Skip navigation links
Oracle® Coherence Java API Reference
Constant Field Values
public static final int WORK_ACCEPTED 1
public static final int WORK_COMPLETED 4
public static final int WORK_REJECTED 2
public static final int WORK_STARTED 3
protected static final int WORK_UNKNOWN 0
protected static final int DEFAULT_LOCK_LEASE_MILLIS 60000
protected static final int DEFAULT_LOCK_OBTAIN_MILLIS 60000
public static final java.lang.String LOCK_LEASE_TIMEOUT "tangosol.coherence.hibernate.lockleasetimeout"
public static final java.lang.String LOCK_OBTAIN_TIMEOUT "tangosol.coherence.hibernate.lockobtaintimeout"
public static final java.lang.String CACHE_CONFIG_PATH "tangosol.coherence.hibernate.cacheconfig"
protected static final java.lang.String DEFAULT_CACHE_CONFIG_PATH "config/hibernate-cache-config.xml"
protected static final java.lang.String PREFIX "tangosol.coherence.hibernate."
protected static final java.lang.String PARAM_IDS "ids"
public static final java.lang.String FORMAT_OUTPUT ""
public static final java.lang.String DEFAULT_ADDRESS "localhost"
public static final int DEFAULT_PORT 8080
public static final java.lang.String AGGREGATOR_REQUEST_REGEX "\\s*(\\w(?:\\w|-)*)\\((.*)\\)"
public static final java.lang.String PROCESSOR_REQUEST_REGEX "\\s*(\\w(?:\\w|-)*)\\((.*)\\)"
public static final java.lang.String CACHENAME_DEATHCERTS "session-death-certificates"
public static final java.lang.String CACHENAME_LOCAL_ATTRIBUTES "local-attribute-storage"
public static final java.lang.String CACHENAME_LOCAL_SESSIONS "local-session-storage"
public static final java.lang.String CACHENAME_SESSIONS "session-storage"
public static final java.lang.String CTX_INIT_ENABLE_SESSION_ACCESS_DEBUG_LOGGING "coherence-session-enable-debug-logging"
public static final java.lang.String CTX_INIT_SESSION_ACCESS_DEBUG_LOGGING_FILTER "coherence-session-debug-logging-filter"
public static final java.lang.String SERVICENAME_OWNERSHIP "SessionOwnership"
public static final int MAGIC_V350 1785231208
public static final java.lang.String THREAD_OWNING_MSG "Thread holding lock to session: "
public static final java.lang.String THREADS_OWNING_MSG "Threads holding lock to session: "
public static final java.lang.String CACHE_CONFIGURATION_PATH "session-cache-config.xml"
public static final java.lang.String CFG_KEY_REAPER "reaper-status"
public static final java.lang.String CTX_ATTR_CONTEXT "coherence-context"
public static final java.lang.String CTX_ATTR_HELPER "coherence-sessionhelper"
public static final java.lang.String CTX_INIT_ALLOW_LOCAL_ATTRIBUTES "coherence-preserve-attributes"
public static final java.lang.String CTX_INIT_APPLICATION_NAME "coherence-application-name"
protected static final java.lang.String CTX_INIT_APPLICATION_NAME_GENERATED "coherence-application-name-generated"
public static final java.lang.String CTX_INIT_ATTR_OVERFLOW_THRESHOLD "coherence-attribute-overflow-threshold"
public static final java.lang.String CTX_INIT_CACHE_DELEGATOR_CLASS "coherence-cache-delegator-class"
public static final java.lang.String CTX_INIT_CACHENAME_CONTEXT "coherence-servletcontext-cachename"
public static final java.lang.String CTX_INIT_CACHENAME_DEATHCERTS "coherence-session-deathcert-cachename"
public static final java.lang.String CTX_INIT_CACHENAME_LOCAL_ATTRIBUTES "coherence-local-attribute-cachename"
public static final java.lang.String CTX_INIT_CACHENAME_LOCAL_SESSIONS "coherence-local-session-cachename"
public static final java.lang.String CTX_INIT_CACHENAME_MANAGEMENT "coherence-session-management-cachename"
public static final java.lang.String CTX_INIT_CACHENAME_OVERFLOW "coherence-session-overflow-cachename"
