Skip Headers
Oracle® Enterprise Manager Cloud Control Upgrade Guide
12c Release 2 (12.1.0.2)
E22625-16
  Go To Table Of Contents
Contents
Go To Index
Index
Previous
Previous
Next
Next
J Recovering Database 11.1.0.7/10.2.0.5 from Microsoft Windows 32 to Microsoft Windows 64
This appendix is based on note:
How To Change Oracle 11g Wordsize from 32-bit to 64-bit. [ID 548978.1]
For information on repository recovery, refer to How To Change Oracle 11g Wordsize from 32-bit to 64-bit [ID 548978.1].
In case of some olap data in win32, at the end of step 0, follow the steps mentioned in Note [ID 386990.1].
This appendix contains the following sections:
On Source Host (Microsoft Windows 32)
To recover Database 11.1.0.7/10.2.0.5 from Microsoft Windows 32 to Microsoft Windows 64, on source host follow these steps:
  1. Go to DB Oracle Home <DB_HOME>\bin\sqlplus /NOLOG
  2. Run the following command:
    SQL> CONNECT / AS SYSDBA :
    If you are using 10.2.0.5 Database, go to <DB HOME>/admin/<SID>/udump and make a backup of this in your local system.
  3. Run the following command:
    SQL> ALTER DATABASE BACKUP CONTROLFILE TO TRACE;
    If you are using 10.2.0.5 Database, the trace file will be generated in <DB HOME>/admin/<SID>/udump. Now compare the files with the backed up <DB HOME>/admin/<SID>/udump. You will find some new trace files. One of the new trace files will contain the steps which will be performed later in Win64 host.
    If you are using 11.1 Database, the command creates a new <sid>_ora_XX.trc file in <DB_BASE>\diag\rdbms\<SID>\<SID>\trace\<sid>_ora_xx.trc. For example:
    C:\DB\diag\rdbms\orcl\orcl\traceorcl_ora_3832.trc
    This file can be used to create the control file in the destination host.
    This file can be identified by the <DB_BASE>\diag\rdbms\<SID>\<SID>\trace\alert_<Sid>.log
    For information about the generated trace file, go to the last few lines.
    Next, go to the console, where you were following the steps for upgrade. Select "Provide Repository Back up details" and then provide the date and time of creation of the trace file which you just identified.
  4. Perform a full offline database backup (optional).
    If you are using 10.2.0.5 Database, run the following command:
    <OMS_HOME>\bin>
    emctl config emkey -copy_to_repos -sysman_pwd <sysman_password>
    For example:
    C:\Oracle\Middleware\oms11g\BIN>emctl config emkey -copy_to_repos -sysman_pwd Welcome1
  5. Run the following command:
    SQL> SHUTDOWN IMMEDIATE;
    STARTUP;
    STARTUP command should also be run after Step 6 on the destination host.
On Destination Host (Microsoft Windows 64)
To recover Database 11.1.0.7/10.2.0.5 from Microsoft Windows 32 to Microsoft Windows 64, on the destination host follow these steps:
  1. Install only the software on the computer.
    Please make sure that the Database being installed here has the same path name as the Database on win32 host. This ensures speedy recovery.
  2. Copy the entire <DB_Base>\oradata directory from Microsoft Windows 32 to <DB_Base>\ directory.
    <DB_HOME>\bin\oradim -new -sid <SID> -maxusers <no. of users> -startmode auto -pfile <DB_HOME>\database\init<SID>.ora
    MAXUSERS may not work with Database 10.2.0.5
    For example:
    C:\DB\db\BIN>oradim.exe -new -sid orcl -maxusers 3 -startmode auto -pfile C:\DB\db\database\initorcl.ora
    You may see an error here. This error can be ignored. However, make sure Instance is created. Also, init<SID>.ora will not be created now.
  4. Copy the entire <DB_Base>\admin directory from win32 to the <DB_Base>\ directory.
  5. Copy the entire <DB_Base>\fast_recovery_area directory from win32 to the <DB_Base>\ directory of win64.
  6. Copy <DBHOME>\database\*.* files from win32 to <DBHOME>\database\ of win64.
    If you are using Database 10.2.0.5, copy <DB_HOME>\dbs\SPFILE<SID>.ORA from win32 to the same location on win64. An example of this file is as follows:
    C:\DB\db\dbs\SPFILEORCL.ORA
    STARTUP;
