Skip Headers
Oracle® Enterprise Manager Cloud Control Upgrade Guide
12c Release 2 (12.1.0.2)
E22625-16
  Go To Table Of Contents
Contents
Go To Index
Index
Previous
Previous
Next
Next
C Overview of Metric Changes in Enterprise Manager Cloud Control
This appendix describes the changes to the metrics of the following targets:
Oracle SOA Infrastructure
The following are the changes to the metrics related to Oracle SOA Infrastructure:
Oracle SOA Composite
The following are the changes to the metrics related to Oracle SOA Composite:
Oracle Service Bus
Oracle WebLogic Server
These are configuration metrics, and therefore, they do not appear on the All Metrics page. Instead, they appear on the Last Collected page of the J2EE application.
JBoss Application Server
In the earlier releases of Enterprise Manager, for monitoring JBoss Application Server, the Management Agent required some JAR files listed in the following file of the agent home:
$<AGENT_HOME>/sysman/config/classpath.lst
This file was populated during discovery, and the Management Agent had to restart to honor the JAR files location and append to its classpath.
In Enterprise Manager Cloud Control, the classpath.lst file is not used because there is a dynamic classloader that loads the classes specific to the target after discovery. So the Management Agent need not restart.
There is a new target instance property Library Path that is added to the target metadata. This property is needed by the monitoring logic to differentiate between the case of local and remote monitoring (target monitored by a local or remote agent).
In the case of local monitoring, this property is null.
In the case of remote monitoring, this property is set to the library path location you provide during discovery, which contains the JAR files required for discovering and monitoring JBoss.
During upgrade, ignore this error.
After upgrade, the monitored target status shows as down and no metrics are collected. So set the Library path instance property on the Monitoring Configuration page of the target. Set it to the JAR files location.
Siebel Enterprise
All the metrics available for Siebel Enterprise target have been moved to Siebel Gateway target in Enterprise Manager Cloud Control. As a result, to view the ECM metrics, access the Siebel Gateway target.
Siebel Server
In the earlier releases of Enterprise Manager, for SARM reports, event log, server process control, and workflow processes, you were required to set only the preferred credentials of the hosts on which Siebel Server and Siebel Gateway Server were running. However, in Enterprise Manager Cloud Control, for these features, you must set several other credentials, besides the host credentials. This section describes the different credentials you must set for various Siebel target types.
This section covers the following:
Setting Preferred Credentials for Siebel Server
For Siebel Server, set the following credentials:
Host Preferred Credentials To do so, in Cloud Control, from the Setup menu, select Security, and then, click Preferred Credentials. On the Preferred Credentials page, select Host and click Manage Preferred Credentials. On the Host Preferred Credentials page, set the operating system credentials of the host on which the Siebel Server is running.
Host Credentials for Siebel Server To do so, in Cloud Control, from the Setup menu, select Security, and then, click Preferred Credentials. On the Preferred Credentials page, select Siebel Server and click Manage Preferred Credentials. On the Siebel Server Preferred Credentials page, in the Target Preferred Credentials section, select the credential set Host Credentials, and click Set to set the operating system credentials of the host on which the Siebel Server is running.
Server Manager Credentials for Siebel Server To do so, in Cloud Control, from the Setup menu, select Security, and then, click Preferred Credentials. On the Preferred Credentials page, select Siebel Server and click Manage Preferred Credentials. On the Siebel Server Preferred Credentials page, in the Target Preferred Credentials section, select the credential set Server Manager Credentials, and click Set to set the server manager credentials.
Setting Preferred Credentials for Siebel Gateway Server
For Siebel Gateway Server, set the following credentials:
Host Preferred Credentials To do so, in Cloud Control, from the Setup menu, select Security, and then, click Preferred Credentials. On the Preferred Credentials page, select Host and click Manage Preferred Credentials. On the Host Preferred Credentials page, set the operating system credentials of the host on which the Siebel Gateway Server is running.
Host Credentials for Siebel Gateway Server To do so, in Cloud Control, from the Setup menu, select Security, and then, click Preferred Credentials. On the Preferred Credentials page, select Siebel Gateway Server and click Manage Preferred Credentials. On the Siebel Gateway Server Preferred Credentials page, in the Target Preferred Credentials section, select the credential set Host Credentials, and click Set to set the operating system credentials of the host on which the Siebel Gateway Server is running.
Server Manager Credentials for Siebel Gateway Server To do so, in Cloud Control, from the Setup menu, select Security, and then, click Preferred Credentials. On the Preferred Credentials page, select Siebel Gateway Server and click Manage Preferred Credentials. On the Siebel Gateway Server Preferred Credentials page, in the Target Preferred Credentials section, select the credential set Manage Preferred Credentials, and click Set to set the server manager credentials.
Setting Preferred Credentials for Siebel Database Repository
For Siebel Database Repository, set the Siebel DBStore Credentials.
To do so, in Cloud Control, from the Setup menu, select Security, and then, click Preferred Credentials. On the Preferred Credentials page, select Siebel Database Repository and click Manage Preferred Credentials. On the Siebel Database Repository Preferred Credentials page, in the Target Preferred Credentials section, select the credential set Siebel DBStore Credentials, and click Set to set the credentials.