public static final java.lang.String CTX_INIT_CACHENAME_SESSIONS "coherence-session-cachename"
public static final java.lang.String CTX_INIT_CLUSTER "coherence-servletcontext-clustered"
public static final java.lang.String CTX_INIT_CLUSTER_OWNED "coherence-cluster-owned"
public static final java.lang.String CTX_INIT_COLLECTION "coherence-sessioncollection-class"
public static final java.lang.String CTX_INIT_CONFIGURATION_CONSISTENCY "coherence-configuration-consistency"
public static final java.lang.String CTX_INIT_COOKIE_DOMAIN "coherence-session-cookie-domain"
public static final java.lang.String CTX_INIT_COOKIE_MAX_AGE "coherence-session-cookie-max-age"
public static final java.lang.String CTX_INIT_COOKIE_NAME "coherence-session-cookie-name"
public static final java.lang.String CTX_INIT_COOKIE_PATH "coherence-session-cookie-path"
public static final java.lang.String CTX_INIT_COOKIE_SECURE "coherence-session-cookie-secure"
public static final java.lang.String CTX_INIT_COOKIES_ENABLED "coherence-session-cookies-enabled"
public static final java.lang.String CTX_INIT_DAEMON_ASSUME_LOCALITY "coherence-reaperdaemon-assume-locality"
public static final java.lang.String CTX_INIT_DAEMON_COORDINATED "coherence-reaperdaemon-cluster-coordinated"
public static final java.lang.String CTX_INIT_DAEMON_CYCLE_SECS "coherence-reaperdaemon-cycle-seconds"
public static final java.lang.String CTX_INIT_DAEMON_MAX_THREADS "coherence-reaperdaemon-max-threads"
public static final java.lang.String CTX_INIT_DAEMON_MIN_THREADS "coherence-reaperdaemon-min-threads"
public static final java.lang.String CTX_INIT_DAEMON_PARALLEL "coherence-reaperdaemon-parallel"
public static final java.lang.String CTX_INIT_DAEMON_PRIORITY "coherence-reaperdaemon-priority"
public static final java.lang.String CTX_INIT_DAEMON_QUEUE_SIZE "coherence-reaperdaemon-queue-size"
public static final java.lang.String CTX_INIT_DAEMON_SWEEP_MODULO "coherence-reaperdaemon-sweep-modulo"
public static final java.lang.String CTX_INIT_DIST_CONTROLLER_CLASS "coherence-distributioncontroller-class"
public static final java.lang.String CTX_INIT_ENABLE_ATTR_LISTENER_OPTIMIZATION "coherence-enable-attribute-listener-optimization"
public static final java.lang.String CTX_INIT_ENABLE_SUSPECT_ATTRIBUTES "coherence-enable-suspect-attributes"
public static final java.lang.String CTX_INIT_FACTORY "coherence-factory-class"
public static final java.lang.String CTX_INIT_FILTER "coherence-filter-class"
public static final java.lang.String CTX_INIT_LISTENS "coherence-eventlisteners"
public static final java.lang.String CTX_INIT_LOG_THREADS_HOLDING_LOCK "coherence-session-log-threads-holding-lock"
public static final java.lang.String CTX_INIT_SCOPE_CONTROLLER_CLASS "coherence-scopecontroller-class"
public static final java.lang.String CTX_INIT_SERVICENAME_OWNERSHIP "coherence-ownership-service"
public static final java.lang.String CTX_INIT_SERVLET "coherence-servlet-class"
public static final java.lang.String CTX_INIT_SESSION_AFFINITY_TOKEN "coherence-session-affinity-token"
public static final java.lang.String CTX_INIT_SESSION_APP_LOCK "coherence-session-app-locking"
public static final java.lang.String CTX_INIT_SESSION_EXPIRE_SECS "coherence-session-expire-seconds"
protected static final java.lang.String CTX_INIT_SESSION_EXPIRY_FILTER_FACTORY "coherence-session-expiry-filter-factory-class"
public static final java.lang.String CTX_INIT_SESSION_GET_LOCK_TIMEOUT "coherence-session-get-lock-timeout"
public static final java.lang.String CTX_INIT_SESSION_ID_GENERATOR_CLASS "coherence-session-id-generator-class"
public static final java.lang.String CTX_INIT_SESSION_ID_LENGTH "coherence-session-id-length"
