Skip Headers
Oracle® Enterprise Manager Cloud Control Upgrade Guide
12c Release 1 (12.1.0.1)
E22625-09
  Go To Table Of Contents
Contents
Go To Index
Index
Previous
Previous
Next
Next
18 Installing Software Now and Upgrading Later in Graphical Mode
This chapter explains how you can install only the software binaries of Enterprise Manager Cloud Control in graphical mode at one point, and upgrade them at a later point.
This is called the software-only mode, and it enables you to divide the upgrade process into two phases, mainly the installation phase and the upgrade phase. Understandably, the installation phase takes less time compared to the upgrade phase because the installation phase involves only copying of binaries. In addition, this approach helps you plan your upgrade according to the time and priorities you have.
While you can perform this software-only upgrade in graphical and silent mode, this chapter describes how you perform it in graphical mode.
This chapter covers the following:
You can find the OMS and Management Agent entries in the /etc/oragchomelist file for all UNIX platforms except HPUNIX, HPia64, Solaris Sparc. On HPUNIX, HPia64, Solaris Sparc platforms, the entries are present in /var/opt/oracle/oragchomelist.
Upgrading in Software-Only Mode with 1-System Upgrade Approach
This section describes how you can upgrade your OMS and Management Repository in software-only mode with 1-System upgrade approach. In particular, this section covers the following:
Installing Software Binaries
To install the software binaries of Enterprise Manager Cloud Control, follow these steps:
  1. Invoke the Enterprise Manager Cloud Control installer on the host where your existing OMS is running.
    <Software_Location>/runInstaller [-invPtrLoc <absolute_path_to_oraInst.loc>]
    • In this command, <Software_Location> refers to the location where you have downloaded software kit.
    • To invoke the installation wizard on UNIX platforms, run runInstaller. To invoke on Microsoft Windows platforms, run setup.exe.
    • For information about the additional, advanced options you can pass while invoking the installer, refer to Advanced Installer Options.
    • The central inventory location you enter must NOT be on a shared file system.
    When you invoke runInstaller or setup.exe, if the Enterprise Manager Cloud Control Installation Wizard does not appear, then it is possible that you do not access to the /stage directory.
    There is a classpath variable that the installation wizard computes for OPatch as ../stage/Components/, and when the TEMP variable is set to /tmp, the installation wizard tries to look for the opatch JAR file in the /tmp/../stage directory, which is equivalent to /stage. However, if you do not have the permission on /stage, then the installation wizard can hang. Under such circumstances, verify if you have access to the /stage directory. If you do not have access to it, then set the TEMP variable to a location where the install user has access to, and then relaunch the installation wizard.
  2. (Optional) On the My Oracle Support Details screen, enter your My Oracle Support credentials to enable Oracle Configuration Manager. If you do not want to enable Oracle Configuration Manager now, go to Step (3).
    If the host from where you are running the installation wizard does not have a connection to the Internet, then enter only the e-mail address and leave the other fields blank. After you complete the installation, manually collect the configuration information and upload it to My Oracle Support.
  3. Click Next.
  4. On the Software Updates screen, select one of the following sources from where the software updates can be installed while the Enterprise Manager system gets upgraded. If you do not want to apply them now, then select Skip.
    • (Recommended) Select Search for Updates, and then, select Local Directory if you have already manually downloaded the software updates to an accessible local or remote location.
      Enter the location where the updates are available, and click Search for Updates. To search the computer and select the location, click Browse. Once the search results appear with patch numbers and their details, click the patch number to view the ReadMe associated with that patch.
      • If the updates have been downloaded to the default location, then select or enter the full path to the scratch path location. For example, if the scratch path location is /scratch/OracleHomes and if the software updates are available in /scratch/OracleHomes/Updates, then enter /scratch/OracleHomes/Updates.
      • If the software updates have been downloaded to a custom location, then select or enter the full path to the custom location. For example, if the custom location is /home/john and if the software updates are available in /home/john/Updates, then enter /home/john/Updates.
    • Select Search for Updates, and then, select My Oracle Support if you want the installer to connect to My Oracle Support and automatically download the updates from there.
