), to the existing Management Repository before creating a backup of the Management Repository. The following commands are applicable for both versions. Note: When you run the following command on Enterprise Manager 11g Grid Control (11.1.0.1), you are prompted for the admin password.
To verify if the emkey is copied properly, log in to the repository as sys user and run the following sql command:
(If the count is 1, then the emkey is copied.) |
(e) |
(Only if your old Enterprise Manager system has Oracle Software Library configured) If you have Oracle Software Library (Software Library) configured, then back up each of the configured Software Library directories to a location accessible from the remote host where you plan to install Enterprise Manager Cloud Control. The location to which you back up the directories is required for reconfiguring the Software Library [as described in Step 3 (l)] once you install Enterprise Manager Cloud Control. For example, if your Software Library was configured in |
(f) |
Back up your existing database, which houses the Management Repository, to a host that can be either a completely new host or the host where your existing OMS is running. Choose to back up the repository on the host where your existing OMS is running only if you have sufficient space to accommodate it. Then, create a new database instance out of it so that the repository configured in it can be upgraded. Note: - Before backing up the database, ensure that you stop all the running and scheduled deployment procedures in your existing Enterprise Manager system. - If you back up the database using DBCA, then ensure that you unlock all the user accounts, except for MGMT_VIEW user, before installing Enterprise Manager Cloud Control. - Do not back up the repository using the DB cloning feature in the Enterprise Manager console. If you do, then you will not see the cloned database discovered in the Enterprise Manager console. - Any Management Agent or target added to the existing Enterprise Manager system after backing up the Management Repository will not be upgraded and will need to be manually added to the upgraded Enterprise Manager system. To identify the targets that need to be manually added to the upgraded system, see the diff report as described in .Chapter 28. |
(g) |
On the backed up Management Repository, meet the following prerequisites:
(h) |
Remove the emkey from the Management Repository by running the following command from the old Enterprise Manager 10g Grid Control Release 5 (10.2.0.5) or Enterprise Manager 11g Grid Control Release 1 (11.1.0.1) OMS home:
(i) |
Provide the date and time when the Management Repository was backed up. Note: Any Management Agent or target added to the existing Enterprise Manager system after backing up the Management Repository will not be upgraded and will need to be manually added to the upgraded Enterprise Manager system. To identify the targets that need to be manually added to the upgraded system, see the diff report as described in .Chapter 28. |
(j) |
Install Enterprise Manager Cloud Control on the remote host and upgrade the Management Repository in the database you backed up in Step 3 (f). You can choose to install in graphical or silent mode. You can also choose to install the software binaries at one point and upgrade them later in graphical or silent mode. If you see an error message that states that you cannot upgrade your OMS because the host on which you are performing the 2-system upgrade does not match with the host name you have entered in the Enterprise Manager 12c Upgrade console, go to the Pre-upgrade Console and provide the correct host name. (Note: If you had chosen to deploy your Management Agents before upgrading the OMS, and if you see this error, fix the error in the Enterprise Manager 12c Upgrade console, and then dploy your Management Agents again, before upgrading the OMS.) If you see an error message stating that you have not copied the emkey before taking a back up of the OMS, run the following command.
(Here, the Management Repository details are details of the existing or old Management Repository. If you are running the installer on Enterprise Manager 11g Grid Control, you will be prompted for the admin server password.) (Note: If you had chosen to deploy your Management Agents before upgrading the OMS, and if you see this error, then after running the previous command, make sure you deploy all the Management Agents again. However, after running the command, and before re-deploying the Management Agents, Oracle recommends that you run the installer to ensure that the error about emkey does not reoccur.) |
(k) |
Link the ealier release of the Management Repository with the upgraded Management Repository. |
(l) |
(Only if your old Enterprise Manager had Software Library configured) Reconfigure the Software Library in Enterprise Manager Cloud Control so that it is independent of the Software Library configured for the old Enterprise Manager system. |
Step 4 |
Upgrade Oracle Management Agent |
(a) |
Deploy and configure the software binaries of Oracle Management Agent 12c. |
(b) |
Generate a health report and check the readiness of the predeployed Management Agents. |
(c) |
Verify and sign off the health check report. |
(d) |
Switch over the old Management Agents to the newly deployed ones so that they can communicate with Enterprise Manager Cloud Control. Note: If you have a large number of agents, then you can choose to upgrade one set of Oracle Management Agents in one attempt, and the next set in the subsequent attempt. In this case, you can repeat Step 4 (a) to Step 4 (d) for each attempt. |
Step 5 |
Perform Postupgrade Task |
(a) |
Check the agent upgrade status |
(b) |
Perform the general post-upgrade tasks. |
(c) |
Track the status of deferred data migration jobs. |
(d) |
Track the status of accrued data migration jobs. |
(e) |
Generate diff reports to identify all configuration or setup-related changes that were manually made to the earlier release of the Enterprise Manager system while it was being upgraded. |
(f) |
View a list of targets that are currently inactive in the upgraded Enterprise Manager system. |
(g) |
Sign off accrued data migration process. |
(h) |
Update the incident rules for metrics associated with the OMS. |
(i) |