public static final java.lang.String CTX_INIT_SESSION_LAZY_ACCESS "coherence-session-lazy-access"
public static final java.lang.String CTX_INIT_SESSION_LOCK "coherence-session-locking"
public static final java.lang.String CTX_INIT_SESSION_LOG_INVALIDATION_EXCEPTIONS "coherence-session-log-invalidation-exceptions"
public static final java.lang.String CTX_INIT_SESSION_MEMBER_LOCK "coherence-session-member-locking"
public static final java.lang.String CTX_INIT_SESSION_RETAIN_MILLIS "coherence-contextless-session-retain-millis"
public static final java.lang.String CTX_INIT_SESSION_STICKY "coherence-sticky-sessions"
public static final java.lang.String CTX_INIT_SESSION_STRICT_SPEC "coherence-session-strict-spec"
public static final java.lang.String CTX_INIT_SESSION_THREAD_LOCK "coherence-session-thread-locking"
public static final java.lang.String CTX_INIT_SESSIONCONTEXT_ENABLED "coherence-enable-sessioncontext"
public static final java.lang.String CTX_INIT_SHUTDOWN_DELAY_SECS "coherence-shutdown-delay-seconds"
public static final java.lang.String CTX_INIT_URLDECODE_DEFAULT "coherence-session-urldecode-bycontainer"
public static final java.lang.String CTX_INIT_URLENCODE_DEFAULT "coherence-session-urlencode-bycontainer"
public static final java.lang.String CTX_INIT_URLENCODE_ENABLED "coherence-session-urlencode-enabled"
public static final java.lang.String CTX_INIT_URLENCODE_NAME "coherence-session-urlencode-name"
public static final java.lang.String DEFAULT_CTXNAME "servletcontext-storage"
public static final java.lang.String DEFAULT_FACTORY "DefaultFactory"
public static final java.lang.String DEFAULT_MGTNAME "session-management"
public static final int EVT_ADDED 1
public static final int EVT_REMOVED 2
public static final int EVT_REPLACED 3
public static final java.lang.String REQ_ATTR_COUNT "coherence-count"
public static final java.lang.String REQ_ATTR_SESSION "coherence-session"
public static final java.lang.String REQ_ATTR_TEST "coherence-test"
public static final java.lang.String CACHENAME_OVERFLOW "session-overflow"
public static final java.lang.String OPT_INSTALL "-install"
public static final java.lang.String OPT_UNINSTALL "-uninstall"
public static final int BLOCK_SIZE 4096
public static final java.lang.String INSTALL_DESCRIPTOR "coherence-web-plugin.xml"
public static final java.lang.String MANIFEST_NAME "META-INF/MANIFEST.MF"
public static final java.lang.String OBJECT_TYPE "type=HttpSessionManager"
public static final java.lang.String INVOCATION_SERVICE_NAME "PortalInvocationService"
public static final java.lang.String PATH_CACHE_CONFIG "config/portal-cache-config.xml"
public static final java.lang.String PATH_PROVIDER_CONFIG "config/portal-provider-config.xml"
protected static final int CHAR_BUF_MASK 255
protected static final int CHAR_BUF_SIZE 256
protected static final int DEFAULT_LIMIT 4194304
protected static final long WAIT_FOREVER -1L
protected static final char BASE64_LF 10
protected static final char BASE64_PAD 61
protected static final int GROUPS_PER_LINE 19
protected static final byte FMT_BINDIFF -12
protected static final byte FMT_EMPTY -10
protected static final byte FMT_REPLACE -11
protected static final int MIN_BLOCK 12
protected static final byte OP_APPEND 2
protected static final byte OP_EXTRACT 1
protected static final byte OP_TERM 3
protected static final int MARK_UNSET 2147483647
public static final int DEFAULT_BUF_SIZE 1024
public static final int MAX_PACKED_INT_SIZE 5
public static final int MAX_PACKED_LONG_SIZE 10
public static final java.lang.String ENVIRONMENT_NAME_PREFIX "bdbtemp"
public static final java.lang.String JE_PROPERTY_PREFIX "je."