      Enter the My Oracle Support account user name and password, and click Search for Updates. Once the search results appear with patch numbers and their details, click the patch number to view the ReadMe associated with that patch
    If you choose to skip installing the software updates during installation by not providing the My Oracle Support credentials, you can always register the credentials later using the Enterprise Manager Cloud Control console and view the recommended security patches. To do so, log in to Enterprise Manager Cloud Control, and from the Setup menu, select My Oracle Support, and then, click Set Credentials. On the My Oracle Support Preferred Credentials page, enter the credentials and click Apply.
  5. Click Next.
  6. On the Prerequisite Checks screen, check the status of the prerequisite checks run by the installation wizard, and verify whether your environment meets all the minimum requirements for a successful upgrade.
    The installation wizard runs the prerequisite checks automatically when you come to this screen. It checks for the required operating system patches, operating system packages, and so on.
    The status of the prerequisite check can be either Warning, Failed, or Succeeded.
    If some checks result in Warning or Failed status, then investigate and correct the problems before you proceed with the upgrade. The screen provides details on why the prerequisites failed and how you can resolve them. After you correct the problems, return to this screen and click Rerun to check the prerequisites again.
    If you prefer to hide the successful checks and view only the ones with Warning or Failed status, then click Hide Successful Checks.
    Although Oracle recommends you to investigate and correct the problems, if you are compelled to proceed without resolving them, then select Ignore to ignore the warnings and failures. However, all package requirements must be met or fixed before proceeding any further. Otherwise, the upgrade might fail.
  7. Click Next.
  8. On the Install Types screen, do the following:
    1. Select Install software only.
    2. Validate or enter the middleware home where you want to install the OMS and other core components.
      • If you do not have Oracle WebLogic Server 11g Release 1 (10.3.5) and Java Development Kit 1.6 v24+ installed, then enter the absolute path to a directory where you want the installer to install them. For example, /oracle/software/. Ensure that the directory you enter does not contain any files or subdirectories.
      • If you have Oracle WebLogic Server and JDK already installed, then ensure that they are of the supported releases—Oracle WebLogic Server 11g Release 1 (10.3.5) and JDK 1.6 v24+. In this case, the installer detects them and displays the middleware home where they are installed. Validate the path to this middleware home.
      • If you want to install Oracle WebLogic Server 11g Release 1 (10.3.5) and Java Development Kit 1.6 v24 yourself, then follow the guidelines outlined in Chapter 3.
  9. Click Next.
  10. On the Select Plug-Ins screen, select the optional plug-ins you want to install from the software kit while installing the software binaries. The screen lists the mandatory plug-ins as well as the optional plug-ins. The grayed rows indicate the mandatory plug-ins that will be installed.
    If you want to install a plug-in that is not available in the software kit, then refer to the point about installing additional plug-ins in Advanced Installer Options.
  11. Click Next.
  12. On the Review screen, review the details you provided for the selected installation type.
    • If you want to change the details, click Back repeatedly until you reach the screen where you want to make the changes.
    • After you verify the details, if you are satisfied, click Install to begin the installation process.
  13. On the Install Progress screen, view the overall progress (in percentage) of the installation.
  14. On the Finish screen, you should see information pertaining to the installation of Enterprise Manager. Review the information and click Close to exit the installation wizard.
  15. Deinstall the Management Agent. For instructions, refer to the chapter on deinstalling a Management Agent in the Oracle Enterprise Manager Cloud Control Advanced Installation and Configuration Guide.
    The Management Agent installed with the OMS is not required because you already have the Management Agent predeployed by the Enterprise Manager 12c Upgrade Console.
Running allroot.sh Script
(For UNIX Only) After you install the software binaries, log in as a root user in a new terminal and run the allroot.sh script from the OMS home:
$<OMS_HOME>/allroot.sh
Configuring and Upgrading
To configure the software binaries of Enterprise Manager Cloud Control, follow these steps:
  1. Invoke the installation wizard by running the following script:
    $<MIDDLEWARE_HOME>/oms/sysman/install/ConfigureGC.sh [-invPtrLoc <absolute_path_to_oraInst.loc>]
    • While installing the software binaries as described in Installing Software Binaries, if you had passed the argument -invPtrLoc, then pass the same argument here as well.
    • For information about the additional, advanced options you can pass while invoking the script, refer to Using Advanced Script Options.
  2. On the Install Types screen, do the following:
    1. Select Upgrade an Existing Enterprise Manager System, and then, select One System Upgrade.
    2. Select the OMS home you want to upgrade.
  3. Click Next.
  4. On the Database Connection Details screen, enter the passwords for the SYS and SYSMAN user accounts of the database that houses the Management Repository for the selected OMS.
