Skip Headers
Oracle® Enterprise Manager Cloud Control Upgrade Guide
12c Release 1 (12.1.0.1)
E22625-09
  Go To Table Of Contents
Contents
Go To Index
Index
Previous
Previous
Next
Next
16 Upgrading OMS and Repository in Graphical Mode
This chapter describes how you can upgrade your existing Oracle Management Service (OMS) and Oracle Management Repository (Management Repository) in graphical mode using one of the upgrade approaches. In particular, this chapter covers the following:
You can find the OMS and Management Agent entries in the /etc/oragchomelist file for all UNIX platforms except HPUNIX, HPia64, Solaris Sparc. On HPUNIX, HPia64, Solaris Sparc platforms, the entries are present in /var/opt/oracle/oragchomelist.
Upgrading with 1-System Upgrade Approach in Graphical Mode
When you upgrade using the 1-System upgrade approach, the Enterprise Manager Cloud Control Installation Wizard does not install a Management Agent with the OMS it installs. The Management Agent is predeployed using the Enterprise Manager 12c Upgrade Console. This is an expected behavior.
To upgrade your existing OMS and Management Repository with 1-System upgrade approach in graphical mode, follow these steps:
  1. Invoke the Enterprise Manager Cloud Control Installation Wizard on the host where your existing OMS is running.
    <Software_Location>/runInstaller
    In this command, <Software_Location> refers to the location where you have downloaded software kit.
    For information about the additional, advanced options you can pass while invoking the installer, refer to Advanced Installer Options.
    To invoke the installation wizard on UNIX platforms, run runInstaller. To invoke on Microsoft Windows platforms, run setup.exe.
    When you invoke runInstaller or setup.exe, if the Enterprise Manager Cloud Control Installation Wizard does not appear, then it is possible that you do not access to the /stage directory.
    There is a classpath variable that the installation wizard computes for OPatch as ../stage/Components/, and when the TEMP variable is set to /tmp, the installation wizard tries to look for the opatch JAR file in the /tmp/../stage directory, which is equivalent to /stage. However, if you do not have the permission on /stage, then the installation wizard can hang. Under such circumstances, verify if you have access to the /stage directory. If you do not have access to it, then set the TEMP variable to a location where the install user has access to, and then relaunch the installation wizard.
  2. (Optional) On the My Oracle Support Details screen, enter your My Oracle Support credentials to enable Oracle Configuration Manager. If you do not want to enable Oracle Configuration Manager now, go to Step (3).
    If the host from where you are running the installation wizard does not have a connection to the Internet, then enter only the e-mail address and leave the other fields blank. After you complete the installation, manually collect the configuration information and upload it to My Oracle Support.
  3. Click Next.
  4. On the Software Updates screen, select one of the following sources from where the software updates can be installed while the Enterprise Manager system gets upgraded. If you do not want to apply them now, then select Skip.
    • (Recommended) Select Search for Updates, and then, select Local Directory if you have already manually downloaded the software updates to an accessible local or remote location.
      Enter the location where the updates are available, and click Search for Updates. To search the computer and select the location, click Browse. Once the search results appear with patch numbers and their details, click the patch number to view the ReadMe associated with that patch.
      • If the updates have been downloaded to the default location, then select or enter the full path to the scratch path location. For example, if the scratch path location is /scratch/OracleHomes and if the software updates are available in /scratch/OracleHomes/Updates, then enter /scratch/OracleHomes/Updates.
      • If the software updates have been downloaded to a custom location, then select or enter the full path to the custom location. For example, if the custom location is /home/john and if the software updates are available in /home/john/Updates, then enter /home/john/Updates.
    • Select Search for Updates, and then, select My Oracle Support if you want the installer to connect to My Oracle Support and automatically download the updates from there.
