Skip navigation links
Oracle® Coherence Java API Reference
Release 3.7.1.0
E22843-01
A B C D E F G H I J K L M N O P Q R S T U V W X Z
A
ABOVE - Static variable in class com.tangosol.util.AbstractSparseArray.Crawler
AbstractAggregator - Class in com.tangosol.util.aggregator
Abstract base class implementation of InvocableMap.EntryAggregator that supports parallel aggregation.
AbstractAggregator() - Constructor for class com.tangosol.util.aggregator.AbstractAggregator
Default constructor (necessary for the ExternalizableLite interface).
AbstractAggregator(ValueExtractor) - Constructor for class com.tangosol.util.aggregator.AbstractAggregator
Construct an AbstractAggregator that will aggregate values extracted from a set of InvocableMap.Entry objects.
AbstractAggregator(String) - Constructor for class com.tangosol.util.aggregator.AbstractAggregator
AbstractBackingMapManager - Class in com.tangosol.net
Abstract base of the BackingMapManager implementations.
AbstractBackingMapManager() - Constructor for class com.tangosol.net.AbstractBackingMapManager
Default constructor.
AbstractBigDecimalAggregator - Class in com.tangosol.util.aggregator
Abstract aggregator that processes Comparable values extracted from a set of entries in a Map and returns a result in a form of a BigDecimal value.
AbstractBigDecimalAggregator() - Constructor for class com.tangosol.util.aggregator.AbstractBigDecimalAggregator
AbstractBigDecimalAggregator(ValueExtractor) - Constructor for class com.tangosol.util.aggregator.AbstractBigDecimalAggregator
Construct an AbstractBigDecimalAggregator object.
AbstractBigDecimalAggregator(String) - Constructor for class com.tangosol.util.aggregator.AbstractBigDecimalAggregator
AbstractBinaryEntryBundler - Class in com.tangosol.net.cache
An abstract BinaryEntry-based bundler that serves as a base for BinaryEntryStore operation bundling.
AbstractBinaryEntryBundler() - Constructor for class com.tangosol.net.cache.AbstractBinaryEntryBundler
AbstractBinaryEntryBundler.Bundle - Class in com.tangosol.net.cache
AbstractBinaryEntryBundler.Bundle() - Constructor for class com.tangosol.net.cache.AbstractBinaryEntryBundler.Bundle
AbstractBinaryStore - Class in com.tangosol.io
Abstract implementation of the BinaryStore interface.
AbstractBinaryStore() - Constructor for class com.tangosol.io.AbstractBinaryStore
AbstractBufferManager - Class in com.tangosol.io.nio
Provides a basic implementation of ByteBufferManager.
AbstractBufferManager(int, int) - Constructor for class com.tangosol.io.nio.AbstractBufferManager
Construct a AbstractBufferManager that supports a buffer of a certain initial and maximum size.
AbstractBundler - Class in com.tangosol.net.cache
An abstract base for processors that implement bundling strategy.
AbstractBundler() - Constructor for class com.tangosol.net.cache.AbstractBundler
Construct the bundler.
AbstractBundler.Bundle - Class in com.tangosol.net.cache
AbstractBundler.Bundle() - Constructor for class com.tangosol.net.cache.AbstractBundler.Bundle
AbstractBundler.Statistics - Class in com.tangosol.net.cache
Statistics class contains the latest bundler statistics.
AbstractBundler.Statistics() - Constructor for class com.tangosol.net.cache.AbstractBundler.Statistics
AbstractByteArrayReadBuffer - Class in com.tangosol.io
The AbstractByteArrayReadBuffer abstract class is intended to serve as a base class for the following: the pre-existing Binary class a new byte[] based class that does not attempt to add the immutability aspect provided by the Binary class a new ByteBuffer based class that will work with Java NIO This implementation is not intended to be thread safe.
AbstractByteArrayReadBuffer() - Constructor for class com.tangosol.io.AbstractByteArrayReadBuffer
Default constructor; intended for deserialization use by subclasses.
AbstractByteArrayReadBuffer(byte[], int, int) - Constructor for class com.tangosol.io.AbstractByteArrayReadBuffer
Construct an AbstractByteArrayReadBuffer on a portion of a byte array.
AbstractByteArrayReadBuffer.ByteArrayBufferInput - Class in com.tangosol.io
This is a simple implementation of the BufferInput interface on top of a byte array.
AbstractByteArrayReadBuffer.ByteArrayBufferInput() - Constructor for class com.tangosol.io.AbstractByteArrayReadBuffer.ByteArrayBufferInput
AbstractByteSequence - Class in com.tangosol.util
A simple base class for ByteSequence implementations.
AbstractByteSequence() - Constructor for class com.tangosol.util.AbstractByteSequence
AbstractByteSequence.AggregateByteSequence - Class in com.tangosol.util
A naive ByteSequence that glues two ByteSequence instances together.
AbstractByteSequence.AggregateByteSequence(ByteSequence, ByteSequence) - Constructor for class com.tangosol.util.AbstractByteSequence.AggregateByteSequence
Construct an AggregateByteSequence from two ByteSequence objects.
AbstractByteSequence.PartialByteSequence - Class in com.tangosol.util
A naive ByteSequence that represents a portion of another ByteSequence.
AbstractByteSequence.PartialByteSequence(ByteSequence, int, int) - Constructor for class com.tangosol.util.AbstractByteSequence.PartialByteSequence
Construct a PartialByteSequence from a ByteSequence.
AbstractCacheLoader - Class in com.tangosol.net.cache
An abstract base class for the JCache CacheLoader.
AbstractCacheLoader() - Constructor for class com.tangosol.net.cache.AbstractCacheLoader
AbstractCacheStore - Class in com.tangosol.net.cache
AbstractCacheStore() - Constructor for class com.tangosol.net.cache.AbstractCacheStore
AbstractComparableAggregator - Class in com.tangosol.util.aggregator
Abstract aggregator that processes values extracted from a set of entries in a Map, with knowledge of how to compare those values.
AbstractComparableAggregator() - Constructor for class com.tangosol.util.aggregator.AbstractComparableAggregator
AbstractComparableAggregator(ValueExtractor) - Constructor for class com.tangosol.util.aggregator.AbstractComparableAggregator
Construct an AbstractComparableAggregator object.
AbstractComparableAggregator(ValueExtractor, Comparator) - Constructor for class com.tangosol.util.aggregator.AbstractComparableAggregator
AbstractComparableAggregator(String) - Constructor for class com.tangosol.util.aggregator.AbstractComparableAggregator
AbstractCompositeExtractor - Class in com.tangosol.util.extractor
Abstract super class for ValueExtractor implementations that are based on an underlying array of ValueExtractor objects.
AbstractCompositeExtractor() - Constructor for class com.tangosol.util.extractor.AbstractCompositeExtractor
Default constructor
AbstractCompositeExtractor(ValueExtractor[]) - Constructor for class com.tangosol.util.extractor.AbstractCompositeExtractor
Construct a AbstractCompositeExtractor based on the specified ValueExtractor array.
AbstractDoubleAggregator - Class in com.tangosol.util.aggregator
Abstract aggregator that processes numeric values extracted from a set of entries in a Map.
AbstractDoubleAggregator() - Constructor for class com.tangosol.util.aggregator.AbstractDoubleAggregator
AbstractDoubleAggregator(ValueExtractor) - Constructor for class com.tangosol.util.aggregator.AbstractDoubleAggregator
Construct an AbstractDoubleAggregator object.
AbstractDoubleAggregator(String) - Constructor for class com.tangosol.util.aggregator.AbstractDoubleAggregator
AbstractEncryptionFilter - Class in com.tangosol.net.security
Deprecated. As of Coherence 3.7, deprecated with no replacement.
AbstractEncryptionFilter() - Constructor for class com.tangosol.net.security.AbstractEncryptionFilter
Deprecated.
AbstractEntryBundler - Class in com.tangosol.net.cache
An abstract entry-based bundler serves as a base for NamedCache.put() and CacheStore.store() operation bundling.
AbstractEntryBundler() - Constructor for class com.tangosol.net.cache.AbstractEntryBundler
AbstractEntryBundler.Bundle - Class in com.tangosol.net.cache
AbstractEntryBundler.Bundle() - Constructor for class com.tangosol.net.cache.AbstractEntryBundler.Bundle
AbstractEventInterceptor - Class in com.tangosol.net.events
An abstract base implementation of EventInterceptor.
AbstractEventInterceptor() - Constructor for class com.tangosol.net.events.AbstractEventInterceptor
Construct an EventInterceptor that subscribes to all events registering at the end of the interceptor chain.
AbstractEventInterceptor(boolean) - Constructor for class com.tangosol.net.events.AbstractEventInterceptor
Construct an EventInterceptor that subscribes to all events.
AbstractEventInterceptor(Set, boolean) - Constructor for class com.tangosol.net.events.AbstractEventInterceptor
Construct an EventInterceptor with specified Event types and chain position.
AbstractEvictionPolicy - Class in com.tangosol.net.cache
An abstract base class for custom cache eviction policies.
AbstractEvictionPolicy() - Constructor for class com.tangosol.net.cache.AbstractEvictionPolicy
AbstractEvolvable - Class in com.tangosol.io
An abstract base class for implementing Evolvable objects.
AbstractEvolvable() - Constructor for class com.tangosol.io.AbstractEvolvable
AbstractExtractor - Class in com.tangosol.util.extractor
Abstract base for ValueExtractor implementations.
AbstractExtractor() - Constructor for class com.tangosol.util.extractor.AbstractExtractor
AbstractHttpServer - Class in com.tangosol.coherence.rest.server
Abstract base class for HttpServer implementations.
AbstractHttpServer() - Constructor for class com.tangosol.coherence.rest.server.AbstractHttpServer
AbstractHttpSessionCollection - Class in com.tangosol.coherence.servlet
Deprecated. In releases following 3.6 customization will be declarative.
AbstractHttpSessionCollection() - Constructor for class com.tangosol.coherence.servlet.AbstractHttpSessionCollection
Deprecated. Default constructor (required).
AbstractHttpSessionCollection.ApplicationScopeController - Class in com.tangosol.coherence.servlet
AbstractHttpSessionCollection.ApplicationScopeController() - Constructor for class com.tangosol.coherence.servlet.AbstractHttpSessionCollection.ApplicationScopeController
Deprecated.
AbstractHttpSessionCollection.DistributedController - Class in com.tangosol.coherence.servlet
AbstractHttpSessionCollection.DistributedController() - Constructor for class com.tangosol.coherence.servlet.AbstractHttpSessionCollection.DistributedController
Deprecated.
AbstractHttpSessionCollection.ExitAgent - Class in com.tangosol.coherence.servlet
AbstractHttpSessionCollection.ExitAgent() - Constructor for class com.tangosol.coherence.servlet.AbstractHttpSessionCollection.ExitAgent
Deprecated. Default constructor.
AbstractHttpSessionCollection.ExitAgent(String) - Constructor for class com.tangosol.coherence.servlet.AbstractHttpSessionCollection.ExitAgent
Deprecated. Construct an ExitAgent to unlock a specific session.
AbstractHttpSessionCollection.ExitObserver - Class in com.tangosol.coherence.servlet
AbstractHttpSessionCollection.ExitObserver() - Constructor for class com.tangosol.coherence.servlet.AbstractHttpSessionCollection.ExitObserver
Deprecated.
AbstractHttpSessionCollection.ExitTask - Class in com.tangosol.coherence.servlet
AbstractHttpSessionCollection.ExitTask(String) - Constructor for class com.tangosol.coherence.servlet.AbstractHttpSessionCollection.ExitTask
Deprecated. Construct an ExitTask to unlock a specific session.
AbstractHttpSessionCollection.GlobalScopeController - Class in com.tangosol.coherence.servlet
AbstractHttpSessionCollection.GlobalScopeController() - Constructor for class com.tangosol.coherence.servlet.AbstractHttpSessionCollection.GlobalScopeController
Deprecated.
AbstractHttpSessionCollection.HybridController - Class in com.tangosol.coherence.servlet
AbstractHttpSessionCollection.HybridController() - Constructor for class com.tangosol.coherence.servlet.AbstractHttpSessionCollection.HybridController
Deprecated.
AbstractHttpSessionCollection.LocalController - Class in com.tangosol.coherence.servlet
AbstractHttpSessionCollection.LocalController() - Constructor for class com.tangosol.coherence.servlet.AbstractHttpSessionCollection.LocalController
Deprecated.
AbstractHttpSessionModel - Class in com.tangosol.coherence.servlet
AbstractHttpSessionModel() - Constructor for class com.tangosol.coherence.servlet.AbstractHttpSessionModel
Deprecated. Default constructor for deserialization.
AbstractHttpSessionModel(AbstractHttpSessionCollection, HttpSession, String) - Constructor for class com.tangosol.coherence.servlet.AbstractHttpSessionModel
Deprecated. Session creation constructor.
AbstractInvocable - Class in com.tangosol.net
An abstract base for Invocable and PriorityTask implementations.
AbstractInvocable() - Constructor for class com.tangosol.net.AbstractInvocable
AbstractJournalRM - Class in com.tangosol.io.journal
The AbstractJournalRM represents a Journal Resource Manager that manages storage for journaled data, and acts as a shared resource for any number of journals that share a common configuration.
AbstractJournalRM(Cluster) - Constructor for class com.tangosol.io.journal.AbstractJournalRM
Construct an AbstractJournalRM.
AbstractJournalRM.CollectorDaemon - Class in com.tangosol.io.journal
The CollectorDaemon evaluates the JournalFile objects to see which ones should be evacuated, it evacuates those that should be, and it deletes those that have been successfully evacuated.
AbstractJournalRM.CollectorDaemon() - Constructor for class com.tangosol.io.journal.AbstractJournalRM.CollectorDaemon
Construct a CollectorDaemon.
AbstractJournalRM.JournalFile - Class in com.tangosol.io.journal
A JournalFile object is created for each file used to store the journal contents.
AbstractJournalRM.JournalFile(int) - Constructor for class com.tangosol.io.journal.AbstractJournalRM.JournalFile
Construct a Journal File.
AbstractJournalRM.JournalImpl - Class in com.tangosol.io.journal
A Journal implementation managed by this Journal Resource Manager.
AbstractJournalRM.JournalImpl() - Constructor for class com.tangosol.io.journal.AbstractJournalRM.JournalImpl
AbstractKeyBasedMap - Class in com.tangosol.util
AbstractKeyBasedMap is a base class for Map implementations.
AbstractKeyBasedMap() - Constructor for class com.tangosol.util.AbstractKeyBasedMap
AbstractKeyBasedMap.EntrySet - Class in com.tangosol.util
A set of entries backed by this map.
AbstractKeyBasedMap.EntrySet() - Constructor for class com.tangosol.util.AbstractKeyBasedMap.EntrySet
AbstractKeyBasedMap.EntrySet.Entry - Class in com.tangosol.util
A Map Entry implementation that defers its value acquisition from the containing map (via Map.get(Object)) if the Entry is constructed with a null value.
AbstractKeyBasedMap.EntrySet.Entry(Object, Object) - Constructor for class com.tangosol.util.AbstractKeyBasedMap.EntrySet.Entry
Construct an Entry.
AbstractKeyBasedMap.EntrySet.EntrySetIterator - Class in com.tangosol.util
An Iterator over the EntrySet that is backed by the Map.
AbstractKeyBasedMap.EntrySet.EntrySetIterator() - Constructor for class com.tangosol.util.AbstractKeyBasedMap.EntrySet.EntrySetIterator
AbstractKeyBasedMap.KeySet - Class in com.tangosol.util
A set of keys backed by this map.
AbstractKeyBasedMap.KeySet() - Constructor for class com.tangosol.util.AbstractKeyBasedMap.KeySet
AbstractKeyBasedMap.ValuesCollection - Class in com.tangosol.util
A Collection of values backed by this map.
AbstractKeyBasedMap.ValuesCollection() - Constructor for class com.tangosol.util.AbstractKeyBasedMap.ValuesCollection
AbstractKeyBasedMap.ValuesCollection.ValuesIterator - Class in com.tangosol.util
An Iterator over the values Collection that is backed by the AbstractKeyBasedMap.
AbstractKeyBasedMap.ValuesCollection.ValuesIterator() - Constructor for class com.tangosol.util.AbstractKeyBasedMap.ValuesCollection.ValuesIterator
AbstractKeyBundler - Class in com.tangosol.net.cache
An abstract key-based bundler serves as a base for NamedCache get() and remove() operation bundling as well as the CacheStore load() and erase() operation bundling.
AbstractKeyBundler() - Constructor for class com.tangosol.net.cache.AbstractKeyBundler
AbstractKeyBundler.Bundle - Class in com.tangosol.net.cache
AbstractKeyBundler.Bundle() - Constructor for class com.tangosol.net.cache.AbstractKeyBundler.Bundle
AbstractKeySetBasedMap - Class in com.tangosol.util
AbstractKeySetBasedMap is an extension to the AbstractKeyBasedMap that has a full awareness of the set of keys upon which the Map is based.
AbstractKeySetBasedMap() - Constructor for class com.tangosol.util.AbstractKeySetBasedMap
AbstractKeySetBasedMap.EntrySet - Class in com.tangosol.util
AbstractKeySetBasedMap.EntrySet() - Constructor for class com.tangosol.util.AbstractKeySetBasedMap.EntrySet
AbstractKeySetBasedMap.KeyIterator - Class in com.tangosol.util
An iterator over the keys from the internal key Set that implements element removal via the Map's removeBlind method.
AbstractKeySetBasedMap.KeyIterator(Iterator) - Constructor for class com.tangosol.util.AbstractKeySetBasedMap.KeyIterator
Construct a KeyIterator.
AbstractKeySetBasedMap.KeySet - Class in com.tangosol.util
AbstractKeySetBasedMap.KeySet() - Constructor for class com.tangosol.util.AbstractKeySetBasedMap.KeySet
AbstractKeySetBasedMap.ValuesCollection - Class in com.tangosol.util
AbstractKeySetBasedMap.ValuesCollection() - Constructor for class com.tangosol.util.AbstractKeySetBasedMap.ValuesCollection
AbstractLongAggregator - Class in com.tangosol.util.aggregator
AbstractLongAggregator() - Constructor for class com.tangosol.util.aggregator.AbstractLongAggregator
AbstractLongAggregator(ValueExtractor) - Constructor for class com.tangosol.util.aggregator.AbstractLongAggregator
Construct an AbstractLongAggregator object.
AbstractLongAggregator(String) - Constructor for class com.tangosol.util.aggregator.AbstractLongAggregator
AbstractLongArray - Class in com.tangosol.util
An implementation of portions of the LongArray interface.
AbstractLongArray() - Constructor for class com.tangosol.util.AbstractLongArray
AbstractMapListener - Class in com.tangosol.util
A base class that simplifies the implementation of a MapListener, particularly inner classes that only implement one or two of the three event methods.
AbstractMapListener() - Constructor for class com.tangosol.util.AbstractMapListener
AbstractMarshaller - Class in com.tangosol.coherence.rest.io
Abstract base class for built-in marshallers.
AbstractMarshaller(Class) - Constructor for class com.tangosol.coherence.rest.io.AbstractMarshaller
Construct a marshaller instance.
AbstractPofHandler - Class in com.tangosol.io.pof
An abstract implementation of PofHandler that delegates to a PofHandler.
AbstractPofHandler(PofHandler) - Constructor for class com.tangosol.io.pof.AbstractPofHandler
Construct a delegating PofHandler.
AbstractPofPath - Class in com.tangosol.io.pof.reflect
Abstract base class for static, path-based implementations of PofNavigator interface.
AbstractPofPath() - Constructor for class com.tangosol.io.pof.reflect.AbstractPofPath
AbstractPofValue - Class in com.tangosol.io.pof.reflect
An abstract base class that implements common functionality for all PofValue types.
AbstractPofValue(PofValue, ReadBuffer, PofContext, int, int) - Constructor for class com.tangosol.io.pof.reflect.AbstractPofValue
Construct a PofValue instance wrapping the supplied buffer.
AbstractPriorityTask - Class in com.tangosol.net
An abstract base for PriorityTask implementations.
AbstractPriorityTask() - Constructor for class com.tangosol.net.AbstractPriorityTask
AbstractProcessor - Class in com.tangosol.util.processor
An AbstractProcessor is a partial EntryProcessor implementation that provides the default implementation of the AbstractProcessor.processAll(java.util.Set) method.
AbstractProcessor() - Constructor for class com.tangosol.util.processor.AbstractProcessor
AbstractProxyServiceLoadBalancer - Class in com.tangosol.net.proxy
An abstract base for ProxyServiceLoadBalancer implementations.
AbstractProxyServiceLoadBalancer() - Constructor for class com.tangosol.net.proxy.AbstractProxyServiceLoadBalancer
AbstractQueryRecorderFilter - Class in com.tangosol.util.filter
Abstract base class implementation of QueryRecorderFilter.
AbstractQueryRecorderFilter() - Constructor for class com.tangosol.util.filter.AbstractQueryRecorderFilter
AbstractReadBuffer - Class in com.tangosol.io
Abstract base implementation of the ReadBuffer interface.
AbstractReadBuffer() - Constructor for class com.tangosol.io.AbstractReadBuffer
AbstractReadBuffer.AbstractBufferInput - Class in com.tangosol.io
This is an implementation of the BufferInput interface that delegates its work back to its ReadBuffer.
AbstractReadBuffer.AbstractBufferInput() - Constructor for class com.tangosol.io.AbstractReadBuffer.AbstractBufferInput
AbstractReapTask - Class in com.tangosol.coherence.servlet
AbstractReapTask(SessionHelper, SessionReaperStatistics, Iterator) - Constructor for class com.tangosol.coherence.servlet.AbstractReapTask
Deprecated. Construct an AbstractReapTask.
AbstractSerializationCache - Class in com.tangosol.net.cache
An abstract base class for serialization-based caches.
AbstractSerializationCache(BinaryStore) - Constructor for class com.tangosol.net.cache.AbstractSerializationCache
Construct a serialization cache on top of a BinaryStore.
AbstractSerializationCache(BinaryStore, ClassLoader) - Constructor for class com.tangosol.net.cache.AbstractSerializationCache
Construct a serialization cache on top of a BinaryStore, using the passed ClassLoader for deserialization.
AbstractSerializationCache(BinaryStore, boolean) - Constructor for class com.tangosol.net.cache.AbstractSerializationCache
Construct a serialization cache on top of a BinaryStore, optionally storing only Binary keys and values.
AbstractSparseArray - Class in com.tangosol.util
A data structure resembling an array indexed by long values, stored as an AVL tree.
AbstractSparseArray() - Constructor for class com.tangosol.util.AbstractSparseArray
AbstractSparseArray.Crawler - Class in com.tangosol.util
A tree node iterator.
AbstractSparseArray.Crawler(AbstractSparseArray.Node, int, boolean) - Constructor for class com.tangosol.util.AbstractSparseArray.Crawler
Crawler constructor.
AbstractSparseArray.Node - Class in com.tangosol.util
An AVL tree node.
AbstractSparseArray.Node() - Constructor for class com.tangosol.util.AbstractSparseArray.Node
AbstractStableIterator - Class in com.tangosol.util
An abstract Iterator implementation that is stable between the AbstractStableIterator.hasNext() and AbstractStableIterator.next() methods, and between the AbstractStableIterator.next() and AbstractStableIterator.remove() methods.
AbstractStableIterator() - Constructor for class com.tangosol.util.AbstractStableIterator
AbstractStoreManager - Class in com.tangosol.io.nio
A base implementation of BinaryStoreManager interface that uses BinaryMap objects built on a ByteBufferManager to provide BinaryStore objects.
AbstractStoreManager(int, int) - Constructor for class com.tangosol.io.nio.AbstractStoreManager
Construct a AbstractStoreManager that uses BinaryMap objests built on the ByteBufferManager(s) with certain initial and maximum size.
AbstractUpdater - Class in com.tangosol.util.extractor
Abstract base for ValueUpdater implementations.
AbstractUpdater() - Constructor for class com.tangosol.util.extractor.AbstractUpdater
AbstractWriteBuffer - Class in com.tangosol.io
The AbstractWriteBuffer is a partial implementation of the WriteBuffer interface intended to be used as a base class for easily creating concrete WriteBuffer implementations.
AbstractWriteBuffer() - Constructor for class com.tangosol.io.AbstractWriteBuffer
AbstractWriteBuffer.AbstractBufferOutput - Class in com.tangosol.io
AbstractBufferOutput is a concrete implementation of BufferOutput for the non-concrete AbstractWriteBuffer implementation.
AbstractWriteBuffer.AbstractBufferOutput() - Constructor for class com.tangosol.io.AbstractWriteBuffer.AbstractBufferOutput
Construct an AbstractBufferOutput that will begin writing at the start of the containing WriteBuffer.
AbstractWriteBuffer.AbstractBufferOutput(int) - Constructor for class com.tangosol.io.AbstractWriteBuffer.AbstractBufferOutput
Construct an AbstractBufferOutput that will begin writing at the specified offset within the containing WriteBuffer.
accept() - Method in interface com.tangosol.net.AddressProvider
This method should be called by the client immediately after it determines that it can successfully use an address returned by the AddressProvider.getNextAddress() method.
accept() - Method in class com.tangosol.net.CompositeAddressProvider
accept() - Method in class com.tangosol.net.CompositeAddressProvider.SingleProvider
accept() - Method in class com.tangosol.net.ConfigurableAddressProvider
accept() - Method in class com.tangosol.net.RefreshableAddressProvider
accept() - Method in class com.tangosol.net.WrapperServerSocket
accept() - Method in class com.tangosol.net.WrapperServerSocketChannel
AccessController - Interface in com.tangosol.net.security
The AccessController interface is used by the cluster services to verify whether or not a caller has sufficient rights to access protected clustered resources.
Action - Interface in com.tangosol.net
An Action represents a controllable action or behavior that a Service might perform.
ACTION_IGNORE - Static variable in class com.tangosol.util.filter.FilterTrigger
Evaluation failure results in restoring the original Entry's value.
ACTION_REMOVE - Static variable in class com.tangosol.util.filter.FilterTrigger
Evaluation failure results in a removal of the entry.
ACTION_ROLLBACK - Static variable in class com.tangosol.util.filter.FilterTrigger
Evaluation failure results in an IllegalArgumentException thrown by the trigger.
ActionPolicy - Interface in com.tangosol.net
ActionPolicy defines which aspects of a Service's behavior are currently allowed.
activate(String, HttpSession) - Method in class com.tangosol.coherence.servlet.AbstractHttpSessionCollection
Deprecated. Move the session into an active state, if it is not already.
activate(HttpSession) - Method in class com.tangosol.coherence.servlet.AbstractHttpSessionModel
Deprecated. Activate the session model.
activate(String, HttpSession) - Method in interface com.tangosol.coherence.servlet.HttpSessionCollection
ACTIVE - Static variable in class com.tangosol.coherence.transaction.Status
The transaction is in the active state.
ADAPTER_INIT_PARAMS - Static variable in class com.tangosol.run.xml.XmlBean.BeanInfo
Parameters for finding the default adapter constructor.
add(BinaryEntry) - Method in class com.tangosol.net.cache.AbstractBinaryEntryBundler.Bundle
Add the specified binary entry to the Bundle.
add(Object, Object) - Method in class com.tangosol.net.cache.AbstractEntryBundler.Bundle
Add the specified entry to the Bundle.
add(Object) - Method in class com.tangosol.net.cache.AbstractKeyBundler.Bundle
Add the specified key to the Bundle.
add(Object) - Method in class com.tangosol.net.cache.ReadWriteBackingMap.ReadQueue
Add a key to the queue.
add(ReadWriteBackingMap.Entry, long) - Method in class com.tangosol.net.cache.ReadWriteBackingMap.WriteQueue
Add an entry to the queue.
add(Object) - Method in class com.tangosol.net.CompositeAddressProvider
Ensures that this collection contains the specified element (optional operation).
add(Guardable, long, float) - Method in class com.tangosol.net.GuardSupport
Add the specified guardable to the set of Guardables managed by this manager, subject to the specified service parameters.
add(Object) - Method in class com.tangosol.net.LoadBalancer.Queue
Add an object to the end of the queue.
add(int) - Method in class com.tangosol.net.partition.PartitionSet
Add the specified partition to the set.
add(PartitionSet) - Method in class com.tangosol.net.partition.PartitionSet
Add the specified PartitionSet to this set.
add(Object) - Method in class com.tangosol.run.xml.SimpleElement.ElementList
Appends the specified element to the end of this list.
add(int, Object) - Method in class com.tangosol.run.xml.SimpleElement.ElementList
Inserts the specified element at the specified position in this list.
add(Object) - Method in class com.tangosol.util.AbstractLongArray
Add the passed element value to the LongArray and return the index at which the element value was stored.
add(Object) - Method in class com.tangosol.util.ChainedMap.EntrySet
add(Object) - Method in class com.tangosol.util.CircularArrayList
Appends the specified element to the end of this List (optional operation).
add(int, Object) - Method in class com.tangosol.util.CircularArrayList
Insert the element at the specified position in this list.
add(Object) - Method in class com.tangosol.util.ConverterCollections.ConverterCollection
Ensures that this Collection contains the specified element.
add(Object) - Method in class com.tangosol.util.ConverterCollections.ConverterEntrySet
add(int, Object) - Method in class com.tangosol.util.ConverterCollections.ConverterList
Inserts the specified element at the specified position in this list (optional operation).
add(Object) - Method in class com.tangosol.util.ConverterCollections.ConverterListIterator
Inserts the specified element into the list.
add(Object) - Method in class com.tangosol.util.CopyOnWriteLongArray
add(Object) - Method in class com.tangosol.util.DeltaSet
add(Object) - Method in class com.tangosol.util.ImmutableMultiList.MultiIterator
add(Object) - Method in class com.tangosol.util.InflatableCollection
add(int, Object) - Method in class com.tangosol.util.InflatableList
add(EventListener) - Method in class com.tangosol.util.Listeners
Add a listener.
add(Object) - Method in class com.tangosol.util.LiteSet
Ensures that this Set contains the specified element.
add(Object) - Method in interface com.tangosol.util.LongArray
add(Object) - Method in class com.tangosol.util.MapSet
add(Object) - Method in class com.tangosol.util.NullImplementation.NullSet
add(Object) - Method in class com.tangosol.util.RestrictedCollections.RestrictedCollection
add(Object) - Method in class com.tangosol.util.RestrictedCollections.RestrictedEntrySet
add(int, Object) - Method in class com.tangosol.util.RestrictedCollections.RestrictedList
add(Object) - Method in class com.tangosol.util.RestrictedCollections.RestrictedListIterator
add(Object) - Method in class com.tangosol.util.SafeLinkedList
Appends the specified element to the end of this List.
add(int, Object) - Method in class com.tangosol.util.SafeLinkedList
Inserts the specified element at the specified position in this List.
add(Object) - Method in class com.tangosol.util.SimpleLongArray
add(String) - Method in class com.tangosol.util.StringTable
Add the passed string to the table.
add(T) - Method in class com.tangosol.util.SubList
Appends the specified element to the end of this list (optional operation).
add(int, T) - Method in class com.tangosol.util.SubList
add(Object) - Method in class com.tangosol.util.SubSet
add(Comparable) - Method in class com.tangosol.util.Tree
Add the passed key to the tree.
add(E) - Method in class com.tangosol.util.WrapperCollections.AbstractWrapperCollection
add(int, E) - Method in class com.tangosol.util.WrapperCollections.AbstractWrapperList
add(E) - Method in class com.tangosol.util.WrapperCollections.AbstractWrapperListIterator
Inserts the specified element into the list (optional operation).
add(E) - Method in class com.tangosol.util.WrapperCollections.ConcurrentWrapperCollection
addAddress(InetSocketAddress) - Method in class com.tangosol.net.CompositeAddressProvider
Add an address.
addAll(Set) - Method in class com.tangosol.net.cache.AbstractBinaryEntryBundler.Bundle
Add the specified set of binary entries to the Bundle.
addAll(Map) - Method in class com.tangosol.net.cache.AbstractEntryBundler.Bundle
Add the specified collection of entries to the Bundle.
addAll(Collection) - Method in class com.tangosol.net.cache.AbstractKeyBundler.Bundle
Add the specified collection of keys to the Bundle.
addAll(Collection) - Method in class com.tangosol.run.xml.SimpleElement.ElementList
Overrides the ArrayList implementation to force this throw the single object add() method.
addAll(int, Collection) - Method in class com.tangosol.run.xml.SimpleElement.ElementList
addAll(Collection) - Method in class com.tangosol.util.CircularArrayList
Appends all of the elements in the specified Collection to the end of this list, in the order that they are returned by the specified Collection's Iterator.