    Before you proceed to the next screen, stop all the associated OMSes. To do so, run the following command on each of the OMS hosts:
    • If you are upgrading from Enterprise Manager 11g Grid Control Release 1 (11.1.0.1.0), then run this command from the OMS home:
      $<OMS_HOME>/bin/emctl stop oms
    • If you are upgrading from Enterprise Manager 10g Grid Control Release 5 (10.2.0.5.0), then run this command from the OMS home:
      $<OMS_HOME>/opmn/bin/opmnctl stopall
  5. Click Next.
    If you see an error about missing plug-ins, then manually download those plug-ins (opar files) to an accessible location, and invoke the installer once again in the following way to install the software binaries of the downloaded plug-ins. Ensure that the location to which you download the plug-ins is meant only for these missing plug-ins.
    <software_kit>/runInstaller -plugininstall -pluginLocation <absolute_path_to_plugin_sw> -mwHome <absolute_path_to_middleware_home> [-invPtrLoc <absolute_path_to_oraInst.loc>]
    The missing plug-ins displayed in the error message have the following format. Ensure that you download and install the same plug-in version and the same or higher plug-in update.
    PluginID:PluginVersion:PluginUpdate
    To download the missing plug-ins, follow these steps:
    1. Navigate to the following location where you installed the software binaries, and check if the plug-in opar files you are looking for are available. If they are available, copy them to an accessible location.
      $<OMS_HOME>/sysman/install/undeployed_plugins
    2. If the opar files are not available in the OMS home, then download them from the following URL:
      http://www.oracle.com/technetwork/oem/grid-control/downloads/oem-upgrade-console-502238.html
    Proceed to the next step only after you have installed these missing plug-ins.
  6. Provide WebLogic Server configuration details:
    • If you are upgrading from Enterprise Manager 10g Grid Control Release 5 (10.2.0.5.0), then on the WebLogic Server Configuration Details screen, enter the credentials for the WebLogic Server user account and the Node Manager user account, and validate the path to the OMS instance base location.
      Ensure that your password contains at least 8 characters without any spaces, begins with a letter, and includes at least one numeric value.
      By default, the WebLogic Domain name is GCDomain, and the Node Manager name is nodemanager. These are non-editable fields. The installer uses this information for creating Oracle WebLogic Domain and other associated components such as the admin server, the managed server, and the node manager. A Node Manager enables you to start, shut down, or restart an Oracle WebLogic Server instance remotely, and is recommended for applications with high availability requirements.
    • If you are upgrading from Enterprise Manager 11g Grid Control Release 1 (11.1.0.1.0), then on the Extend WebLogic Server Domain screen, validate the AdminServer host name and its port, and the WebLogic user name. Enter the WebLogic user account password for extending the existing Oracle WebLogic Server Domain to the upgraded release.
    • If you are upgrading an additional OMS from 10g Release 5 (10.2.0.5) or from 11g Release 1 (11.1.0.1), then enter the host name and port of the AdminServer configured for the first OMS, and then, enter the credentials for the existing WebLogic Server user account.
  7. Click Next.
  8. On the Tablespace Location screen, validate the location where the data file (mgmt_ad4j.dbf ) for JVM Diagnostics data tablespace can be stored. You can choose to edit it if you want. In that case, ensure that the path leads up to the file name. Enterprise Manager Cloud Control requires this data file to store monitoring data related to JVM Diagnostics and Application Dependency Performance (ADP).
    This screen appears only if you are upgrading from Enterprise Manager 10g Grid Control Release 5 (10.2.0.5.0).
  9. Click Next.
  10. On the Port Configuration Details screen, customize the ports to be used for various components.
    • If you are upgrading from Enterprise Manager 11g Grid Control Release 1 (11.1.0.1.0), then you will NOT see the Port Configuration Details screen because the ports used by the old OMS and the old Management Agent will be reused by the upgraded OMS and the Management Agent. Hence, go to Step (12).
    • If you are upgrading from Enterprise Manager 10g Grid Control Release 5 (10.2.0.5.0), then on the Port Configuration Details screen, customize the ports to be used for various components.