      Enter the My Oracle Support account user name and password, and click Search for Updates. Once the search results appear with patch numbers and their details, click the patch number to view the ReadMe associated with that patch
    If you choose to skip installing the software updates during installation by not providing the My Oracle Support credentials, you can always register the credentials later using the Enterprise Manager Cloud Control console and view the recommended security patches. To do so, log in to Enterprise Manager Cloud Control, and from the Setup menu, select My Oracle Support, and then, click Set Credentials. On the My Oracle Support Preferred Credentials page, enter the credentials and click Apply.
  5. Click Next.
  6. On the Prerequisite Checks screen, check the status of the prerequisite checks run by the installation wizard, and verify whether your environment meets all the minimum requirements for a successful upgrade.
    The installation wizard runs the prerequisite checks automatically when you come to this screen. It checks for the required operating system patches, operating system packages, and so on.
    The status of the prerequisite check can be either Warning, Failed, or Succeeded.
    If some checks result in Warning or Failed status, then investigate and correct the problems before you proceed with the upgrade. The screen provides details on why the prerequisites failed and how you can resolve them. After you correct the problems, return to this screen and click Rerun to check the prerequisites again.
    If you prefer to hide the successful checks and view only the ones with Warning or Failed status, then click Hide Successful Checks.
    Although Oracle recommends you to investigate and correct the problems, if you are compelled to proceed without resolving them, then select Ignore to ignore the warnings and failures. However, all package requirements must be met or fixed before proceeding any further. Otherwise, the upgrade might fail.
  7. Click Next.
  8. On the Install Types screen, do the following:
    1. Select Upgrade an Existing Enterprise Manager System, and then, select One System Upgrade.
    2. Select the OMS home you want to upgrade.
    3. Validate or enter the middleware home.
      • If you do not have Oracle WebLogic Server 11g Release 1 (10.3.5) and Java Development Kit 1.6 v24+ installed, then enter the absolute path to a directory where you want the installer to install them. For example, /oracle/software/. Ensure that the directory you enter does not contain any files or subdirectories.
      • If you have Oracle WebLogic Server and JDK already installed, then ensure that they are of the supported releases—Oracle WebLogic Server 11g Release 1 (10.3.5) and JDK 1.6 v24+. In this case, the installer detects them and displays the middleware home where they are installed. Validate the path to this middleware home.
      • If you want to install Oracle WebLogic Server 11g Release 1 (10.3.5) and Java Development Kit 1.6 v24 yourself, then follow the guidelines outlined in Chapter 3.
  9. Click Next.
  10. On the Database Connection Details screen, enter the passwords for the SYS and SYSMAN user accounts of the database that houses the Management Repository for the selected OMS.
    Before you proceed to the next screen, stop all the associated OMSes. To do so, run the following command on each of the OMS hosts:
    • If you are upgrading from Enterprise Manager 11g Grid Control Release 1 (11.1.0.1.0), then run this command from the OMS home:
      $<OMS_HOME>/bin/emctl stop oms
    • If you are upgrading from Enterprise Manager 10g Grid Control Release 5 (10.2.0.5.0), then run this command from the OMS home:
      $<OMS_HOME>/opmn/bin/opmnctl stopall
  11. Click Next.
    If you encounter a Provisioning Archive Framework (PAF) prerequisite check error, then exit the installer, stop all the running and scheduled deployment procedures in your existing Enterprise Manager system, invoke the installer all over again, and retry the upgrade process.
  12. On the Select Plug-Ins screen, select the optional plug-ins you want to install from the software kit (DVD, downloaded software) while upgrading the Enterprise Manager system.
    The screen lists the mandatory plug-ins as well as the optional plug-ins. The grayed rows indicate the mandatory plug-ins that will be installed.
    The grayed rows might also include the plug-ins you installed while predeploying Oracle Management Agent 12c using the Enterprise Manager 12c Upgrade Console. However, if the grayed rows do not include the plug-ins you installed then, it means that those plug-ins are not available in the software kit. In that case, manually download those plug-ins to an accessible location and invoke the installer with an advanced option. For more information, see Advanced Installer Options for the point on installing additional plug-ins.