addAll(int, Collection) - Method in class com.tangosol.util.CircularArrayList
Inserts all of the elements in the specified Collection into this list, starting at the specified position.
addAll(Collection) - Method in class com.tangosol.util.ConverterCollections.ConverterCollection
Adds all of the elements in the specified Collection to this Collection (optional operation).
addAll(Collection) - Method in class com.tangosol.util.ConverterCollections.ConverterEntrySet
addAll(int, Collection) - Method in class com.tangosol.util.ConverterCollections.ConverterList
Inserts all of the elements in the specified collection into this list at the specified position (optional operation).
addAll(int, Collection) - Method in class com.tangosol.util.InflatableList
addAll(Listeners) - Method in class com.tangosol.util.Listeners
Add all listeners from another Listeners object.
addAll(Collection) - Method in class com.tangosol.util.LiteSet
Adds all of the elements in the specified Collection to this Set if they are not already present.
addAll(Collection) - Method in class com.tangosol.util.MapSet
Adds all of the elements in the specified Collection to this Set if they're not already present.
addAll(Collection) - Method in class com.tangosol.util.RestrictedCollections.RestrictedCollection
addAll(Collection) - Method in class com.tangosol.util.RestrictedCollections.RestrictedEntrySet
addAll(int, Collection) - Method in class com.tangosol.util.RestrictedCollections.RestrictedList
addAll(int, Collection) - Method in class com.tangosol.util.SafeLinkedList
Inserts all of the elements in the specified collection at the specified location in this List.
addAll(Collection) - Method in class com.tangosol.util.SafeLinkedList
Appends all of the elements in the specified collection to the end of this List, in the order that they are returned by the specified collection's iterator.
addAll(StringTable) - Method in class com.tangosol.util.StringTable
Adds all of the nodes in the specified StringTable to this StringTable if they are not already present.
addAll(Collection) - Method in class com.tangosol.util.SubList
Appends all of the elements in the specified collection to the end of this list, in the order that they are returned by the specified collection's iterator (optional operation).
addAll(int, Collection) - Method in class com.tangosol.util.SubList
addAll(Collection) - Method in class com.tangosol.util.SubSet
Adds all of the elements in the specified collection to this collection.
addAll(Tree) - Method in class com.tangosol.util.Tree
Adds all of the nodes in the specified Tree to this Tree if they are not already present.
addAll(Collection) - Method in class com.tangosol.util.WrapperCollections.AbstractWrapperCollection
Adds all of the elements in the specified collection to this collection (optional operation).
addAll(int, Collection) - Method in class com.tangosol.util.WrapperCollections.AbstractWrapperList
addAll(Collection) - Method in class com.tangosol.util.WrapperCollections.ConcurrentWrapperCollection
addAttribute(String) - Method in class com.tangosol.run.xml.SimpleElement
Provides a means to add a new attribute value.
addAttribute(String) - Method in interface com.tangosol.run.xml.XmlElement
addBuffer() - Method in class com.tangosol.io.MultiBufferWriteBuffer
Once the current buffer is full, allocate a new one and make it the current buffer.
addElement(String) - Method in class com.tangosol.run.xml.SimpleElement
Create a new element and add it as a child element to this element.
addElement(String) - Method in interface com.tangosol.run.xml.XmlElement
addElement(Object) - Method in class com.tangosol.util.Dequeue
Adds an element to the dequeue.
addElements(XmlElement, Iterator) - Static method in class com.tangosol.run.xml.XmlHelper
Add the elements from the iterator to the passed XML.
addEnteredThread() - Method in class com.tangosol.coherence.servlet.AbstractHttpSessionModel
Deprecated. Add the currently running thread to the list of threads that have entered this session model.
addEnumeration(Enumeration) - Method in class com.tangosol.util.ChainedEnumerator
Add the Enumeration to the end of the chain.
addEventInterceptor(String, EventInterceptor, Set, boolean) - Method in interface com.tangosol.net.events.EventDispatcher
Add a uniquely identified EventInterceptor to this dispatcher to be used to process Events.
addHttpSessionAttributeListener(HttpSessionAttributeListener) - Method in class com.tangosol.coherence.servlet.AbstractHttpSessionCollection
Deprecated. Sign up the specified listener to receive HttpSessionBindingEvent objects.
addHttpSessionAttributeListener(HttpSessionAttributeListener) - Method in interface com.tangosol.coherence.servlet.HttpSessionCollection
addHttpSessionListener(HttpSessionListener) - Method in class com.tangosol.coherence.servlet.AbstractHttpSessionCollection
Deprecated. Sign up the specified listener to receive HttpSessionEvent objects.
addHttpSessionListener(HttpSessionListener) - Method in interface com.tangosol.coherence.servlet.HttpSessionCollection
addIgnoreAttributeName(String) - Method in class com.tangosol.coherence.servlet.SessionHelper
Deprecated. Register a name to ignore events for.
addIndex(ValueExtractor, boolean, Comparator) - Method in class com.tangosol.net.cache.ContinuousQueryCache
Add an index to this QueryMap.
addIndex(ValueExtractor, boolean, Comparator) - Method in class com.tangosol.net.cache.NearCache
addIndex(ValueExtractor, boolean, Comparator) - Method in class com.tangosol.net.cache.WrapperNamedCache
addIndex(ValueExtractor, boolean, Comparator) - Method in class com.tangosol.util.ConverterCollections.ConverterNamedCache
addIndex(ValueExtractor, boolean, Comparator) - Method in class com.tangosol.util.ConverterCollections.ConverterQueryMap
addIndex(ValueExtractor, boolean, Comparator, ObservableMap, Map) - Static method in class com.tangosol.util.InvocableMapHelper
Add an index to the given map of indexes, keyed by the given extractor.
addIndex(ValueExtractor, boolean, Comparator) - Method in interface com.tangosol.util.QueryMap
addInternalValueDecoration(Object, int, Object) - Method in interface com.tangosol.net.BackingMapManagerContext
Decorate a specified value in the internal form with a specified decoration in the "normal" Object form.
addInternalValueDecoration(Object, int, Object) - Method in class com.tangosol.util.NullImplementation.NullBackingMapManagerContext
addInverseCollectionMapping(Map, Object, Object) - Method in class com.tangosol.util.SimpleMapIndex
Add new mappings from the elements of the given value to the given key in the supplied index.
addInverseMapping(Object, Object) - Method in class com.tangosol.util.SimpleMapIndex
Add a new mapping from the given indexed value to the given key in the inverse index.
addInverseMapping(Map, Object, Object) - Method in class com.tangosol.util.SimpleMapIndex
Add a new mapping from the given indexed value to the given key in the supplied index.
addIterator(Iterator) - Method in class com.tangosol.util.ChainedEnumerator
Add the Iterator to the end of the chain.
addListener(MapListener, Filter, boolean) - Method in class com.tangosol.util.MapListenerSupport
Add a map listener that receives events based on a filter evaluation.
addListener(MapListener, Object, boolean) - Method in class com.tangosol.util.MapListenerSupport
Add a map listener for a specific key.
addListenerState(Map, Object, MapListener, boolean) - Static method in class com.tangosol.util.MapListenerSupport
Add a state information (lite or standard) associated with specified key and listener.
addLocalClass(Class) - Method in class com.tangosol.coherence.servlet.AbstractHttpSessionCollection.HybridController
Deprecated. Add a class which should never be distributed in the coherence cache.
addMap(int, Map) - Method in class com.tangosol.net.partition.PartitionSplittingBackingMap.MapArray
Add a new mapping between a partition ID and its backing map.
addMapListener(MapListener) - Method in class com.tangosol.net.cache.AbstractSerializationCache
Add a standard map listener that will receive all events (inserts, updates, deletes) that occur against the map, with the key, old-value and new-value included.
addMapListener(MapListener, Object, boolean) - Method in class com.tangosol.net.cache.AbstractSerializationCache
addMapListener(MapListener, Filter, boolean) - Method in class com.tangosol.net.cache.AbstractSerializationCache
addMapListener(MapListener) - Method in class com.tangosol.net.cache.ContinuousQueryCache
addMapListener(MapListener, Object, boolean) - Method in class com.tangosol.net.cache.ContinuousQueryCache
addMapListener(MapListener, Filter, boolean) - Method in class com.tangosol.net.cache.ContinuousQueryCache
addMapListener(MapListener) - Method in class com.tangosol.net.cache.NearCache
Add a standard map listener.
addMapListener(MapListener, Object, boolean) - Method in class com.tangosol.net.cache.NearCache
addMapListener(MapListener, Filter, boolean) - Method in class com.tangosol.net.cache.NearCache
addMapListener(MapListener) - Method in class com.tangosol.net.cache.OldCache
Deprecated. Add a standard map listener that will receive all events (inserts, updates, deletes) that occur against the map, with the key, old-value and new-value included.
addMapListener(MapListener, Object, boolean) - Method in class com.tangosol.net.cache.OldCache
Deprecated. Add a map listener for a specific key.
addMapListener(MapListener, Filter, boolean) - Method in class com.tangosol.net.cache.OldCache
Deprecated. Add a map listener that receives events based on a filter evaluation.
addMapListener(MapListener) - Method in class com.tangosol.net.cache.OverflowMap
addMapListener(MapListener, Object, boolean) - Method in class com.tangosol.net.cache.OverflowMap
addMapListener(MapListener, Filter, boolean) - Method in class com.tangosol.net.cache.OverflowMap
addMapListener(MapListener) - Method in class com.tangosol.net.cache.ReadWriteBackingMap
addMapListener(MapListener, Object, boolean) - Method in class com.tangosol.net.cache.ReadWriteBackingMap
addMapListener(MapListener, Filter, boolean) - Method in class com.tangosol.net.cache.ReadWriteBackingMap
addMapListener(MapListener, Object, boolean) - Method in class com.tangosol.net.partition.ObservableSplittingBackingMap
addMapListener(MapListener, Filter, boolean) - Method in class com.tangosol.net.partition.ObservableSplittingBackingMap
addMapListener(MapListener) - Method in class com.tangosol.util.ConverterCollections.ConverterObservableMap
addMapListener(MapListener, Object, boolean) - Method in class com.tangosol.util.ConverterCollections.ConverterObservableMap
addMapListener(MapListener, Filter, boolean) - Method in class com.tangosol.util.ConverterCollections.ConverterObservableMap
addMapListener(MapListener) - Method in class com.tangosol.util.NullImplementation.NullObservableMap
addMapListener(MapListener, Object, boolean) - Method in class com.tangosol.util.NullImplementation.NullObservableMap
addMapListener(MapListener, Filter, boolean) - Method in class com.tangosol.util.NullImplementation.NullObservableMap
addMapListener(MapListener) - Method in class com.tangosol.util.ObservableHashMap
addMapListener(MapListener, Object, boolean) - Method in class com.tangosol.util.ObservableHashMap
addMapListener(MapListener, Filter, boolean) - Method in class com.tangosol.util.ObservableHashMap
addMapListener(MapListener) - Method in interface com.tangosol.util.ObservableMap
addMapListener(MapListener, Object, boolean) - Method in interface com.tangosol.util.ObservableMap
addMapListener(MapListener, Filter, boolean) - Method in interface com.tangosol.util.ObservableMap
addMapListener(MapListener) - Method in class com.tangosol.util.WrapperObservableMap
addMapListener(MapListener, Object, boolean) - Method in class com.tangosol.util.WrapperObservableMap
addMapListener(MapListener, Filter, boolean) - Method in class com.tangosol.util.WrapperObservableMap
addMemberListener(MemberListener) - Method in interface com.tangosol.net.Service
Add a Member listener.
addMemberListener(MemberListener) - Method in class com.tangosol.net.WrapperService
addPartitionListener(PartitionListener) - Method in interface com.tangosol.net.PartitionedService
Add a PartitionListener to this service.
addProvider(AddressProvider) - Method in class com.tangosol.net.CompositeAddressProvider
Add an AddressProvider.
address - Variable in class com.tangosol.net.LoadBalancer.AddressPort
The address.
AddressProvider - Interface in com.tangosol.net
The AddressProvider is an interface that serves as a means to provide addresses to a consumer.
addSafeListener(Map, Object, MapListener) - Static method in class com.tangosol.util.MapListenerSupport
Ensure that the specified map has an Listeners object associated with the specified key and add the specified listener to it.
addServiceListener(ServiceListener) - Method in class com.tangosol.net.WrapperService
Register a ServiceListener that will receive events pertaining to the lifecycle of this Service.
addServiceListener(ServiceListener) - Method in interface com.tangosol.util.Service
addUnits(Object) - Method in class com.tangosol.util.SimpleMapIndex
Increase the size for the index by the estimated size of the specified added value.
addWait(Collection) - Method in class com.tangosol.coherence.commonj.WorkManager.WorkHolder
Add a collection to a wait list.
adjust(int) - Method in class com.tangosol.io.MultiBufferWriteBuffer.MultiBufferOutput
Adjust the offset of this BufferOutput based on a write that by-passed this BufferOutput's own super-class implementation that is responsible for maintaining the offset.
adjust() - Method in class com.tangosol.net.cache.AbstractBundler
Adjust this Bundler's parameters according to the available statistical information.
adjustDepth(int) - Method in class com.tangosol.io.pof.LoggingPofHandler
Adjust the complex data structure depth.
adjustDoubleBalance(AbstractSparseArray.Node, AbstractSparseArray.Node, int) - Method in class com.tangosol.util.AbstractSparseArray
Adjust the balance factor of a node and its decendentans prior to a a double rotation.
ADJUSTMENT_FREQUENCY - Static variable in class com.tangosol.net.cache.AbstractBundler
Frequency of the adjustment attempts.
adjustOffsetInternal(int) - Method in class com.tangosol.io.AbstractReadBuffer.AbstractBufferInput
Adjust the internal stream offset.
adjustOffsetInternal(int) - Method in class com.tangosol.io.nio.ByteBufferReadBuffer.ByteBufferInput
adjustOpenBlockOffset(int, int) - Method in class com.tangosol.io.nio.BinaryMap
When an open block changes position in the buffer, this method is invoked to adjust the cache of open blocks.
adjustSize(int) - Method in class com.tangosol.net.cache.OverflowMap
Adjust the number of entries in the OverflowMap.
adjustUnits(int) - Method in class com.tangosol.net.cache.OldCache
Deprecated. Adjust current size.
adopt(Map) - Method in class com.tangosol.run.xml.XmlBean
Helper to adopt a Map of XmlBean objects.
adopt(Collection) - Method in class com.tangosol.run.xml.XmlBean
Helper to adopt a Collection of XmlBean objects.
adopt(Iterator) - Method in class com.tangosol.run.xml.XmlBean
Helper to adopt a collection of XmlBean objects.
adopt(Object[]) - Method in class com.tangosol.run.xml.XmlBean
adopt(XmlBean) - Method in class com.tangosol.run.xml.XmlBean
When an XmlBean adds a contained XmlBean, it should invoke this method to relate the contained XmlBean with this XmlBean.
adopt(AbstractSparseArray.Node, boolean) - Method in class com.tangosol.util.AbstractSparseArray.Node
Adopt a child node
advance() - Method in class com.tangosol.io.MultiBufferWriteBuffer.MultiBufferOutput
Advance past the end of the current underlying BufferOutput by switching to the BufferOutput of the next underlying WriteBuffer, creating one if necessary.
advance(boolean) - Method in class com.tangosol.io.pof.PofDeltaCompressor.ChangeTracker
Update the tracker to indicate that the most recently scanned region was the same or different.
advance() - Method in class com.tangosol.net.cache.OverflowMap.EntrySet.EntrySetIterator
Advance to the next object.
advance() - Method in class com.tangosol.net.cache.OverflowMap.InternalKeySet.InternalKeySetIterator
advance() - Method in class com.tangosol.net.cache.SimpleOverflowMap.KeyIterator
Advance to the next key.
advance() - Method in class com.tangosol.net.CompositeAddressProvider.AddressIterator
advance() - Method in class com.tangosol.net.partition.PartitionedIterator
advance() - Method in class com.tangosol.net.partition.PartitionSplittingBackingMap.PartitionedIterator
advance() - Method in class com.tangosol.util.AbstractKeySetBasedMap.KeyIterator
advance() - Method in class com.tangosol.util.AbstractStableIterator
advance() - Method in class com.tangosol.util.BinaryRadixTree.KeyIterator
advance() - Method in class com.tangosol.util.SafeHashMap.EntrySet.EntrySetIterator
advance() - Method in class com.tangosol.util.SafeSortedMap.ViewMap.EntryIterator
advance() - Method in class com.tangosol.util.SegmentedHashMap.EntrySet.EntrySetIterator
Advance to the next object in the iteration.
advanceCurrentPage(SerializationPagedCache.WrapperBinaryStore) - Method in class com.tangosol.net.cache.SerializationPagedCache.PagedBinaryStore
Advance the current page, using the passed BinaryStore as the store for the new current page, and returning the oldest active page, if the maximum number of active pages is exceeded by the advancing of the current page.
advancePage() - Method in class com.tangosol.net.cache.SerializationPagedCache
Advance to a new current page, and deactivate the oldest page is the maximum number of active pages has been reached.
advanceTo(int) - Method in class com.tangosol.io.pof.PofBufferReader
Advance through the POF stream until the specified property is found.
advanceTo(int) - Method in class com.tangosol.io.pof.PofBufferReader.UserTypeReader
aggregate(String, String, AggregatorRegistry) - Method in class com.tangosol.coherence.rest.CacheResource
Perform an aggregating operation against the entries that satisfy the specified criteria.
aggregate(String, AggregatorRegistry) - Method in class com.tangosol.coherence.rest.EntrySetResource
Perform an aggregating operation against the entries.
aggregate(Collection, InvocableMap.EntryAggregator) - Method in class com.tangosol.net.cache.ContinuousQueryCache
Perform an aggregating operation against the entries specified by the passed keys.
aggregate(Filter, InvocableMap.EntryAggregator) - Method in class com.tangosol.net.cache.ContinuousQueryCache
Perform an aggregating operation against the set of entries that are selected by the given Filter.
aggregate(Collection, InvocableMap.EntryAggregator) - Method in class com.tangosol.net.cache.NearCache
aggregate(Filter, InvocableMap.EntryAggregator) - Method in class com.tangosol.net.cache.NearCache
aggregate(Collection, InvocableMap.EntryAggregator) - Method in class com.tangosol.net.cache.WrapperNamedCache
aggregate(Filter, InvocableMap.EntryAggregator) - Method in class com.tangosol.net.cache.WrapperNamedCache
aggregate(Set) - Method in class com.tangosol.util.aggregator.AbstractAggregator
Process a set of InvocableMap.Entry objects in order to produce an aggregated result.
aggregate(Set) - Method in class com.tangosol.util.aggregator.CompositeAggregator
Process a set of InvocableMap Entry objects using each of the underlying agregators in order to produce an array of aggregated results.
aggregate(Set) - Method in class com.tangosol.util.aggregator.Count
aggregate(Set) - Method in class com.tangosol.util.aggregator.GroupAggregator
Process a set of InvocableMap Entry objects using the underlying extractor to split the entries into non-intersecting (distinct) groups and then apply the underlying aggregator separately to each group.
aggregate(Set) - Method in class com.tangosol.util.aggregator.PriorityAggregator
aggregate(Set) - Method in class com.tangosol.util.aggregator.QueryRecorder
aggregate(Collection, InvocableMap.EntryAggregator) - Method in class com.tangosol.util.ConverterCollections.ConverterInvocableMap
aggregate(Filter, InvocableMap.EntryAggregator) - Method in class com.tangosol.util.ConverterCollections.ConverterInvocableMap
aggregate(Collection, InvocableMap.EntryAggregator) - Method in class com.tangosol.util.ConverterCollections.ConverterNamedCache
aggregate(Filter, InvocableMap.EntryAggregator) - Method in class com.tangosol.util.ConverterCollections.ConverterNamedCache
aggregate(Collection, InvocableMap.EntryAggregator) - Method in interface com.tangosol.util.InvocableMap
aggregate(Filter, InvocableMap.EntryAggregator) - Method in interface com.tangosol.util.InvocableMap
aggregate(Set) - Method in interface com.tangosol.util.InvocableMap.EntryAggregator
aggregateResults(Collection) - Method in class com.tangosol.util.aggregator.AbstractAggregator
Aggregate the results of the parallel aggregations.
aggregateResults(Collection) - Method in class com.tangosol.util.aggregator.CompositeAggregator.Parallel
aggregateResults(Collection) - Method in class com.tangosol.util.aggregator.Count
aggregateResults(Collection) - Method in class com.tangosol.util.aggregator.GroupAggregator.Parallel
aggregateResults(Collection) - Method in class com.tangosol.util.aggregator.PriorityAggregator
aggregateResults(Collection) - Method in class com.tangosol.util.aggregator.QueryRecorder
aggregateResults(Collection) - Method in interface com.tangosol.util.InvocableMap.ParallelAwareAggregator
AGGREGATOR_REQUEST_REGEX - Static variable in class com.tangosol.coherence.rest.util.aggregator.AggregatorRegistry
Regex pattern that defines the aggregator request syntax.
AggregatorFactory - Interface in com.tangosol.coherence.rest.util.aggregator
A factory for aggregators.
AggregatorRegistry - Class in com.tangosol.coherence.rest.util.aggregator
A registry for AggregatorFactory instances.
AggregatorRegistry() - Constructor for class com.tangosol.coherence.rest.util.aggregator.AggregatorRegistry
Construct an AggregatorRegistry.
AggregatorRegistry(Collection) - Constructor for class com.tangosol.coherence.rest.util.aggregator.AggregatorRegistry
Construct an AggregatorRegistry that includes built-in aggregators in addition to the specified aggregators.
ALGORITHM - Static variable in class com.tangosol.net.security.PeerX509TrustManager
The alogorithm used by this TrustManager.
ALL - Static variable in class com.tangosol.net.ClusterPermission
All actions.
ALL_ALLOWED - Static variable in class com.tangosol.net.ConfigurableQuorumPolicy.MembershipQuorumPolicy.QuorumRule
A QuorumRule that permits all actions.
AllFilter - Class in com.tangosol.util.filter
Filter which returns the logical "and" of a filter array.
AllFilter() - Constructor for class com.tangosol.util.filter.AllFilter
AllFilter(Filter[]) - Constructor for class com.tangosol.util.filter.AllFilter
Construct an "all" filter.
allocate(int) - Method in class com.tangosol.io.BufferManagerAdapter
Allocate a WriteBuffer for use by the MultiBufferWriteBuffer.
allocate(int) - Method in class com.tangosol.io.ByteArrayWriteBuffer.Allocator
Allocate a new ByteArrayWriteBuffer.
allocate(byte[]) - Method in class com.tangosol.io.journal.FlashJournalRM.BufferPool
Allocate a buffer from the buffer pool.
allocate() - Method in class com.tangosol.io.journal.RamJournalRM.BufferPool
Allocate a WriteBuffer from the buffer pool.
allocate(int) - Method in interface com.tangosol.io.MultiBufferWriteBuffer.WriteBufferPool
allocate(int) - Method in class com.tangosol.io.MultiplexingWriteBufferPool
allocate(int) - Method in class com.tangosol.io.nio.BinaryMap.Block
Allocate this free block (or at least a specified number of bytes of this block) as an Entry block.
allocateBlock(int) - Method in class com.tangosol.io.nio.BinaryMap
Allocate a free Block object of at least a certain size.
allocateBuffer() - Method in class com.tangosol.io.journal.FlashJournalRM.JournalFile
Allocate a Buffer to use with this JournalFile.
allocateBuffer() - Method in class com.tangosol.io.nio.AbstractBufferManager
Allocate a new buffer, copying old data if there is any.
allocateBuffer() - Method in class com.tangosol.io.nio.DirectBufferManager
allocateBuffer() - Method in class com.tangosol.io.nio.MappedBufferManager
AlwaysFilter - Class in com.tangosol.util.filter
Filter which always evaluates to true.
AlwaysFilter() - Constructor for class com.tangosol.util.filter.AlwaysFilter
Construct an AlwaysFilter.
analyzeDistribution(SimpleAssignmentStrategy.AnalysisContext) - Method in class com.tangosol.net.partition.MirroringAssignmentStrategy
Analyze the distribution using the specified analysis context.
analyzeDistribution() - Method in interface com.tangosol.net.partition.PartitionAssignmentStrategy
Analyze the distribution and return the desired time interval before the next distribution analysis.
analyzeDistribution() - Method in class com.tangosol.net.partition.SimpleAssignmentStrategy
analyzeDistribution(SimpleAssignmentStrategy.AnalysisContext) - Method in class com.tangosol.net.partition.SimpleAssignmentStrategy
AndFilter - Class in com.tangosol.util.filter
Filter which returns the logical "and" of two other filters.
AndFilter() - Constructor for class com.tangosol.util.filter.AndFilter
AndFilter(Filter, Filter) - Constructor for class com.tangosol.util.filter.AndFilter
Construct an "and" filter.
AnnotatedStandardMBean - Class in com.tangosol.net.management
AnnotatedStandardMBean is an extension of a StandardMBean that uses the Description annotation for describing the attributes, operations and the bean on the designated MBean interface.
AnnotatedStandardMBean(T, Class) - Constructor for class com.tangosol.net.management.AnnotatedStandardMBean
Make a DynamicMBean out of the object implementation, using the specified mbeanInterface class.
AnnotatedStandardMBean(Class) - Constructor for class com.tangosol.net.management.AnnotatedStandardMBean
Make a DynamicMBean using the specified mbeanInterface class.
AnyEvent - Class in com.tangosol.util
An AnyEvent is an event used when no specific event implementation fits and it is not worth making one.
AnyEvent(Object, Object) - Constructor for class com.tangosol.util.AnyEvent
Construct a new AnyEvent.
AnyFilter - Class in com.tangosol.util.filter
Filter which returns the logical "or" of a filter array.
AnyFilter() - Constructor for class com.tangosol.util.filter.AnyFilter
AnyFilter(Filter[]) - Constructor for class com.tangosol.util.filter.AnyFilter
Construct an "any" filter.
AnyListener - Interface in com.tangosol.util
append(List, BinaryRadixTree.Node) - Method in class com.tangosol.util.BinaryRadixTree.KeyIterator
Recursively append all the nodes to the list that meet the criteria of this Iterator.
appendDefaultSerializerToUserTypes(XmlElement) - Method in class com.tangosol.io.pof.ConfigurablePofContext
Process <default-serializer> element from the specified xml configuration and append information about the serializer to each <user-type> element within <user-type-list> unless user type already has a serializer specified.
apply(ServerSocket) - Method in class com.tangosol.net.SocketOptions
Configure the specified socket.
apply(Socket) - Method in class com.tangosol.net.SocketOptions
apply(DatagramSocket) - Method in class com.tangosol.net.SocketOptions
apply(MulticastSocket) - Method in class com.tangosol.net.SocketOptions
apply(SocketOptions, ServerSocket) - Static method in class com.tangosol.net.SocketOptions
Apply the specified options to a socket.
apply(SocketOptions, Socket) - Static method in class com.tangosol.net.SocketOptions
apply(SocketOptions, DatagramSocket) - Static method in class com.tangosol.net.SocketOptions
apply(SocketOptions, MulticastSocket) - Method in class com.tangosol.net.SocketOptions
applyChanges() - Method in class com.tangosol.io.pof.reflect.AbstractPofValue
Apply all the changes that were made to this value and return a binary representation of the new value.
applyChanges() - Method in interface com.tangosol.io.pof.reflect.PofValue
applyConfig(String, XmlElement) - Method in class com.tangosol.io.journal.AbstractJournalRM
Parse the XML configuration for the specified setting name, and configure the Journal Resource Manager accordingly.
applyConfig(String, XmlElement) - Method in class com.tangosol.io.journal.FlashJournalRM
applyConfig(String, XmlElement) - Method in class com.tangosol.io.journal.RamJournalRM
applyDelta(ReadBuffer, ReadBuffer) - Method in class com.tangosol.io.BinaryDeltaCompressor
Apply a delta to an old value in order to create a new value.
applyDelta(ReadBuffer, ReadBuffer) - Method in class com.tangosol.io.DecoratedBinaryDeltaCompressor
applyDelta(ReadBuffer, ReadBuffer) - Method in class com.tangosol.io.DecorationOnlyDeltaCompressor
applyDelta(ReadBuffer, ReadBuffer) - Method in interface com.tangosol.io.DeltaCompressor
applyDelta(ReadBuffer, ReadBuffer) - Method in class com.tangosol.util.NullImplementation.NullDeltaCompressor
applyFilter(Filter, int, Map, Set, QueryContext, QueryRecord.PartialResult.TraceStep) - Method in class com.tangosol.util.filter.ArrayFilter
Apply the specified IndexAwareFilter to the specified keySet.
applyIndex(Map, Set, QueryContext, QueryRecord.PartialResult.TraceStep) - Method in class com.tangosol.util.filter.AllFilter
applyIndex(Map, Set) - Method in class com.tangosol.util.filter.AlwaysFilter
Filter remaining keys using a Map of available indexes.
applyIndex(Map, Set, QueryContext, QueryRecord.PartialResult.TraceStep) - Method in class com.tangosol.util.filter.AnyFilter
applyIndex(Map, Set) - Method in class com.tangosol.util.filter.ArrayFilter
applyIndex(Map, Set, QueryContext, QueryRecord.PartialResult.TraceStep) - Method in class com.tangosol.util.filter.ArrayFilter
applyIndex(Map, Set) - Method in class com.tangosol.util.filter.ContainsAllFilter
applyIndex(Map, Set) - Method in class com.tangosol.util.filter.ContainsAnyFilter
applyIndex(Map, Set) - Method in class com.tangosol.util.filter.ContainsFilter
applyIndex(Map, Set) - Method in class com.tangosol.util.filter.EqualsFilter
applyIndex(Map, Set) - Method in class com.tangosol.util.filter.GreaterEqualsFilter
applyIndex(Map, Set) - Method in class com.tangosol.util.filter.GreaterFilter
applyIndex(Map, Set) - Method in interface com.tangosol.util.filter.IndexAwareFilter
applyIndex(Map, Set) - Method in class com.tangosol.util.filter.InFilter
applyIndex(Map, Set) - Method in class com.tangosol.util.filter.InKeySetFilter
applyIndex(Map, Set) - Method in class com.tangosol.util.filter.KeyFilter
applyIndex(Map, Set) - Method in class com.tangosol.util.filter.LessEqualsFilter
applyIndex(Map, Set) - Method in class com.tangosol.util.filter.LessFilter
applyIndex(Map, Set) - Method in class com.tangosol.util.filter.LikeFilter
applyIndex(Map, Set) - Method in class com.tangosol.util.filter.LimitFilter
applyIndex(Map, Set) - Method in class com.tangosol.util.filter.NeverFilter
applyIndex(Map, Set) - Method in class com.tangosol.util.filter.NotEqualsFilter
applyIndex(Map, Set) - Method in class com.tangosol.util.filter.NotFilter
applyIndex(Map, Set) - Method in class com.tangosol.util.filter.PresentFilter
applyIndex(Map, Set) - Method in class com.tangosol.util.filter.PriorityFilter
applyIndex(Map, Set, QueryContext, QueryRecord.PartialResult.TraceStep) - Method in class com.tangosol.util.filter.XorFilter
applyScopeToServiceName(String) - Method in class com.tangosol.net.DefaultConfigurableCacheFactory
Apply the scope name prefix to the given service name.
ArrayAdapter - Class in com.tangosol.run.xml
An ArrayAdapter supports properties of Java array types (not including arrays of primitive types).
ArrayAdapter(XmlBean.BeanInfo, Class, String, String, XmlElement) - Constructor for class com.tangosol.run.xml.ArrayAdapter
Construct a ArrayAdapter.
ArrayFilter - Class in com.tangosol.util.filter
Filter which is a logical operator of a filter array.
ArrayFilter() - Constructor for class com.tangosol.util.filter.ArrayFilter
Default constructor (necessary for the ExternalizableLite interface).
ArrayFilter(Filter[]) - Constructor for class com.tangosol.util.filter.ArrayFilter
Construct a logical filter that applies a binary operator to a filter array.
ArrayFilter.WeightedFilter - Class in com.tangosol.util.filter
A thin wrapper around a Filter allowing for sorting the filters according to their effectiveness.
ArrayFilter.WeightedFilter(Filter, int) - Constructor for class com.tangosol.util.filter.ArrayFilter.WeightedFilter
Construct the WeightedFilter.