public static final java.lang.String TEMP_FILE_NAME_PREFIX "cohbdb"
public static final java.lang.String LOCK_FILE_NAME "coherence.lck"
protected static final long MASK_COMPACT_FLAG -9223372036854775808L
protected static final long MASK_COMPACT_LENGTH 504403158265495552L
public static final double MAX_COLLECT_PCT 0.99
public static final double MIN_COLLECT_PCT 0.01
protected static final int SHIFT_COMPACT_FLAG 63
protected static final int SHIFT_COMPACT_LENGTH 56
protected static final int STATE_CONFIGURED 1
protected static final int STATE_INITIAL 0
protected static final int STATE_RUNNING 2
protected static final int STATE_STOPPED 4
protected static final int STATE_STOPPING 3
public static final long STATE_APPENDING 0L
public static final long STATE_CONGESTION 1152921504606846976L
public static final long STATE_DISCARDED 5764607523034234880L
public static final long STATE_EVACUATING 3458764513820540928L
public static final long STATE_FULL 2305843009213693952L
public static final long STATE_GARBAGE 4611686018427387904L
public static final long STATE_MASK -1152921504606846976L
public static final int DFT_BACKLOG_SIZE 16777216
public static final int DFT_BLOCK_SIZE 262144
public static final double DFT_COLLECT_PCT 0.25
public static final long DFT_FILE_SIZE 2147483648L
public static final int DFT_POOL_SIZE 16777216
public static final int DFT_PURGE_DELAY_MILLIS 7200000
protected static final long MASK_FILE_ID 9205357638345293824L
protected static final long MASK_LENGTH 67108863L
protected static final long MASK_OFFSET 18014398442373120L
public static final int MAX_BACKLOG_SIZE 1073741824
public static final int MAX_BLOCK_SIZE 1048576
public static final long MAX_FILE_SIZE 4294967296L
public static final int MAX_POOL_SIZE 1073741824
public static final int MAX_VALUE_SIZE 67108863
public static final int MIN_BACKLOG_SIZE 4096
public static final int MIN_BLOCK_SIZE 4096
public static final long MIN_FILE_SIZE 1048576L
protected static final int SHIFT_FILE_ID 54
protected static final int SHIFT_LENGTH 0
protected static final int SHIFT_OFFSET 26
protected static final int SHIFT_OFFSET_RAW 22
public static final double DFT_COLLECT_PCT 0.84
public static final long DFT_FILE_SIZE 2097152L
public static final long DFT_POOL_SIZE 16777216L
public static final long DFT_TOTAL_SIZE 1073741824L
public static final int DFT_VALUE_SIZE 16384
protected static final long MASK_FILE_ID 4602678819172646912L
protected static final long MASK_LENGTH 4194303L
protected static final long MASK_OFFSET 9007199250546688L
protected static final long MASK_RAM_FLAG 4611686018427387904L
public static final long MAX_FILE_SIZE 2147483647L
public static final long MAX_POOL_SIZE 68719476736L
public static final long MAX_TOTAL_SIZE 68719476736L
public static final int MAX_VALUE_SIZE 4194303
public static final long MIN_TOTAL_SIZE 16777216L
protected static final int SHIFT_FILE_ID 53
protected static final int SHIFT_OFFSET 22
protected static final int SHIFT_RAM_FLAG 62
public static final double DEFAULT_MAXLOADFACTOR 0.875
public static final double DEFAULT_MINLOADFACTOR 0.75
protected static final byte FILL_BYTE 0
protected static final int MAX_OPEN_BLOCKS 8
protected static final int MAX_SIZE_CODES 26
protected static final boolean MODE_DEBUG false
protected static final int NIL -1
protected static final int SIZE_COPY_BUFFER 1024
public static final int ENTRY 2
public static final int FREE 1
public static final int MIN_ENTRY 29
public static final int MIN_FREE 17
public static final int MIN_SPLIT 64
public static final int NONE 0
public static final int OFFSET_HASH 17
public static final int OFFSET_KEY 21
public static final int OFFSET_VALUE 25
public static final int CLEANUP_FINALIZERS 1
public static final int CLEANUP_GC 2
public static final int CLEANUP_NONE 0
public static final int DEFAULT_MAX_SIZE 2147483647
public static final int DEFAULT_MIN_SIZE 16384
public static final java.lang.String PROPERTY_CONFIG "tangosol.pof.config"
public static final int J_BIG_DECIMAL 11
public static final int J_BIG_INTEGER 7
public static final int J_BINARY 12