  13. Click Next.
  14. Provide WebLogic Server Configuration Details
    • If you are upgrading from Enterprise Manager 10g Grid Control Release 5 (10.2.0.5.0), then on the WebLogic Server Configuration Details screen, enter the credentials for the WebLogic Server user account and the Node Manager user account, and validate the path to the OMS instance base location.
      Ensure that your password contains at least 8 characters without any spaces, begins with a letter, and includes at least one numeric value.
      By default, the WebLogic Domain name is GCDomain, and the Node Manager name is nodemanager. These are non-editable fields. The installer uses this information for creating Oracle WebLogic Domain and other associated components such as the admin server, the managed server, and the node manager. A Node Manager enables you to start, shut down, or restart an Oracle WebLogic Server instance remotely, and is recommended for applications with high availability requirements.
    • If you are upgrading from Enterprise Manager 11g Grid Control Release 1 (11.1.0.1.0), then on the Extend WebLogic Server Domain screen, validate the AdminServer host name and its port, and the WebLogic user name. Enter the WebLogic user account password for extending the existing Oracle WebLogic Server Domain to the upgraded release.
    • If you are upgrading an additional OMS from 10g Release 5 (10.2.0.5) or from 11g Release 1 (11.1.0.1), then enter the host name and port of the AdminServer configured for the first OMS that you have already upgraded, and then, enter the credentials for the existing WebLogic Server user account.
  15. Click Next.
  16. On the Tablespace Location screen, validate the location where the data file (mgmt_ad4j.dbf ) for JVM Diagnostics data tablespace can be stored. You can choose to edit it if you want. In that case, ensure that the path leads up to the file name. Enterprise Manager Cloud Control requires this data file to store monitoring data related to JVM Diagnostics and Application Dependency Performance (ADP).
    This screen appears only if you are upgrading from Enterprise Manager 10g Grid Control Release 5 (10.2.0.5.0).
  17. Click Next.
  18. Provide the port configuration details:
    • If you are upgrading from Enterprise Manager 11g Grid Control Release 1 (11.1.0.1.0), then you will NOT see the Port Configuration Details screen because the ports used by the old OMS and the old Management Agent will be reused by the upgraded OMS and the Management Agent. Hence, go to Step (20).
    • If you are upgrading from Enterprise Manager 10g Grid Control Release 5 (10.2.0.5.0), then on the Port Configuration Details screen, customize the ports to be used for various components.
      • By default, this screen lists the default ports for all the core components. However, if you are upgrading an additional OMS, then the screen does not list the Admin Server HTTP SSL port because you will reuse the Admin Server configured for the first OMS.
      • If all the ports on this screen appear as -1, then it indicates that the installer is unable to bind the ports on the host. To resolve this issue, exit the installer, verify the host name and the IP configuration of this host (ensure that the IP address of the host is not being used by another host), restart the installer, and try again.
      You can enter a free custom port that is either within or outside the port range recommended by Oracle.
      To verify if a port is free, run the following command:
      On Unix:
      netstat -anp | grep <port no>
      On Microsoft Windows:
      netstat -an|findstr <port_no>
      However, the custom port must be greater than 1024 and lesser than 65535. Alternatively, if you already have the ports predefined in a staticports.ini file and if you want to use those ports, then click Import staticports.ini File and select the file.
      If the staticports.ini file is passed during installation, then by default, the ports defined in the staticports.ini file are displayed. Otherwise, the first available port from the recommended range is displayed.
  19. Click Next.
  20. On the Review screen, review the details you have provided for the upgrade.
    1. If you want to change the details, click Back repeatedly until you reach the screen where you want to make the changes.
    2. After you verify the details, if you are satisfied, click Install to begin the upgrade.
  21. On the Install Progress screen, view the overall progress (in percentage) of the upgrade operation and the status of each of the Configuration Assistants.