ARRIVED - Static variable in class com.tangosol.net.events.PartitionedServiceDispatcher.TransferEvent.Type
This PartitionedServiceDispatcher.TransferEvent is dispatched when a set of BinaryEntrys have been transferred to or restored by the current member.
assertEqual(Class, Class) - Static method in class com.tangosol.io.pof.PofBufferWriter
Assert that a class is equal to another class.
assertIdentity(Object, Service) - Method in class com.tangosol.net.security.DefaultIdentityAsserter
Asserts an identity based on a token-based identity assertion.
assertIdentity(Object, Service) - Method in interface com.tangosol.net.security.IdentityAsserter
AssertionException - Exception in com.tangosol.util
An AssertionException is thrown when an assertion fails.
AssertionException() - Constructor for exception com.tangosol.util.AssertionException
Constructs a AssertionException with no detail message.
AssertionException(String) - Constructor for exception com.tangosol.util.AssertionException
Constructs a AssertionException with the specified detail message.
assign(long) - Method in class com.tangosol.util.WrapperConcurrentMap.Lock
Assign the ownership of this Lock to the calling thread.
AsymmetricEncryptionFilter - Class in com.tangosol.net.security
Deprecated. As of Coherence 3.7, deprecated replaced by SSL.
AsymmetricEncryptionFilter() - Constructor for class com.tangosol.net.security.AsymmetricEncryptionFilter
AsymmetricEncryptionFilter.IdentityInputStream - Class in com.tangosol.net.security
Deprecated. Stream which reads an unencrypted identity header followed by an encrypted payload.
AsymmetricEncryptionFilter.IdentityInputStream(InputStream) - Constructor for class com.tangosol.net.security.AsymmetricEncryptionFilter.IdentityInputStream
Deprecated. Construct a IdentityInputStream around the supplied stream.
AsymmetricEncryptionFilter.IdentityOutputStream - Class in com.tangosol.net.security
Deprecated. Stream which writes an unencrypted identity header followed by an encrypted payload.
AsymmetricEncryptionFilter.IdentityOutputStream(OutputStream) - Constructor for class com.tangosol.net.security.AsymmetricEncryptionFilter.IdentityOutputStream
Deprecated. Construct a IdentityOutputStream around the supplied stream.
AsyncBinaryStore - Class in com.tangosol.io
An AsyncBinaryStore is a BinaryStore wrapper that performs the "O" (output) portion of its I/O asynchronously on a daemon thread.
AsyncBinaryStore(BinaryStore) - Constructor for class com.tangosol.io.AsyncBinaryStore
Construct an AsyncBinaryStore.
AsyncBinaryStore(BinaryStore, int) - Constructor for class com.tangosol.io.AsyncBinaryStore
AsyncBinaryStore.QueueDaemon - Class in com.tangosol.io
A daemon that processes queued writes.
AsyncBinaryStore.QueueDaemon() - Constructor for class com.tangosol.io.AsyncBinaryStore.QueueDaemon
Construct a queue daemon to process pending writes.
AsyncBinaryStoreManager - Class in com.tangosol.io
An AsyncBinaryStoreManager is a wrapper BinaryStoreManager that creates wrapper AsyncBinaryStore objects.
AsyncBinaryStoreManager(BinaryStoreManager) - Constructor for class com.tangosol.io.AsyncBinaryStoreManager
Construct an AsyncBinaryStoreManager.
AsyncBinaryStoreManager(BinaryStoreManager, int) - Constructor for class com.tangosol.io.AsyncBinaryStoreManager
AttributeHolder - Class in com.tangosol.coherence.servlet
An immutable object to hold attribute values and related information.
AttributeHolder() - Constructor for class com.tangosol.coherence.servlet.AttributeHolder
Default constructor is required for deserialization purposes.
AttributeHolder(AbstractHttpSessionModel) - Constructor for class com.tangosol.coherence.servlet.AttributeHolder
AttributeHolder(String, Object, AbstractHttpSessionModel) - Constructor for class com.tangosol.coherence.servlet.AttributeHolder
Construct an AttributeHolder for a value.
available() - Method in class com.tangosol.io.AbstractReadBuffer.AbstractBufferInput
Returns the number of bytes that can be read (or skipped over) from this input stream without causing a blocking I/O condition to occur.
available() - Method in class com.tangosol.io.Base64InputStream
Returns the number of bytes that can be read (or skipped over) from this input stream without blocking by the next caller of a method for this input stream.
available() - Method in interface com.tangosol.io.InputStreaming
available() - Method in class com.tangosol.io.MultiByteArrayInputStream
available() - Method in class com.tangosol.io.nio.ByteBufferInputStream
available() - Method in class com.tangosol.io.nio.ByteBufferReadBuffer.ByteBufferInput
available() - Method in class com.tangosol.io.pof.PofInputStream
available() - Method in interface com.tangosol.io.ReadBuffer.BufferInput
available() - Method in class com.tangosol.io.WrapperBufferInput
available() - Method in class com.tangosol.io.WrapperDataInputStream
available() - Method in class com.tangosol.io.WrapperInputStream
available() - Method in class com.tangosol.io.WrapperObjectInputStream
available() - Method in class com.tangosol.net.security.BlockCipherInputStream
await() - Method in class com.tangosol.util.SingleWaiterMultiNotifier
Wait for a notification (which may have already occurred).
B
BackingMapBinaryEntry - Class in com.tangosol.net.cache
An implementation of the BinaryEntry interface that is based on specified binary key, binary value and BackingMapManagerContext.
BackingMapBinaryEntry(Binary, Binary, Binary, BackingMapManagerContext) - Constructor for class com.tangosol.net.cache.BackingMapBinaryEntry
Construct a BackingMapBinaryEntry with the specified binary key, values and BackingMapManagerContext.
BackingMapContext - Interface in com.tangosol.net
The BackingMapContext provides an execution context to server side agents such as EntryProcessors and EntryAggregators.
BackingMapDispatcher - Interface in com.tangosol.net.events
A BackingMapDispatcher raises the following server-side BackingMapDispatcher.EntryEvents pertaining to backing-map operations: BackingMapDispatcher.EntryEvents BackingMapDispatcher.InvocationEvents
BackingMapDispatcher.EntryEvent - Interface in com.tangosol.net.events
An EntryEvent captures information relating to actions performed on BinaryEntrys.
BackingMapDispatcher.EntryEvent.Type - Class in com.tangosol.net.events
The BackingMapDispatcher.EntryEvent types.
BackingMapDispatcher.InvocationEvent - Interface in com.tangosol.net.events
An BackingMapDispatcher.InvocationEvent captures information relating to the execution of InvocableMap.EntryProcessors.
BackingMapDispatcher.InvocationEvent.Type - Class in com.tangosol.net.events
The BackingMapDispatcher.InvocationEvent types.
BackingMapManager - Interface in com.tangosol.net
A callback interface used by CacheService implementations.
BackingMapManagerContext - Interface in com.tangosol.net
The BackingMapManager context is used by the CacheService to pass information to the BackingMapManager during the service initialization.
BackupJournalRM - Class in com.tangosol.io.journal
The BackupJournalRM is a "meta" journal resource manager that is intended to be used for storage of "backup" data.
BackupJournalRM(RamJournalRM, double) - Constructor for class com.tangosol.io.journal.BackupJournalRM
Construct a BackupJournalRM based on a RamJournalRM.
BackupJournalRM.FlashConsumer - Class in com.tangosol.io.journal
The FlashConsumer is a "dummy" consumer used to obtain a flash journal instance.
BackupJournalRM.FlashConsumer() - Constructor for class com.tangosol.io.journal.BackupJournalRM.FlashConsumer
BackupJournalRM.JournalImpl - Class in com.tangosol.io.journal
BackupJournalRM.JournalImpl(Journal, Journal) - Constructor for class com.tangosol.io.journal.BackupJournalRM.JournalImpl
Construct a Journal that writes to the RAM journal until the configured load factor is exceeded, a which point it will write to the flash journal instead.
BackupJournalRM.RamConsumer - Class in com.tangosol.io.journal
The RamConsumer is a pass-through consumer used to obtain a ram journal instance.
BackupJournalRM.RamConsumer() - Constructor for class com.tangosol.io.journal.BackupJournalRM.RamConsumer
balance - Variable in class com.tangosol.util.AbstractSparseArray.Node
The AVL balance factor of the sub-tree.
balancedInsertion(AbstractSparseArray.Node, AbstractSparseArray.Node) - Method in class com.tangosol.util.AbstractSparseArray
Insert a node into a tree and rebalance.
balancePostRemove(AbstractSparseArray.Node, boolean) - Method in class com.tangosol.util.AbstractSparseArray
Rebalance the tree following the removal of a node.
barEntry(long) - Method in class com.tangosol.util.ThreadGate
Bar entry of the thread gate by other threads, but do not wait for the gate to close.
Base - Class in com.tangosol.util
Base class for providing standard functionality.
Base() - Constructor for class com.tangosol.util.Base
BASE64_ALPHABET - Static variable in class com.tangosol.io.Base64OutputStream
Base64 encodes into this "alphabet" of 64 characters.
BASE64_LF - Static variable in class com.tangosol.io.Base64OutputStream
The Base64 line feed character.
BASE64_PAD - Static variable in class com.tangosol.io.Base64OutputStream
The Base64 padding character.
Base64InputStream - Class in com.tangosol.io
Reads binary data from a Reader using IETF RFC 2045 Base64 Content Transfer Encoding.
Base64InputStream(Reader) - Constructor for class com.tangosol.io.Base64InputStream
Construct a Base64InputStream on a Reader object.
Base64OutputStream - Class in com.tangosol.io
Writes binary data into a Writer using IETF RFC 2045 Base64 Content Transfer Encoding.
Base64OutputStream(Writer) - Constructor for class com.tangosol.io.Base64OutputStream
Construct a Base64OutputStream on a Writer object.
Base64OutputStream(Writer, boolean) - Constructor for class com.tangosol.io.Base64OutputStream
Construct a Base64OutputStream on a Writer object and specifying a line-break option.
BASE_VALUE - Static variable in class com.tangosol.util.SafeSortedMap
Placeholder for a non-existent (deleted) value.
begin(int, String) - Method in class com.tangosol.io.pof.LoggingPofHandler
Begin a complex data structure, such as a user type or a collection.
begin() - Method in interface com.tangosol.util.TransactionMap
Start a transaction for this TransactionMap.
beginArray(int, int) - Method in class com.tangosol.io.pof.AbstractPofHandler
Report that an array of values has been encountered in the POF stream.
beginArray(int, int) - Method in class com.tangosol.io.pof.DuplexingPofHandler
beginArray(int, int) - Method in class com.tangosol.io.pof.LoggingPofHandler
beginArray(int, int) - Method in interface com.tangosol.io.pof.PofHandler
beginArray(int, int) - Method in class com.tangosol.io.pof.ValidatingPofHandler
beginArray(int, int) - Method in class com.tangosol.io.pof.WritingPofHandler
beginArray(int, int) - Method in class com.tangosol.util.NullImplementation.NullPofHandler
beginBulkKeyProcess(Object[]) - Method in class com.tangosol.net.cache.SimpleOverflowMap
Begin key-level procecessing for any number of keys.
beginCollection(int, int) - Method in class com.tangosol.io.pof.AbstractPofHandler
Report that a collection of values has been encountered in the POF stream.
beginCollection(int, int) - Method in class com.tangosol.io.pof.DuplexingPofHandler
beginCollection(int, int) - Method in class com.tangosol.io.pof.LoggingPofHandler
beginCollection(int, int) - Method in interface com.tangosol.io.pof.PofHandler
beginCollection(int, int) - Method in class com.tangosol.io.pof.ValidatingPofHandler
beginCollection(int, int) - Method in class com.tangosol.io.pof.WritingPofHandler
beginCollection(int, int) - Method in class com.tangosol.util.NullImplementation.NullPofHandler
beginKeyProcess(Object) - Method in class com.tangosol.net.cache.OverflowMap
Block until a key is available for processing, and return the Status object for that key.
beginKeyProcess(Object) - Method in class com.tangosol.net.cache.SimpleOverflowMap
beginMap(int, int) - Method in class com.tangosol.io.pof.AbstractPofHandler
Report that a map of key/value pairs has been encountered in the POF stream.
beginMap(int, int) - Method in class com.tangosol.io.pof.DuplexingPofHandler
beginMap(int, int) - Method in class com.tangosol.io.pof.LoggingPofHandler
beginMap(int, int) - Method in interface com.tangosol.io.pof.PofHandler
beginMap(int, int) - Method in class com.tangosol.io.pof.ValidatingPofHandler
beginMap(int, int) - Method in class com.tangosol.io.pof.WritingPofHandler
beginMap(int, int) - Method in class com.tangosol.util.NullImplementation.NullPofHandler
beginMapProcess() - Method in class com.tangosol.net.cache.OverflowMap
Block until this thread has exclusive access to perform operations against the OverflowMap.
beginMapProcess() - Method in class com.tangosol.net.cache.SimpleOverflowMap
beginProperty(int) - Method in class com.tangosol.io.pof.PofBufferWriter
Report that a POF property is about to be written to the POF stream.
beginProperty(int) - Method in class com.tangosol.io.pof.PofBufferWriter.UserTypeWriter
beginSparseArray(int, int) - Method in class com.tangosol.io.pof.AbstractPofHandler
Report that a sparse array of values has been encountered in the POF stream.
beginSparseArray(int, int) - Method in class com.tangosol.io.pof.DuplexingPofHandler
beginSparseArray(int, int) - Method in class com.tangosol.io.pof.LoggingPofHandler
beginSparseArray(int, int) - Method in interface com.tangosol.io.pof.PofHandler
beginSparseArray(int, int) - Method in class com.tangosol.io.pof.ValidatingPofHandler
beginSparseArray(int, int) - Method in class com.tangosol.io.pof.WritingPofHandler
beginSparseArray(int, int) - Method in class com.tangosol.util.NullImplementation.NullPofHandler
beginUniformArray(int, int, int) - Method in class com.tangosol.io.pof.AbstractPofHandler
Report that a uniform array of values has been encountered in the POF stream.
beginUniformArray(int, int, int) - Method in class com.tangosol.io.pof.DuplexingPofHandler
beginUniformArray(int, int, int) - Method in class com.tangosol.io.pof.LoggingPofHandler
beginUniformArray(int, int, int) - Method in interface com.tangosol.io.pof.PofHandler
beginUniformArray(int, int, int) - Method in class com.tangosol.io.pof.ValidatingPofHandler
beginUniformArray(int, int, int) - Method in class com.tangosol.io.pof.WritingPofHandler
beginUniformArray(int, int, int) - Method in class com.tangosol.util.NullImplementation.NullPofHandler
beginUniformCollection(int, int, int) - Method in class com.tangosol.io.pof.AbstractPofHandler
Report that a uniform collection of values has been encountered in the POF stream.
beginUniformCollection(int, int, int) - Method in class com.tangosol.io.pof.DuplexingPofHandler
beginUniformCollection(int, int, int) - Method in class com.tangosol.io.pof.LoggingPofHandler
beginUniformCollection(int, int, int) - Method in interface com.tangosol.io.pof.PofHandler
beginUniformCollection(int, int, int) - Method in class com.tangosol.io.pof.ValidatingPofHandler
beginUniformCollection(int, int, int) - Method in class com.tangosol.io.pof.WritingPofHandler
beginUniformCollection(int, int, int) - Method in class com.tangosol.util.NullImplementation.NullPofHandler
beginUniformKeysMap(int, int, int) - Method in class com.tangosol.io.pof.AbstractPofHandler
Report that a map of key/value pairs (with the keys being of a uniform type) has been encountered in the POF stream.
beginUniformKeysMap(int, int, int) - Method in class com.tangosol.io.pof.DuplexingPofHandler
beginUniformKeysMap(int, int, int) - Method in class com.tangosol.io.pof.LoggingPofHandler
beginUniformKeysMap(int, int, int) - Method in interface com.tangosol.io.pof.PofHandler
beginUniformKeysMap(int, int, int) - Method in class com.tangosol.io.pof.ValidatingPofHandler
beginUniformKeysMap(int, int, int) - Method in class com.tangosol.io.pof.WritingPofHandler
beginUniformKeysMap(int, int, int) - Method in class com.tangosol.util.NullImplementation.NullPofHandler
beginUniformMap(int, int, int, int) - Method in class com.tangosol.io.pof.AbstractPofHandler
Report that a map of key/value pairs (with the keys being of a uniform type and the values being of a uniform type) has been encountered in the POF stream.
beginUniformMap(int, int, int, int) - Method in class com.tangosol.io.pof.DuplexingPofHandler
beginUniformMap(int, int, int, int) - Method in class com.tangosol.io.pof.LoggingPofHandler
beginUniformMap(int, int, int, int) - Method in interface com.tangosol.io.pof.PofHandler
beginUniformMap(int, int, int, int) - Method in class com.tangosol.io.pof.ValidatingPofHandler
beginUniformMap(int, int, int, int) - Method in class com.tangosol.io.pof.WritingPofHandler
beginUniformMap(int, int, int, int) - Method in class com.tangosol.util.NullImplementation.NullPofHandler
beginUniformSparseArray(int, int, int) - Method in class com.tangosol.io.pof.AbstractPofHandler
Report that a uniform sparse array of values has been encountered in the POF stream.
beginUniformSparseArray(int, int, int) - Method in class com.tangosol.io.pof.DuplexingPofHandler
beginUniformSparseArray(int, int, int) - Method in class com.tangosol.io.pof.LoggingPofHandler
beginUniformSparseArray(int, int, int) - Method in interface com.tangosol.io.pof.PofHandler
beginUniformSparseArray(int, int, int) - Method in class com.tangosol.io.pof.ValidatingPofHandler
beginUniformSparseArray(int, int, int) - Method in class com.tangosol.io.pof.WritingPofHandler
beginUniformSparseArray(int, int, int) - Method in class com.tangosol.util.NullImplementation.NullPofHandler
beginUserType(int, int, int) - Method in class com.tangosol.io.pof.AbstractPofHandler
Report that a value of a "user type" has been encountered in the POF stream.
beginUserType(int, int, int) - Method in class com.tangosol.io.pof.DuplexingPofHandler
beginUserType(int, int, int) - Method in class com.tangosol.io.pof.LoggingPofHandler
beginUserType(int, int, int) - Method in interface com.tangosol.io.pof.PofHandler
beginUserType(int, int, int) - Method in class com.tangosol.io.pof.ValidatingPofHandler
beginUserType(int, int, int) - Method in class com.tangosol.io.pof.WritingPofHandler
beginUserType(int, int, int, int) - Method in class com.tangosol.io.pof.WritingPofHandler
beginUserType(int, int, int) - Method in class com.tangosol.util.NullImplementation.NullPofHandler
BerkeleyDBBinaryStore - Class in com.tangosol.io.bdb
An implementation of the BinaryStore interface using Sleepycat Berkeley DB Java Edition.
BerkeleyDBBinaryStore(String, DatabaseFactory) - Constructor for class com.tangosol.io.bdb.BerkeleyDBBinaryStore
Create a new Berkeley DB BinaryStore using the supplied DatabaseFactory.
BerkeleyDBBinaryStore.DatabaseHolder - Class in com.tangosol.io.bdb
The DatabaseHolder class is used as a wrapper around a Berkeley DB Database object.
BerkeleyDBBinaryStore.DatabaseHolder(String) - Constructor for class com.tangosol.io.bdb.BerkeleyDBBinaryStore.DatabaseHolder
Construct a DatabaseHolder, including a Database.
BerkeleyDBBinaryStoreManager - Class in com.tangosol.io.bdb
An implementation of the BinaryStoreManager interface using Sleepycat Berkeley DB Java Edition.
BerkeleyDBBinaryStoreManager() - Constructor for class com.tangosol.io.bdb.BerkeleyDBBinaryStoreManager
Default constructor.
BerkeleyDBBinaryStoreManager(File, String) - Constructor for class com.tangosol.io.bdb.BerkeleyDBBinaryStoreManager
Construct a Berkeley DB BinaryStoreManager for the specified directory.
BetweenFilter - Class in com.tangosol.util.filter
Filter which compares the result of a method invocation with a value for "Between" condition.
BetweenFilter() - Constructor for class com.tangosol.util.filter.BetweenFilter
BetweenFilter(String, Comparable, Comparable) - Constructor for class com.tangosol.util.filter.BetweenFilter
Construct a BetweenFilter for testing "Between" condition.
BetweenFilter(ValueExtractor, Comparable, Comparable) - Constructor for class com.tangosol.util.filter.BetweenFilter
BetweenFilter(String, int, int) - Constructor for class com.tangosol.util.filter.BetweenFilter
BetweenFilter(String, long, long) - Constructor for class com.tangosol.util.filter.BetweenFilter
BetweenFilter(String, float, float) - Constructor for class com.tangosol.util.filter.BetweenFilter
BetweenFilter(String, double, double) - Constructor for class com.tangosol.util.filter.BetweenFilter
BIGDECIMAL_ZERO - Static variable in class com.tangosol.io.pof.PofHelper
The default BigDecimal value.
BigDecimalAverage - Class in com.tangosol.util.aggregator
Calculates an average for values of any numberic type extracted from a set of entries in a Map in a form of a BigDecimal value.
BigDecimalAverage() - Constructor for class com.tangosol.util.aggregator.BigDecimalAverage
BigDecimalAverage(ValueExtractor) - Constructor for class com.tangosol.util.aggregator.BigDecimalAverage
Construct a BigDecimalAverage aggregator.
BigDecimalAverage(String) - Constructor for class com.tangosol.util.aggregator.BigDecimalAverage
Construct an BigDecimalAverage object.
BigDecimalMax - Class in com.tangosol.util.aggregator
Calculates a maximum of numeric values extracted from a set of entries in a Map in a form of a BigDecimal value.
BigDecimalMax() - Constructor for class com.tangosol.util.aggregator.BigDecimalMax
BigDecimalMax(ValueExtractor) - Constructor for class com.tangosol.util.aggregator.BigDecimalMax
Construct a BigDecimalMax aggregator.
BigDecimalMax(String) - Constructor for class com.tangosol.util.aggregator.BigDecimalMax
BigDecimalMin - Class in com.tangosol.util.aggregator
Calculates a minimum of numeric values extracted from a set of entries in a Map in a form of a BigDecimal value.
BigDecimalMin() - Constructor for class com.tangosol.util.aggregator.BigDecimalMin
BigDecimalMin(ValueExtractor) - Constructor for class com.tangosol.util.aggregator.BigDecimalMin
Construct a BigDecimalMin aggregator.
BigDecimalMin(String) - Constructor for class com.tangosol.util.aggregator.BigDecimalMin
BigDecimalSum - Class in com.tangosol.util.aggregator
Calculates an sum for values of any numberic type extracted from a set of entries in a Map in a form of a BigDecimal value.
BigDecimalSum() - Constructor for class com.tangosol.util.aggregator.BigDecimalSum
BigDecimalSum(ValueExtractor) - Constructor for class com.tangosol.util.aggregator.BigDecimalSum
Construct a BigDecimalSum aggregator.
BigDecimalSum(String) - Constructor for class com.tangosol.util.aggregator.BigDecimalSum
Construct an BigDecimalSum object.
BIGGEST_MODULO - Static variable in class com.tangosol.util.SafeHashMap
Biggest possible modulo.
BIGGEST_MODULO - Static variable in class com.tangosol.util.SegmentedHashMap
BIGINTEGER_MAX_LONG - Static variable in class com.tangosol.io.pof.PofHelper
The BigInteger representation of Long.MAX_VALUE.
BIGINTEGER_MIN_LONG - Static variable in class com.tangosol.io.pof.PofHelper
The BigInteger representation of Long.MIN_VALUE.
bin(String) - Static method in class com.tangosol.io.nio.BinaryMap
Internal debugging support: Turn a String into a Binary.
BIN_DECO_ONLY - Static variable in class com.tangosol.io.DecorationOnlyDeltaCompressor
A place-holder Binary value used by the compressor to indicate a decoration-only update.
BIN_STORE_PENDING - Static variable in class com.tangosol.net.cache.ReadWriteBackingMap
The binary form of the decoration indicating that the CacheStore on the primary member has not yet written the value.
Binary - Class in com.tangosol.util
A thread-safe immutable binary object.
Binary() - Constructor for class com.tangosol.util.Binary
Default constructor for a binary object.
Binary(byte[]) - Constructor for class com.tangosol.util.Binary
Construct a binary object from a byte array.
Binary(byte[], int, int) - Constructor for class com.tangosol.util.Binary
Construct a binary object from a portion of a byte array.
Binary(Binary) - Constructor for class com.tangosol.util.Binary
Construct a Binary object from a Binary object.
Binary(ByteArrayOutputStream) - Constructor for class com.tangosol.util.Binary
Construct a Binary object from the contents of a ByteArrayOutputStream.
Binary(DataInput) - Constructor for class com.tangosol.util.Binary
Construct a binary object from a DataInput interface.
BINARY_EMPTY - Static variable in class com.tangosol.io.pof.PofHelper
An empty Binary value.
BinaryDeltaCompressor - Class in com.tangosol.io
A DeltaCompressor implementation that works with opaque (binary) values.
BinaryDeltaCompressor() - Constructor for class com.tangosol.io.BinaryDeltaCompressor
BinaryEntry - Interface in com.tangosol.util
Map.Entry that internally stores both key and value in a Binary format and uses an underlying Serializer to convert it to and from an Object view.
BinaryEntryStore - Interface in com.tangosol.net.cache
BinaryEntryStore is analogous to the CacheStore, but operates on BinaryEntry objects.
BinaryMap - Class in com.tangosol.io.nio
Implements the Map interface to store Binary objects using Java's NIO buffers.
BinaryMap(ByteBuffer) - Constructor for class com.tangosol.io.nio.BinaryMap
Construct a BinaryMap on a specific buffer with the default modulo growth and shrinkage (load factor) settings.
BinaryMap(ByteBuffer, double, double, boolean) - Constructor for class com.tangosol.io.nio.BinaryMap
Construct a BinaryMap on a specific buffer with the specified modulo growth and shrinkage (load factor) settings.
BinaryMap(ByteBufferManager) - Constructor for class com.tangosol.io.nio.BinaryMap
Construct a BinaryMap using a buffer from the specified ByteBufferManager, and using the default modulo growth and shrinkage (load factor) settings.
BinaryMap(ByteBufferManager, double, double, boolean) - Constructor for class com.tangosol.io.nio.BinaryMap
Construct a BinaryMap using a buffer from the specified ByteBufferManager, and using the specified modulo growth and shrinkage (load factor) settings.
BinaryMap() - Constructor for class com.tangosol.io.nio.BinaryMap
Construct a BinaryMap.
BinaryMap.Block - Class in com.tangosol.io.nio
A Block is the unit of storage within a Buffer.
BinaryMap.Block() - Constructor for class com.tangosol.io.nio.BinaryMap.Block
Construct a Block.
BinaryMap.Entry - Class in com.tangosol.io.nio
A map entry (key-value pair).
BinaryMap.Entry(Binary, Binary) - Constructor for class com.tangosol.io.nio.BinaryMap.Entry
Construct an Entry with a key and a value.
BinaryMap.EntrySet - Class in com.tangosol.io.nio
A set of entries backed by this map.
BinaryMap.EntrySet() - Constructor for class com.tangosol.io.nio.BinaryMap.EntrySet
BinaryMap.KeySet - Class in com.tangosol.io.nio
BinaryMap.KeySet() - Constructor for class com.tangosol.io.nio.BinaryMap.KeySet
BinaryMap.ValuesCollection - Class in com.tangosol.io.nio
A collection of values backed by this map.
BinaryMap.ValuesCollection() - Constructor for class com.tangosol.io.nio.BinaryMap.ValuesCollection
BinaryMapStore - Class in com.tangosol.io.nio
An implementation of BinaryStore backed by a BinaryMap.
BinaryMapStore(BinaryMap) - Constructor for class com.tangosol.io.nio.BinaryMapStore
Construct a BinaryMapStore object, which is an implementation of the BinaryStore interface backed by a BinaryMap.
BinaryMemoryCalculator - Class in com.tangosol.net.cache
A UnitCalculator implementation that weighs a cache entry based upon the amount of physical memory (in bytes) required to store the entry.
BinaryMemoryCalculator() - Constructor for class com.tangosol.net.cache.BinaryMemoryCalculator
BinaryRadixTree - Class in com.tangosol.util
A BinaryRadixTree is a memory-optimized radix tree (aka a Patricia trie) that is intended to efficiently store a mapping from Binary values to long values.
BinaryRadixTree() - Constructor for class com.tangosol.util.BinaryRadixTree
Construct an empty BinaryRadixTree.
BinaryRadixTree.AllKeyIterator - Class in com.tangosol.util
An Iterator that iterates all of the Binary keys in the radix tree.
BinaryRadixTree.AllKeyIterator() - Constructor for class com.tangosol.util.BinaryRadixTree.AllKeyIterator
BinaryRadixTree.BinaryLongMap - Class in com.tangosol.util
A Map of Binary to Long.
BinaryRadixTree.BinaryLongMap() - Constructor for class com.tangosol.util.BinaryRadixTree.BinaryLongMap
BinaryRadixTree.FilteredIterator - Class in com.tangosol.util
An Iterator that iterates only the Binary keys in the radix tree whose associated value matches (via some bit-mask) a specified value.
BinaryRadixTree.FilteredIterator(long, long) - Constructor for class com.tangosol.util.BinaryRadixTree.FilteredIterator
Construct an iterator of all of the keys that have values that match the specified value as seen through the passed bit-mask.
BinaryRadixTree.KeyIterator - Class in com.tangosol.util
An Iterator that iterates Binary keys from Nodes.
BinaryRadixTree.KeyIterator() - Constructor for class com.tangosol.util.BinaryRadixTree.KeyIterator
BinaryStore - Interface in com.tangosol.io
A simple mapping of CacheStore operations for Binary objects into a Java interface.
BinaryStore.SizeAware - Interface in com.tangosol.io
If a BinaryStore is aware of the number of keys that it stores, then it should implement this optional interface in order to allow that information to be efficiently communicated to an intelligent consumer of the BinaryStore interface.
BinaryStoreCacheStore - Class in com.tangosol.net.cache
A CacheStore that sits directly on top of a BinaryStore.
BinaryStoreCacheStore(BinaryStore) - Constructor for class com.tangosol.net.cache.BinaryStoreCacheStore
Create a CacheStore that delegates to a BinaryStore.
BinaryStoreCacheStore(BinaryStore, ClassLoader) - Constructor for class com.tangosol.net.cache.BinaryStoreCacheStore
Create a CacheStore that delegates to a BinaryStore, using the passed ClassLoader for deserialization.
BinaryStoreCacheStore(BinaryStore, boolean) - Constructor for class com.tangosol.net.cache.BinaryStoreCacheStore
Create a CacheStore that delegates to a BinaryStore, optionally storing only Binary keys and values.
BinaryStoreManager - Interface in com.tangosol.io
A manager that is capable of creating and destroying BinaryStore objects.
BinaryWriteBuffer - Class in com.tangosol.util
a WriteBuffer implementation whose primary purpose is to be used to create Binary objects.
BinaryWriteBuffer(int) - Constructor for class com.tangosol.util.BinaryWriteBuffer
Construct an BinaryWriteBuffer with a certain initial capacity.
BinaryWriteBuffer(int, int) - Constructor for class com.tangosol.util.BinaryWriteBuffer
Construct an BinaryWriteBuffer with a certain initial capacity and a certain maximum capacity.
bind(AttributeHolder, AttributeHolder) - Method in class com.tangosol.coherence.servlet.AbstractHttpSessionModel
Deprecated. Bind the specified session attribute, replacing the specified attribute if it exists.
bind(SocketAddress) - Method in class com.tangosol.net.TcpDatagramSocket
bind(int, InetAddress) - Method in class com.tangosol.net.TcpDatagramSocket.Impl
bind(SocketAddress) - Method in class com.tangosol.net.TcpDatagramSocket.Impl
Bind the socket to the specified address.
bind(SocketAddress) - Method in class com.tangosol.net.WrapperServerSocket
bind(SocketAddress, int) - Method in class com.tangosol.net.WrapperServerSocket
bind(SocketAddress) - Method in class com.tangosol.net.WrapperSocket
bindService(String) - Method in class com.tangosol.net.partition.MirroringAssignmentStrategy
Bind this assignment strategy to the specified partitioned service, and return the bound service.
BitHelper - Class in com.tangosol.util
A collection of methods for bit-based operations.
BitHelper() - Constructor for class com.tangosol.util.BitHelper
BLOCK_BUF - Static variable in class com.tangosol.coherence.servlet.WebPluginInstaller.ApplyPatch
Deprecated. The buffer to use for buffered I/O.
BLOCK_SIZE - Static variable in class com.tangosol.coherence.servlet.WebPluginInstaller.ApplyPatch
Deprecated. The size (in bytes) to perform buffered I/O on.
BlockCipherInputStream - Class in com.tangosol.net.security
InputStream which supports block ciphers, and data sizes which exceed the Cipher's block size.