public static final int J_BOOLEAN 1
public static final int J_BOOLEAN_ARRAY 24
public static final int J_BYTE 2
public static final int J_BYTE_ARRAY 25
public static final int J_CHAR_ARRAY 26
public static final int J_CHARACTER 3
public static final int J_COLLECTION 34
public static final int J_DATE 14
public static final int J_DATETIME 16
public static final int J_DOUBLE 9
public static final int J_DOUBLE_ARRAY 31
public static final int J_FLOAT 8
public static final int J_FLOAT_ARRAY 30
public static final int J_INT_ARRAY 28
public static final int J_INTEGER 5
public static final int J_LONG 6
public static final int J_LONG_ARRAY 29
public static final int J_MAP 35
public static final int J_NULL 0
public static final int J_OBJECT_ARRAY 32
public static final int J_QUAD 10
public static final int J_RAW_DATE 18
public static final int J_RAW_DATETIME 20
public static final int J_RAW_DAY_TIME_INTERVAL 23
public static final int J_RAW_TIME 19
public static final int J_RAW_TIME_INTERVAL 22
public static final int J_RAW_YEAR_MONTH_INTERVAL 21
public static final int J_SHORT 4
public static final int J_SHORT_ARRAY 27
public static final int J_SPARSE_ARRAY 33
public static final int J_STRING 13
public static final int J_TIME 15
public static final int J_TIMESTAMP 17
public static final int J_USER_TYPE 36
public static final int MAX_DECIMAL128_SCALE 6144
public static final int MAX_DECIMAL32_SCALE 96
public static final int MAX_DECIMAL64_SCALE 384
public static final int MIN_DECIMAL128_SCALE -6143
public static final int MIN_DECIMAL32_SCALE -95
public static final int MIN_DECIMAL64_SCALE -383
public static final int T_ARRAY -24
public static final int T_BOOLEAN -11
public static final int T_CHAR -14
public static final int T_CHAR_STRING -15
public static final int T_COLLECTION -22
public static final int T_DATE -16
public static final int T_DATETIME -20
public static final int T_DAY_TIME_INTERVAL -21
public static final int T_DECIMAL128 -10
public static final int T_DECIMAL32 -8
public static final int T_DECIMAL64 -9
public static final int T_FLOAT128 -7
public static final int T_FLOAT32 -5
public static final int T_FLOAT64 -6
public static final int T_IDENTITY -31
public static final int T_INT128 -4
public static final int T_INT16 -1
public static final int T_INT32 -2
public static final int T_INT64 -3
public static final int T_MAP -28
public static final int T_OCTET -12
public static final int T_OCTET_STRING -13
public static final int T_REFERENCE -32
public static final int T_SPARSE_ARRAY -26
public static final int T_TIME -18
public static final int T_TIME_INTERVAL -19
public static final int T_UNIFORM_ARRAY -25
public static final int T_UNIFORM_COLLECTION -23
public static final int T_UNIFORM_KEYS_MAP -29
public static final int T_UNIFORM_MAP -30
public static final int T_UNIFORM_SPARSE_ARRAY -27
public static final int T_UNKNOWN -65
public static final int T_YEAR_MONTH_INTERVAL -17
public static final int V_BOOLEAN_FALSE -33
public static final int V_BOOLEAN_TRUE -34
public static final int V_COLLECTION_EMPTY -36
public static final int V_FP_NAN -40
public static final int V_FP_NEG_INFINITY -39
public static final int V_FP_POS_INFINITY -38
public static final int V_INT_0 -42
public static final int V_INT_1 -43
public static final int V_INT_10 -52
public static final int V_INT_11 -53
public static final int V_INT_12 -54
public static final int V_INT_13 -55
public static final int V_INT_14 -56
public static final int V_INT_15 -57
public static final int V_INT_16 -58
public static final int V_INT_17 -59
public static final int V_INT_18 -60
public static final int V_INT_19 -61
public static final int V_INT_2 -44
public static final int V_INT_20 -62
public static final int V_INT_21 -63
public static final int V_INT_22 -64
public static final int V_INT_3 -45
public static final int V_INT_4 -46
public static final int V_INT_5 -47
public static final int V_INT_6 -48
public static final int V_INT_7 -49
public static final int V_INT_8 -50
public static final int V_INT_9 -51
public static final int V_INT_NEG_1 -41