    If the OMS Configuration Assistant fails with an exception, particularly when you are upgrading from Enterprise Manager 11g Grid Control Release 1 (11.1.0.1.0), then stop the AdminServer and try again. To stop the AdminServer, run the following command on each of the OMS hosts:
    $<OMS_HOME>/bin/emctl stop oms -all
    If a Configuration Assistant fails, the installer stops and none of the subsequent Configuration Assistants are run until the issue related to the failed Configuration Assistant is resolved. In this case, diagnose the issue, resolve it, and then, click Retry on the Install Progress screen to rerun the Configuration Assistants starting from the Configuration Assistant that failed.
    However, if you accidently exit the installer before clicking Retry, then do NOT restart the installer to reach the same screen; instead, invoke the runConfig.sh script from the OMS home to rerun the Configuration Assistant in silent mode:
    $<OMS_HOME>/oui/bin/runConfig.sh ORACLE_HOME=<absolute_path_to_OMS_home> MODE=perform ACTION=configure COMPONENT_XML={encap_oms.1_0_0_0_0.xml}
  22. Once the software binaries are copied and configured, you are prompted to run the allroot.sh script. Open another window, log in as root, and manually run the scripts.
    If you are installing on Microsoft Windows operating system, then you will NOT be prompted to run this script.
  23. On the Finish screen, you should see information pertaining to the upgrade of Enterprise Manager. Review the information and click Close to exit the wizard.
The following are some additional, advanced options you can pass while invoking the installer:
  • When you upgrade from Enterprise Manager 10g Grid Control Release 5 (10.2.0.5.0), a new WebLogic domain named GCDomain is created by default. If you want to override this with a custom name, then invoke the installer with the WLS_DOMAIN_NAME option, and enter a unique custom name.
    For example, if you want to use the custom name EMDomain, then run the following command:
    ./runInstaller WLS_DOMAIN_NAME=EMDomain
  • By default, a Provisioning Advisor Framework (PAF) staging directory is created for copying the Software Library entities related to the deployment procedures. By default, this location is the scratch path location (/tmp). The location is used only for provisioning activities—entities are copied for a deployment procedure, and then, deleted once the deployment procedure ends.
    If you want to override this location with a custom location, then invoke the installer with the EM_STAGE_DIR option, and enter a unique custom location.
    For example,
    ./runInstaller EM_STAGE_DIR=/home/john/software/oracle/pafdir
  • During upgrade, if you want to install some plug-ins that are not in the software kit (DVD, downloaded software), then follow these steps:
    1. Manually download the plug-ins from the following URL, and store them in an accessible location.
      http://www.oracle.com/technetwork/oem/grid-control/downloads/oem-upgrade-console-502238.html
    2. Invoke the installer with the following option, and pass the location where the plug-ins you want to install are available:
      ./runInstaller -pluginLocation <absolute_path_to_plugin_software_location>
      This displays a list of plug-ins available in the software kit (DVD, downloaded software) as well as the plug-ins available in this custom location. You can choose the ones you want to install.
  • After the upgrade operation ends successfully, the OMS and the Management Agent start automatically. If you do not want them to start automatically, then invoke the installer with START_OMS and b_startAgent options, and set them to TRUE or FALSE depending on what you want to control.
    For example, if you do not want the Management Agent to start automatically, then run the following command:
    ./runInstaller START_OMS=TRUE b_startAgent=FALSE
    To understand the limitations involved with this advanced option, see Limitations.
Limitations
When you use START_OMS and b_startAgent as advanced options to control the way the OMS and the Management Agent start up automatically, sometimes the Management Agent and the host on which it was installed do not appear as targets in the Cloud Control console.
Table 16-1 lists the different combinations of these advanced options, and describes the workaround to be followed for each combination:
Table 16-1 Advanced Options and Workarounds
Advanced Option Workaround
START_OMS=FALSE
b_startAgent=FALSE
  1. Start the OMS:
    $<OMS_HOME>/bin/emctl start oms
  2. Secure the Management Agent:
    $<AGENT_HOME>/bin/emctl secure agent
  3. Start the Management Agent:
    $<AGENT_HOME>/bin/emctl start agent
  4. Add the targets:
    $<AGENT_HOME>/bin/emctl config agent addinternaltargets
  5. Upload the targets:
    $<AGENT_HOME>/bin/emctl upload agent
  6. Manually configure the EMCLI tool in the $<ORACLE_HOME>/bin directory. To do so, refer to the Oracle Enterprise Manager Command Line Interface Guide.