BlockCipherInputStream(InputStream, Cipher) - Constructor for class com.tangosol.net.security.BlockCipherInputStream
Construct a BlockCipherInputStream around the supplied stream and decrypt output data with the supplied cipher.
BlockCipherInputStream(InputStream, Cipher, int) - Constructor for class com.tangosol.net.security.BlockCipherInputStream
BlockCipherOutputStream - Class in com.tangosol.net.security
BlockCipherOutputStream(OutputStream, Cipher) - Constructor for class com.tangosol.net.security.BlockCipherOutputStream
Construct a BlockCipherOutputStream around the supplied stream and encrypt output data with the supplied cipher.
BlockCipherOutputStream(OutputStream, Cipher, int) - Constructor for class com.tangosol.net.security.BlockCipherOutputStream
BOOLEAN_ARRAY_EMPTY - Static variable in class com.tangosol.io.pof.PofHelper
An empty array of bytes.
BroadKeyPartitioningStrategy - Class in com.tangosol.net.partition
The BroadKeyPartitioningStrategy is a strategy that could be used in cases when the standard key association-based strategy produces very uneven partition distribution - some partitions having significantly larger amount of data than others.
BroadKeyPartitioningStrategy(int) - Constructor for class com.tangosol.net.partition.BroadKeyPartitioningStrategy
Construct the BroadKeyPartitioningStrategy based on the specified span.
BUCKET_COUNTS - Static variable in class com.tangosol.io.nio.BinaryMap
These are potential bucket counts.
buffercopy(ByteBuffer, int, int, int, byte[]) - Static method in class com.tangosol.io.nio.BinaryMap
Copy from one part of the buffer to another.
BufferManagerAdapter - Class in com.tangosol.io
The BufferManagerAdapter is a WriteBufferPool implementation that is backed by a BufferManager.
BufferManagerAdapter(BufferManager) - Constructor for class com.tangosol.io.BufferManagerAdapter
Construct BufferManagerAdapter based on the specified BufferManager.
buildCache(String, Properties) - Method in class com.tangosol.coherence.hibernate.CoherenceCacheProvider
Returns a Hibernate cache region (creating a clustered NamedCache instance if necessary).
buildFactory(XmlElement, ClassLoader) - Method in class com.tangosol.net.ScopedCacheFactoryBuilder
Construct a ConfigurableCacheFactory for the specified XML configuration.
buildPlan() - Method in class com.tangosol.util.filter.LikeFilter
Build a plan for processing the LIKE functionality.
bundle(Set) - Method in class com.tangosol.net.cache.AbstractBinaryEntryBundler
The bundle operation to be performed against a collected set of binary entries by the concrete AbstractEntryBundler implementations.
bundle(Map) - Method in class com.tangosol.net.cache.AbstractEntryBundler
The bundle operation to be performed against a collected map of entries by the concrete AbstractEntryBundler implementations.
bundle(Collection) - Method in class com.tangosol.net.cache.AbstractKeyBundler
The bundle operation to be performed against a collected set of keys by the concrete AbstractKeyBundler implementations.
bundle(Collection) - Method in class com.tangosol.net.cache.BundlingNamedCache.GetBundler
A pass through the the underlying getAll operation.
bundle(Map) - Method in class com.tangosol.net.cache.BundlingNamedCache.PutBundler
A pass through the the underlying putAll() operation.
bundle(Collection) - Method in class com.tangosol.net.cache.BundlingNamedCache.RemoveBundler
A pass through the the underlying keySet().removeAll() operation.
BundlingNamedCache - Class in com.tangosol.net.cache
Bundling NamedCache implementation.
BundlingNamedCache(NamedCache) - Constructor for class com.tangosol.net.cache.BundlingNamedCache
Construct a BundlingNamedCache based on the specified NamedCache.
BundlingNamedCache.GetBundler - Class in com.tangosol.net.cache
BundlingNamedCache.GetBundler() - Constructor for class com.tangosol.net.cache.BundlingNamedCache.GetBundler
BundlingNamedCache.PutBundler - Class in com.tangosol.net.cache
BundlingNamedCache.PutBundler() - Constructor for class com.tangosol.net.cache.BundlingNamedCache.PutBundler
BundlingNamedCache.RemoveBundler - Class in com.tangosol.net.cache
BundlingNamedCache.RemoveBundler() - Constructor for class com.tangosol.net.cache.BundlingNamedCache.RemoveBundler
BYTE_ARRAY_EMPTY - Static variable in class com.tangosol.io.pof.PofHelper
ByteArrayReadBuffer - Class in com.tangosol.io
A ReadBuffer on top of a byte array.
ByteArrayReadBuffer() - Constructor for class com.tangosol.io.ByteArrayReadBuffer
Default constructor provided for subclasses.
ByteArrayReadBuffer(byte[]) - Constructor for class com.tangosol.io.ByteArrayReadBuffer
Construct a ByteArrayReadBuffer object from a byte array.
ByteArrayReadBuffer(byte[], int, int) - Constructor for class com.tangosol.io.ByteArrayReadBuffer
Construct a ByteArrayReadBuffer object from a portion of a byte array.
ByteArrayReadBuffer(byte[], int, int, boolean, boolean, boolean) - Constructor for class com.tangosol.io.ByteArrayReadBuffer
ByteArrayWriteBuffer - Class in com.tangosol.io
ByteArrayWriteBuffer is an implementation of WriteBuffer on a byte array.
ByteArrayWriteBuffer() - Constructor for class com.tangosol.io.ByteArrayWriteBuffer
Default constructor; intended only for use by subclasses.
ByteArrayWriteBuffer(byte[]) - Constructor for class com.tangosol.io.ByteArrayWriteBuffer
Construct a ByteArrayWriteBuffer on a byte array.
ByteArrayWriteBuffer(int) - Constructor for class com.tangosol.io.ByteArrayWriteBuffer
Construct an ByteArrayWriteBuffer with a certain initial capacity.
ByteArrayWriteBuffer(int, int) - Constructor for class com.tangosol.io.ByteArrayWriteBuffer
Construct an ByteArrayWriteBuffer with a certain initial capacity and a certain maximum capacity.
ByteArrayWriteBuffer(WriteBuffer, int, int) - Constructor for class com.tangosol.io.ByteArrayWriteBuffer
Create a new ByteArrayWriteBuffer based on a region of an already existing WriteBuffer.
ByteArrayWriteBuffer.Allocator - Class in com.tangosol.io
Allocator is a WriteBufferPool implementation which allocates a new ByteArrayWriteBuffer on each request to the pool, and does not retain the returned buffer.
ByteArrayWriteBuffer.Allocator(int) - Constructor for class com.tangosol.io.ByteArrayWriteBuffer.Allocator
Construct an Allocator for ByteArrayWriteBuffers of a given size.
ByteArrayWriteBuffer.ByteArrayBufferOutput - Class in com.tangosol.io
ByteArrayBufferOutput is an implementation of BufferOutput optimized for writing to the buffer's underlying byte array.
ByteArrayWriteBuffer.ByteArrayBufferOutput() - Constructor for class com.tangosol.io.ByteArrayWriteBuffer.ByteArrayBufferOutput
Construct an ByteArrayBufferOutput that will begin writing at the start of the containing WriteBuffer.
ByteArrayWriteBuffer.ByteArrayBufferOutput(int) - Constructor for class com.tangosol.io.ByteArrayWriteBuffer.ByteArrayBufferOutput
Construct an ByteArrayBufferOutput that will begin writing at the specified offset within the containing WriteBuffer.
byteAt(int) - Method in class com.tangosol.io.AbstractByteArrayReadBuffer
Returns the byte at the specified offset.
byteAt(int) - Method in class com.tangosol.io.MultiBufferReadBuffer
byteAt(int) - Method in class com.tangosol.io.nio.ByteBufferReadBuffer
byteAt(int) - Method in interface com.tangosol.io.ReadBuffer
byteAt(int) - Method in class com.tangosol.util.AbstractByteSequence.AggregateByteSequence
Determine the n-th byte of the byte sequence.
byteAt(int) - Method in class com.tangosol.util.AbstractByteSequence.PartialByteSequence
byteAt(int) - Method in interface com.tangosol.util.ByteSequence
ByteBufferInputStream - Class in com.tangosol.io.nio
An InputStream implementation on top of a Java NIO ByteBuffer.
ByteBufferInputStream(ByteBuffer) - Constructor for class com.tangosol.io.nio.ByteBufferInputStream
Construct a ByteBufferInputStream on a ByteBuffer object.
ByteBufferManager - Interface in com.tangosol.io.nio
An interface for managing a ByteBuffer.
ByteBufferOutputStream - Class in com.tangosol.io.nio
An OutputStream implementation on top of a Java NIO ByteBuffer.
ByteBufferOutputStream(ByteBuffer) - Constructor for class com.tangosol.io.nio.ByteBufferOutputStream
Construct a ByteBufferOutputStream on a ByteBuffer object.
ByteBufferReadBuffer - Class in com.tangosol.io.nio
A ReadBuffer implementation on top of a Java NIO ByteBuffer.
ByteBufferReadBuffer(ByteBuffer) - Constructor for class com.tangosol.io.nio.ByteBufferReadBuffer
Construct a ByteBufferReadBuffer on an NIO ByteBuffer.
ByteBufferReadBuffer.ByteBufferInput - Class in com.tangosol.io.nio
This is a simple implementation of the BufferInput interface on top of a ByteBuffer.
ByteBufferReadBuffer.ByteBufferInput(ByteBuffer) - Constructor for class com.tangosol.io.nio.ByteBufferReadBuffer.ByteBufferInput
ByteBufferWriteBuffer - Class in com.tangosol.io.nio
A WriteBuffer implementation on top of a Java NIO ByteBuffer.
ByteBufferWriteBuffer(ByteBuffer) - Constructor for class com.tangosol.io.nio.ByteBufferWriteBuffer
Construct a ByteBufferWriteBuffer on an NIO ByteBuffer.
ByteBufferWriteBuffer(ByteBufferWriteBuffer) - Constructor for class com.tangosol.io.nio.ByteBufferWriteBuffer
Perform a shallow clone of the supplied ByteBufferWriteBuffer.
ByteBufferWriteBuffer.ByteBufferOutput - Class in com.tangosol.io.nio
This is a simple implementation of the BufferOutput interface on top of a ByteBuffer.
ByteBufferWriteBuffer.ByteBufferOutput(int) - Constructor for class com.tangosol.io.nio.ByteBufferWriteBuffer.ByteBufferOutput
Construct a ByteBufferOutput on top of an NIO ByteBuffer.
ByteSequence - Interface in com.tangosol.util
Represents a sequence of bytes.
C
CACHE_CONFIG_PATH - Static variable in class com.tangosol.coherence.hibernate.CoherenceCacheProvider
The system property specifying the path to the cache configuration used to configure the hibernate L2 caches.
CACHE_CONFIGURATION_PATH - Static variable in class com.tangosol.coherence.servlet.SessionHelper
Deprecated. The name of the resource that will be used to configure the session management module's own ConfigurableCacheFactory.
CACHE_NAME - Static variable in class com.tangosol.net.DefaultConfigurableCacheFactory
The name of the replaceable parameter representing the cache name.
CACHE_REF - Static variable in class com.tangosol.net.DefaultConfigurableCacheFactory
The name of the replaceable parameter representing a cache reference.
CACHE_TYPE - Static variable in interface com.tangosol.net.management.Registry
String representing the "type" part of ObjectName for the CacheMBean.
CacheAdapter - Class in com.tangosol.run.jca
CacheAdapter encapsulates the operations neccessary to communicate with Coherence™ resource adapter (coherence-tx.rar).
CacheAdapter() - Constructor for class com.tangosol.run.jca.CacheAdapter
Construct the adapter using a default InitialContext, standard JNDI name, "optimistic" concurrency, "committed" isolation level an no timeout.
CacheAdapter(Context, String, int, int, int) - Constructor for class com.tangosol.run.jca.CacheAdapter
Construct the adapter using the specified Context and JNDI name
CacheAdapter.CacheConnectionSpec - Class in com.tangosol.run.jca
CacheConnectionSpec is an implementation of ConnectionSpec interface used to pass the connection info to the adapter.
CacheAdapter.CacheConnectionSpec(String, String, String, String, int, int, int) - Constructor for class com.tangosol.run.jca.CacheAdapter.CacheConnectionSpec
Construct a ConnectionSpec based on the specified parameters.
CacheCollator - Class in com.tangosol.util
Implements a collator which caches its keys.
CacheCollator(Collator) - Constructor for class com.tangosol.util.CacheCollator
Construct this collator to cache the results of another collator.
CacheDelegator - Interface in com.tangosol.coherence.servlet
An interface for a class that will perform all cluster cache related operations
CacheEvent - Class in com.tangosol.net.cache
An extension of the MapEvent which allows to differentiate between client driven (natural) events and cache internal (synthetic) events.
CacheEvent(ObservableMap, int, Object, Object, Object, boolean) - Constructor for class com.tangosol.net.cache.CacheEvent
Constructs a new CacheEvent.
CacheFactory - Class in com.tangosol.net
Factory for the Coherence™ cache product.
CacheFactory() - Constructor for class com.tangosol.net.CacheFactory
CacheFactoryBuilder - Interface in com.tangosol.net
CacheFactoryBuilder provides the means for building and managing configurable cache factories across class loaders in a pluggable fashion.
CacheFactoryLogHandler - Class in com.tangosol.coherence.servlet
CacheFactoryLogHandler() - Constructor for class com.tangosol.coherence.servlet.CacheFactoryLogHandler
CacheLoader - Interface in com.tangosol.net.cache
A JCache CacheLoader.
CacheLoaderCacheStore - Class in com.tangosol.net.cache
A read-only CacheStore that wraps a CacheLoader.
CacheLoaderCacheStore(CacheLoader) - Constructor for class com.tangosol.net.cache.CacheLoaderCacheStore
The CacheLoader to delegate to.
CacheLoaderCacheStore.Iterable - Class in com.tangosol.net.cache
An extension to the CacheLoaderCacheStore that implements the IterableCacheLoader interface.
CacheLoaderCacheStore.Iterable(IterableCacheLoader) - Constructor for class com.tangosol.net.cache.CacheLoaderCacheStore.Iterable
CacheMap - Interface in com.tangosol.net.cache
A CacheMap is a Map that supports caching.
CACHENAME_DEATHCERTS - Static variable in class com.tangosol.coherence.servlet.AbstractHttpSessionCollection
Deprecated. The name of the clustered cache that stores the IDs of "recently departed" sessions.
CACHENAME_LOCAL_ATTRIBUTES - Static variable in class com.tangosol.coherence.servlet.AbstractHttpSessionCollection
Deprecated. The name of the local cache that stores the session attributes that are not distributed (if there is a distribution controller or attributes are allowed to become local when serialization fails).
CACHENAME_LOCAL_SESSIONS - Static variable in class com.tangosol.coherence.servlet.AbstractHttpSessionCollection
Deprecated. The name of the local cache that stores the sessions that are not yet distributed (if there is a distribution controller).
CACHENAME_OVERFLOW - Static variable in class com.tangosol.coherence.servlet.SplitHttpSessionCollection
Deprecated. The name of the clustered cache that stores the attributes that are too large to store as part of the session objects.
CACHENAME_SESSIONS - Static variable in class com.tangosol.coherence.servlet.AbstractHttpSessionCollection
Deprecated. The name of the clustered cache that stores the sessions.
CacheResource - Class in com.tangosol.coherence.rest
RESTful wrapper around a Coherence NamedCache.
CacheResource(NamedCache, Class, Class, MarshallerRegistry) - Constructor for class com.tangosol.coherence.rest.CacheResource
Construct a new CacheResource.
CacheResource(NamedCache, Class, Class, KeyConverter, MarshallerRegistry) - Constructor for class com.tangosol.coherence.rest.CacheResource
CacheService - Interface in com.tangosol.net
A CacheService is a clustered service providing a collection of named Maps that hold resources shared among members of a cluster.
CacheService.CacheAction - Interface in com.tangosol.net
CacheAction represents a type of action taken by a CacheService.
CacheStatistics - Interface in com.tangosol.net.cache
An interface for exposing Cache statistics.
CacheStore - Interface in com.tangosol.net.cache
A JCache cache store.
CacheStoreMap - Class in com.tangosol.net.cache
A backing Map implementation that delegates all operations to a CacheStore.
CacheStoreMap(BackingMapManagerContext, IterableCacheLoader) - Constructor for class com.tangosol.net.cache.CacheStoreMap
Construct a read-only CacheStoreMap.
CacheStoreMap(BackingMapManagerContext, CacheStore) - Constructor for class com.tangosol.net.cache.CacheStoreMap
Construct a read/write CacheStoreMap.
CacheStoreMap(BackingMapManagerContext, CacheStore, boolean) - Constructor for class com.tangosol.net.cache.CacheStoreMap
CacheStoreMap.ReadWriteMap - Class in com.tangosol.net.cache
A Map implementation that delegates straight through to a CacheStore.
CacheStoreMap.ReadWriteMap(CacheStore, boolean) - Constructor for class com.tangosol.net.cache.CacheStoreMap.ReadWriteMap
CachingMap - Class in com.tangosol.net.cache
Map implementation that wraps two maps - a front map (assumed to be "inexpensive" and probably "incomplete") and a back map (assumed to be "complete" and "correct", but more "expensive") - using a read-through/write-through approach.
CachingMap(Map, Map) - Constructor for class com.tangosol.net.cache.CachingMap
Construct a CachingMap using two specified maps: FrontMap (aka "cache", "near" or "shallow") and BackMap (aka "actual", "real" or "deep").
CachingMap(Map, Map, int) - Constructor for class com.tangosol.net.cache.CachingMap
Construct a CachingMap using two specified maps: FrontMap (aka "cache", "near" or "shallow") and BackMap (aka "actual", "real" or "deep") and using the specified front map invalidation strategy.
CachingMap.BackMapListener - Class in com.tangosol.net.cache
MapListener for back map responsible for keeping the front map coherent with the back map.
CachingMap.BackMapListener() - Constructor for class com.tangosol.net.cache.CachingMap.BackMapListener
CachingMap.FrontMapListener - Class in com.tangosol.net.cache
MapListener for front map responsible for deregistering back map listeners upon front map eviction.
CachingMap.FrontMapListener() - Constructor for class com.tangosol.net.cache.CachingMap.FrontMapListener
calcDecimalSize(BigDecimal) - Static method in class com.tangosol.io.pof.PofHelper
Determine the minimum size (in bytes) of the IEEE754 decimal type that would be capable of holding the passed value.
calculateAverage(MBeanServer, String, String) - Static method in class com.tangosol.net.management.MBeanHelper
Calculate the average of the attribute values across all the MBeans with a given name pattern.
calculateBasePartition(PartitionedService, Object) - Static method in class com.tangosol.net.partition.DefaultKeyPartitioningStrategy
Determine the partition to which the given key should be assigned for the specified PartitionService.
calculateBucket(int) - Method in class com.tangosol.io.nio.BinaryMap
Calculate the bucket for the specified hash code.
calculateEffectiveness(Map, Set) - Method in class com.tangosol.util.filter.AllFilter
Given a Map of available indexes, determine if this IndexAwareFilter can use any of the indexes to assist in its processing, and if so, determine how effective the use of that index would be.
calculateEffectiveness(Map, Set) - Method in class com.tangosol.util.filter.AlwaysFilter
calculateEffectiveness(Map, Set) - Method in class com.tangosol.util.filter.AnyFilter
calculateEffectiveness(Map, Set) - Method in class com.tangosol.util.filter.ContainsAllFilter
calculateEffectiveness(Map, Set) - Method in class com.tangosol.util.filter.ContainsAnyFilter
calculateEffectiveness(Map, Set) - Method in class com.tangosol.util.filter.ContainsFilter
calculateEffectiveness(Map, Set) - Method in class com.tangosol.util.filter.EqualsFilter
calculateEffectiveness(Map, Set) - Method in class com.tangosol.util.filter.GreaterEqualsFilter
calculateEffectiveness(Map, Set) - Method in class com.tangosol.util.filter.GreaterFilter
calculateEffectiveness(Map, Set) - Method in interface com.tangosol.util.filter.IndexAwareFilter
calculateEffectiveness(Map, Set) - Method in class com.tangosol.util.filter.InFilter
calculateEffectiveness(Map, Set) - Method in class com.tangosol.util.filter.InKeySetFilter
calculateEffectiveness(Map, Set) - Method in class com.tangosol.util.filter.KeyFilter
calculateEffectiveness(Map, Set) - Method in class com.tangosol.util.filter.LessEqualsFilter
calculateEffectiveness(Map, Set) - Method in class com.tangosol.util.filter.LessFilter
calculateEffectiveness(Map, Set) - Method in class com.tangosol.util.filter.LikeFilter
calculateEffectiveness(Map, Set) - Method in class com.tangosol.util.filter.LimitFilter
calculateEffectiveness(Map, Set) - Method in class com.tangosol.util.filter.NeverFilter
calculateEffectiveness(Map, Set) - Method in class com.tangosol.util.filter.NotEqualsFilter
calculateEffectiveness(Map, Set) - Method in class com.tangosol.util.filter.NotFilter
calculateEffectiveness(Map, Set) - Method in class com.tangosol.util.filter.PresentFilter
calculateEffectiveness(Map, Set) - Method in class com.tangosol.util.filter.PriorityFilter
calculateEffectiveness(Map, Set) - Method in class com.tangosol.util.filter.XorFilter
calculateFairShare(boolean) - Method in class com.tangosol.net.partition.SimpleAssignmentStrategy.AnalysisContext
Return the "fair share" (F) load.
calculateFilters(Map, Set) - Method in class com.tangosol.util.filter.ArrayFilter
Calculate the effectiveness and sort all the participating filters according to their effectiveness.
calculateHeadWeight() - Method in class com.tangosol.util.SafeSortedMap.Split
Estimate the weight of the head portion of the Split.
calculateIteratorEffectiveness(int) - Static method in class com.tangosol.util.filter.ComparisonFilter
Helper method to calculate effectiveness (or rather ineffectiveness) of a simple iteration against a key set that has to be performed due to an absence of corresponding index.
calculateKeyPartition(PartitionedService, Object) - Static method in class com.tangosol.net.partition.DefaultKeyPartitioningStrategy
Determine the partition to which the given key should be assigned for the specified PartitionService, taking into consideration the associations provided by the service's KeyAssociator.
calculateMatchEffectiveness(Map, Set) - Method in class com.tangosol.util.filter.ComparisonFilter
Helper method to calculate effectiveness for ComparisonFilters that need no more than a single index match in order to retrieve all necessary keys to perform the applyIndex() operation.
calculateNaturalPartition(int) - Method in class com.tangosol.util.Binary
Calculate the partition ID to which the specified Binary should be naturally assigned.
calculatePreviousBucket(int) - Method in class com.tangosol.io.nio.BinaryMap
Calculate the old bucket for the specified hash code.
calculateRandomLevel() - Method in class com.tangosol.util.SafeSortedMap
Randomly generate a level value 0 <= L <= MAX_LEVEL, in such a way that the probability p(l) of generating level l is equal to p(l)=(1/span)^(l+1) and p(0)=1-(sum of p(l) over l=1..MAX_LEVEL).
calculateRangeEffectiveness(Map, Set) - Method in class com.tangosol.util.filter.ComparisonFilter
Helper method to calculate effectiveness for ComparisonFilters that need a range of values from an index in order to retrieve all necessary keys to perform the applyIndex() operation.
calculateRequeueDelay(ReadWriteBackingMap.WriteQueue) - Method in class com.tangosol.net.cache.ReadWriteBackingMap.StoreWrapper
Calculate the requeue delay after a store operation failed.
calculateShallowSize(Class) - Static method in class com.tangosol.net.cache.SimpleMemoryCalculator
Calculate the approximate number of bytes required to store an instance of the given class and its non-static fields in memory.
calculateSize() - Method in interface com.tangosol.util.Sizable
Calculate the memory footprint for this instance.
calculateSizeCode(int) - Static method in class com.tangosol.io.nio.BinaryMap
Determine which "free bucket" a block of a particular size would go into.
calculateTotalLength(Object[][]) - Static method in class com.tangosol.util.ImmutableMultiList
Calculate the total number of element in the array of arrays.
calculateUnits(Object, Object) - Method in class com.tangosol.net.cache.BinaryMemoryCalculator
Calculate the approximate number of bytes required to cache the given Binary key and value.
calculateUnits(Object, Object) - Method in interface com.tangosol.net.cache.ConfigurableCacheMap.UnitCalculator
Calculate a cache cost for the specified cache entry key and value.
calculateUnits(Object) - Method in class com.tangosol.net.cache.OldCache.Entry
Deprecated. Calculate a cache cost for the specified object.
calculateUnits(Object, Object) - Method in class com.tangosol.net.cache.OldCache.InternalUnitCalculator
Deprecated. Calculate a cache cost for the specified cache entry key and value.
calculateUnits(Object, Object) - Method in class com.tangosol.net.cache.SimpleMemoryCalculator
calculateUnits(int) - Method in class com.tangosol.net.partition.ObservableSplittingBackingCache
Aggregate the number of units across all of the partition backing maps.
calculateVersion(Object) - Method in class com.tangosol.run.jca.SimpleValidator
Generate the Comparable version indicator for a given resource value.
calcUTF(String) - Method in class com.tangosol.io.AbstractWriteBuffer.AbstractBufferOutput
Figure out how many bytes it will take to hold the passed String.
calibrate() - Method in class com.tangosol.io.nio.AbstractBufferManager
Determine the grow and shrink thresholds based on the current capacity.
cancel() - Method in class com.tangosol.net.cache.ReadWriteBackingMap.ReadLatch
Cancel the load operation.
cancel(Throwable) - Method in class com.tangosol.net.cache.ReadWriteBackingMap.ReadLatch
Cancel the load operation due to an exception.
cancel() - Method in class com.tangosol.net.WrapperSelector.WrapperSelectionKey
cancelOutstandingReads(Object) - Method in class com.tangosol.net.cache.ReadWriteBackingMap
Cancel any outstanding asynchronous reads for a key.
cancelPostedWork() - Method in class com.tangosol.coherence.commonj.WorkManager
Cancel all posted work that has not yet completed.
capacity() - Method in class com.tangosol.util.Dequeue
Determine the current capacity of this dequeue.
cardinality() - Method in class com.tangosol.net.partition.PartitionSet
Returns the number of marked partitions.
casNext(Object, Object) - Method in class com.tangosol.util.SafeSortedMap.EntryNode
Atomically set the next EntryNode to the specified node iff the current next EntryNode matches the expected node.
casNext(SafeSortedMap.SkipNode, SafeSortedMap.SkipNode) - Method in class com.tangosol.util.SafeSortedMap.SkipNode
Atomically set the specified next SkipNode iff the current next node matches the expected node.
casTopNode(SafeSortedMap.IndexNode, SafeSortedMap.IndexNode) - Method in class com.tangosol.util.SafeSortedMap
Atomically set specified IndexNode to the top node iff the current top node is the expected top node.
casValue(Object, Object) - Method in class com.tangosol.util.SafeSortedMap.EntryNode
Atomically set the value of this EntryNode to the specified value iff the current value matches the assumed value.
casValueInternal(Object, Object) - Method in class com.tangosol.util.SegmentedConcurrentMap.LockableEntry
Set the value of this entry to the specified value iff the current value matches the assumed value.
cEntries - Variable in class com.tangosol.util.SegmentedHashMap.Segment
The number of Entry objects (including synthetics) in this segment.
CFG_KEY_REAPER - Static variable in class com.tangosol.coherence.servlet.SessionHelper
Deprecated. The key in the configuration cache for coordating cluster-wide session reaping.
chainComparators(Comparator, Comparator, Comparator) - Static method in class com.tangosol.net.partition.SimpleAssignmentStrategy
Helper method to return a Comparator chaining the specified comparators.
ChainedComparator - Class in com.tangosol.util.comparator
Composite comparator implementation based on a collection of comparators.
ChainedComparator() - Constructor for class com.tangosol.util.comparator.ChainedComparator
Default constructor (for ExternalizableLite and PortableObject).
ChainedComparator(Comparator, Comparator) - Constructor for class com.tangosol.util.comparator.ChainedComparator
Construct a ChainedComparator with the specified comparators.
ChainedComparator(Comparator, Comparator, Comparator) - Constructor for class com.tangosol.util.comparator.ChainedComparator
ChainedComparator(Comparator[]) - Constructor for class com.tangosol.util.comparator.ChainedComparator
Construct a ChainedComparator.
ChainedEnumerator - Class in com.tangosol.util
Provide an enumerator which enumerates the contents of multiple enumerators.
ChainedEnumerator() - Constructor for class com.tangosol.util.ChainedEnumerator
Construct an enumerator that will first enumerate multiple enumerators.
ChainedEnumerator(Enumeration) - Constructor for class com.tangosol.util.ChainedEnumerator
Construct an enumerator that will first enumerate the passed Enumeration.
ChainedEnumerator(Iterator) - Constructor for class com.tangosol.util.ChainedEnumerator
Construct an enumerator that will first enumerate the passed Iterator.
ChainedEnumerator(Enumeration, Enumeration) - Constructor for class com.tangosol.util.ChainedEnumerator
Construct an enumerator that will first enumerate the first Enumeration and then will enumerate the second Enumeration as if they were together a single Enumeration.
ChainedEnumerator(Iterator, Iterator) - Constructor for class com.tangosol.util.ChainedEnumerator
Construct an enumerator that will first enumerate the first Iterator and then will enumerate the second Iterator as if they were together a single Iterator.
ChainedEnumerator(Enumeration[]) - Constructor for class com.tangosol.util.ChainedEnumerator
Construct an enumerator that will first enumerate the Enumerations passed in the array as if they were together a single enumerator.
ChainedEnumerator(Iterator[]) - Constructor for class com.tangosol.util.ChainedEnumerator
Construct an enumerator that will first enumerate the Iterators passed in the array as if they were together a single enumerator.
ChainedExtractor - Class in com.tangosol.util.extractor
Composite ValueExtractor implementation based on an array of extractors.
ChainedExtractor() - Constructor for class com.tangosol.util.extractor.ChainedExtractor
Default constructor (necessary for the ExternalizableLite interface).
ChainedExtractor(ValueExtractor[]) - Constructor for class com.tangosol.util.extractor.ChainedExtractor
Construct a ChainedExtractor based on a specified ValueExractor array.
ChainedExtractor(ValueExtractor, ValueExtractor) - Constructor for class com.tangosol.util.extractor.ChainedExtractor
Construct a ChainedExtractor based on two extractors.
ChainedExtractor(String) - Constructor for class com.tangosol.util.extractor.ChainedExtractor
Construct a ChainedExtractor for a specified method name sequence.
ChainedMap - Class in com.tangosol.util
Chains two maps into one virtual map.
ChainedMap(Map, Map) - Constructor for class com.tangosol.util.ChainedMap
Construct a ChainedMap out of two maps.
ChainedMap.EntrySet - Class in com.tangosol.util
ChainedMap.EntrySet() - Constructor for class com.tangosol.util.ChainedMap.EntrySet
changeState(int, Daemon.DaemonWorker) - Method in class com.tangosol.io.journal.FlashJournalRM.PreparerDaemon
Change the state of the daemon.
changeState(int) - Method in class com.tangosol.net.cache.ContinuousQueryCache
Change the state of the ContinuousQueryCache.
changeState(int, Daemon.DaemonWorker) - Method in class com.tangosol.util.Daemon
channel() - Method in class com.tangosol.net.WrapperSelector.WrapperSelectionKey
CHAR_ARRAY_EMPTY - Static variable in class com.tangosol.io.pof.PofHelper
An empty array of chars.
CHAR_BUF_MASK - Static variable in class com.tangosol.io.AbstractWriteBuffer
Bitmask used against a raw offset to determine the offset within the temporary character buffer.