public static final int V_REFERENCE_NULL -37
public static final int V_STRING_ZERO_LENGTH -35
public static final int TYPE_PORTABLE 2147483646
public static final int TYPE_SERIALIZABLE 2147483647
public static final java.lang.String TYPE_DISTRIBUTED "DistributedCache"
public static final java.lang.String TYPE_LOCAL "LocalCache"
public static final java.lang.String TYPE_OPTIMISTIC "OptimisticCache"
public static final java.lang.String TYPE_REMOTE "RemoteCache"
public static final java.lang.String TYPE_REPLICATED "ReplicatedCache"
public static final int ALL 7
public static final int CREATE 1
public static final int DESTROY 2
public static final int JOIN 4
public static final java.lang.String ROLE_ALL "*role-any*"
public static final int MASK_DISTRIBUTION 1
public static final int MASK_READ 4
public static final int MASK_RESTORE 2
public static final int MASK_WRITE 8
public static final int MASK_CONNECT 1
public static final long DEFAULT_WAIT_MILLIS 5000L
public static final java.lang.String CACHE_NAME "{cache-name}"
public static final java.lang.String CACHE_REF "{cache-ref}"
public static final java.lang.String CLASS_LOADER "{class-loader}"
public static final java.lang.String FILE_CFG_CACHE "coherence-cache-config.xml"
public static final java.lang.String JOURNAL_SERVICE_NAME "journalservice"
public static final java.lang.String MGR_CONTEXT "{manager-context}"
public static final int SCHEME_CLASS 11
public static final int SCHEME_DISK 8
public static final int SCHEME_DISTRIBUTED 3
public static final int SCHEME_EXTERNAL 9
public static final int SCHEME_EXTERNAL_PAGED 10
public static final int SCHEME_FLASHJOURNAL 19
public static final int SCHEME_INVOCATION 14
public static final int SCHEME_LOCAL 6
public static final int SCHEME_NEAR 4
public static final int SCHEME_OPTIMISTIC 2
public static final int SCHEME_OVERFLOW 7
public static final int SCHEME_PROXY 15
public static final int SCHEME_RAMJOURNAL 20
public static final int SCHEME_READ_WRITE_BACKING 12
public static final java.lang.String SCHEME_REF "{scheme-ref}"
public static final int SCHEME_REMOTE_CACHE 16
public static final int SCHEME_REMOTE_INVOCATION 17
public static final int SCHEME_REPLICATED 1
public static final int SCHEME_TRANSACTIONAL 18
public static final int SCHEME_UNKNOWN 0
public static final int SCHEME_VERSIONED_BACKING 13
public static final int SCHEME_VERSIONED_NEAR 5
public static final int STATE_HEALTHY 1
public static final int STATE_RECOVERY 2
public static final int STATE_TERMINATING 3
protected static final long GUARDIAN_EARLY_THRESHOLD 500L
protected static final long GUARDIAN_LATE_THRESHOLD 10000L
protected static final long GUARDIAN_LOG_INTERVAL 3000L
public static final long GUARDIAN_MAX_CHECK_INTERVAL 5000L
public static final java.lang.String TYPE_DEFAULT "Invocation"
public static final java.lang.String TYPE_REMOTE "RemoteInvocation"
public static final int MEMBER_JOINED 1
public static final int MEMBER_LEAVING 2
public static final int MEMBER_LEFT 3
public static final int SCHEDULE_FIRST 1
public static final int SCHEDULE_IMMEDIATE 2
public static final int SCHEDULE_STANDARD 0
public static final long TIMEOUT_DEFAULT 0L
public static final long TIMEOUT_NONE -1L
public static final long REFRESH_DEFAULT 10000L
protected static final java.lang.String URI_DEFAULT "$Default$"
public static final java.lang.String XML_NAME "socket-providers"
public static final java.lang.String XML_PROVIDER_NAME "socket-provider"
public static final java.lang.String XML_NAME "system"
public static final int HEADER_SIZE 4
public static final int PROTOCOL_MAGIC 232718554
public static final java.lang.String XML_NAME "tcp"
public static final int STATUS_EXCEPTION 3
public static final int STATUS_OPEN 0
public static final int STATUS_PENDING 1
public static final int STATUS_PROCESSED 2
public static final long EXPIRY_DEFAULT 0L
public static final long EXPIRY_NEVER -1L
public static final int LISTEN_ALL 2
public static final int LISTEN_AUTO 3
public static final int LISTEN_NONE 0
public static final int LISTEN_PRESENT 1