START_OMS=TRUE
b_startAgent=FALSE
  1. Secure the Management Agent:
  2. Start the Management Agent:
  3. Add the targets:
  4. Upload the targets:
START_OMS=FALSE
b_startAgent=TRUE
  1. Start the OMS:
  3. Add the targets:
  5. Manually configure the EMCLI tool in the $<ORACLE_HOME>/bin directory. To do so, refer to the Oracle Enterprise Manager Command Line Interface Guide.
Upgrading with 2-System Upgrade Approach in Graphical Mode
To upgrade your existing OMS and Management Repository with 2-System upgrade approach in graphical mode, follow these steps:
  1. Invoke the Enterprise Manager Cloud Control Installation Wizard on the host where you plan to install Oracle Management Service 12c:
    <Software_Location>/runInstaller [ALLOW_ONLY_SECURE_ACCESS_TO_CONSOLE=FALSE LOCK_ORACLE_MANAGEMENT_SERVICE=FALSE]
    In this command, <Software_Location> refers to the location where you have downloaded the software kit.
    • For information about the additional, advanced options you can pass while invoking the installer, refer to Advanced Installer Options.
    • To invoke the installation wizard on UNIX platforms, run runInstaller. To invoke on Microsoft Windows platforms, run setup.exe.
    • Ensure that the host on which you are invoking the installer matches with the host you entered in the Enterpriser Manager 12c Upgrade Console.
      If you are invoking the installer on a different host, and if you choose to modify the host name in the Enterpriser Manager 12c Upgrade Console, then follow these steps:
      1. Exit the installer.
      2. Discard the backed up database.
      3. Access the Enterpriser Manager 12c Upgrade Console:
        (a) On the Identify Host and Port for New Enterprise Manager System page, change the host name. For instructions, see Chapter 8.
        (b) On the Deploy and Configure Agents page, reconfigure the Management Agents that have already been deployed. For instructions, see Chapter 11.
        Important: On the Deploy and Configure Agents page, in the Select Operation Type section, ensure that you deselect Deploy Agent and Plug-In Software.
      4. Take a fresh backup of the database now.
      5. Invoke the installer all over again, and retry the upgrade process.
    • If the Enterprise Manager Upload Http Port and Enterprise Manager Central Console Http Port are unlocked in your existing Enterprise Manager system, then pass the optional arguments ALLOW_ONLY_SECURE_ACCESS_TO_CONSOLE and LOCK_ORACLE_MANAGEMENT_SERVICE while invoking the installer.
      If you skip passing these arguments now, and if you want to unlock the ports later, then after upgrading the OMS, run these commands from the upgraded OMS home:
      $<OMS_HOME>/bin/emctl secure unlock -console
      $<OMS_HOME>/bin/emctl secure unlock -upload
  3. Click Next.
  4. On the Software Updates screen, select one of the following sources from where the software updates can be installed while the installation of the Enterprise Manager system is in progress. If you do not want to apply them now, then select Skip.
    If you choose to skip installing the software updates during installation by not providing the My Oracle Support credentials, you can always register the credentials later using the Enterprise Manager Cloud Control console and view the recommended security patches. To do so, log in to Enterprise Manager Cloud Control, and click Preferences from the top-right corner of the screen. On the General page, from the left menu bar, click Preferred Credentials. On the Preferred Credentials page, from the My Oracle Support Preferred Credentials section, click Set Credentials. On the My Oracle Support Preferred Credentials page, specify the credentials and click Apply.
  5. Click Next.
    If Enterprise Manager Cloud Control is the first Oracle product you are installing on the host that is running on UNIX operating system, then the Oracle Inventory screen appears. For details, see step (6). Otherwise, the Check Prerequisites screen appears. For details, see step (8).