CHAR_BUF_SIZE - Static variable in class com.tangosol.io.AbstractWriteBuffer
Size of the temporary character buffer.
check() - Method in class com.tangosol.io.MultiByteArrayOutputStream
Verify that the stream is still open.
check(String) - Method in class com.tangosol.io.nio.BinaryMap
Debugging support: Validate the buffer's data structures, the hash buckets, free lists, etc.
check() - Method in class com.tangosol.net.GuardSupport
Check the registered Guardable objects for timeout, taking appropriate action and calculate the timestamp when the next check should be performed.
check() - Method in class com.tangosol.util.ThreadLocalObject
Deprecated. as of Coherence 3.3 this method is a no-op
checkActive() - Method in class com.tangosol.coherence.servlet.AbstractHttpSessionModel
Deprecated. Make sure that the model is 'active', 'usable' and 'valid'.
checkAndInvalidate(String) - Method in class com.tangosol.coherence.servlet.AbstractReapTask
Deprecated. Check the specified session to see if it has expired, and in that case invalidate it.
checkBackupBalance(SimpleAssignmentStrategy.AnalysisContext) - Method in class com.tangosol.net.partition.SimpleAssignmentStrategy
Check that the distribution of backup partitions is balanced.
checkBackupStrong(SimpleAssignmentStrategy.AnalysisContext) - Method in class com.tangosol.net.partition.SimpleAssignmentStrategy
Check that the backups are strong.
checkBounds(int, int) - Method in class com.tangosol.io.AbstractReadBuffer
Check if the specified read is within bounds.
checkBounds(int, int) - Method in class com.tangosol.io.ByteArrayWriteBuffer
Validate the ranges for the passed bounds and make sure that the underlying array is big enough to handle them.
checkBounds(int, int) - Method in class com.tangosol.io.DelegatingWriteBuffer
Test an offset and length of data to write to see if it can be written to this buffer.
checkBounds(int, int) - Method in class com.tangosol.util.BinaryWriteBuffer
checkBufferGrow(int) - Method in class com.tangosol.io.nio.BinaryMap
If there is a buffer manager, check if the current buffer should be grown.
checkBufferShrink() - Method in class com.tangosol.io.nio.BinaryMap
If there is a buffer manager, check if the current buffer should be shrunk.
checkClientTrusted(X509Certificate[], String) - Method in class com.tangosol.net.security.PeerX509TrustManager
Determine if the leaf certificate in the given certificate chain is contained in the trusted peer key store.
checkCompatible(ValidatingConfiguration) - Method in class com.tangosol.coherence.servlet.ConfigurationImpl
Deprecated.
checkConfigConsistency(ValidatingConfiguration) - Method in class com.tangosol.coherence.servlet.SessionHelper
Deprecated. Check that configuration is consistent with that of existing members.
checkDate(int, int, int) - Static method in class com.tangosol.io.pof.PofHelper
Validate date information.
checkDayTimeInterval(int, int, int, int, int) - Static method in class com.tangosol.io.pof.PofHelper
Validate a day-time interval.
checkDecimalRange(BigDecimal, int) - Static method in class com.tangosol.io.pof.PofHelper
Verify that the specified decimal value will fit in the specified number of bits.
checkDestroy() - Method in class com.tangosol.net.cache.SerializationPagedCache.WrapperBinaryStore
Test if the underlying store can be destroyed, and if so, destroy it.
checkElement(XmlElement) - Method in class com.tangosol.run.xml.SimpleElement.ElementList
Validates the passed XmlElement, copying the element into a new valid element if necessary.
checkElementCount(int) - Static method in class com.tangosol.io.pof.PofHelper
Verify that the number of elements is valid.
checkEndangered(SimpleAssignmentStrategy.AnalysisContext) - Method in class com.tangosol.net.partition.SimpleAssignmentStrategy
Check the distribution to ensure that backups are created for any "endangered" partitions.
checkEntry(Map.Entry) - Method in class com.tangosol.net.cache.ContinuousQueryCache
Check the passed value to verify that it does belong in this ContinuousQueryCache.
checkEntry(Object, Object) - Method in class com.tangosol.net.cache.ContinuousQueryCache
checkError() - Method in class com.tangosol.io.WriterPrintStream
Flush the stream and check its error state.
checkExpiry() - Method in class com.tangosol.net.cache.SerializationCache
Make sure that the cache does not contain expired items.
checkFlush() - Method in class com.tangosol.net.cache.OldCache
Deprecated. as of Coherence 3.5, use OldCache.evict()
checkForDeadSessions() - Method in class com.tangosol.coherence.servlet.SessionHelper
Deprecated. Discard the HttpSession objects that are no longer alive.
checkInitializing() - Method in class com.tangosol.io.journal.AbstractJournalRM
Verify that the AbstractJournalRM is still initializing.
checkKey(Object) - Method in class com.tangosol.util.RestrictedCollections.RestrictedMap
Check the passed object to verify that it passes the "key" restriction of this Map.
checkLeaving(SimpleAssignmentStrategy.AnalysisContext) - Method in class com.tangosol.net.partition.SimpleAssignmentStrategy
Check for any service members that are leaving, and adjust the distribution plan accordingly.
checkModulo() - Method in class com.tangosol.io.nio.BinaryMap
Determine if the modulo should be changed.
checkMutable() - Method in class com.tangosol.run.xml.SimpleDocument
Validates that the document is mutable, otherwise throws an UnsupportedOperationException.
checkMutable() - Method in class com.tangosol.run.xml.SimpleElement
Validates that the element is mutable, otherwise throws an UnsupportedOperationException.
checkMutable() - Method in class com.tangosol.run.xml.XmlBean
Verify that this XmlBean is mutable.
checkMutable() - Method in class com.tangosol.util.InvocableMapHelper.SimpleEntry
Verify that this SimpleEntry is mutable.
checkNotInitialized() - Method in class com.tangosol.io.pof.ConfigurablePofContext
Verify that the ConfigurablePofContext has not already been initialized.
checkObject(Object) - Method in class com.tangosol.util.RestrictedCollections.RestrictedCollection
Check the passed object to verify that it passes the restriction of this Collection.
checkObject(Object) - Method in class com.tangosol.util.RestrictedCollections.RestrictedListIterator
Check the passed object to verify that it passes the restriction of this ListIterator.
checkPage() - Method in class com.tangosol.net.cache.SerializationPagedCache
Determine if the time has come to set up a new page for storing current cache data.
checkPeerTrusted(X509Certificate[], String) - Method in class com.tangosol.net.security.PeerX509TrustManager
checkPending(Object) - Method in class com.tangosol.net.cache.ReadWriteBackingMap.WriteQueue
Check for an item known to the WriteBehind queue.
checkPermission(NamedCache) - Static method in class com.tangosol.net.DefaultConfigurableCacheFactory
Check if the current user is allowed to "join" the cache.
checkPermission(ClusterPermission, Subject) - Method in interface com.tangosol.net.security.AccessController
Determine whether the cluster access request indicated by the specified permission should be allowed or denied for a given Subject (requestor).
checkPermission(ClusterPermission, Subject) - Method in class com.tangosol.net.security.DefaultController
checkPermission(Cluster, String, String, String) - Static method in class com.tangosol.net.security.Security
Check if the current user has permission to perform the action against "clustered resources", such as clustered services and caches.
checkPosition(int) - Method in class com.tangosol.io.pof.ValidatingPofHandler
Validate the specified value position in the POF stream.
checkPosition(int) - Method in class com.tangosol.io.pof.ValidatingPofHandler.Complex
Notify the Complex object that a value has been encountered.
checkPosition(int) - Method in class com.tangosol.io.pof.ValidatingPofHandler.ComplexMap
checkPrimaryBalance(SimpleAssignmentStrategy.AnalysisContext) - Method in class com.tangosol.net.partition.SimpleAssignmentStrategy
Check the distribution to ensure that primary the partition load is balanced.
checkReadOnly() - Method in class com.tangosol.net.cache.ContinuousQueryCache
Check the read-only setting to verify that the cache is NOT read-only.
checkReferenceRange(int) - Static method in class com.tangosol.io.pof.PofHelper
Validate a reference identifier to make sure it is in a valid range.
checkRoleQuorum(String, Set, Set, Set, Set) - Method in class com.tangosol.net.ConfigurableQuorumPolicy.ClusterQuorumPolicy
Check whether the cluster quorum for the specified role will be satisfied if the set of suspect members is disconnected from the cluster, given the sets of "healthy" and "announcing" members.
checkServerTrusted(X509Certificate[], String) - Method in class com.tangosol.net.security.PeerX509TrustManager
checkShrinkFromOther() - Method in class com.tangosol.util.LiteMap
After a mutation operation has reduced the size of an underlying Map, check if the delegation model should be replaced with a more size- efficient storage approach, and switch accordingly.
checkShrinkFromOther() - Method in class com.tangosol.util.LiteSet
After a mutation operation has reduced the size of an underlying Set, check if the delegation model should be replaced with a more size- efficient storage approach, and switch accordingly.
checkSize() - Method in class com.tangosol.net.cache.OldCache
Deprecated. Check if the cache is too big, and if it is prune it by discarding the lowest priority cache entries.
checkSize() - Method in class com.tangosol.net.cache.SerializationCache
Make sure the size of the cache isn't too big.
checkStrict() - Method in class com.tangosol.net.cache.ReadonlyNamedCache
Enforce the "strict" read-only policy.
checkTime(int, int, int, int) - Static method in class com.tangosol.io.pof.PofHelper
Validate time information.
checkTimeInterval(int, int, int, int) - Static method in class com.tangosol.io.pof.PofHelper
Validate a time interval.
checkTimeZone(int, int) - Static method in class com.tangosol.io.pof.PofHelper
Check the specified timezone offset.
checkType(int) - Static method in class com.tangosol.io.pof.PofHelper
Validate a type identifier.
checkUsable() - Method in class com.tangosol.coherence.servlet.AbstractHttpSessionModel
Deprecated. Make sure that the model is 'usable'.
checkValid() - Method in class com.tangosol.coherence.servlet.AbstractHttpSessionModel
Deprecated. Make sure that the model is 'usable' and 'valid'.
checkValue(Object) - Method in class com.tangosol.util.RestrictedCollections.RestrictedEntrySet
Check the passed object to verify that it passes the "value" restriction of this Map.
checkValue(Object) - Method in class com.tangosol.util.RestrictedCollections.RestrictedMap
checkYearMonthInterval(int, int) - Static method in class com.tangosol.io.pof.PofHelper
Validate a year-month interval.
chooseServer() - Method in class com.tangosol.coherence.commonj.WorkManager
Choose a Member to run a next Work at.
CircularArrayList - Class in com.tangosol.util
Resizable-array implementation of the List interface.
CircularArrayList() - Constructor for class com.tangosol.util.CircularArrayList
Create a new CircularArrayList with default settings.
CircularArrayList(int) - Constructor for class com.tangosol.util.CircularArrayList
Create a new CircularArrayList with the specified initial capacity.
CircularArrayList(Collection) - Constructor for class com.tangosol.util.CircularArrayList
Construct a CircularArrayList containing the elements of the specified collection in the order they are returned by the collection's iterator.
CLASS_LOADER - Static variable in class com.tangosol.net.DefaultConfigurableCacheFactory
The name of the replaceable parameter representing the class loader.
ClassFilter - Class in com.tangosol.util
Filter which discards all objects that are not of a certain class.
ClassFilter(Class) - Constructor for class com.tangosol.util.ClassFilter
Constructor.
ClassHelper - Class in com.tangosol.util
This abstract class contains dynamic (reflect-based) class, method, and field manipulation methods.
ClassHelper() - Constructor for class com.tangosol.util.ClassHelper
ClassLoaderAware - Interface in com.tangosol.io
The ClassLoaderAware interface provides the ability to configure a ClassLoader to be used by the implementing object when loading classes or resources.
CLEANUP_FINALIZERS - Static variable in class com.tangosol.io.nio.DirectBufferManager
Use Runtime.runFinalization() to trigger finalization (default).
CLEANUP_GC - Static variable in class com.tangosol.io.nio.DirectBufferManager
Use Runtime.gc() to trigger finalization.
CLEANUP_NONE - Static variable in class com.tangosol.io.nio.DirectBufferManager
Do not perform any buffer cleanup.
cleanupBuffers() - Method in class com.tangosol.io.nio.DirectBufferManager
Determines if and how to induce the JVM to run finalizers.
clear() - Method in class com.tangosol.coherence.hibernate.CoherenceCache
Clear the entire cache.
clear() - Method in class com.tangosol.coherence.weblogic.PortalCacheProvider.CacheImpl
Remove all entries from the Cache.
clear() - Method in class com.tangosol.io.AbstractWriteBuffer
Set the length of the buffer as indicated by the WriteBuffer.length() method to zero.
clear() - Method in class com.tangosol.io.DelegatingWriteBuffer
clear() - Method in class com.tangosol.io.nio.BinaryMap.Block
Zero the block.
Removes all mappings from this map.
clear() - Method in class com.tangosol.io.nio.BinaryMap.EntrySet
Removes all of the elements from this set of Keys by clearing the underlying Map.
clear() - Method in class com.tangosol.io.nio.BinaryMap.KeySet
clear() - Method in class com.tangosol.io.nio.BinaryMap.ValuesCollection
Removes all of the elements from this Collection of values by clearing the underlying Map.
clear() - Method in class com.tangosol.io.pof.PofHelper.ReadableEntrySetMap
clear() - Method in interface com.tangosol.io.WriteBuffer
clear() - Method in class com.tangosol.net.cache.AbstractSerializationCache
Clear all key/value mappings.
clear() - Method in class com.tangosol.net.cache.CacheStoreMap.ReadWriteMap
Clear is explicitly not implemented.
clear() - Method in class com.tangosol.net.cache.CachingMap
Clears both the front and back maps.
clear() - Method in class com.tangosol.net.cache.ContinuousQueryCache
clear() - Method in class com.tangosol.net.cache.LocalCache
clear() - Method in class com.tangosol.net.cache.OldCache
Deprecated. Remove everything from the cache.
clear() - Method in class com.tangosol.net.cache.OverflowMap
clear() - Method in class com.tangosol.net.cache.ReadonlyNamedCache
Should not be called.
clear() - Method in class com.tangosol.net.cache.ReadWriteBackingMap
Remove everything from the Map.
clear() - Method in class com.tangosol.net.cache.ReadWriteBackingMap.EntrySet
clear() - Method in class com.tangosol.net.cache.ReadWriteBackingMap.KeySet
clear() - Method in class com.tangosol.net.cache.ReadWriteBackingMap.ReadQueue
Remove all keys from the queue.
clear() - Method in class com.tangosol.net.cache.ReadWriteBackingMap.ValuesCollection
clear() - Method in class com.tangosol.net.cache.SerializationCache
clear() - Method in class com.tangosol.net.cache.SerializationMap
clear() - Method in class com.tangosol.net.cache.SerializationPagedCache
clear() - Method in class com.tangosol.net.cache.SimpleOverflowMap
clear() - Method in class com.tangosol.net.cache.SimpleSerializationMap
clear() - Method in class com.tangosol.net.partition.PartitionSet
Clear the set.
clear() - Method in class com.tangosol.net.partition.PartitionSplittingBackingMap
clear() - Method in class com.tangosol.run.xml.SimpleElement.AttributeMap
clear() - Method in class com.tangosol.run.xml.SimpleElement.ElementList
Removes all of the elements from this list.
clear() - Method in class com.tangosol.util.AbstractKeyBasedMap
clear() - Method in class com.tangosol.util.AbstractKeyBasedMap.EntrySet
clear() - Method in class com.tangosol.util.AbstractKeyBasedMap.KeySet
clear() - Method in class com.tangosol.util.AbstractKeyBasedMap.ValuesCollection
Removes all of the elements from this Collection by clearing the underlying Map.
clear() - Method in class com.tangosol.util.AbstractLongArray
Remove all nodes from the LongArray.
clear() - Method in class com.tangosol.util.AbstractSparseArray
clear() - Method in class com.tangosol.util.BinaryRadixTree.BinaryLongMap
Initialize the tree to an empty state.
clear() - Method in class com.tangosol.util.CircularArrayList
Removes all of the elements from this collection (optional operation).
clear() - Method in interface com.tangosol.util.ConcurrentMap
clear() - Method in class com.tangosol.util.ConverterCollections.ConverterCollection
Removes all of the elements from this Collection.
clear() - Method in class com.tangosol.util.ConverterCollections.ConverterEntrySet
clear() - Method in class com.tangosol.util.ConverterCollections.ConverterMap
clear() - Method in class com.tangosol.util.CopyOnWriteLongArray
clear() - Method in class com.tangosol.util.DeltaSet
clear() - Method in class com.tangosol.util.InflatableCollection
clear() - Method in class com.tangosol.util.LiteMap
clear() - Method in class com.tangosol.util.LiteSet
Removes all of the elements from this Set.
clear() - Method in interface com.tangosol.util.LongArray
clear() - Method in class com.tangosol.util.MapListenerSupport
Remove all signed up listeners.
clear() - Method in class com.tangosol.util.MapSet
clear() - Method in class com.tangosol.util.NullImplementation.NullSet
clear() - Method in class com.tangosol.util.ObservableHashMap
clear() - Method in class com.tangosol.util.RestrictedCollections.RestrictedCollection
clear() - Method in class com.tangosol.util.RestrictedCollections.RestrictedEntrySet
clear() - Method in class com.tangosol.util.RestrictedCollections.RestrictedMap
clear() - Method in class com.tangosol.util.SafeHashMap
clear() - Method in class com.tangosol.util.SafeHashMap.EntrySet
clear() - Method in class com.tangosol.util.SafeHashMap.KeySet
clear() - Method in class com.tangosol.util.SafeHashMap.ValuesCollection
clear() - Method in class com.tangosol.util.SafeLinkedList
Removes all of the elements from this List.
clear() - Method in class com.tangosol.util.SafeSortedMap
Removes all mappings from this map (optional operation).
clear() - Method in class com.tangosol.util.SegmentedConcurrentMap
clear() - Method in class com.tangosol.util.SegmentedHashMap
clear() - Method in class com.tangosol.util.SegmentedHashMap.EntrySet
clear() - Method in class com.tangosol.util.SegmentedHashMap.KeySet
clear() - Method in class com.tangosol.util.SegmentedHashMap.ValuesCollection
clear() - Method in class com.tangosol.util.SimpleLongArray
clear() - Method in class com.tangosol.util.StringTable
Remove all strings from the table.
clear() - Method in class com.tangosol.util.SubList
Removes all of the elements from this list (optional operation).
clear() - Method in class com.tangosol.util.SubSet
clear() - Method in class com.tangosol.util.Tree
Remove all nodes from the tree.
clear() - Method in class com.tangosol.util.WrapperCollections.AbstractWrapperCollection
clear() - Method in class com.tangosol.util.WrapperCollections.AbstractWrapperMap
clear() - Method in class com.tangosol.util.WrapperCollections.ConcurrentWrapperCollection
clear() - Method in class com.tangosol.util.WrapperCollections.ConcurrentWrapperMap
clear() - Method in class com.tangosol.util.WrapperConcurrentMap
clear() - Method in class com.tangosol.util.WrapperObservableMap
clearBucketOffsets() - Method in class com.tangosol.io.nio.BinaryMap
Clear out all references in the array of hash buckets.
clearBucketOffsets(int) - Method in class com.tangosol.io.nio.BinaryMap
Clear out all references in the array of hash buckets starting with the specified bucket.
clearBuffer() - Method in class com.tangosol.io.nio.BinaryMap
Create one big free block in the buffer.
clearConverted() - Method in class com.tangosol.util.ConverterCollections.ConverterMapEvent
Remove any cached conversions of the key or values.
clearFreeLists() - Method in class com.tangosol.io.nio.BinaryMap
Clear out all references in the array of free lists.
clearPending() - Method in class com.tangosol.net.cache.ReadWriteBackingMap.WriteQueue
Clear the map of pending entries.
clearStoredConfiguration() - Method in class com.tangosol.coherence.servlet.management.HttpSessionManager
Removes the stored configuration which is used to check configuration consistency.
clearStoredConfiguration() - Method in interface com.tangosol.coherence.servlet.management.HttpSessionManagerMBean
clearStoredConfiguration() - Method in class com.tangosol.coherence.servlet.SessionHelper
Deprecated. Removes the storeSessd configuration.
clearValue() - Method in class com.tangosol.io.nio.BinaryMap.Block
Zero the value portion of the block.
clone() - Method in class com.tangosol.io.AbstractReadBuffer
Create a clone of this ReadBuffer object.
clone() - Method in class com.tangosol.io.AbstractWriteBuffer
Create a clone of this WriteBuffer object.
clone() - Method in class com.tangosol.io.ByteArrayReadBuffer
Create a clone of this ByteArrayReadBuffer object.
clone() - Method in class com.tangosol.io.MultiBufferWriteBuffer
clone() - Method in class com.tangosol.io.nio.ByteBufferReadBuffer
clone() - Method in class com.tangosol.io.nio.ByteBufferWriteBuffer
clone() - Method in interface com.tangosol.io.ReadBuffer
clone() - Method in interface com.tangosol.io.WriteBuffer
clone() - Method in class com.tangosol.net.partition.Ownership
Create a clone of this Ownership.
clone(Object) - Method in class com.tangosol.run.xml.ArrayAdapter
Make a clone of the passed object.
clone(Object) - Method in class com.tangosol.run.xml.CollectionAdapter
clone(Object) - Method in class com.tangosol.run.xml.MapAdapter
clone(Object) - Method in class com.tangosol.run.xml.PrimitiveArrayAdapter.BooleanArrayAdapter
clone(Object) - Method in class com.tangosol.run.xml.PrimitiveArrayAdapter.ByteArrayAdapter
clone(Object) - Method in class com.tangosol.run.xml.PrimitiveArrayAdapter.CharArrayAdapter
clone(Object) - Method in class com.tangosol.run.xml.PrimitiveArrayAdapter.DoubleArrayAdapter
clone(Object) - Method in class com.tangosol.run.xml.PrimitiveArrayAdapter.FloatArrayAdapter
clone(Object) - Method in class com.tangosol.run.xml.PrimitiveArrayAdapter.IntArrayAdapter
clone(Object) - Method in class com.tangosol.run.xml.PrimitiveArrayAdapter.LongArrayAdapter
clone(Object) - Method in class com.tangosol.run.xml.PrimitiveArrayAdapter.ShortArrayAdapter
clone(Object) - Method in class com.tangosol.run.xml.PropertyAdapter
clone(Object) - Method in class com.tangosol.run.xml.SerializableAdapter
clone() - Method in class com.tangosol.run.xml.SimpleDocument
Creates and returns a copy of this XmlDocument.
clone() - Method in class com.tangosol.run.xml.SimpleElement.AttributeMap
Creates and returns a copy of this SimpleElement.
clone() - Method in class com.tangosol.run.xml.SimpleValue
Creates and returns a copy of this SimpleValue.
clone() - Method in class com.tangosol.run.xml.XmlBean
Clone the value object.
clone() - Method in interface com.tangosol.run.xml.XmlDocument
clone() - Method in interface com.tangosol.run.xml.XmlElement
Creates and returns a copy of this XmlElement.
clone(Object) - Method in class com.tangosol.run.xml.XmlSerializableAdapter
clone() - Method in interface com.tangosol.run.xml.XmlValue
clone() - Method in class com.tangosol.util.AbstractKeyBasedMap
Returns a shallow copy of this AbstractKeyBasedMap instance; the keySet, entrySet and values collections are not cloned or copied to (shared by) the clone.
clone() - Method in class com.tangosol.util.AbstractLongArray
Make a clone of the LongArray.
clone() - Method in class com.tangosol.util.AbstractSparseArray
clone() - Method in class com.tangosol.util.AbstractSparseArray.Crawler
Make a shallow copy of the node crawler.
clone() - Method in class com.tangosol.util.AbstractSparseArray.Node
Make a shallow copy of the node and its sub-nodes.
clone() - Method in class com.tangosol.util.Binary
Create a clone of this Binary object.
clone(byte[], int, int) - Static method in class com.tangosol.util.Binary
Create a clone of the specified binary region.
clone() - Method in class com.tangosol.util.CacheCollator
Clone the caching collator.
clone() - Method in class com.tangosol.util.CircularArrayList
Returns a shallow copy of this list instance.
clone() - Method in class com.tangosol.util.CopyOnWriteLongArray
clone() - Method in class com.tangosol.util.DeltaSet
Clone the delta set.
clone() - Method in class com.tangosol.util.Dequeue
Creates a clone of the dequeue.
clone() - Method in class com.tangosol.util.filter.LimitFilter
Clone this filter.
clone() - Method in class com.tangosol.util.ImmutableArrayList
Create a clone of the ImmutableArrayList.
clone() - Method in class com.tangosol.util.LiteMap
clone() - Method in class com.tangosol.util.LiteSet
Create a clone of this Set.
clone() - Method in interface com.tangosol.util.LongArray
clone() - Method in class com.tangosol.util.MapSet
Create a clone of this MapSet.
clone() - Method in class com.tangosol.util.RecyclingLinkedList
Create a deep clone of the list.
clone() - Method in class com.tangosol.util.SafeHashMap
Create a clone of the SafeHashMap.
clone() - Method in class com.tangosol.util.SafeHashMap.Entry
Clone the Entry.
clone() - Method in class com.tangosol.util.SafeLinkedList
Create a clone of the SafeLinkedList.
clone() - Method in class com.tangosol.util.SafeLinkedList.Node
clone() - Method in class com.tangosol.util.SimpleLongArray
clone() - Method in class com.tangosol.util.SimpleMapEntry
Clone the Entry.
clone() - Method in class com.tangosol.util.StringTable
Make a new string table with a copy of the tree and a copy of the collator.
clone() - Method in class com.tangosol.util.SubSet
Clone the subset.
clone() - Method in class com.tangosol.util.Tree
Make a shallow copy of the tree and its nodes.
cloneEntryList(SafeHashMap.Entry) - Method in class com.tangosol.util.SafeHashMap
Clone an entire linked list of entries.
cloneOwnership(Ownership, int) - Static method in class com.tangosol.net.partition.SimpleAssignmentStrategy
Clone the specified ownership for the purpose of enacting a transfer of the specified storage index.
close() - Method in class com.tangosol.coherence.servlet.CacheFactoryLogHandler
close() - Method in interface com.tangosol.coherence.transaction.Connection
Close the logical connection.
close() - Method in class com.tangosol.io.AbstractReadBuffer.AbstractBufferInput
Close the InputStream and release any system resources associated with it.
close() - Method in class com.tangosol.io.AbstractWriteBuffer.AbstractBufferOutput
Close the OutputStream and release any system resources associated with it.
close() - Method in class com.tangosol.io.AsyncBinaryStore
Close the store.
close() - Method in class com.tangosol.io.Base64InputStream
Close the stream, flushing any accumulated bytes.
close() - Method in class com.tangosol.io.Base64OutputStream
close() - Method in class com.tangosol.io.bdb.BerkeleyDBBinaryStore
Close the BinaryStore.
close() - Method in class com.tangosol.io.DebugDataOutputStream
Closes this OutputStream and releases any associated system resources.
close() - Method in interface com.tangosol.io.InputStreaming
close() - Method in class com.tangosol.io.journal.AbstractJournalRM
Deprecated. use the Disposable interface
close() - Method in class com.tangosol.io.journal.BackupJournalRM
close() - Method in class com.tangosol.io.journal.JournalBinaryStore
close() - Method in class com.tangosol.io.MultiBufferWriteBuffer.MultiBufferOutput
close() - Method in class com.tangosol.io.MultiByteArrayInputStream
Close the stream.
close() - Method in class com.tangosol.io.MultiByteArrayOutputStream
close() - Method in class com.tangosol.io.nio.BinaryMap.Block
Close the Block object, flushing any pending changes, resetting its contents and recycling the object.
close() - Method in class com.tangosol.io.nio.BinaryMapStore
Deprecated. use the Disposable interface instead
close() - Method in class com.tangosol.io.nio.ByteBufferInputStream
close() - Method in class com.tangosol.io.nio.ByteBufferOutputStream
close() - Method in class com.tangosol.io.nio.MappedBufferManager
Close the underlying resources.
close() - Method in interface com.tangosol.io.OutputStreaming
close() - Method in class com.tangosol.io.pof.PofInputStream
close() - Method in class com.tangosol.io.pof.PofOutputStream
close() - Method in interface com.tangosol.io.ReadBuffer.BufferInput
close() - Method in class com.tangosol.io.Utf8Reader
Close the stream.
close() - Method in class com.tangosol.io.Utf8Writer
Close the stream, flushing it first.
close() - Method in class com.tangosol.io.WrapperBufferInput
close() - Method in class com.tangosol.io.WrapperBufferOutput
close() - Method in class com.tangosol.io.WrapperDataInputStream
close() - Method in class com.tangosol.io.WrapperDataOutputStream
close() - Method in class com.tangosol.io.WrapperInputStream
close() - Method in class com.tangosol.io.WrapperObjectInputStream
close() - Method in class com.tangosol.io.WrapperOutputStream
close() - Method in interface com.tangosol.io.WriteBuffer.BufferOutput
close() - Method in class com.tangosol.io.WriterPrintStream
Close the stream.
close() - Method in class com.tangosol.net.cache.SerializationPagedCache.PagedBinaryStore
Release underlying resources.
close() - Method in class com.tangosol.net.cache.SerializationPagedCache.WrapperBinaryStore
Used to specify that the page is no longer current.
close() - Method in class com.tangosol.net.CompressionFilter.DeflaterOutputShell
Deprecated. Close the input stream.
close() - Method in class com.tangosol.net.CompressionFilter.InflaterInputShell
close() - Method in class com.tangosol.net.DatagramPacketOutputStream
Closes this output stream and releases any system resources associated with this stream.
close() - Method in class com.tangosol.net.security.AsymmetricEncryptionFilter.IdentityInputStream
Deprecated. Close the InputStream and release any system resources associated with it.
close() - Method in class com.tangosol.net.TcpDatagramSocket.Impl
close() - Method in class com.tangosol.net.WrapperServerSocket
close() - Method in class com.tangosol.net.WrapperSocket
close() - Method in class com.tangosol.run.jca.CacheAdapter
Close the connection assosiated with this adapter.
close(long) - Method in interface com.tangosol.util.Gate
Close the gate.
close() - Method in class com.tangosol.util.NullImplementation.NullOutputStream
close() - Method in class com.tangosol.util.NullImplementation.NullWriter
close(long) - Method in class com.tangosol.util.ThreadGate
Close the gate.
close(long) - Method in class com.tangosol.util.ThreadGateLite
Close the gate.
close(long) - Method in class com.tangosol.util.WrapperReentrantGate
Close the gate.
closeDb() - Method in class com.tangosol.io.bdb.BerkeleyDBBinaryStore.DatabaseHolder
Close the Database.
closeEnvironment(boolean) - Method in class com.tangosol.io.bdb.DatabaseFactory.EnvironmentHolder
Close an Environment.
closeInbound(TcpDatagramSocket.Impl.ConnectionStatus, SocketChannel) - Method in class com.tangosol.net.TcpDatagramSocket.Impl
Close the inbound channel.
closeNested() - Method in class com.tangosol.io.pof.PofBufferReader.UserTypeReader
Notify the UserTypeReader that it is being "closed".
closeNested() - Method in class com.tangosol.io.pof.PofBufferWriter.UserTypeWriter
Notify the UserTypeWriter that it is being "closed".
closeOutbound(SocketAddress) - Method in class com.tangosol.net.TcpDatagramSocket.Impl
Close the outbound socket.
closeProcessing() - Method in class com.tangosol.net.cache.OverflowMap.Status
Finish the processing of the entry for which this Status exists and proceed to the commit phase.
closeProcessing() - Method in class com.tangosol.net.cache.SimpleOverflowMap.Status
closeSession(Session) - Method in class com.tangosol.coherence.hibernate.HibernateCacheLoader
Close a Hibernate Session.
closeStatus(OverflowMap.Status) - Method in class com.tangosol.net.cache.OverflowMap
Helper method to close a Status, processing any pending events as part of the process.
Cluster - Interface in com.tangosol.net
The Cluster interface represents a collection of services that operate in a clustered network environment.
Cluster.MemberTimeoutAction - Interface in com.tangosol.net
MemberTimeoutAction is taken by the cluster service to remove members from the cluster who have exceeded a network timeout (e.g. packet-timeout).
CLUSTER_TYPE - Static variable in interface com.tangosol.net.management.Registry
String representation of the ObjectName for the ClusterMBean.
ClusterEncryptionFilter - Class in com.tangosol.net.security
Deprecated. As of Coherence 3.7, deprecated replaced by SSL.
ClusterEncryptionFilter() - Constructor for class com.tangosol.net.security.ClusterEncryptionFilter
Deprecated.
ClusterEncryptionFilter.DemultiplexingInputStream - Class in com.tangosol.net.security
Deprecated. WrapperInputStram which chooses the appropriate wrapper based on the protocol context.
ClusterEncryptionFilter.DemultiplexingInputStream(InputStream) - Constructor for class com.tangosol.net.security.ClusterEncryptionFilter.DemultiplexingInputStream
Deprecated. Construct a DemultiplexingInputStream.
ClusterEncryptionFilter.MultiplexingOutputStream - Class in com.tangosol.net.security
Deprecated. WrapperOutputStram which chooses the appropriate wrapper based on the protocol context.