      If all the ports on this screen appear as -1, then it indicates that the installer is unable to bind the ports on the host. To resolve this issue, exit the installer, verify the host name and the IP configuration of this host (ensure that the IP address of the host is not being used by another host), restart the installer, and try again.
      You can enter a free custom port that is either within or outside the port range recommended by Oracle.
      To verify if a port is free, run the following command:
      On Unix:
      netstat -anp | grep <port no>
      On Microsoft Windows:
      netstat -an|findstr <port_no>
      However, the custom port must be greater than 1024 and lesser than 65535. Alternatively, if you already have the ports predefined in a staticports.ini file and if you want to use those ports, then click Import staticports.ini File and select the file.
      If the staticports.ini file is passed during installation, then by default, the ports defined in the staticports.ini file are displayed. Otherwise, the first available port from the recommended range is displayed.
  11. Click Next.
    • After you verify the details, if you are satisfied, click Configure to begin the installation process.
    If a Configuration Assistant fails, the installer stops and none of the subsequent Configuration Assistants are run until the issue related to the failed Configuration Assistant is resolved. In this case, diagnose the issue, resolve it, and then, click Retry on the Install Progress screen to rerun the Configuration Assistants starting from the Configuration Assistant that failed.
    However, if you accidentally exit the installer before clicking Retry, then do NOT restart the installer to reach the same screen; instead, invoke the runConfig.sh script from the OMS home to rerun the Configuration Assistant in silent mode:
    $<OMS_HOME>/oui/bin/runConfig.sh ORACLE_HOME=<absolute_path_to_OMS_home> MODE=perform ACTION=configure COMPONENT_XML={encap_oms.1_0_0_0_0.xml}
The following are some additional, advanced options you can pass while invoking the configureGC.sh script:
  • By default, GCDomain is the default name used for creating the WebLogic Domain. To override this and use a custom WebLogic Domain name, invoke the script with the WLS_DOMAIN_NAME option, and enter a unique custom name.
    For example, if you want to use the custom name EMDomain, then run the following command:
    $<MIDDLEWARE_HOME>/oms/sysman/install/ConfigureGC.sh WLS_DOMAIN_NAME=EMDomain
  • After the configuration ends successfully, the OMS and the Management Agent start automatically. If you do not want them to start automatically, then invoke the script with START_OMS and b_startAgent options, and set them to TRUE or FALSE depending on what you want to control.
    For example, if you do not want the Management Agent to start automatically, then run the following command:
    $<MIDDLEWARE_HOME>/oms/sysman/install/ConfigureGC.sh START_OMS=TRUE b_startAgent=FALSE
    To understand the limitations involved with this advanced option, see Limitations.
Upgrading in Software-Only Mode with 2-System Upgrade Approach
This section describes how you can upgrade your OMS and Management Repository in software-only mode with 2-System upgrade approach. In particular, this section covers the following:
To install the software binaries, follow the steps outlined in Installing Software Binaries.
If the Enterprise Manager Upload Http Port and Enterprise Manager Central Console Http Port are unlocked in your existing Enterprise Manager system, then while invoking the installer, pass the arguments ALLOW_ONLY_SECURE_ACCESS_TO_CONSOLE and LOCK_ORACLE_MANAGEMENT_SERVICE.
For example,
<Software_Location>/runInstaller -invPtrLoc /home/john/software/oracle/oraInst.loc ALLOW_ONLY_SECURE_ACCESS_TO_CONSOLE=FALSE LOCK_ORACLE_MANAGEMENT_SERVICE=FALSE
If you skip passing these arguments now, and if you want to unlock the ports later, then after upgrading the OMS, run these commands from the upgraded OMS home:
$<OMS_HOME>/bin/emctl secure unlock -console
$<OMS_HOME>/bin/emctl secure unlock -upload
To run the allroot.sh script, Running allroot.sh Script.
To configure and upgrade your existing Enterprise Manager system, follow these steps:
  2. On the Install Types screen, select Upgrade an Existing Enterprise Manager System, and then, select Two System Upgrade.
  3. Click Next.
  4. On the Database Connection Details screen, enter the fully qualified name of the host where the backed up database resides, its listener port and its service name or system ID (SID), and the SYS and SYSMAN user account passwords.
    Oracle Real Application Cluster (Oracle RAC) nodes are referred to by their virtual IP (vip) names. The service_name parameter is used instead of the system identifier (SID) in connect_data mode, and failover is turned on. For more information, refer to Oracle Database Net Services Administrator's Guide.