    If Enterprise Manager Cloud Control is the first Oracle product you are installing on the host that is running on Microsoft Windows operating system, then the Oracle Inventory screen does not appear. On Microsoft Windows, the following is the default inventory directory:
    <system drive>\Program Files\Oracle\Inventory
  6. On the Oracle Inventory screen, do the following. You will see this screen only if this turns out to be your first ever installation of an Oracle product on the host.
    1. Enter the full path to a directory where the inventory files and directories can be placed.
      • The central inventory location you enter must NOT be on a shared file system. If it is already on a shared file system, then switch over to a non-shared file system.
      • If this is the first Oracle product on the host, then the default central inventory location is <home directory>/oraInventory. However, if you already have some Oracle products on the host, then the central inventory location can be found in the oraInst.loc file. The oraInst.loc file is located in the /etc directory for Linux and AIX, and in the /var/opt/oracle directory for Solaris, HP-UX, and Tru64.
    2. Select the appropriate operating system group name that will own the Oracle inventory directories. The group that you select must have write permissions on the Oracle Inventory directories.
  7. Click Next.
  8. On the Prerequisite Checks screen, check the status of the prerequisite checks run by the installation wizard, and verify whether your environment meets all the minimum requirements for a successful upgrade.
  9. Click Next.
  10. On the Install Types screen, do the following:
    1. Select Upgrade an Existing Enterprise Manager System, and then, select Two System Upgrade.
    2. Validate or enter the middleware home where you want to install the OMS and other core components.
      • If you have manually installed Oracle WebLogic Server and JDK, then ensure that they are of the supported releases—Oracle WebLogic Server 11g Release 1 (10.3.5) and JDK 1.6 v24+.
  11. Click Next.
  12. On the Database Connection Details screen, enter the fully qualified name of the host where the backed up database resides, its listener port and its service name or system ID (SID), and the SYS and SYSMAN user account passwords.
    Oracle Real Application Cluster (Oracle RAC) nodes are referred to by their virtual IP (vip) names. The service_name parameter is used instead of the system identifier (SID) in connect_data mode, and failover is turned on. For more information, refer to Oracle Database Net Services Administrator's Guide.
    The installer uses this information to connect to the backed up database for configuring the SYSMAN schema. SYSMAN schema holds most of the relational data used in managing Enterprise Manager Cloud Control.
  13. Click Next.
    • If you are connecting to an Oracle RAC database, and if you have entered the virtual IP address of one of its nodes, then the installation wizard prompts you with a Connection String dialog and requests you to update the connection string with information about the other nodes that are part of the cluster. Update the connection string and click OK. If you want to test the connection, click Test Connection.
    • Oracle Real Application Cluster (Oracle RAC) nodes are referred to by their virtual IP (vip) names. The service_name parameter is used instead of the system identifier (SID) in connect_data mode, and failover is turned on. For more information, refer to Oracle Database Net Services Administrator's Guide.
    • If you encounter a Provisioning Archive Framework (PAF) prerequisite check error, then do the following:
      • Exit the installer, run the following SQL command on the backed up database, invoke the installer all over again, and retry the upgrade process.
        UPDATE MGMT_PAF_STATES
        SET status = 6
        WHERE state_type = 0
        AND status IN (0, 1);
      • Exit the installer, discard the backed up database, stop all the running and scheduled deployment procedures in your existing Enterprise Manager system, take a fresh backup of the database now, invoke the installer all over again, and retry the upgrade process.
    • If you encounter any validation error, then follow these steps:
      3. Resolve the issue in the Enterprise Manager 12c Upgrade Console.
    • If you see a warning asking you to unlock the MGMT_VIEW user account and change the password, ignore it because the installer automatically unlocks it for you.
  14. On the Select Plug-Ins screen, select the plug-ins you want to install while upgrading the Enterprise Manager system.