ClusterEncryptionFilter.MultiplexingOutputStream(OutputStream) - Constructor for class com.tangosol.net.security.ClusterEncryptionFilter.MultiplexingOutputStream
Deprecated. Construct a MultiplexingOutputStream.
ClusterException - Exception in com.tangosol.net
Deprecated. As of release 3.4, replaced by PortableException
ClusterException() - Constructor for exception com.tangosol.net.ClusterException
Deprecated. Constructs a ClusterException with no detail message.
ClusterException(String) - Constructor for exception com.tangosol.net.ClusterException
Deprecated. Constructs a ClusterException with the specified detail message.
ClusterException(Throwable) - Constructor for exception com.tangosol.net.ClusterException
Deprecated. Construct a ClusterException from a Throwable object.
ClusterException(String, Throwable) - Constructor for exception com.tangosol.net.ClusterException
Deprecated. Construct a ClusterException from a Throwable object and an additional description.
ClusterPermission - Class in com.tangosol.net
This class represents access to a clustered resource such as a Service or NamedCache.
ClusterPermission(String, String) - Constructor for class com.tangosol.net.ClusterPermission
Construct a ClusterPermission object.
CMP_AUTO - Static variable in class com.tangosol.util.comparator.EntryComparator
Indicates that this EntryComparator should choose the comparison style based on the underying comparator type.
CMP_ENTRY - Static variable in class com.tangosol.util.comparator.EntryComparator
Indicates that entries that implement QueryMap.Entry interface will be compared using the compareEntries() method.
CMP_KEY - Static variable in class com.tangosol.util.comparator.EntryComparator
Indicates that this EntryComparator should compare the entries' keys.
CMP_VALUE - Static variable in class com.tangosol.util.comparator.EntryComparator
Indicates that this EntryComparator should compare the entries' values.
codec() - Method in interface com.tangosol.io.pof.annotation.PortableProperty
A codec to use to short-circuit determining the type via either method return type or field type.
Codec - Interface in com.tangosol.io.pof.reflect
A Codec provides an interception point for any specific code that needs to be executed pre or post (de)serialization.
Codecs - Class in com.tangosol.io.pof.reflect
Codecs is a container for accessing default Codecs.AbstractCodec implementations.
Codecs() - Constructor for class com.tangosol.io.pof.reflect.Codecs
Codecs.AbstractCodec - Class in com.tangosol.io.pof.reflect
Abstract Codec implementations that encodes objects by simply delegating to PofWriter.writeObject(int, Object).
Codecs.AbstractCodec() - Constructor for class com.tangosol.io.pof.reflect.Codecs.AbstractCodec
Codecs.DefaultCodec - Class in com.tangosol.io.pof.reflect
Implementation of Codec that simply delegates to PofReader.readObject(int) and PofWriter.writeObject(int, Object) to deserialize and serialize an object.
Codecs.DefaultCodec() - Constructor for class com.tangosol.io.pof.reflect.Codecs.DefaultCodec
CoherenceCache - Class in com.tangosol.coherence.hibernate
Provides a cache wrapper for storing Hibernate objects in Coherence NamedCache instances.
CoherenceCache(NamedCache, Properties) - Constructor for class com.tangosol.coherence.hibernate.CoherenceCache
Construct a Hibernate cache instance.
CoherenceCacheProvider - Class in com.tangosol.coherence.hibernate
Serves as the integration point for the Coherence Cache Provider for Hibernate.
CoherenceCacheProvider() - Constructor for class com.tangosol.coherence.hibernate.CoherenceCacheProvider
CoherenceHttpSessionCollection - Interface in com.tangosol.coherence.servlet
collectEndangered(PartitionSet) - Method in class com.tangosol.net.partition.SimpleAssignmentStrategy.AnalysisContext
Return a partition set representing the subset of the specified partitions that are "endangered".
COLLECTION_EMPTY - Static variable in class com.tangosol.io.pof.PofHelper
An empty (and immutable) collection.
CollectionAdapter - Class in com.tangosol.run.xml
A CollectionAdapter supports properties whose types implement the java.util.Collection interface.
CollectionAdapter(XmlBean.BeanInfo, Class, String, String, XmlElement) - Constructor for class com.tangosol.run.xml.CollectionAdapter
Construct a CollectionAdapter.
CollectionHelper - Class in com.tangosol.util
This abstract class contains helper functions for manipulating collections and enumerations.
CollectionHelper() - Constructor for class com.tangosol.util.CollectionHelper
collectListeners(MapEvent) - Method in class com.tangosol.util.MapListenerSupport
Collect all Listeners that should be notified for a given event.
collectMembershipInfo() - Method in class com.tangosol.coherence.commonj.WorkManager
Inform all the members about this node's role (client or server) and collect the information regarding other nodes' roles
collectServiceSchemes(XmlElement) - Static method in class com.tangosol.net.DefaultConfigurableCacheFactory
Collect a map keyed by service names with values of corresponding service schemes in the specified cache configuration.
collectServiceSchemes(XmlElement, XmlElement, HashMap) - Static method in class com.tangosol.net.DefaultConfigurableCacheFactory
Collect the service-schemes referenced by the specified scheme element in the cache configuration and update the specified mapping of service names to the associated service schemes.
collectWeak(PartitionSet) - Method in class com.tangosol.net.partition.SimpleAssignmentStrategy.AnalysisContext
Return a partition set representing the subset of the specified partitions that are "weak" or "vulnerable" (as defined by the backup strength).
com.tangosol.coherence.commonj - package com.tangosol.coherence.commonj
Contains Coherence-based WorkManager implementation classes.
com.tangosol.coherence.hibernate - package com.tangosol.coherence.hibernate
Contains classes related to the Coherence Cache Provider for Hibernate.
com.tangosol.coherence.jpa - package com.tangosol.coherence.jpa
Contains classes related to the Coherence CacheStore for JPA.
com.tangosol.coherence.rest - package com.tangosol.coherence.rest
Contains classes related to the Coherence REST API.
com.tangosol.coherence.rest.io - package com.tangosol.coherence.rest.io
Contains classes related to REST marshalling.
com.tangosol.coherence.rest.server - package com.tangosol.coherence.rest.server
Contains classes related to embedded HTTP server integration.
com.tangosol.coherence.rest.util.aggregator - package com.tangosol.coherence.rest.util.aggregator
Contains classes related to REST-based aggregation.
com.tangosol.coherence.rest.util.processor - package com.tangosol.coherence.rest.util.processor
Contains classes related to REST-based entry processing.
com.tangosol.coherence.servlet - package com.tangosol.coherence.servlet
Contains classes related to the HTTP Session Replication Module.
com.tangosol.coherence.servlet.management - package com.tangosol.coherence.servlet.management
Contains Coherence*Web MBean classes.
com.tangosol.coherence.toplink - package com.tangosol.coherence.toplink
Contains classes related to the Coherence CacheStore for TopLink.
com.tangosol.coherence.transaction - package com.tangosol.coherence.transaction
Contains classes related to the Coherence Transaction Framework.
com.tangosol.coherence.transaction.exception - package com.tangosol.coherence.transaction.exception
com.tangosol.coherence.weblogic - package com.tangosol.coherence.weblogic
Contains classes related to the Coherence Cache Provider for WebLogic Portal.
com.tangosol.io - package com.tangosol.io
Contains classes providing cache persistence of serialized objects.
com.tangosol.io.bdb - package com.tangosol.io.bdb
Contains Sleepycat Berkeley DB BinaryStore implementation classes.
com.tangosol.io.journal - package com.tangosol.io.journal
Contains classes related to the journaling services.
com.tangosol.io.nio - package com.tangosol.io.nio
Contains classes related to J2SE 1.4 NIO functionality.
com.tangosol.io.pof - package com.tangosol.io.pof
Contains classes related to POF serialization and deserialization.
com.tangosol.io.pof.annotation - package com.tangosol.io.pof.annotation
POF Annotation classes
com.tangosol.io.pof.reflect - package com.tangosol.io.pof.reflect
Contains classes related to POF stream navigation and manipulation.
com.tangosol.net - package com.tangosol.net
Contains basic cluster interfaces and factories.
com.tangosol.net.cache - package com.tangosol.net.cache
Contains classes providing various caching strategies.
com.tangosol.net.events - package com.tangosol.net.events
com.tangosol.net.management - package com.tangosol.net.management
Contains classes related to the Coherence Management Framework.
com.tangosol.net.management.annotation - package com.tangosol.net.management.annotation
Contains annotations used by the Coherence Management Framework.
com.tangosol.net.partition - package com.tangosol.net.partition
Contains interfaces and classes related to partitioned services.
com.tangosol.net.proxy - package com.tangosol.net.proxy
Contains interfaces and classes related to proxy services.
com.tangosol.net.security - package com.tangosol.net.security
Contains classes related to the Coherence Security Framework.
com.tangosol.run.jca - package com.tangosol.run.jca
Contains classes providing Java 2 Connector Architecture functionality.
com.tangosol.run.xml - package com.tangosol.run.xml
Contains classes providing basic XML related functionality.
com.tangosol.util - package com.tangosol.util
Contains various generic utilities.
com.tangosol.util.aggregator - package com.tangosol.util.aggregator
Contains concrete InvocableMap.EntryAggregator implementations.
com.tangosol.util.comparator - package com.tangosol.util.comparator
Contains concrete Comparator implementations and related interfaces.
com.tangosol.util.extractor - package com.tangosol.util.extractor
Contains ValueExtractor and ValueUpdater related classes.
com.tangosol.util.filter - package com.tangosol.util.filter
Contains concrete Filter implementations and related interfaces.
com.tangosol.util.processor - package com.tangosol.util.processor
Contains concrete InvocableMap.EntryProcessor implementations.
com.tangosol.util.transformer - package com.tangosol.util.transformer
Contains concrete MapEventTransformer implementations.
commit() - Method in interface com.tangosol.coherence.transaction.Connection
Commit the active transaction.
commit() - Method in interface com.tangosol.util.TransactionMap
Commit the changes made to the TransactionMap.
commitAndMaybeInvalidate() - Method in class com.tangosol.net.cache.OverflowMap.Status
Finish the commit for the entry for which this Status exists.
commitAndMaybeInvalidate() - Method in class com.tangosol.net.cache.SimpleOverflowMap.Status
COMMITTED - Static variable in class com.tangosol.coherence.transaction.Status
The transaction has been committed.
COMMITTING - Static variable in class com.tangosol.coherence.transaction.Status
The transaction is in the process of being committed.
commitTransactionCollection(Collection, int) - Static method in class com.tangosol.net.CacheFactory
Commit the transaction represented by a collection of TransactionMap objects.
compactAll() - Method in class com.tangosol.io.nio.BinaryMap
Full linear compaction of the buffer.
compactBegin() - Method in class com.tangosol.io.nio.BinaryMap
Configure the incremental compact.
compactComplete() - Method in class com.tangosol.io.nio.BinaryMap
Complete the incremental compact.
compactEntryInfoMap(Map, Object, PortalCacheProvider.CacheImpl.EntryInfo) - Method in class com.tangosol.coherence.weblogic.PortalCacheProvider.CacheImpl
Remove the given EntryInfo from the specified Map if it is safe to do so.
compactEntryInfoMap(Map, Object, PortalCacheProvider.CacheImpl.EntryInfo) - Method in class com.tangosol.coherence.weblogic.PortalCacheProvider.ReloadableCacheImpl
compactNext() - Method in class com.tangosol.io.nio.BinaryMap
Perform an incremental compaction of the next block.
compactUntil(int) - Method in class com.tangosol.io.nio.BinaryMap
Perform an an incremental compact at the specified block.
ComparableMax - Class in com.tangosol.util.aggregator
Calculates a maximum among values extracted from a set of entries in a Map.
ComparableMax() - Constructor for class com.tangosol.util.aggregator.ComparableMax
ComparableMax(ValueExtractor) - Constructor for class com.tangosol.util.aggregator.ComparableMax
Construct a ComparableMax aggregator.
ComparableMax(ValueExtractor, Comparator) - Constructor for class com.tangosol.util.aggregator.ComparableMax
ComparableMax(String) - Constructor for class com.tangosol.util.aggregator.ComparableMax
ComparableMin - Class in com.tangosol.util.aggregator
Calculates a minimum among values extracted from a set of entries in a Map.
ComparableMin() - Constructor for class com.tangosol.util.aggregator.ComparableMin
ComparableMin(ValueExtractor) - Constructor for class com.tangosol.util.aggregator.ComparableMin
Construct a ComparableMin aggregator.
ComparableMin(ValueExtractor, Comparator) - Constructor for class com.tangosol.util.aggregator.ComparableMin
ComparableMin(String) - Constructor for class com.tangosol.util.aggregator.ComparableMin
comparator() - Method in class com.tangosol.util.ConverterCollections.ConverterSortedMap
Returns the comparator associated with this sorted map, or null if it uses its keys' natural ordering.
comparator() - Method in class com.tangosol.util.ConverterCollections.ConverterSortedSet
Returns the comparator associated with this sorted set, or null if it uses its elements' natural ordering.
comparator() - Method in class com.tangosol.util.ImmutableArrayList
comparator() - Method in class com.tangosol.util.RestrictedCollections.RestrictedSortedMap
comparator() - Method in class com.tangosol.util.RestrictedCollections.RestrictedSortedSet
comparator() - Method in class com.tangosol.util.SafeSortedMap
comparator() - Method in class com.tangosol.util.SafeSortedMap.ViewMap
comparator() - Method in class com.tangosol.util.WrapperCollections.AbstractWrapperSortedSet
compare(Object, Object) - Method in class com.tangosol.net.cache.SimpleOverflowMap.HashcodeComparator
compare(InetAddress, InetAddress) - Static method in class com.tangosol.net.InetAddressHelper
Compare two InetAddresses for ordering purposes.
compare(Object, Object) - Method in class com.tangosol.net.partition.SimpleAssignmentStrategy.AnalysisContext.LoadComparator
Compares its two arguments for order.
compare(Object, Object) - Method in class com.tangosol.net.partition.SimpleAssignmentStrategy.AnalysisContext.StrengthComparator
compare(String, String) - Method in class com.tangosol.util.CacheCollator
Compares the source string to the target string according to the collation rules for this Collator.
compare(Object, Object) - Method in class com.tangosol.util.comparator.ChainedComparator
compare(Object, Object) - Method in class com.tangosol.util.comparator.EntryComparator
Compares two arguments for order.
compare(Object, Object) - Method in class com.tangosol.util.comparator.ExtractorComparator
Compares extracted values (by specified ValueExtractor) of given arguments for order.
compare(Object, Object) - Method in class com.tangosol.util.comparator.InverseComparator
Use the wrapped Comparator to compare the two arguments for order and negate the result.
compare(Object, Object) - Method in class com.tangosol.util.comparator.SafeComparator
compare(Object, Object) - Method in class com.tangosol.util.extractor.AbstractExtractor
compareEntries(QueryMap.Entry, QueryMap.Entry) - Method in class com.tangosol.util.comparator.ChainedComparator
Compare two entries based on the rules specified by Comparator.
compareEntries(QueryMap.Entry, QueryMap.Entry) - Method in class com.tangosol.util.comparator.InverseComparator
Compare two entries using the underlying comparator and negate the result.
compareEntries(QueryMap.Entry, QueryMap.Entry) - Method in interface com.tangosol.util.comparator.QueryMapComparator
compareEntries(QueryMap.Entry, QueryMap.Entry) - Method in class com.tangosol.util.comparator.SafeComparator
Compare two entries using the underlying comparator.
compareEntries(QueryMap.Entry, QueryMap.Entry) - Method in class com.tangosol.util.extractor.AbstractExtractor
compareEntries(QueryMap.Entry, QueryMap.Entry) - Method in class com.tangosol.util.extractor.MultiExtractor
compareKeyList(ObjectName, ObjectName) - Static method in class com.tangosol.net.management.MBeanHelper
Compare two global MBean names forcing numeric comparison of the node ID while using string comparison on all other key properties.
compareSafe(Comparator, Object, Object) - Static method in class com.tangosol.util.comparator.SafeComparator
compareTo(Object) - Method in class com.tangosol.coherence.commonj.WorkManager.WorkHolder
Compare this WorkItem with the specified object for order.
compareTo(Object) - Method in class com.tangosol.util.Binary
Compares this object with the specified object for order.
compareTo(Object) - Method in class com.tangosol.util.filter.ArrayFilter.WeightedFilter
Compares this WeightedFilter with the specified WeightedFilter for order.
compareTo(Object) - Method in class com.tangosol.util.ImmutableArrayList
Compare this ImmutableArrayList with the passed Object to determine order.
compareTo(Object) - Method in class com.tangosol.util.UID
compareTo(Object) - Method in class com.tangosol.util.UUID
ComparisonFilter - Class in com.tangosol.util.filter
Filter which compares the result of a method invocation with a value.
ComparisonFilter() - Constructor for class com.tangosol.util.filter.ComparisonFilter
ComparisonFilter(ValueExtractor, Object) - Constructor for class com.tangosol.util.filter.ComparisonFilter
Construct a ComparisonFilter.
ComparisonFilter(String, Object) - Constructor for class com.tangosol.util.filter.ComparisonFilter
ComparisonValueExtractor - Class in com.tangosol.util.extractor
A synthetic ValueExtractor that returns a result of comparison between two values extracted from the same target.
ComparisonValueExtractor() - Constructor for class com.tangosol.util.extractor.ComparisonValueExtractor
ComparisonValueExtractor(String, String) - Constructor for class com.tangosol.util.extractor.ComparisonValueExtractor
Constuct a ComparisonValueExtractor based on two method names.
ComparisonValueExtractor(String, String, Comparator) - Constructor for class com.tangosol.util.extractor.ComparisonValueExtractor
Constuct a ComparisonValueExtractor based on two method names and a Comparator object.
ComparisonValueExtractor(ValueExtractor, ValueExtractor) - Constructor for class com.tangosol.util.extractor.ComparisonValueExtractor
Constuct a ComparisonValueExtractor based on two specified extractors.
ComparisonValueExtractor(ValueExtractor, ValueExtractor, Comparator) - Constructor for class com.tangosol.util.extractor.ComparisonValueExtractor
Constuct a ComparisonValueExtractor based on two specified extractors and a Comparator object.
complete(int) - Method in class com.tangosol.io.pof.PofBufferReader
Register the completion of the parsing of a value.
complete(int) - Method in class com.tangosol.io.pof.PofBufferReader.UserTypeReader
complete(Object) - Method in class com.tangosol.net.cache.ReadWriteBackingMap.ReadLatch
Complete the load operation.
ComplexPofValue - Class in com.tangosol.io.pof.reflect
An abstract base class for complex POF types, such as collections, arrays, maps, and user types.
ComplexPofValue(PofValue, ReadBuffer, PofContext, int, int, int) - Constructor for class com.tangosol.io.pof.reflect.ComplexPofValue
Construct a PofValue instance wrapping the supplied buffer.
CompositeAddressProvider - Class in com.tangosol.net
CompositeAddressProvider is a composite of one or more AddressProviders or addresses that also implements the Set interface.
CompositeAddressProvider() - Constructor for class com.tangosol.net.CompositeAddressProvider
Default constructor.
CompositeAddressProvider(AddressProvider) - Constructor for class com.tangosol.net.CompositeAddressProvider
Construct a ComposititeAddressProvider from the specified AddressProvider.
CompositeAddressProvider.AddressIterator - Class in com.tangosol.net
An Iterator over the addresses in this AddressProvider.
CompositeAddressProvider.AddressIterator(List) - Constructor for class com.tangosol.net.CompositeAddressProvider.AddressIterator
CompositeAddressProvider.SingleProvider - Class in com.tangosol.net
AddressProvider wrapper for a single address dynamically added to this AddressSet.
CompositeAddressProvider.SingleProvider(InetSocketAddress) - Constructor for class com.tangosol.net.CompositeAddressProvider.SingleProvider
Constructor
CompositeAggregator - Class in com.tangosol.util.aggregator
CompositeAggregator provides an ability to execute a collection of aggregators against the same subset of the entries in an InvocableMap, resulting in a list of corresponding aggregation results.
CompositeAggregator() - Constructor for class com.tangosol.util.aggregator.CompositeAggregator
CompositeAggregator(InvocableMap.EntryAggregator[]) - Constructor for class com.tangosol.util.aggregator.CompositeAggregator
Construct a CompositeAggregator based on a specified EntryAggregator array.
CompositeAggregator.Parallel - Class in com.tangosol.util.aggregator
Parallel implementation of the CompositeAggregator.
CompositeAggregator.Parallel() - Constructor for class com.tangosol.util.aggregator.CompositeAggregator.Parallel
CompositeAggregator.Parallel(InvocableMap.ParallelAwareAggregator[]) - Constructor for class com.tangosol.util.aggregator.CompositeAggregator.Parallel
Construct a CompositeParallelAggregator based on a specified EntryAggregator array.
CompositeKey - Class in com.tangosol.util
Key class that consists of a primary and secondary component.
CompositeKey() - Constructor for class com.tangosol.util.CompositeKey
CompositeKey(Object, Object) - Constructor for class com.tangosol.util.CompositeKey
Create a new CompositeKey that consists of the given primary and secondary components.
CompositeProcessor - Class in com.tangosol.util.processor
The CompositeProcessor represents a collection of entry processors that are invoked sequentially against the same Entry.
CompositeProcessor() - Constructor for class com.tangosol.util.processor.CompositeProcessor
CompositeProcessor(InvocableMap.EntryProcessor[]) - Constructor for class com.tangosol.util.processor.CompositeProcessor
Construct a CompositeProcessor for the specified array of individual entry processors.
CompositeUpdater - Class in com.tangosol.util.extractor
A ValueUpdater implementation based on an extractor-updater pair that could also be used as a ValueManipulator.
CompositeUpdater() - Constructor for class com.tangosol.util.extractor.CompositeUpdater
CompositeUpdater(ValueExtractor, ValueUpdater) - Constructor for class com.tangosol.util.extractor.CompositeUpdater
Construct a CompositeUpdater based on the specified extractor and updater.
CompositeUpdater(String) - Constructor for class com.tangosol.util.extractor.CompositeUpdater
Construct a CompositeUpdater for a specified method name sequence.
CompressionFilter - Class in com.tangosol.net
CompressionFilter() - Constructor for class com.tangosol.net.CompressionFilter
Deprecated.
CompressionFilter.DeflaterOutputShell - Class in com.tangosol.net
Deprecated. DeflaterOutputShell enforces the "end" call for the corresponding Deflater object.
CompressionFilter.DeflaterOutputShell(OutputStream, Deflater) - Constructor for class com.tangosol.net.CompressionFilter.DeflaterOutputShell
Deprecated. Create a new input stream with the specified decompressor.
CompressionFilter.DeflaterOutputShell(OutputStream, Deflater, int) - Constructor for class com.tangosol.net.CompressionFilter.DeflaterOutputShell
Deprecated. Create a new input stream with the specified decompressor and buffer size.
CompressionFilter.InflaterInputShell - Class in com.tangosol.net
Deprecated. InflaterInputShell enforces the "end" call for the corresponding Inflater object.
CompressionFilter.InflaterInputShell(InputStream, Inflater) - Constructor for class com.tangosol.net.CompressionFilter.InflaterInputShell
CompressionFilter.InflaterInputShell(InputStream, Inflater, int) - Constructor for class com.tangosol.net.CompressionFilter.InflaterInputShell
computeProbabilityThresholds(int, int) - Static method in class com.tangosol.util.SafeSortedMap
Compute and return an array, indexed by level, of the probability thresholds used to determine what level an entry should be indexed to.
computeTmpDir() - Method in class com.tangosol.io.bdb.DatabaseFactory.EnvironmentHolder
Compute the system's temp directory.
concat(Binary) - Method in class com.tangosol.util.Binary
Concatenate the passed Binary onto this Binary.
CONCUR_EXTERNAL - Static variable in class com.tangosol.run.jca.CacheAdapter
Same as TransactionMap.CONCUR_EXTERNAL
CONCUR_EXTERNAL - Static variable in interface com.tangosol.util.TransactionMap
External concurrency.
CONCUR_OPTIMISTIC - Static variable in class com.tangosol.run.jca.CacheAdapter
Same as TransactionMap.CONCUR_OPTIMISTIC
CONCUR_OPTIMISTIC - Static variable in interface com.tangosol.util.TransactionMap
Optimistic concurrency.
CONCUR_PESSIMISTIC - Static variable in class com.tangosol.run.jca.CacheAdapter
Same as TransactionMap.CONCUR_PESSIMISTIC
CONCUR_PESSIMISTIC - Static variable in interface com.tangosol.util.TransactionMap
Pessimistic concurrency.
ConcurrentMap - Interface in com.tangosol.util
Map with additional concurrency features.
ConditionalExtractor - Class in com.tangosol.util.extractor
An IndexAwareExtractor implementation that is only used to create a ConditionalIndex.
ConditionalExtractor() - Constructor for class com.tangosol.util.extractor.ConditionalExtractor
Construct the ConditionalExtractor.
ConditionalExtractor(Filter, ValueExtractor, boolean) - Constructor for class com.tangosol.util.extractor.ConditionalExtractor
ConditionalIndex - Class in com.tangosol.util
ConditionalIndex is a MapIndex implemenation that uses an associated filter to evaluate whether or not an entry should be indexed.
ConditionalIndex(Filter, ValueExtractor, boolean, Comparator, boolean, BackingMapContext) - Constructor for class com.tangosol.util.ConditionalIndex
Construct a ConditionalIndex.
ConditionalProcessor - Class in com.tangosol.util.processor
Conditional entry processor represents a processor that is invoked conditionally based on the result of an entry evaluation.
ConditionalProcessor() - Constructor for class com.tangosol.util.processor.ConditionalProcessor
Default constructor (necessary for the ExternalizableLite interface).
ConditionalProcessor(Filter, InvocableMap.EntryProcessor) - Constructor for class com.tangosol.util.processor.ConditionalProcessor
Construct a ConditionalProcessor for the specified filter and the processor.
ConditionalPut - Class in com.tangosol.util.processor
ConditionalPut is an EntryProcessor that performs an Entry.setValue operation if the specified condition is satisfied.
ConditionalPut() - Constructor for class com.tangosol.util.processor.ConditionalPut
ConditionalPut(Filter, Object) - Constructor for class com.tangosol.util.processor.ConditionalPut
Construct a ConditionalPut that updates an entry with a new value if and only if the filter applied to the entry evaluates to true.
ConditionalPut(Filter, Object, boolean) - Constructor for class com.tangosol.util.processor.ConditionalPut
ConditionalPutAll - Class in com.tangosol.util.processor
ConditionalPutAll is an EntryProcessor that performs a Entry.setValue operation for multiple entries that satisfy the specified condition.
ConditionalPutAll() - Constructor for class com.tangosol.util.processor.ConditionalPutAll
ConditionalPutAll(Filter, Map) - Constructor for class com.tangosol.util.processor.ConditionalPutAll
Construct a ConditionalPutAll processor that updates an entry with a new value if and only if the filter applied to the entry evaluates to true.
ConditionalRemove - Class in com.tangosol.util.processor
ConditionalRemove is an EntryProcessor that performs an Entry.remove operation if the specified condition is satisfied.
ConditionalRemove() - Constructor for class com.tangosol.util.processor.ConditionalRemove
ConditionalRemove(Filter) - Constructor for class com.tangosol.util.processor.ConditionalRemove
Construct a ConditionalRemove processor that removes an InvocableMap entry if and only if the filter applied to the entry evaluates to true.
ConditionalRemove(Filter, boolean) - Constructor for class com.tangosol.util.processor.ConditionalRemove
ConfigurableAddressProvider - Class in com.tangosol.net
ConfigurableAddressProvider is an implementation of the AddressProvider interface based on a static list of addresses configured in an XML element that contains one or more items in the following format: <socket-address>   <address>...
ConfigurableAddressProvider(XmlElement) - Constructor for class com.tangosol.net.ConfigurableAddressProvider
Construct an instance of ConfigurableAddressProvider based on the specified XML element.
ConfigurableAddressProvider(XmlElement, boolean) - Constructor for class com.tangosol.net.ConfigurableAddressProvider
ConfigurableAddressProvider.AddressHolder - Class in com.tangosol.net
A stateful holder for an obtaining an InetSocketAddress object.
ConfigurableAddressProvider.AddressHolder(String, int) - Constructor for class com.tangosol.net.ConfigurableAddressProvider.AddressHolder
Construct an AddressHolder for the specified host and port.
ConfigurableCacheFactory - Interface in com.tangosol.net
An interface for XML driven cache factory.
ConfigurableCacheMap - Interface in com.tangosol.net.cache
An extension to the CacheMap interface that supports runtime configuration and monitoring of various caching properties.
ConfigurableCacheMap.Entry - Interface in com.tangosol.net.cache
A cache Entry carries information additional to the base Map Entry in order to support eviction and expiry.
ConfigurableCacheMap.EvictionPolicy - Interface in com.tangosol.net.cache
An eviction policy is an object that the cache provides with access information, and when requested, the eviction policy selects and evicts entries from the cache.
ConfigurableCacheMap.UnitCalculator - Interface in com.tangosol.net.cache
A unit calculator is an object that can calculate the cost of caching an object.
ConfigurableLocalAddressProvider - Class in com.tangosol.net
ConfiguableLocalAddressProvider is an AddressProvider which is only capable of return local addresses.
ConfigurableLocalAddressProvider(XmlElement) - Constructor for class com.tangosol.net.ConfigurableLocalAddressProvider
Construct an instance of ConfigurableLocalAddressProvider based on the specified XML element.
ConfigurableLocalAddressProvider(XmlElement, boolean) - Constructor for class com.tangosol.net.ConfigurableLocalAddressProvider
ConfigurablePofContext - Class in com.tangosol.io.pof
This class implements the PofContext interface using information provided in a configuration file (or in a passed XML configuration).
ConfigurablePofContext() - Constructor for class com.tangosol.io.pof.ConfigurablePofContext
ConfigurablePofContext(String) - Constructor for class com.tangosol.io.pof.ConfigurablePofContext
Create a ConfigurablePofContext that will load configuration information from the specified locator.
ConfigurablePofContext(XmlElement) - Constructor for class com.tangosol.io.pof.ConfigurablePofContext
Create a ConfigurablePofContext that will use the passed configuration information.
ConfigurablePofContext.PofConfig - Class in com.tangosol.io.pof
The information related to the configuration of a particular PofContext for a specific URI and ClassLoader.
ConfigurablePofContext.PofConfig() - Constructor for class com.tangosol.io.pof.ConfigurablePofContext.PofConfig
ConfigurableQuorumPolicy - Class in com.tangosol.net
ConfigurableQuorumPolicy provides a Quorum-based ActionPolicy for services based on the cluster-configuration.
ConfigurableQuorumPolicy() - Constructor for class com.tangosol.net.ConfigurableQuorumPolicy
Create a ConfigurableQuorumPolicy.
ConfigurableQuorumPolicy.ClusterQuorumPolicy - Class in com.tangosol.net
ClusterQuorumPolicy defines an action policy that is applicable to the cluster.
ConfigurableQuorumPolicy.ClusterQuorumPolicy(Map) - Constructor for class com.tangosol.net.ConfigurableQuorumPolicy.ClusterQuorumPolicy
Construct a ClusterQuorumPolicy with the specified quorum map.
ConfigurableQuorumPolicy.MembershipQuorumPolicy - Class in com.tangosol.net
MembershipQuorumPolicy is a quorum policy that is stateless and based solely on service membership sizes.
ConfigurableQuorumPolicy.MembershipQuorumPolicy() - Constructor for class com.tangosol.net.ConfigurableQuorumPolicy.MembershipQuorumPolicy
Create a MembershipQuorumPolicy.
ConfigurableQuorumPolicy.MembershipQuorumPolicy.QuorumListener - Class in com.tangosol.net
QuorumListener is used to subscribe the quorum policy to receive service membership events.
ConfigurableQuorumPolicy.MembershipQuorumPolicy.QuorumListener() - Constructor for class com.tangosol.net.ConfigurableQuorumPolicy.MembershipQuorumPolicy.QuorumListener
ConfigurableQuorumPolicy.MembershipQuorumPolicy.QuorumRule - Class in com.tangosol.net
A quorum rule defines a set of allowable actions beyond the rule's threshold size.
ConfigurableQuorumPolicy.MembershipQuorumPolicy.QuorumRule(int, int) - Constructor for class com.tangosol.net.ConfigurableQuorumPolicy.MembershipQuorumPolicy.QuorumRule
Construct a state with the specified threshold and numeric representation.
ConfigurableQuorumPolicy.PartitionedCacheQuorumPolicy - Class in com.tangosol.net
PartitionedCacheQuorumPolicy defines a configurable quorum policy that is applicable to a DistributedCacheService.