public static final int STATE_CONFIGURED 2
public static final int STATE_CONFIGURING 1
public static final int STATE_DISCONNECTED 0
public static final int STATE_INIT 0
public static final int STATE_SYNCHRONIZED 3
public static final int DEFAULT_EXPIRE 0
public static final int DEFAULT_UNITS 2147483647
public static final int DEFAULT_EXPIRE 3600000
public static final int DEFAULT_FLUSH 60000
public static final double DEFAULT_PRUNE 0.8
public static final int DEFAULT_UNITS 1000
public static final int EVICTION_POLICY_EXTERNAL 3
public static final int EVICTION_POLICY_HYBRID 0
public static final int EVICTION_POLICY_LFU 2
public static final int EVICTION_POLICY_LRU 1
public static final int UNIT_CALCULATOR_BINARY 1
public static final int UNIT_CALCULATOR_EXTERNAL 2
public static final int UNIT_CALCULATOR_FIXED 0
public static final int ENTRY_DELETED 3
public static final int ENTRY_INSERTED 1
public static final int ENTRY_UPDATED 2
protected static final int STATE_MASK_BACK 16
protected static final int STATE_MASK_EXISTS 24
protected static final int STATE_MASK_FRONT 8
protected static final int STATE_MASK_INSYNC 32
protected static final int STATE_MASK_RETAIN 31
protected static final int STATE_MASK_STATUS 7
protected static final int STATUS_AVAILABLE 0
protected static final int STATUS_COMMITTING 2
protected static final int STATUS_INVALIDATED 3
protected static final int STATUS_PROCESSING 1
protected static final float GUARD_RECOVERY 0.8999999761581421f
protected static final int STATE_MASK_INSYNC 16
protected static final int STATE_VALUE_RETAIN 16
protected static final int STATUS_COMMITTING 3
protected static final int STATUS_INVALIDATED 4
protected static final int STATUS_PROCESSING 2
protected static final int STATUS_RESERVED 1
public static final long MAX_LOCK_WAIT 0L
public static final int DEFAULT_HTTP_PORT 8888
public static final int DEFAULT_RMI_CONNECTION_PORT 3000
public static final java.lang.String DEFAULT_RMI_HOST "localhost"
public static final int DEFAULT_RMI_REGISTRY_PORT 9000
public static final java.lang.String HELP_COMMAND_LINE_ARG "help"
public static final java.lang.String HTTP_COMMAND_LINE_ARG "http"
public static final java.lang.String HTTP_PORT_PROPERTY ""
public static final java.lang.String RMI_COMMAND_LINE_ARG "rmi"
public static final java.lang.String RMI_CONNECTION_PORT_PROPERTY ""
public static final java.lang.String RMI_HOST_PROPERTY ""
public static final java.lang.String RMI_REGISTRY_PORT_PROPERTY ""
public static final java.lang.String CACHE_TYPE "type=Cache"
public static final java.lang.String CLUSTER_TYPE "type=Cluster"
public static final java.lang.String CONNECTION_MANAGER_TYPE "type=ConnectionManager"
public static final java.lang.String CONNECTION_TYPE "type=Connection"
public static final java.lang.String JOURNAL_TYPE "type=Journal"
public static final java.lang.String MANAGEMENT_TYPE "type=Management"
public static final java.lang.String NODE_TYPE "type=Node"
public static final java.lang.String POINT_TO_POINT_TYPE "type=PointToPoint"
public static final java.lang.String REPORTER_TYPE "type=Reporter"
public static final java.lang.String SERVICE_TYPE "type=Service"
public static final java.lang.String STORAGE_MANAGER_TYPE "type=StorageManager"
public static final java.lang.String TRANSACTION_MANAGER_TYPE "type=TransactionManager"
protected static final int PROP_HIGH_UNITS 1
protected static final int PROP_LOW_UNITS 2
protected static final int PROP_UNITS 0
public static final int OPT_BY_MEMBER 2
public static final int OPT_BY_PARTITION 0
public static final int OPT_ENTRIES 1
public static final int OPT_KEYS 0
public static final int OPT_RANDOMIZED 4
public static final int PARTITION_ASSIGNED 7
public static final int PARTITION_LOST 1
public static final int PARTITION_RECEIVE_BEGIN 5
public static final int PARTITION_RECEIVE_COMMIT 6
public static final int PARTITION_TRANSMIT_BEGIN 2
public static final int PARTITION_TRANSMIT_COMMIT 3
public static final int PARTITION_TRANSMIT_ROLLBACK 4
protected static final int MARKED_ALL 3
protected static final int MARKED_FEW 1