    The grayed rows might also include the plug-ins you installed while predeploying Oracle Management Agent 12c using the Enterprise Manager 12c Upgrade Console. If the grayed rows do not include the plug-ins you installed then, it means that those plug-ins are not available in the software kit. In that case, manually download those plug-ins to an accessible location and invoke the installer with an advanced option. For more information, see Advanced Installer Options for the point on installing additional plug-ins.
  15. Click Next.
  16. On the WebLogic Server Configuration Details screen, enter the credentials for the WebLogic Server user account and the Node Manager user account, and validate the path to the Oracle Management Service instance base location.
  17. Click Next.
  18. On the Old Repository Details screen, validate the connect string and enter the SYSMAN password of the old Management Repository.
    The details are used to connect to the old Management Repository, check for accrued data, and seamlessly transfer it to the upgraded Management Repository. Accrued data refers to the data that was uploaded to the old Management Repository from the time it was backed up till the time it was upgraded.
    Typically, the connect string is prepopulated. However, if it is not prepopulated, then enter it in the following format:
    • With SID
      (DESCRIPTION=(ADDRESS_LIST=(ADDRESS=(PROTOCOL=TCP)(HOST=<host_name>)(PORT=<port>)))(CONNECT_DATA=(SID=<sid>)))
    • With Service Name
      (DESCRIPTION=(ADDRESS_LIST=(ADDRESS=(PROTOCOL=TCP)(HOST=<host_name>)(PORT=<port>)))(CONNECT_DATA=(SERVICE_NAME=<service_name>)))
  19. Click Next.
  20. On the Tablespace Location screen, validate the location where the data file (mgmt_ad4j.dbf ) for JVM Diagnostics data tablespace can be stored. You can choose to edit it if you want. In that case, ensure that the path leads up to the file name. Enterprise Manager Cloud Control requires this data file to store monitoring data related to JVM Diagnostics and Application Dependency Performance (ADP).
  21. Click Next.
  22. On the Port Configuration Details screen, customize the ports to be used for various components.
    • Ensure that the ports you enter for Enterprise Manager Upload Http Port and Enterprise Manager Upload Http SSL Port match with the unsecure and secure ports you entered in the Enterprise Manager 12c Upgrade Console.
      If the ports mentioned in this screen are different from the ports you had entered in the Enterprise Manager 12c Upgrade Console, and if you decide to change the ports in the Enterprise Manager 12c Upgrade Console, then follow these steps:
      3. Change the ports in the Enterprise Manager 12c Upgrade Console.
    • For other components, you can enter a free custom port that is either within or outside the port range recommended by Oracle. However, the custom port must be greater than 1024 and lesser than 65535.
      On Unix:
    • Alternatively, if you already have the ports predefined in a staticports.ini file and if you want to use those ports, then click Import staticports.ini File and select the file.
      If the staticports.ini file is passed during installation, then by default, the ports defined in the staticports.ini file are displayed. Otherwise, the first available port from the recommended range is displayed. If you do pass this file, then ensure that the ports you enter for Enterprise Manager Upload Http Port and Enterprise Manager Upload Http SSL Port match with the unsecure and secure ports you entered in the Enterprise Manager 12c Upgrade Console.
  23. Click Next.
  24. On the Review screen, review the details you provided for the selected installation type.
    • If you want to change the details, click Back repeatedly until you reach the screen where you want to make the changes.
    • After you verify the details, if you are satisfied, click Install to begin the installation process.
  25. On the Install Progress screen, view the overall progress (in percentage) of the installation and the status of each of the Configuration Assistants. Configuration Assistants are run for configuring the installed components of Enterprise Manager Cloud Control.
  26. Once the software binaries are copied and configured, you are prompted to run the allroot.sh script, and the oraInstRoot.sh script if this is the first Oracle product installation on the host. Open another window, log in as root, and manually run the scripts.
  27. On the Finish screen, you should see information pertaining to the installation of Enterprise Manager. Review the information and click Close to exit the installation wizard.
    For more information about this installation, refer to the following file available in the OMS home:
    $<OMS_HOME>/install/setupinfo.txt