ConfigurableQuorumPolicy.PartitionedCacheQuorumPolicy(ConfigurableQuorumPolicy.MembershipQuorumPolicy.QuorumRule[]) - Constructor for class com.tangosol.net.ConfigurableQuorumPolicy.PartitionedCacheQuorumPolicy
Construct a PartitionedCacheQuorumPolicy with the specified rule.
ConfigurableQuorumPolicy.ProxyQuorumPolicy - Class in com.tangosol.net
ProxyQuorumPolicy defines a configurable quorum policy that is applicable to a proxy service.
ConfigurableQuorumPolicy.ProxyQuorumPolicy(ConfigurableQuorumPolicy.MembershipQuorumPolicy.QuorumRule[]) - Constructor for class com.tangosol.net.ConfigurableQuorumPolicy.ProxyQuorumPolicy
Construct a ProxyQuorumPolicy with the specified rule.
ConfigurableQuorumPolicy.WrapperQuorumPolicy - Class in com.tangosol.net
WrapperQuorumPolicy is a ConfigurableQuorumPolicy that wraps an arbitrary ActionPolicy instance.
ConfigurableQuorumPolicy.WrapperQuorumPolicy(ActionPolicy) - Constructor for class com.tangosol.net.ConfigurableQuorumPolicy.WrapperQuorumPolicy
Create a WrapperQuorumPolicy around the specified ActionPolicy, instantiated by the specified configuration.
ConfigurableSerializerFactory - Class in com.tangosol.io
A SerializerFactory implementation that creates instances of a Serializer class configured using an XmlElement of the following structure: <!
ConfigurableSerializerFactory() - Constructor for class com.tangosol.io.ConfigurableSerializerFactory
ConfigurationImpl - Class in com.tangosol.coherence.servlet
Deprecated. In releases following 3.6 customization will be declarative.
ConfigurationImpl() - Constructor for class com.tangosol.coherence.servlet.ConfigurationImpl
Deprecated.
configure(XmlElement, SessionHelper) - Method in class com.tangosol.coherence.servlet.AbstractHttpSessionCollection
Deprecated.
configure(XmlElement, SessionHelper) - Method in interface com.tangosol.coherence.servlet.CoherenceHttpSessionCollection
configure(int, int) - Method in class com.tangosol.coherence.servlet.SessionHelper
Deprecated. Called immediately after construction.
configure(XmlElement, SessionHelper) - Method in class com.tangosol.coherence.servlet.SplitHttpSessionCollection
Deprecated.
configure(BerkeleyDBBinaryStoreManager) - Method in class com.tangosol.io.bdb.DatabaseFactory.EnvironmentHolder
Configure the new Environment.
configure(XmlElement) - Method in class com.tangosol.io.journal.AbstractJournalRM
Configure the controllable service.
configure(XmlElement) - Method in class com.tangosol.io.journal.FlashJournalRM
The Flash Journal Resource Manager supports the following additional configuration options above the configuration options for AbstractJournalRM.
configure(XmlElement) - Method in class com.tangosol.io.journal.RamJournalRM
configure(XmlElement) - Method in class com.tangosol.net.ConfigurableAddressProvider
Configure this ConfigurableAddressProvider based on the specified XML.
configure(ConfigurableQuorumPolicy.MembershipQuorumPolicy.QuorumRule[]) - Method in class com.tangosol.net.ConfigurableQuorumPolicy.MembershipQuorumPolicy
Configure and initialize this policy with the specified quorum rules.
configure(TcpDatagramSocket) - Method in class com.tangosol.net.TcpSocketProvider
Configure the socket.
configure(XmlElement) - Method in class com.tangosol.net.WrapperService
configure(XmlElement) - Method in interface com.tangosol.util.Controllable
configureBackingMap(DefaultConfigurableCacheFactory.CacheInfo, XmlElement, BackingMapManagerContext, ClassLoader, Map) - Method in class com.tangosol.net.DefaultConfigurableCacheFactory
Configures a backing map according to the scheme.
configureCache(DefaultConfigurableCacheFactory.CacheInfo, XmlElement, ClassLoader) - Method in class com.tangosol.net.DefaultConfigurableCacheFactory
Ensures a cache for given scheme.
configureCacheStore(ReadWriteBackingMap.StoreWrapper, boolean) - Method in class com.tangosol.net.cache.ReadWriteBackingMap
Set up the StoreWrapper that this backing map will use.
CONFIGURED - Static variable in class com.tangosol.util.SimpleMapIndex.IndexCalculator.CalculatorState
configureEviction(int, ConfigurableCacheMap.EvictionPolicy) - Method in class com.tangosol.net.cache.OldCache
Deprecated. Configure the eviction type and policy.
configureFile(File) - Method in class com.tangosol.io.nio.MappedBufferManager
Configure the buffer manager based on the passed file, which may be null to imply a default temp file, a directory to imply that a file be created in that directory, or it may be the temp file itself.
configureInternalCache(ObservableMap) - Method in class com.tangosol.net.cache.ReadWriteBackingMap
Configure the internal cache that this backing map uses to store its "in-memory" data.
configureJaxbMarshaller(JSONMarshaller) - Method in class com.tangosol.coherence.rest.io.JsonJaxbMarshaller
Configure a JAXB marshaller.
configureJaxbMarshaller(Marshaller) - Method in class com.tangosol.coherence.rest.io.XmlJaxbMarshaller
configureJaxbUnmarshaller(JSONUnmarshaller) - Method in class com.tangosol.coherence.rest.io.JsonJaxbMarshaller
Configure a JAXB unmarshaller.
configureJaxbUnmarshaller(Unmarshaller) - Method in class com.tangosol.coherence.rest.io.XmlJaxbMarshaller
configureLogger() - Method in class com.tangosol.coherence.servlet.SessionHelper
Deprecated.
configureObjectMapper(ObjectMapper) - Method in class com.tangosol.coherence.rest.io.JsonJacksonMarshaller
Configure a Jackson ObjectMapper.
configureReadThread(double) - Method in class com.tangosol.net.cache.ReadWriteBackingMap
Set up the optional refresh-ahead thread and queue that this backing map will use.
configureScope(String, ClassLoader, XmlElement, ConfigurableCacheFactory) - Method in class com.tangosol.net.ScopedCacheFactoryBuilder
For a given cache configuration URI and ClassLoader, configure the scope name for the associated ConfigurableCacheFactory.
configureSynchronization(boolean) - Method in class com.tangosol.net.cache.ContinuousQueryCache
Set up the listeners that keep the ContinuousQueryCache up-to-date.
configureUnitCalculator(int, ConfigurableCacheMap.UnitCalculator) - Method in class com.tangosol.net.cache.OldCache
Deprecated. Configure the unit calculator type and implementation.
configureUnitCalculator(XmlElement, ConfigurableCacheMap, DefaultConfigurableCacheFactory.CacheInfo, BackingMapManagerContext, ClassLoader) - Method in class com.tangosol.net.DefaultConfigurableCacheFactory
Configure a UnitCalculator for the specified ConfigurableCacheMap.
configureWorker(Daemon.DaemonWorker) - Method in class com.tangosol.util.Daemon
Configure a worker to use as a daemon.
configureWriteThread(int) - Method in class com.tangosol.net.cache.ReadWriteBackingMap
Set up the optional write-behind thread and queue that this backing map will use.
congestionCheck(int) - Method in class com.tangosol.io.journal.FlashJournalRM.JournalFile
Check if a change to the backlog causes a change to the congestion state.
congestionDelay() - Method in class com.tangosol.io.journal.FlashJournalRM.JournalFile
Wait until write congestion subsides.
CONNECT - Static variable in interface com.tangosol.net.ProxyService.ProxyAction
Singleton action for accepting a client connection.
connect(SocketAddress) - Method in class com.tangosol.net.WrapperSocket
connect(SocketAddress, int) - Method in class com.tangosol.net.WrapperSocket
connect(SocketAddress) - Method in class com.tangosol.net.WrapperSocketChannel
connect(String, String, String) - Method in class com.tangosol.run.jca.CacheAdapter
Connect the adapter to the specified clustered service.
connect(String, String, String, String) - Method in class com.tangosol.run.jca.CacheAdapter
Connection - Interface in com.tangosol.coherence.transaction
Represents a logical connection to a Coherence data grid.
CONNECTION_MANAGER_TYPE - Static variable in interface com.tangosol.net.management.Registry
String representing the "type" part of ObjectName for the ConnectionManagerMBean.
CONNECTION_TYPE - Static variable in interface com.tangosol.net.management.Registry
String representing the "type" part of ObjectName for the ConnectionMBean.
ConnectionClosedException - Exception in com.tangosol.coherence.transaction.exception
Indicates that an attempt was made to use a closed Connection.
ConnectionClosedException(String) - Constructor for exception com.tangosol.coherence.transaction.exception.ConnectionClosedException
Create a new ConnectionClosedException.
ConnectionFactory - Interface in com.tangosol.coherence.transaction
A factory for connections to a Coherence data grid.
ConnectionFactory.ConnectionSpec - Interface in com.tangosol.coherence.transaction
The connection spec is used to pass connection properties to connection factory during a connection request.
ConnectionSpecImpl - Class in com.tangosol.coherence.transaction
The connection spec implementation used to pass the connection info to the connection request on the connection factory.
ConnectionSpecImpl() - Constructor for class com.tangosol.coherence.transaction.ConnectionSpecImpl
Constructor
ConnectionSpecImpl(String) - Constructor for class com.tangosol.coherence.transaction.ConnectionSpecImpl
Constructor
contains(Object) - Method in class com.tangosol.io.nio.BinaryMap.EntrySet
Returns true if this collection contains the specified element.
contains(Object) - Method in class com.tangosol.io.nio.BinaryMap.KeySet
Determine if a particular key is present in the Set.
contains(Object) - Method in class com.tangosol.net.cache.OverflowMap.InternalKeySet
contains(Object) - Method in class com.tangosol.net.cache.ReadWriteBackingMap.EntrySet
contains(Object) - Method in class com.tangosol.net.cache.ReadWriteBackingMap.KeySet
contains(int) - Method in class com.tangosol.net.ConfigurableQuorumPolicy.MembershipQuorumPolicy.QuorumRule
Return true if the current rule contains the specified action mask.
contains(int) - Method in class com.tangosol.net.partition.PartitionSet
Check whether or not the specified partition belongs to the set.
contains(PartitionSet) - Method in class com.tangosol.net.partition.PartitionSet
Check whether or not the specified partition set belongs to this set.
contains(Object) - Method in class com.tangosol.util.AbstractKeyBasedMap.EntrySet
contains(Object) - Method in class com.tangosol.util.AbstractKeyBasedMap.KeySet
contains(Object) - Method in class com.tangosol.util.AbstractKeyBasedMap.ValuesCollection
contains(Object) - Method in class com.tangosol.util.AbstractLongArray
Determine if the LongArray contains the specified element.
contains(Object) - Method in class com.tangosol.util.ChainedMap.EntrySet
contains(Object) - Method in class com.tangosol.util.CircularArrayList
contains(Object) - Method in class com.tangosol.util.ConverterCollections.ConverterCollection
Returns true if this Collection contains the specified element.
contains(Object) - Method in class com.tangosol.util.ConverterCollections.ConverterEntrySet
contains(Object) - Method in class com.tangosol.util.CopyOnWriteLongArray
contains(Object) - Method in class com.tangosol.util.DeltaSet
contains(Object) - Method in class com.tangosol.util.ImmutableArrayList
Returns true if this List contains the specified element.
contains(Object) - Method in class com.tangosol.util.ImmutableMultiList
contains(Object) - Method in class com.tangosol.util.InflatableCollection
contains(EventListener) - Method in class com.tangosol.util.Listeners
Check if a listener is in the list of listeners.
contains(Object) - Method in class com.tangosol.util.LiteMap.EntrySet
contains(Object) - Method in class com.tangosol.util.LiteSet
Returns true if this Set contains the specified element.
contains(Object) - Method in interface com.tangosol.util.LongArray
contains(Object) - Method in class com.tangosol.util.MapSet
contains(Object) - Method in class com.tangosol.util.NullImplementation.NullSet
contains(Object) - Method in class com.tangosol.util.RestrictedCollections.RestrictedCollection
contains(Object) - Method in class com.tangosol.util.RestrictedCollections.RestrictedEntrySet
contains(Object) - Method in class com.tangosol.util.SafeHashMap.EntrySet
contains(Object) - Method in class com.tangosol.util.SafeHashMap.KeySet
contains(Object) - Method in class com.tangosol.util.SafeLinkedList
contains(Object) - Method in class com.tangosol.util.SegmentedHashMap.EntrySet
contains(Object) - Method in class com.tangosol.util.SegmentedHashMap.KeySet
contains(Object) - Method in class com.tangosol.util.SimpleLongArray
contains(String) - Method in class com.tangosol.util.StringTable
Determine if the passed string is in the table.
contains(Object) - Method in class com.tangosol.util.SubList
Returns true if this list contains the specified element.
contains(Object) - Method in class com.tangosol.util.SubSet
contains(Comparable) - Method in class com.tangosol.util.Tree
Determine if the passed key is in the tree.
contains(Object) - Method in class com.tangosol.util.WrapperCollections.AbstractWrapperCollection
contains(Object) - Method in class com.tangosol.util.WrapperCollections.ConcurrentWrapperCollection
containsAll(Collection) - Method in class com.tangosol.util.ConverterCollections.ConverterCollection
Returns true if this Collection contains all of the elements in the specified Collection.
containsAll(Collection) - Method in class com.tangosol.util.ConverterCollections.ConverterEntrySet
containsAll(Collection) - Method in class com.tangosol.util.LiteSet
Returns true if this Set contains all of the elements in the specified Collection.
containsAll(Collection) - Method in class com.tangosol.util.MapSet
containsAll(Collection) - Method in class com.tangosol.util.RestrictedCollections.RestrictedCollection
containsAll(Collection) - Method in class com.tangosol.util.RestrictedCollections.RestrictedEntrySet
containsAll(Collection) - Method in class com.tangosol.util.SafeLinkedList
Returns true if this List contains all of the elements of the specified collection.
containsAll(Collection) - Method in class com.tangosol.util.SubList
Returns true if this list contains all of the elements of the specified collection.
containsAll(Collection) - Method in class com.tangosol.util.SubSet
Returns true if this collection contains all of the elements in the specified collection.
containsAll(Collection) - Method in class com.tangosol.util.WrapperCollections.AbstractWrapperCollection
containsAll(Collection) - Method in class com.tangosol.util.WrapperCollections.ConcurrentWrapperCollection
ContainsAllFilter - Class in com.tangosol.util.filter
Filter which tests a Collection or Object array value returned from a method invocation for containment of all values in a Set.
ContainsAllFilter() - Constructor for class com.tangosol.util.filter.ContainsAllFilter
ContainsAllFilter(ValueExtractor, Set) - Constructor for class com.tangosol.util.filter.ContainsAllFilter
Construct an ContainsAllFilter for testing containment of the given Set of values.
ContainsAllFilter(String, Set) - Constructor for class com.tangosol.util.filter.ContainsAllFilter
ContainsAnyFilter - Class in com.tangosol.util.filter
Filter which tests a Collection or Object array value returned from a method invocation for containment of any value in a Set.
ContainsAnyFilter() - Constructor for class com.tangosol.util.filter.ContainsAnyFilter
ContainsAnyFilter(ValueExtractor, Set) - Constructor for class com.tangosol.util.filter.ContainsAnyFilter
Construct an ContainsAnyFilter for testing containment of any value in the given Set.
ContainsAnyFilter(String, Set) - Constructor for class com.tangosol.util.filter.ContainsAnyFilter
ContainsFilter - Class in com.tangosol.util.filter
Filter which tests a Collection or Object array value returned from a method invocation for containment of a given value.
ContainsFilter() - Constructor for class com.tangosol.util.filter.ContainsFilter
ContainsFilter(ValueExtractor, Object) - Constructor for class com.tangosol.util.filter.ContainsFilter
Construct an ContainsFilter for testing containment of the given object.
ContainsFilter(String, Object) - Constructor for class com.tangosol.util.filter.ContainsFilter
containsKey(String, AbstractHttpSessionCollection) - Method in interface com.tangosol.coherence.servlet.CacheDelegator
Check if the cluster cache contains a session obj.
containsKey(String, AbstractHttpSessionCollection) - Method in class com.tangosol.coherence.servlet.DefaultCacheDelegator
containsKey(String, AbstractHttpSessionCollection) - Method in class com.tangosol.coherence.servlet.SessionLocalBackingMapCacheDelegator
containsKey(Object) - Method in class com.tangosol.coherence.weblogic.PortalCacheProvider.CacheImpl
Determine in an entry exists in the Cache.
containsKey(Object) - Method in class com.tangosol.io.nio.BinaryMap
Returns true if this map contains a mapping for the specified key.
containsKey(Object) - Method in class com.tangosol.net.cache.CacheStoreMap.ReadWriteMap
containsKey(Object) - Method in class com.tangosol.net.cache.CachingMap
Check whether or not this map contains a mapping for the specified key.
containsKey(Object) - Method in class com.tangosol.net.cache.OldCache
Deprecated. Returns true if the cache contains the specified key.
containsKey(Object) - Method in class com.tangosol.net.cache.OverflowMap
containsKey(Object) - Method in class com.tangosol.net.cache.ReadWriteBackingMap
containsKey(Object) - Method in class com.tangosol.net.cache.ReadWriteBackingMap.WriteQueue
containsKey(Object) - Method in class com.tangosol.net.cache.SerializationCache
containsKey(Object) - Method in class com.tangosol.net.cache.SimpleOverflowMap
containsKey(Object) - Method in class com.tangosol.net.cache.SimpleSerializationMap
containsKey(Object) - Method in class com.tangosol.net.partition.PartitionSplittingBackingMap
containsKey(Object) - Method in class com.tangosol.net.partition.PartitionSplittingBackingMap.MaskedPartitionMap
containsKey(Object) - Method in class com.tangosol.run.xml.SimpleElement.AttributeMap
containsKey(Object) - Method in class com.tangosol.util.AbstractKeyBasedMap
containsKey(Object) - Method in class com.tangosol.util.AbstractKeySetBasedMap
containsKey(Object) - Method in class com.tangosol.util.BinaryRadixTree.BinaryLongMap
containsKey(Object) - Method in class com.tangosol.util.ChainedMap
containsKey(Object) - Method in interface com.tangosol.util.ConcurrentMap
containsKey(Object) - Method in class com.tangosol.util.ConverterCollections.ConverterMap
containsKey(Object) - Method in class com.tangosol.util.LiteMap
containsKey(Object) - Method in class com.tangosol.util.NullImplementation.NullMap
containsKey(Object) - Method in class com.tangosol.util.RestrictedCollections.RestrictedMap
containsKey(Object) - Method in class com.tangosol.util.SafeHashMap
containsKey(Object) - Method in class com.tangosol.util.SafeSortedMap
containsKey(Object) - Method in class com.tangosol.util.SafeSortedMap.ViewMap
containsKey(Object) - Method in class com.tangosol.util.SegmentedHashMap
Returns true iff this map contains a mapping for the specified key.
containsKey(Object) - Method in class com.tangosol.util.WrapperCollections.AbstractWrapperMap
containsKey(Object) - Method in class com.tangosol.util.WrapperCollections.ConcurrentWrapperMap
containsStandardListeners(Filter) - Method in class com.tangosol.util.MapListenerSupport
Checks whether or not this MapListenerSupport object contains any standard (not lite) listeners for a given filter.
containsStandardListeners(Object) - Method in class com.tangosol.util.MapListenerSupport
Checks whether or not this MapListenerSupport object contains any standard (not lite) listeners for a given key.
containsValue(Object) - Method in class com.tangosol.net.cache.CachingMap
Check whether or not this CachingMap maps one or more keys to the specified value.
containsValue(Object) - Method in class com.tangosol.net.cache.ReadWriteBackingMap
Returns true if this CachingMap maps one or more keys to the specified value.
containsValue(Object) - Method in class com.tangosol.net.cache.SerializationCache
Returns true if this Map maps one or more keys to the specified value.
containsValue(Object) - Method in class com.tangosol.net.cache.SerializationMap
containsValue(Object) - Method in class com.tangosol.net.cache.SimpleSerializationMap
containsValue(Object) - Method in class com.tangosol.util.AbstractKeyBasedMap
containsValue(Object) - Method in interface com.tangosol.util.ConcurrentMap
Returns true if this map maps one or more keys to the specified value.
containsValue(Object) - Method in class com.tangosol.util.ConverterCollections.ConverterMap
containsValue(Object) - Method in class com.tangosol.util.NullImplementation.NullMap
containsValue(Object) - Method in class com.tangosol.util.RestrictedCollections.RestrictedMap
containsValue(Object) - Method in class com.tangosol.util.SegmentedHashMap
containsValue(Object) - Method in class com.tangosol.util.WrapperCollections.AbstractWrapperMap
containsValue(Object) - Method in class com.tangosol.util.WrapperCollections.ConcurrentWrapperMap
containsValue(Object) - Method in class com.tangosol.util.WrapperObservableMap
contendForSegment(int) - Method in class com.tangosol.util.SegmentedHashMap
Wait for a segment to be unlocked.
contextDestroyed() - Method in class com.tangosol.coherence.servlet.SessionHelper
Deprecated. Called by the Coherence ServletContextListener on contextDestroyed() if an event listener is registered.
contextInitialized() - Method in class com.tangosol.coherence.servlet.SessionHelper
Deprecated. Called by the Coherence ServletContextListener on contextInitialized() if an event listener is registered.
Continuation - Interface in com.tangosol.util
Continuation interface is used to implement asynchronous post-processing, the pattern that is also known as the "Continuation-passing style".
ContinuousQueryCache - Class in com.tangosol.net.cache
Create a materialized view of a NamedCache using the Coherence Continuous Query capability.
ContinuousQueryCache(NamedCache, Filter) - Constructor for class com.tangosol.net.cache.ContinuousQueryCache
Create a locally materialized view of a NamedCache using a Filter.
ContinuousQueryCache(NamedCache, Filter, boolean) - Constructor for class com.tangosol.net.cache.ContinuousQueryCache
Create a materialized view of a NamedCache using a Filter.
ContinuousQueryCache(NamedCache, Filter, MapListener) - Constructor for class com.tangosol.net.cache.ContinuousQueryCache
ContinuousQueryCache.AddListener - Class in com.tangosol.net.cache
A MapListener for adding items to the ContinuousQueryCache.
ContinuousQueryCache.AddListener() - Constructor for class com.tangosol.net.cache.ContinuousQueryCache.AddListener
ContinuousQueryCache.EventRouter - Class in com.tangosol.net.cache
An EventRouter routes events from the internal cache of the ContinuousQueryCache to the client listeners, and it can do so asynchronously when appropriate.
ContinuousQueryCache.EventRouter(MapListener) - Constructor for class com.tangosol.net.cache.ContinuousQueryCache.EventRouter
Construct an EventRouter to route events from the internal cache of the ContinuousQueryCache to the client listeners.
ContinuousQueryCache.RemoveListener - Class in com.tangosol.net.cache
A MapListener for evicting items from the ContinuousQueryCache.
ContinuousQueryCache.RemoveListener() - Constructor for class com.tangosol.net.cache.ContinuousQueryCache.RemoveListener
ContinuousQueryCache.ServiceListener - Class in com.tangosol.net.cache
MemberListener for the underlying cache's service.
ContinuousQueryCache.ServiceListener() - Constructor for class com.tangosol.net.cache.ContinuousQueryCache.ServiceListener
Controllable - Interface in com.tangosol.util
The Controllable interface represents a configurable daemon-like object, quite often referred to as a service, that usually operates on its own thread and has a controllable life cycle.
convert(Object) - Method in class com.tangosol.net.cache.SimpleOverflowMap.FrontFilterConverter
Extracts the key from the Status object.
convert(Object, int) - Method in class com.tangosol.run.xml.SimpleValue
Convert the passed Object to the specified type.
convert(Object, int) - Static method in class com.tangosol.run.xml.XmlHelper
convert(Collection, Converter) - Static method in class com.tangosol.util.CollectionHelper
Convert a collection from one set of objects to a new set of objects.
convert(Iterator, Converter) - Static method in class com.tangosol.util.CollectionHelper
Convert an Iterator from one set of objects to a new set of objects.
convert(Enumeration, Converter) - Static method in class com.tangosol.util.CollectionHelper
Convert an Enumeration from one set of objects to a new set of objects.
convert(Object) - Method in interface com.tangosol.util.Converter
Convert the passed object to another object.
convert(Object) - Method in class com.tangosol.util.NullImplementation.NullConverter
convertArray(Object[], Converter) - Static method in class com.tangosol.util.ConverterCollections
Convert the contents of the passed array.
convertArray(Object[], Converter, Object[]) - Static method in class com.tangosol.util.ConverterCollections
Convert the contents of the passed source array into an array with the component type of the passed destination array, using the destination array itself if it is large enough, and placing a null in the first unused element of the destination array if it is larger than the source array.
convertClassToEntry(String) - Method in class com.tangosol.coherence.servlet.WebPluginInstaller.ApplyPatch
Deprecated. Convert the given Java class name to its corresponding Jar entry name.
convertDouble(XmlValue) - Method in class com.tangosol.net.DefaultConfigurableCacheFactory
Convert the value in the specified XmlValue to a double.
convertEntryToClass(String) - Method in class com.tangosol.coherence.servlet.WebPluginInstaller.ApplyPatch
Deprecated. Convert the given Jar entry name to its corresponding Java class name.
Converter - Interface in com.tangosol.util
Provide for "pluggable" object conversions.
ConverterCollections - Class in com.tangosol.util
A collection of Collection implementation classes that use the Converter interface to convert the items stored in underlying collection objects.
ConverterCollections() - Constructor for class com.tangosol.util.ConverterCollections
ConverterCollections.AbstractConverterEntry - Class in com.tangosol.util
An abstract Map Entry that lazily converts the key and value.
ConverterCollections.AbstractConverterEntry(Map.Entry) - Constructor for class com.tangosol.util.ConverterCollections.AbstractConverterEntry
Constructor.
ConverterCollections.ConverterCacheEvent - Class in com.tangosol.util
A Converter CacheEvent views an underlying CacheEvent through a set of key and value Converters.
ConverterCollections.ConverterCacheEvent(ObservableMap, CacheEvent, Converter, Converter) - Constructor for class com.tangosol.util.ConverterCollections.ConverterCacheEvent
Constructor.
ConverterCollections.ConverterCacheEvent(ObservableMap, CacheEvent, Converter, Converter, BackingMapManagerContext) - Constructor for class com.tangosol.util.ConverterCollections.ConverterCacheEvent
Construct a ConverterMapEvent.
ConverterCollections.ConverterCacheMap - Class in com.tangosol.util
A Converter CacheMap views an underlying CacheMap through a set of key and value Converters.
ConverterCollections.ConverterCacheMap(CacheMap, Converter, Converter, Converter, Converter) - Constructor for class com.tangosol.util.ConverterCollections.ConverterCacheMap
Constructor.
ConverterCollections.ConverterCollection - Class in com.tangosol.util
A Converter Collection views an underlying Collection through a Converter.
ConverterCollections.ConverterCollection(Collection, Converter, Converter) - Constructor for class com.tangosol.util.ConverterCollections.ConverterCollection
Constructor.
ConverterCollections.ConverterConcurrentMap - Class in com.tangosol.util
A Converter ConcurrentMap views an underlying ConcurrentMap through a set of key and value Converters.
ConverterCollections.ConverterConcurrentMap(ConcurrentMap, Converter, Converter, Converter, Converter) - Constructor for class com.tangosol.util.ConverterCollections.ConverterConcurrentMap
Constructor.
ConverterCollections.ConverterEntry - Class in com.tangosol.util
A Map Entry that lazily converts the key and value.
ConverterCollections.ConverterEntry(Map.Entry, Converter, Converter, Converter) - Constructor for class com.tangosol.util.ConverterCollections.ConverterEntry
Constructor.
ConverterCollections.ConverterEntrySet - Class in com.tangosol.util
A Converter Entry Set views an underlying Entry Set through a set of key and value Converters.
ConverterCollections.ConverterEntrySet(Collection, Converter, Converter, Converter, Converter) - Constructor for class com.tangosol.util.ConverterCollections.ConverterEntrySet
Constructor.
ConverterCollections.ConverterEntrySet.ConverterEntry - Class in com.tangosol.util
ConverterCollections.ConverterEntrySet.ConverterEntry(Map.Entry) - Constructor for class com.tangosol.util.ConverterCollections.ConverterEntrySet.ConverterEntry
Constructor.
ConverterCollections.ConverterEntrySet.ConverterIterator - Class in com.tangosol.util
A Map Entry Iterator that converts the key and value types.
ConverterCollections.ConverterEntrySet.ConverterIterator(Iterator) - Constructor for class com.tangosol.util.ConverterCollections.ConverterEntrySet.ConverterIterator
Constructor.
ConverterCollections.ConverterInvocableMap - Class in com.tangosol.util
A Converter InvocableMap views an underlying InvocableMap through a set of key and value Converters.
ConverterCollections.ConverterInvocableMap(InvocableMap, Converter, Converter, Converter, Converter) - Constructor for class com.tangosol.util.ConverterCollections.ConverterInvocableMap
Constructor.
ConverterCollections.ConverterList - Class in com.tangosol.util
A Converter List views an underlying List through a Converter.
ConverterCollections.ConverterList(List, Converter, Converter) - Constructor for class com.tangosol.util.ConverterCollections.ConverterList
Constructor.
ConverterCollections.ConverterListIterator - Class in com.tangosol.util
A Converter ListIterator views an underlying ListIterator through a Converter.
ConverterCollections.ConverterListIterator(ListIterator, Converter, Converter) - Constructor for class com.tangosol.util.ConverterCollections.ConverterListIterator
Constructor.
ConverterCollections.ConverterMap - Class in com.tangosol.util
A Converter Map views an underlying Map through a set of key and value Converters.
ConverterCollections.ConverterMap(Map, Converter, Converter, Converter, Converter) - Constructor for class com.tangosol.util.ConverterCollections.ConverterMap
Constructor.
ConverterCollections.ConverterMapEvent - Class in com.tangosol.util
A ConverterMapEvent views an underlying MapEvent through a set of key and value Converters.
ConverterCollections.ConverterMapEvent(ObservableMap, MapEvent, Converter, Converter) - Constructor for class com.tangosol.util.ConverterCollections.ConverterMapEvent
ConverterCollections.ConverterMapEvent(ObservableMap, MapEvent, Converter, Converter, BackingMapManagerContext) - Constructor for class com.tangosol.util.ConverterCollections.ConverterMapEvent
ConverterCollections.ConverterMapEvent.ConverterMapEventBinaryEntry - Class in com.tangosol.util
ConverterMapEventBinaryEntry provides both the Map Entry and the BinaryEntry interfaces to the information encapsulated inside the ConverterMapEvent.
ConverterCollections.ConverterMapEvent.ConverterMapEventBinaryEntry(boolean) - Constructor for class com.tangosol.util.ConverterCollections.ConverterMapEvent.ConverterMapEventBinaryEntry
Constructor.
ConverterCollections.ConverterMapEvent.ConverterMapEventEntry - Class in com.tangosol.util
ConverterMapEventEntry provides the Map Entry interface to the information encapsulated inside the ConverterMapEvent.
ConverterCollections.ConverterMapEvent.ConverterMapEventEntry(boolean) - Constructor for class com.tangosol.util.ConverterCollections.ConverterMapEvent.ConverterMapEventEntry
Constructor.
ConverterCollections.ConverterMapListener - Class in com.tangosol.util
A converter MapListener that converts events of the underlying MapListener for the underlying map.
ConverterCollections.ConverterMapListener(ObservableMap, MapListener, Converter, Converter) - Constructor for class com.tangosol.util.ConverterCollections.ConverterMapListener
Constructor.
ConverterCollections.ConverterNamedCache - Class in com.tangosol.util
A Converter NamedCache views an underlying NamedCache through a set of key and value Converters.
ConverterCollections.ConverterNamedCache(NamedCache, Converter, Converter, Converter, Converter) - Constructor for class com.tangosol.util.ConverterCollections.ConverterNamedCache
Constructor.
ConverterCollections.ConverterObservableMap - Class in com.tangosol.util
A Converter ObservableMap views an underlying ObservableMap through a set of key and value Converters.
ConverterCollections.ConverterObservableMap(ObservableMap, Converter, Converter, Converter, Converter) - Constructor for class com.tangosol.util.ConverterCollections.ConverterObservableMap
Constructor.
ConverterCollections.ConverterQueryMap - Class in com.tangosol.util
A Converter QueryMap views an underlying QueryMap through a set of key and value Converters.