protected static final int MARKED_MANY 2
protected static final int MARKED_NONE 0
protected static final int MACHINE_SAFE 2
protected static final int NODE_SAFE 1
protected static final int RACK_SAFE 3
protected static final int SITE_SAFE 4
public static final java.lang.String DEFAULT_KEYSTORE_PATH ".keystore"
public static final java.lang.String DEFAULT_KEYSTORE_TYPE "JKS"
public static final java.lang.String DEFAULT_TRANSFORMATION "RSA/ECB/PKCS1PADDING"
public static final java.lang.String PROPERTY_CONFIG ""
public static final java.lang.String ALGORITHM "PeerX509"
public static final java.lang.String NAME "CoherenceSecurityProvider"
public static final java.lang.String DEFAULT_ALGORITHM "ARCFOUR"
public static final int DEFAULT_KEY_LENGTH 128
public static final java.lang.String DEFAULT_KEYSTORE_TYPE "JCEKS"
public static final int CONCUR_EXTERNAL 3
public static final int CONCUR_OPTIMISTIC 2
public static final int CONCUR_PESSIMISTIC 1
public static final int TRANSACTION_GET_COMMITTED 1
public static final int TRANSACTION_REPEATABLE_GET 2
public static final int TRANSACTION_SERIALIZABLE 3
protected static final int FOUND 0
protected static final int REMOVED 2
protected static final int RETURNED 1
public static final char URI_DELIM 45
public static final char URI_NULL 33
public static final int TYPE_BINARY 7
public static final int TYPE_BOOLEAN 1
public static final int TYPE_DATE 8
public static final int TYPE_DATETIME 10
public static final int TYPE_DECIMAL 5
public static final int TYPE_DOUBLE 4
public static final int TYPE_INT 2
public static final int TYPE_LONG 3
public static final int TYPE_STRING 6
public static final int TYPE_TIME 9
protected static final int ABOVE 0
protected static final int LEFT 1
protected static final int RIGHT 3
protected static final int SITTING 2
public static final long NOT_FOUND -1L
protected static final int PLAN_ALL_LISTENER 2
protected static final int PLAN_KEY_LISTENER 3
protected static final int PLAN_NO_LISTENERS 1
protected static final int PLAN_NO_OPTIMIZE 4
protected static final int PLAN_NONE 0
protected static final int DEFAULT_RECYCLE_MAX 256
public static final float DEFAULT_GROWTHRATE 3.0f
public static final float DEFAULT_LOADFACTOR 1.0f
protected static final int DEFAULT_MAX_LEVEL 16
protected static final int DEFAULT_SPAN 3
protected static final int SEARCH_EQ 1
protected static final int SEARCH_GT 4
protected static final int SEARCH_GTEQ 5
protected static final int SEARCH_LT 2
protected static final int SEARCH_LTEQ 3
protected static final long LOCK_ALL_PENDING 2305843009213693952L
protected static final int LOCK_ALL_PENDING_IDX 61
protected static final int LOCK_COUNT 62
protected static final long LOCKS_ALL -1L
protected static final long LOCKS_NONE 0L
protected static final int MIN_SEGMENT_CAPACITY 2
protected static final int PUTALL_THRESHOLD 91
protected static final int SEGMENT_COUNT 61
protected static final int SEGMENT_LOCK_MAX_SPIN 15
public static final int SERVICE_STARTED 2
public static final int SERVICE_STARTING 1
public static final int SERVICE_STOPPED 4
public static final int SERVICE_STOPPING 3
public static final long MAX 2147483647L
protected static final int DEFAULT_SIZE 32
public static final int GATE_CLOSED 2
public static final int GATE_CLOSING 1
public static final int GATE_DESTROYED 3
public static final int GATE_OPEN 0
public static final int CMP_AUTO 0
public static final int CMP_ENTRY 3
public static final int CMP_KEY 2
public static final int CMP_VALUE 1
public static final int KEY 1
public static final int VALUE 0
public static final int ACTION_IGNORE 1
public static final int ACTION_REMOVE 2
public static final int ACTION_ROLLBACK 0
public static final int E_ALL 7
public static final int E_DELETED 4
public static final int E_INSERTED 1
public static final int E_KEYSET 29
public static final int E_UPDATED 2
public static final int E_UPDATED_ENTERED 8
public static final int E_UPDATED_LEFT 16
public static final int E_UPDATED_WITHIN 32
Copyright © 2000, 2011, Oracle and/or its affiliates. All rights reserved.