  7. Set the following environment variables:
    • set ORACLE_HOME=<DB_home>
    • set ORACLE_SID=<SID>
  8. Go to the 64-bit DB_HOME\rdbms\admin directory.
    If you cannot find sqlplus inside this, then go to <DB_HOME>\bin
  9. Run the following command:
    sqlplus /NOLOG
  10. Connect /as sysdba.
  11. Run the following command:
    SQL> create pfile from spfile;
    : If you are using Database10.2.0.5, run the following command:
    create pfile='<DB_HOME>\database\init<SID>.ora' from SPFILE='<DB_HOME>\dbs\SPFILE<SID>.ORA';
    For example:
    create pfile='C:\DB\db\database\initorcl.ora' from SPFILE='C:\DB\db\dbs\SPFILEORCL.ORA';
    If you are using Database 11.1.0.7, run the following command:
    create pfile='<DB_HOME>\database\init<SID>.ora' from SPFILE='<DB_HOME>\database\SPFILE<SID>.ORA';
    For example:
    create pfile='C:\DB\db\database\initorcl.ora' from SPFILE='C:\DB\db\database\SPFILEORCL.ORA';
  12. Edit <DB_HOME>\database\init<SID>.ora by adding _SYSTEM_TRIG_ENABLED=FALSE.
  13. Run the following command:
    SQL> create spfile from pfile
    The spfile gets created in the same directory.
  14. Run the following command:
    SQL> startup nomount
    The Instance starts as nomount.
    You may receive a failure message as follows:
    ORA-00119: invalid specification for system parameter LOCAL_LISTENER
    ORA-00132: syntax error or unresolved network name '<listener name>'
    To correct this you may need to edit pfile, spfile;
    To edit the pfile and spfile, open '<DB_HOME>\database\init<SID>.ora' and delete the following line:
    LOCAL_LISTENER
    Next, run the following command:
    Sql> create spfile from pfile
  15. Go to the file <sid>_ora_xx.trc as identified in 0 of Microsoft Windows 32. Steps 15, 16 and 17 are to be carried out from this file. For your reference, example of these steps are as follows:
    SQL > CREATE CONTROLFILE REUSE DATABASE "ORCL" NORESETLOGS  NOARCHIVELOG
        MAXLOGFILES 16
        MAXLOGMEMBERS 3
        MAXDATAFILES 100
        MAXINSTANCES 8
        MAXLOGHISTORY 292
    LOGFILE
      GROUP 1 'C:\DB\ORADATA\ORCL\REDO01.LOG'  SIZE 50M BLOCKSIZE 512,
      GROUP 2 'C:\DB\ORADATA\ORCL\REDO02.LOG'  SIZE 50M BLOCKSIZE 512,
      GROUP 3 'C:\DB\ORADATA\ORCL\REDO03.LOG'  SIZE 50M BLOCKSIZE 512
    DATAFILE
      'C:\DB\ORADATA\ORCL\SYSTEM01.DBF',
      'C:\DB\ORADATA\ORCL\SYSAUX01.DBF',
      'C:\DB\ORADATA\ORCL\UNDOTBS01.DBF',
      'C:\DB\ORADATA\ORCL\USERS01.DBF',
      'C:\DB\ORADATA\ORCL\MGMT_ECM_DEPOT1.DBF',
      'C:\DB\ORADATA\ORCL\MGMT.DBF',
      'C:\DB\ORADATA\ORCL\MGMT_AD4J.DBF'
    CHARACTER SET WE8MSWIN1252;
    : In case you find an error here, try the following command:
    SQL> RECOVER DATABASE;
  16. Run the following command:
    SQL>ALTER DATABASE OPEN;
  17. Run the following command:
    SQL>ALTER TABLESPACE TEMP ADD TEMPFILE 'C:\DB\ORADATA\ORCL\TEMP01.DBF' SIZE 20971520 REUSE AUTOEXTEND ON NEXT 655360 MAXSIZE 32767M;
    This command updates the temp table space.
  18. Run the following command:
  19. Run the following command:
    SQL> startup upgrade;
  20. Run the following command:
    SQL> SPOOL mig32-64.log;
  21. Run the following command:
    SQL> SET ECHO ON;
  22. Run the following command:
    SQL> @utlirp.sql;
    If you are using sqlplus from <DB_HOME>\bin\ then run the following command:
    SQL> @ <DB_HOME>\RDBMS\ADMIN\utlirp.sql
    or
    SQL> @ ?/RDBMS/ADMIN?utlirp.sql
  23. Run the following command:
    SQL> spool off;
  24. Run the following command:
    SQL> shutdown immediate;