    The installer uses this information to connect to the backed up database for upgrading the SYSMAN schema. SYSMAN schema holds most of the relational data used in managing Enterprise Manager Cloud Control.
  5. Click Next.
    • If you are connecting to an Oracle RAC database, and if you have entered the virtual IP address of one of its nodes, then the installation wizard prompts you with a Connection String dialog and requests you to update the connection string with information about the other nodes that are part of the cluster. Update the connection string and click OK. If you want to test the connection, click Test Connection.
    • Oracle Real Application Cluster (Oracle RAC) nodes are referred to by their virtual IP (vip) names. The service_name parameter is used instead of the system identifier (SID) in connect_data mode, and failover is turned on. For more information, refer to Oracle Database Net Services Administrator's Guide.
    • If you encounter a Provisioning Archive Framework (PAF) prerequisite check error, then do the following:
      • Exit the installer, run the following SQL command on the backed up database, invoke the installer all over again, and retry the upgrade process.
        UPDATE MGMT_PAF_STATES
        SET status = 6
        WHERE state_type = 0
        AND status IN (0, 1);
      • Exit the installer, discard the backed up database, stop all the running and schedule deployment procedures in your existing Enterprise Manager system, take a fresh backup of the database now, invoke the installer all over again, and retry the upgrade process.
    • If you see a warning asking you to unlock the MGMT_VIEW user account and change the password, ignore it because the installer automatically unlocks it for you.
  6. On the WebLogic Server Configuration Details screen, enter the credentials for the WebLogic Server user account and the Node Manager user account, and validate the path to the Oracle Management Service instance base location.
  7. Click Next.
  8. On the Old Repository Details screen, validate the connect string and enter the SYSMAN password of the old Management Repository.
    The details are used to connect to the old Management Repository, check for accrued data, and seamlessly transfer it to the upgraded Management Repository. Accrued data refers to the data that was uploaded to the old Management Repository from the time it was backed up till the time it was upgraded.
    Typically, the connect string is prepopulated. However, if it is not prepopulated, then enter it in the following format:
    • With SID
      (DESCRIPTION=(ADDRESS_LIST=(ADDRESS=(PROTOCOL=TCP)(HOST=<host_name>)(PORT=<port>)))(CONNECT_DATA=(SID=<sid>)))
    • With Service Name
      (DESCRIPTION=(ADDRESS_LIST=(ADDRESS=(PROTOCOL=TCP)(HOST=<host_name>)(PORT=<port>)))(CONNECT_DATA=(SERVICE_NAME=<service_name>)))
  9. Click Next.
  10. On the Tablespace Location screen, validate the location where the data file (mgmt_ad4j.dbf ) for JVM Diagnostics data tablespace can be stored. You can choose to edit it if you want. In that case, ensure that the path leads up to the file name. Enterprise Manager Cloud Control requires this data file to store monitoring data related to JVM Diagnostics and Application Dependency Performance (ADP).
  11. Click Next.
  12. On the Port Configuration Details screen, customize the ports to be used for various components.
    • Ensure that the ports you enter for Enterprise Manager Upload Http Port and Enterprise Manager Upload Http SSL Port match with the unsecure and secure ports you entered in the Enterprise Manager 12c Upgrade Console.
    • For other components, you can enter a free custom port that is either within or outside the port range recommended by Oracle. However, the custom port must be greater than 1024 and lesser than 65535.
      On Unix:
    • Alternatively, if you already have the ports predefined in a staticports.ini file and if you want to use those ports, then click Import staticports.ini File and select the file.
      If the staticports.ini file is passed during installation, then by default, the ports defined in the staticports.ini file are displayed. Otherwise, the first available port from the recommended range is displayed. If you do pass this file, then ensure that the ports you enter for Enterprise Manager Upload Http Port and Enterprise Manager Upload Http SSL Port match with the unsecure and secure ports you entered in the Enterprise Manager 12c Upgrade Console.
  13. Click Next.
  14. On the Review screen, review the details you provided for the selected installation type.
  15. On the Install Progress screen, view the overall progress (in percentage) of the installation.
  16. On the Finish screen, you should see information pertaining to the installation of Enterprise Manager. Review the information and click Close to exit the installation wizard.