  25. Run the following command:
    SQL> startup
  26. Run the following script. To run the script paste it in SQL>prompt and press Enter.
    begin
      update obj$ set status=5 where obj#=(select obj# from obj$,javasnm$
        where owner#=0 and type#=29 and short(+)=name and
        nvl(longdbcs,name)='oracle/aurora/rdbms/Compiler');
      commit;
      declare
        cursor C1 is select
           'DROP JAVA DATA "' || u.name || '"."' || o.name || '"'
           from obj$ o,user$ u where o.type#=56 and u.user#=o.owner#;
        ddl_statement varchar2(200);
        iterations number;
        previous_iterations number;
        loop_count number;
        my_err     number;
      begin
        previous_iterations := 10000000;
        loop
          -- To make sure we eventually stop, pick a max number of iterations
          select count(*) into iterations from obj$ where type#=56;
          exit when iterations=0 or iterations >= previous_iterations;
          previous_iterations := iterations;
          loop_count := 0;
          open C1;
         loop
           begin
             fetch C1 into ddl_statement;
             exit when C1%NOTFOUND or loop_count > iterations;
          exception when others then
             my_err := sqlcode;
             if my_err = -1555 then -- snapshot too old, re-execute fetch query
               exit;
             else
               raise;
            end if;
          end;
          initjvmaux.exec(ddl_statement);
          loop_count := loop_count + 1;
         end loop;
         close C1;
        end loop;
      end;
      commit;
      initjvmaux.drp('delete from java$policy$shared$table');
      update obj$ set status=1 where obj#=(select obj# from obj$,javasnm$
      commit;
    end;
    create or replace java system;
  27. Run the following command:
    SQL> @utlrp.sql
    If you are using sqlplus from <DB_HOME>\bin\ then, run the following command:
    SQL> @ <DB_HOME>\RDBMS\ADMIN\utlrp.sql
    or
    SQL> @ ?/RDBMS/ADMIN?utlrp.sql
    If it succeeds, then continue to 0 Else, if you receive an error, do the following:
      SQL> alter system reset "_system_trig_enabled" scope = spfile;
      If you see errrors, ignore them and continue to the next step.
    2. Remove olap by running the following commands:
      SQL> @?/olap/admin/catnoamd.sql
      If you get an error related to files not found then, for each of those files, use the following command:
      SQL>@C:\DB\db\olap\admin\<filename>.sql;
      However, even if you receive errors, you can just continue.
      SQL> @?/olap/admin/catnoaps.sql
      SQL> @?/olap/admin/olapidrp.plb
    3. Add olap by running the following commands:
      SQL> connect SYS as SYSDBA
      SQL> spool olap.log
      SQL> @?/olap/admin/olap.sql SYSAUX TEMP;
    4. Reenter the following command:
      SQl> @utlrp.sql
      : If you are using sqlplus from <DB_HOME>\bin\ then, run the following command:
      or
    5. Check for the following (optional):
      - Invalid OLAPSYS objects, by running the following command:
      SQL> select owner, object_name, object_type, status from dba_objects where status = 'INVALID' and OWNER = 'OLAPSYS' ;
      - OLAP components in the DBA_REGISTRY, by running the following commands:
      SQL> column comp_name format a35
      SQL> SELECT comp_name, status, substr(version,1,10) as version from dba_registry;
      SQL> Spool Off
  28. Delete the line _SYSTEM_TRIG_ENABLED=FALSE in init<SID>.ora in step 11 and run the following commands:
    SQL> ALTER SYSTEM RESET "_system_trig_enabled" SCOPE=SPFILE sid='*';
    commit;
    shutdown immediate;
    startup;
Final Steps
To finalize the process, do the following:
On Microsoft Windows 32 computer, do the following:
  1. Go to <DB_HOME>\bin.
    sqlplus "/as sysdba"
    SQL>startup;
    <OMS_HOME>\bin>emctl config emkey -remove_from_repos
    For example:
    C:\Oracle\Middleware\oms11g\BIN>emctl config emkey -remove_from_repos
  3. Go to <DB_HOME>\bin.
    shutdown immediate;
    startup;
On Microsoft Windows 64 computer, do the following:
  1. Start the listener, by running the following command:
    <DB_HOME>\bin\listener.exe start
    Alternatively, you can start the listener, by running the following command:
    <DB_HOME>\bin\netca
    This can be done before or after recovery.
  2. If the listener does not start, perform the following commands with <SID>:
    <DB_HOME>\bin\sqlplus "/as sysdba"
    SQL>alter system register;
    SQL>commit;
    SQL>shutdown immediate;
    SQL>startup;
Troubleshooting
If you still face any issues, follow these steps:
These steps have been tested with Database 10.2.0.5.
    <DB_HOME>\BIN\orapwd file=<DB_HOME>\database\PWDorcl.ora password=<enter_password> entries=30 FORCE=Y
  2. You may need to add an entry in tnsnames.ora. An example of the entry is as follows:
    ORCL =
      (DESCRIPTION =
        (ADDRESS = (PROTOCOL = TCP)(HOST = adc2111519.us.oracle.com)(PORT = 1521))
        (CONNECT_DATA =
          (SERVER = DEDICATED)
          (SERVICE_NAME = orcl.us.oracle.com)
    Where, orcl is the SID.
  3. Bounce the database from SQLPlus by running the following commands:
    SQL>startup;
  4. Bounce the listener by running the following commands:
    <DB_HOME>\bin\listener.exe stop
    <DB_HOME>\bin\listener.exe status (to be repeated till you see the service name)