ConverterCollections.ConverterQueryMap(QueryMap, Converter, Converter, Converter, Converter) - Constructor for class com.tangosol.util.ConverterCollections.ConverterQueryMap
Constructor.
ConverterCollections.ConverterSet - Class in com.tangosol.util
A Converter Set views an underlying Set through a Converter.
ConverterCollections.ConverterSet(Set, Converter, Converter) - Constructor for class com.tangosol.util.ConverterCollections.ConverterSet
Constructor.
ConverterCollections.ConverterSortedMap - Class in com.tangosol.util
A Converter SortedMap views an underlying SortedMap through a set of key and value Converters.
ConverterCollections.ConverterSortedMap(SortedMap, Converter, Converter, Converter, Converter) - Constructor for class com.tangosol.util.ConverterCollections.ConverterSortedMap
Constructor.
ConverterCollections.ConverterSortedSet - Class in com.tangosol.util
A Converter SortedSet views an underlying SortedSet through a Converter.
ConverterCollections.ConverterSortedSet(SortedSet, Converter, Converter) - Constructor for class com.tangosol.util.ConverterCollections.ConverterSortedSet
Constructor.
ConverterEnumerator - Class in com.tangosol.util
Provide an implementation of an enumerator which converts each of the items which it enumerates.
ConverterEnumerator(Enumeration, Converter) - Constructor for class com.tangosol.util.ConverterEnumerator
Construct the Converter enumerator based on an Enumeration.
ConverterEnumerator(Iterator, Converter) - Constructor for class com.tangosol.util.ConverterEnumerator
Construct the Converter enumerator based on an Iterator.
ConverterEnumerator(Object[], Converter) - Constructor for class com.tangosol.util.ConverterEnumerator
Construct the Converter enumerator based on an array of objects.
convertEvent(MapEvent, ObservableMap, Converter, Converter) - Static method in class com.tangosol.util.MapListenerSupport
Convert the specified map event into another MapEvent that ensures the lazy event data conversion using the specified converters.
convertInt(XmlValue) - Method in class com.tangosol.net.DefaultConfigurableCacheFactory
Convert the value in the specified XmlValue to an int.
convertInt(XmlValue, int) - Method in class com.tangosol.net.DefaultConfigurableCacheFactory
convertLong(XmlValue) - Method in class com.tangosol.net.DefaultConfigurableCacheFactory
Convert the value in the specified XmlValue to a long.
convertNumber(Number, int) - Static method in class com.tangosol.io.pof.PofHelper
Convert the passed number to the specified type.
convertToDate(Object) - Static method in class com.tangosol.io.pof.PofHelper
Convert a date, time or date/time value to a Java Date.
convertUTF(int, int) - Method in class com.tangosol.io.AbstractByteArrayReadBuffer.ByteArrayBufferInput
Convert a UTF-8 encoded section of the binary stream into a String.
convertUTF(int, int) - Method in class com.tangosol.io.AbstractReadBuffer.AbstractBufferInput
convertUTF(int, int) - Method in class com.tangosol.io.nio.ByteBufferReadBuffer.ByteBufferInput
copy(InputStream, OutputStream, byte[]) - Method in class com.tangosol.net.LoadBalancer.SocketHandler
Process the transfer of data from one stream to another.
copyArray(LongArray) - Method in class com.tangosol.util.CopyOnWriteLongArray
Return a shallow copy of the specified LongArray.
copyBufferInputPortion(int, ReadBuffer.BufferInput, int) - Method in class com.tangosol.io.AbstractWriteBuffer
Read a portion of the specified BufferInput and write it to the specified offset within this buffer.
copyBufferInputRemainder(int, ReadBuffer.BufferInput, int) - Method in class com.tangosol.io.AbstractWriteBuffer
Read the remaining contents of the specified BufferInput and write it to the specified offset within this buffer.
copyBytes(int, int, byte[], int) - Method in class com.tangosol.io.AbstractByteArrayReadBuffer
Copies bytes from this ReadBuffer into the destination byte array.
copyBytes(int, int, byte[], int) - Method in class com.tangosol.io.MultiBufferReadBuffer
copyBytes(int, int, byte[], int) - Method in class com.tangosol.io.nio.ByteBufferReadBuffer
copyBytes(int, int, byte[], int) - Method in interface com.tangosol.io.ReadBuffer
copyEntry(ApplicationEntry, ApplicationReader, ApplicationWriter) - Method in class com.tangosol.coherence.servlet.WebPluginInstaller.ApplyPatch
Deprecated. Copy an entry from one application archive to another.
copyEntry(ApplicationEntry, InputStream, ApplicationWriter) - Method in class com.tangosol.coherence.servlet.WebPluginInstaller.ApplyPatch
Deprecated. Copy an entry from a stream to an application archive.
copyFrom(SafeHashMap.Entry) - Method in class com.tangosol.net.cache.OldCache.Entry
Deprecated. Copy this Entry's information from another Entry.
copyFrom(SafeHashMap.Entry) - Method in class com.tangosol.util.SafeHashMap.Entry
CopyOnWriteLongArray - Class in com.tangosol.util
A thread-safe variant of LongArray in which all mutating operations (e.g.
CopyOnWriteLongArray() - Constructor for class com.tangosol.util.CopyOnWriteLongArray
CopyOnWriteLongArray(Class) - Constructor for class com.tangosol.util.CopyOnWriteLongArray
Construct a CopyOnWriteLongArray with an underlying array of the specified type.
CopyOnWriteLongArray(LongArray) - Constructor for class com.tangosol.util.CopyOnWriteLongArray
Construct a CopyOnWriteLongArray, initialized with the contents of the specified LongArray.
CopyOnWriteLongArray.UnmodifiableIterator - Class in com.tangosol.util
Unmodifiable view of a LongArray.Iterator.
CopyOnWriteLongArray.UnmodifiableIterator(LongArray.Iterator) - Constructor for class com.tangosol.util.CopyOnWriteLongArray.UnmodifiableIterator
Construct a wrapper for the specified Iterator.
copyOptions(SocketOptions) - Method in class com.tangosol.net.SocketOptions
Copy the options in the specified SocketOptions into this SocketOptions.
copyStream(int, InputStreaming, int) - Method in class com.tangosol.io.AbstractWriteBuffer
Store the remaining contents of the specified InputStreaming object at the specified offset within this buffer.
copyStream(int, InputStreaming, int) - Method in class com.tangosol.io.ByteArrayWriteBuffer
copyStream(int, InputStreaming, int) - Method in class com.tangosol.io.DelegatingWriteBuffer
Count - Class in com.tangosol.util.aggregator
Calculates a number of values in an entry set.
Count() - Constructor for class com.tangosol.util.aggregator.Count
countBits(byte) - Static method in class com.tangosol.util.BitHelper
Count the number of bits set in the passed integral value.
countBits(int) - Static method in class com.tangosol.util.BitHelper
countBits(long) - Static method in class com.tangosol.util.BitHelper
create(HttpSession) - Method in class com.tangosol.coherence.servlet.AbstractHttpSessionCollection
Deprecated. This method creates a new session, returning the session model for the new session.
create(HttpSession, String) - Method in class com.tangosol.coherence.servlet.AbstractHttpSessionCollection
Deprecated. This method attempts to create a new session with a specific ID, returning the session model for the new session.
create(HttpSession, String, boolean) - Method in class com.tangosol.coherence.servlet.AbstractHttpSessionCollection
create(HttpSession) - Method in interface com.tangosol.coherence.servlet.HttpSessionCollection
create(HttpSession, String) - Method in interface com.tangosol.coherence.servlet.HttpSessionCollection
CREATE - Static variable in class com.tangosol.net.ClusterPermission
Create action.
create() - Method in class com.tangosol.net.TcpDatagramSocket.Impl
createAddressProvider(XmlElement, ClassLoader) - Static method in class com.tangosol.net.ConfigurableAddressProvider
Instantiate an AddressProvider configured according to the specified XML.
createAggregator(ValueExtractor) - Method in class com.tangosol.coherence.rest.util.aggregator.DefaultAggregatorFactory
Create and initialize a new aggregator instance.
createBinaryStore() - Method in class com.tangosol.io.AsyncBinaryStoreManager
Factory method: Returns a new BinaryStore.
createBinaryStore() - Method in class com.tangosol.io.bdb.BerkeleyDBBinaryStoreManager
Return a new BinaryStore.
createBinaryStore() - Method in interface com.tangosol.io.BinaryStoreManager
createBinaryStore() - Method in class com.tangosol.io.journal.AbstractJournalRM
Create a new BinaryStore that will journal its information using this Journal Resource Manager.
createBinaryStore() - Method in class com.tangosol.io.journal.BackupJournalRM
createBinaryStore() - Method in class com.tangosol.io.nio.AbstractStoreManager
createBinaryStore() - Method in class com.tangosol.net.cache.SerializationPagedCache
Create and register a new BinaryStore object, using this cache's BinaryStoreManager.
createBufferManager() - Method in class com.tangosol.io.nio.AbstractStoreManager
Create a ByteBufferManager to be used by a BinaryStore.
createBufferManager() - Method in class com.tangosol.io.nio.DirectStoreManager
createBufferManager() - Method in class com.tangosol.io.nio.MappedStoreManager
createConnection() - Method in interface com.tangosol.coherence.transaction.ConnectionFactory
Create a connection to a Coherence data grid.
createConnection(String) - Method in interface com.tangosol.coherence.transaction.ConnectionFactory
createConnection(ClassLoader) - Method in interface com.tangosol.coherence.transaction.ConnectionFactory
createConnection(String, ClassLoader) - Method in interface com.tangosol.coherence.transaction.ConnectionFactory
createConnection(ConnectionFactory.ConnectionSpec) - Method in interface com.tangosol.coherence.transaction.ConnectionFactory
Create a connection to a Coherence data grid using the specified connection specification.
createConnection() - Method in class com.tangosol.coherence.transaction.DefaultConnectionFactory
createConnection(String) - Method in class com.tangosol.coherence.transaction.DefaultConnectionFactory
createConnection(ClassLoader) - Method in class com.tangosol.coherence.transaction.DefaultConnectionFactory
createConnection(String, ClassLoader) - Method in class com.tangosol.coherence.transaction.DefaultConnectionFactory
createConnection(ConnectionFactory.ConnectionSpec) - Method in class com.tangosol.coherence.transaction.DefaultConnectionFactory
createDefaultMarshaller(Class, String) - Method in class com.tangosol.coherence.rest.io.MarshallerRegistry
Create default marshaller for the specified class and media type.
createDelegateEntry(ApplicationEntry, ApplicationReader, ApplicationWriter) - Method in class com.tangosol.coherence.servlet.WebPluginInstaller.ApplyPatch
Deprecated. Create a new delegate class entry that extends the given class entry and delegates all methods to a wrapped instance of the class entry.
createDelegateMethod(ClassFile, Method, String, Method) - Method in class com.tangosol.coherence.servlet.WebPluginInstaller.ApplyPatch
Deprecated. Creates a delegate method in the given ClassFile that delegates the given method to the object returned by the given accessor method.
createDelta(ReadBuffer, ReadBuffer) - Method in class com.tangosol.io.BinaryDeltaCompressor
Actually create a delta in the binary delta format.
createDelta(ReadBuffer, ReadBuffer) - Method in class com.tangosol.io.pof.PofDeltaCompressor
createEntityFromId(Object) - Method in class com.tangosol.coherence.hibernate.HibernateCacheLoader
Create a transient entity instance given an entity id
createExtractor(String) - Static method in class com.tangosol.util.QueryHelper
Make a new ValueExtracter from the given String.
createExtractors(String) - Static method in class com.tangosol.util.extractor.ChainedExtractor
Parse a dot-delimited sequence of method names and instantiate a corresponding array of ReflectionExtractor objects.
createExtractors(String) - Static method in class com.tangosol.util.extractor.MultiExtractor
Parse a comma-delimited sequence of method names and instantiate a corresponding array of ValueExtractor objects.
createFilter(String) - Static method in class com.tangosol.util.QueryHelper
Make a new Filter from the given String.
createFilter(String, Object[]) - Static method in class com.tangosol.util.QueryHelper
createFilter(String, Map) - Static method in class com.tangosol.util.QueryHelper
createFilter(String, Object[], Map) - Static method in class com.tangosol.util.QueryHelper
createHttpSession() - Method in class com.tangosol.coherence.servlet.SessionHelper
Deprecated. Create a new HttpSession object.
createIndex(boolean, Comparator, Map, BackingMapContext) - Method in class com.tangosol.util.extractor.ConditionalExtractor
Create an index and associate it with the corresponding extractor.
createIndex(boolean, Comparator, Map, BackingMapContext) - Method in interface com.tangosol.util.extractor.IndexAwareExtractor
createInstance(XmlElement, ClassLoader, XmlHelper.ParameterResolver) - Static method in class com.tangosol.run.xml.XmlHelper
Create an instance of the class configured using an XmlElement of the following structure: <!
createInstance(XmlElement, ClassLoader, XmlHelper.ParameterResolver, Class) - Static method in class com.tangosol.run.xml.XmlHelper
createInstance(InvocableMap.EntryAggregator[]) - Static method in class com.tangosol.util.aggregator.CompositeAggregator
Create an instance of CompositeAggregator based on a specified EntryAggregator array.
createInstance(String, InvocableMap.EntryAggregator) - Static method in class com.tangosol.util.aggregator.GroupAggregator
Create an instance of GroupAggregator based on a specified method name(s) and an EntryAggregator.
createInstance(String, InvocableMap.EntryAggregator, Filter) - Static method in class com.tangosol.util.aggregator.GroupAggregator
Create an instance of GroupAggregator based on a specified method name(s), an EntryAggregator and a result evaluation filter.
createInstance(ValueExtractor, InvocableMap.EntryAggregator) - Static method in class com.tangosol.util.aggregator.GroupAggregator
Create an instance of GroupAggregator based on a specified extractor and an EntryAggregator.
createInstance(ValueExtractor, InvocableMap.EntryAggregator, Filter) - Static method in class com.tangosol.util.aggregator.GroupAggregator
Create an instance of GroupAggregator based on a specified extractor and an EntryAggregator and a result evaluation filter.
createJournal(Journal.JournalConsumer) - Method in class com.tangosol.io.journal.AbstractJournalRM
Create a new Journal that exposes the storage capabilities of this Journal Resource Manager.
createJournal(Journal.JournalConsumer) - Method in class com.tangosol.io.journal.BackupJournalRM
createKey(Class, String) - Method in class com.tangosol.coherence.rest.io.MarshallerRegistry
Create a key for the marshallers map.
createMarshaller(Class, String, Class) - Method in class com.tangosol.coherence.rest.io.MarshallerRegistry
Create marshaller instance.
createNamedDatabase(String) - Method in class com.tangosol.io.bdb.DatabaseFactory
Create a named Database instance.
createNestedPofReader(int) - Method in class com.tangosol.io.pof.PofBufferReader
Obtain a PofReader that can be used to read a set of properties from a single property of the current user type.
createNestedPofReader(int) - Method in class com.tangosol.io.pof.PofBufferReader.UserTypeReader
createNestedPofReader(int) - Method in interface com.tangosol.io.pof.PofReader
createNestedPofWriter(int) - Method in class com.tangosol.io.pof.PofBufferWriter
Obtain a PofWriter that can be used to write a set of properties into a single property of the current user type.
createNestedPofWriter(int) - Method in class com.tangosol.io.pof.PofBufferWriter.UserTypeWriter
createNestedPofWriter(int) - Method in interface com.tangosol.io.pof.PofWriter
createPartition(int) - Method in class com.tangosol.net.partition.ObservableSplittingBackingCache
Add a partition to the PartitionAwareBackingMap.
createPartition(int) - Method in class com.tangosol.net.partition.ObservableSplittingBackingMap
createPartition(int) - Method in interface com.tangosol.net.partition.PartitionAwareBackingMap
createPartition(int) - Method in class com.tangosol.net.partition.PartitionSplittingBackingMap
createPartition(int) - Method in class com.tangosol.net.partition.ReadWriteSplittingBackingMap
createPersistentEnvironment() - Method in class com.tangosol.io.bdb.DatabaseFactory.EnvironmentHolder
Create a persistent Environment.
createPofConfig() - Method in class com.tangosol.io.pof.ConfigurablePofContext
Create a PofConfig object based on a configuration that was either provided as XML, or can be loaded from the specified (or default) URI using the provided ClassLoader.
createProvider(XmlElement) - Method in class com.tangosol.net.SocketProviderFactory
Create and return a SocketProvider based upon a supplied configuration.
createRequestContext(ServletRequest, ServletResponse) - Method in class com.tangosol.coherence.servlet.SessionHelper
Deprecated. Given the specified request and response, provide a request context.
createSerializer(ClassLoader) - Method in class com.tangosol.io.ConfigurableSerializerFactory
Create a new Serializer.
createSerializer(ClassLoader) - Method in interface com.tangosol.io.SerializerFactory
createServiceHelper() - Method in class com.tangosol.coherence.servlet.SessionHelper
Deprecated. Create a ServiceHelper.
createSessionExpiryFilter(Filter) - Method in interface com.tangosol.coherence.servlet.SessionExpiryFilterFactory
Creates a new session expiry filter.
createTemporaryEnvironment() - Method in class com.tangosol.io.bdb.DatabaseFactory.EnvironmentHolder
Create a temporary Environment.
CTX_ATTR_CONTEXT - Static variable in class com.tangosol.coherence.servlet.SessionHelper
Deprecated. The name of the application server context's attribute that Coherence stores its servlet context object under.
CTX_ATTR_HELPER - Static variable in class com.tangosol.coherence.servlet.SessionHelper
Deprecated. The name of the application server context's attribute that Coherence stores its session helper object under.
CTX_INIT_ALLOW_LOCAL_ATTRIBUTES - Static variable in class com.tangosol.coherence.servlet.SessionHelper
Deprecated. The configuration property that specifies whether non-serializable attributes should be preserved as local.
CTX_INIT_APPLICATION_NAME - Static variable in class com.tangosol.coherence.servlet.SessionHelper
Deprecated. The configuration property that overrides the name of the web application.
CTX_INIT_APPLICATION_NAME_GENERATED - Static variable in class com.tangosol.coherence.servlet.SessionHelper
Deprecated. Whether the application name was generated by Coherence*Web
CTX_INIT_ATTR_OVERFLOW_THRESHOLD - Static variable in class com.tangosol.coherence.servlet.SessionHelper
Deprecated. The configuration property for the "split" model that overrides the length that attributes must be below to be stored inside a session ("embedded") or above which they will be stored in the separated "overflow" cache ("external").
CTX_INIT_ATTR_OVERFLOW_THRESHOLD - Static variable in class com.tangosol.coherence.servlet.SplitHttpSessionCollection
CTX_INIT_ATTR_OVERFLOW_THRESHOLD_DEFAULT - Static variable in class com.tangosol.coherence.servlet.SplitHttpSessionCollection
Deprecated.
CTX_INIT_CACHE_DELEGATOR_CLASS - Static variable in class com.tangosol.coherence.servlet.SessionHelper
Deprecated. The configuration property that defines the cache delegator class.
CTX_INIT_CACHENAME_CONTEXT - Static variable in class com.tangosol.coherence.servlet.SessionHelper
Deprecated. The name of the Coherence cache that will be used to hold the servlet context data if the servlet context is clustered by Coherence.
CTX_INIT_CACHENAME_DEATHCERTS - Static variable in class com.tangosol.coherence.servlet.SessionHelper
Deprecated. The configuration property that overrides the name of the clustered cache that stores the IDs of "recently departed" sessions.
CTX_INIT_CACHENAME_LOCAL_ATTRIBUTES - Static variable in class com.tangosol.coherence.servlet.SessionHelper
Deprecated. The configuration property that overrides the name of the local cache that stores non-distributed session attributes (if allowed.)
CTX_INIT_CACHENAME_LOCAL_SESSIONS - Static variable in class com.tangosol.coherence.servlet.SessionHelper
Deprecated. The configuration property that overrides the name of the local cache that stores non-distributed sessions when the SessionDistributionController option is implemented.
CTX_INIT_CACHENAME_MANAGEMENT - Static variable in class com.tangosol.coherence.servlet.SessionHelper
Deprecated. The configuration property that overrides the name of the clustered cache that stores the sessions management configuration data.
CTX_INIT_CACHENAME_OVERFLOW - Static variable in class com.tangosol.coherence.servlet.SessionHelper
Deprecated. The configuration property that overrides the name of the clustered cache that stores the "overflowing" (split-out due to size) session attributes.
CTX_INIT_CACHENAME_OVERFLOW - Static variable in class com.tangosol.coherence.servlet.SplitHttpSessionCollection
CTX_INIT_CACHENAME_SESSIONS - Static variable in class com.tangosol.coherence.servlet.SessionHelper
Deprecated. The configuration property that overrides the name of the clustered cache that stores the sessions.
CTX_INIT_CLUSTER - Static variable in class com.tangosol.coherence.servlet.SessionHelper
Deprecated. The name of the application server context's initialization parameter that specifies whether the ServletContext attribute values will be clustered.
CTX_INIT_CLUSTER_OWNED - Static variable in class com.tangosol.coherence.servlet.SessionHelper
Deprecated. True if the cluster software is deployed as part of the application and thus must be shut down fully by the application when it shuts down.
CTX_INIT_COLLECTION - Static variable in class com.tangosol.coherence.servlet.SessionHelper
Deprecated. The name of the application server context's initialization parameter that specifies the fully qualified class name of the HttpSessionCollection implementation to use.
CTX_INIT_CONFIGURATION_CONSISTENCY - Static variable in class com.tangosol.coherence.servlet.SessionHelper
Deprecated. The configuration property that indicates whether configuration consistency should be checked.
CTX_INIT_COOKIE_DOMAIN - Static variable in class com.tangosol.coherence.servlet.SessionHelper
Deprecated. The domain of the session cookie.
CTX_INIT_COOKIE_MAX_AGE - Static variable in class com.tangosol.coherence.servlet.SessionHelper
Deprecated. The maximum age in seconds of the session cookie.
CTX_INIT_COOKIE_NAME - Static variable in class com.tangosol.coherence.servlet.SessionHelper
Deprecated. The name of the session cookie.
CTX_INIT_COOKIE_PATH - Static variable in class com.tangosol.coherence.servlet.SessionHelper
Deprecated. The path of the session cookie.
CTX_INIT_COOKIE_SECURE - Static variable in class com.tangosol.coherence.servlet.SessionHelper
Deprecated. True to ensure that the session cookie is only sent from a web client over a SSL connection.
CTX_INIT_COOKIES_ENABLED - Static variable in class com.tangosol.coherence.servlet.SessionHelper
Deprecated. True to enable session cookies.
CTX_INIT_DAEMON_ASSUME_LOCALITY - Static variable in class com.tangosol.coherence.servlet.SessionHelper
Deprecated. True to assume that the sessions in the cache are split across only the servers that are doing reaping.
CTX_INIT_DAEMON_COORDINATED - Static variable in class com.tangosol.coherence.servlet.SessionHelper
Deprecated. True to coordinate reaping in the cluster such that only one server will perform reaping within a given reaping cycle, and it will check all session ids in the cluster.
CTX_INIT_DAEMON_CYCLE_SECS - Static variable in class com.tangosol.coherence.servlet.SessionHelper
Deprecated. The number of seconds that the daemon rests between reaping.
CTX_INIT_DAEMON_MAX_THREADS - Static variable in class com.tangosol.coherence.servlet.SessionHelper
Deprecated. Configuration parameter for setting the minimum number of threads for the session reaper daemon.
CTX_INIT_DAEMON_MIN_THREADS - Static variable in class com.tangosol.coherence.servlet.SessionHelper
Deprecated. Configuration parameter for setting the maximum number of threads for the session reaper daemon.
CTX_INIT_DAEMON_PARALLEL - Static variable in class com.tangosol.coherence.servlet.SessionHelper
Deprecated. Configuration parameter for enabling parallel session reaping.
CTX_INIT_DAEMON_PRIORITY - Static variable in class com.tangosol.coherence.servlet.SessionHelper
Deprecated. The priority for the session reaper daemon.
CTX_INIT_DAEMON_QUEUE_SIZE - Static variable in class com.tangosol.coherence.servlet.SessionHelper
Deprecated. Configuration parameter for setting the queue size of the session reaper work manager.
CTX_INIT_DAEMON_SWEEP_MODULO - Static variable in class com.tangosol.coherence.servlet.SessionHelper
Deprecated. The number of times that the reaper reaps the sessions that are being used locally before it will check sessions that may be orphaned or expired elsewhere in the cluster.
CTX_INIT_DIST_CONTROLLER_CLASS - Static variable in class com.tangosol.coherence.servlet.SessionHelper
Deprecated. The configuration property that specifies an implementation of the SessionDistributionController interface to use.
CTX_INIT_ENABLE_ATTR_LISTENER_OPTIMIZATION - Static variable in class com.tangosol.coherence.servlet.SessionHelper
Deprecated. Determines if attribute listeners should be executed if the same instance of a session attribute is being replaced in the session.
CTX_INIT_ENABLE_SESSION_ACCESS_DEBUG_LOGGING - Static variable in class com.tangosol.coherence.servlet.AbstractHttpSessionCollection
Deprecated. Configuration property to enable debug logging for Session access.
CTX_INIT_ENABLE_SESSION_ACCESS_DEBUG_LOGGING - Static variable in class com.tangosol.coherence.servlet.SessionHelper
Deprecated. Enable Debug logging for Session access, creation, invalidation, and attribute access/insertion/update/removal
CTX_INIT_ENABLE_SUSPECT_ATTRIBUTES - Static variable in class com.tangosol.coherence.servlet.SessionHelper
Deprecated. Whether we try to determine suspect attributes.
CTX_INIT_FACTORY - Static variable in class com.tangosol.coherence.servlet.SessionHelper
Deprecated. The name of the application server context's initialization parameter that specifies the fully qualified class name of the SessionHelper Factory to use.
CTX_INIT_FILTER - Static variable in class com.tangosol.coherence.servlet.SessionHelper
Deprecated. In the filter's configuration, the name of the filter class that is wrapped by the Coherence filter.
CTX_INIT_LISTENS - Static variable in class com.tangosol.coherence.servlet.SessionHelper
Deprecated. The comma-delimited list of names of application classes that wish to receive events from the web container.
CTX_INIT_LOG_THREADS_HOLDING_LOCK - Static variable in class com.tangosol.coherence.servlet.SessionHelper
Deprecated. The configuration property that specifies whether an diagnostic invocation service is executed when a member is unable to acquire the cluster lock for a session.
CTX_INIT_SCOPE_CONTROLLER_CLASS - Static variable in class com.tangosol.coherence.servlet.SessionHelper
Deprecated. The configuration property that specifies an implementation of the AttributeScopeController interface to use.
CTX_INIT_SERVICENAME_OWNERSHIP - Static variable in class com.tangosol.coherence.servlet.SessionHelper
Deprecated. The configuration property that specifies the name of the invocation service that will be used to manage sticky session ownership.
CTX_INIT_SERVLET - Static variable in class com.tangosol.coherence.servlet.SessionHelper
Deprecated. In the servlet's configuration, the name of the servlet class that is wrapped by the Coherence servlet.
CTX_INIT_SESSION_ACCESS_DEBUG_LOGGING_FILTER - Static variable in class com.tangosol.coherence.servlet.AbstractHttpSessionCollection
CTX_INIT_SESSION_ACCESS_DEBUG_LOGGING_FILTER - Static variable in class com.tangosol.coherence.servlet.SessionHelper
Deprecated. Comma separated list of session attribute prefixes not to be logged
CTX_INIT_SESSION_AFFINITY_TOKEN - Static variable in class com.tangosol.coherence.servlet.SessionHelper
Deprecated. The configuration property that specifies session id affinity suffix token.
CTX_INIT_SESSION_APP_LOCK - Static variable in class com.tangosol.coherence.servlet.SessionHelper
Deprecated. The configuration property that specifies application level session locking.
CTX_INIT_SESSION_EXPIRE_SECS - Static variable in class com.tangosol.coherence.servlet.SessionHelper
Deprecated. The configuration property that overrides the session expirty time.
CTX_INIT_SESSION_EXPIRY_FILTER_FACTORY - Static variable in class com.tangosol.coherence.servlet.SessionHelper
Deprecated. Parameter name for specifying a custom session expiry filter factory
CTX_INIT_SESSION_GET_LOCK_TIMEOUT - Static variable in class com.tangosol.coherence.servlet.SessionHelper
Deprecated. The configuration property that specifies session lock acquisition timeout.
CTX_INIT_SESSION_ID_GENERATOR_CLASS - Static variable in class com.tangosol.coherence.servlet.SessionHelper
Deprecated. The configuration property that specifies the fully qualified class name of the HttpSessionIdGenerator implementation to use.
CTX_INIT_SESSION_ID_LENGTH - Static variable in class com.tangosol.coherence.servlet.SessionHelper
Deprecated. The configuration property that overrides the session id length.
CTX_INIT_SESSION_LAZY_ACCESS - Static variable in class com.tangosol.coherence.servlet.SessionHelper
Deprecated. The configuration property that allows lazy access to a session.
CTX_INIT_SESSION_LOCK - Static variable in class com.tangosol.coherence.servlet.SessionHelper
Deprecated. The configuration property that specifies that session locking is enabled.
CTX_INIT_SESSION_LOG_INVALIDATION_EXCEPTIONS - Static variable in class com.tangosol.coherence.servlet.SessionHelper
Deprecated. The configuration property that specifies if Coherence*Web is to log exceptions thrown by session attribute listeners during invalidation.
CTX_INIT_SESSION_MEMBER_LOCK - Static variable in class com.tangosol.coherence.servlet.SessionHelper
Deprecated. The configuration property that specifies member level session locking.
CTX_INIT_SESSION_RETAIN_MILLIS - Static variable in class com.tangosol.coherence.servlet.SessionHelper
Deprecated. The length of time to defer async exit on a session that is accessed "out of context".
CTX_INIT_SESSION_STICKY - Static variable in class com.tangosol.coherence.servlet.SessionHelper
Deprecated. The configuration property that specifies whether sticky sessions optimizations will be used.
CTX_INIT_SESSION_STRICT_SPEC - Static variable in class com.tangosol.coherence.servlet.SessionHelper
Deprecated. The configuration property that specifies strict spec adherence.
CTX_INIT_SESSION_THREAD_LOCK - Static variable in class com.tangosol.coherence.servlet.SessionHelper
Deprecated. The configuration property that specifies thread level session locking.
CTX_INIT_SESSIONCONTEXT_ENABLED - Static variable in class com.tangosol.coherence.servlet.SessionHelper
Deprecated. True to allow the application to iterate sessions from the session context, thus disobeying the deprecation in the servlet spec.
CTX_INIT_SHUTDOWN_DELAY_SECS - Static variable in class com.tangosol.coherence.servlet.SessionHelper
Deprecated. The configuration property that overrides the shutdown delay time.
CTX_INIT_URLDECODE_DEFAULT - Static variable in class com.tangosol.coherence.servlet.SessionHelper
Deprecated. True to use the container's decoding of the URL session ID.
CTX_INIT_URLENCODE_DEFAULT - Static variable in class com.tangosol.coherence.servlet.SessionHelper
Deprecated. True to use the container's encoding of the URL session ID.
CTX_INIT_URLENCODE_ENABLED - Static variable in class com.tangosol.coherence.servlet.SessionHelper
Deprecated. True to enable URL encoding of session ids.
CTX_INIT_URLENCODE_NAME - Static variable in class com.tangosol.coherence.servlet.SessionHelper
Deprecated. The parameter name to encode the session id into the URL with.
current() - Method in class com.tangosol.run.xml.SimpleParser
Returns the current token and advances to the next token.
current - Variable in class com.tangosol.util.AbstractSparseArray.Crawler
currentNode() - Method in class com.tangosol.util.AbstractSparseArray.Crawler
Returns the current Node in the iteration.
D
Daemon - Class in com.tangosol.util
A abstract Daemon thread handler.
Daemon() - Constructor for class com.tangosol.util.Daemon
Default constructor.
Daemon(String) - Constructor for class com.tangosol.util.Daemon
Creates a Daemon with the specified name.
Daemon(String, int, boolean) - Constructor for class com.tangosol.util.Daemon
Creates a Daemon with a specified name and priority.
Daemon.DaemonWorker - Class in com.tangosol.util
The sub-class of Thread that this Daemon uses as the actual thread of execution.
Daemon.DaemonWorker() - Constructor for class com.tangosol.util.Daemon.DaemonWorker
DaemonThreadFactory - Class in com.tangosol.util
DaemonThreadFactory is a ThreadFactory which produces daemon threads.
DaemonThreadFactory() - Constructor for class com.tangosol.util.DaemonThreadFactory
Construct a new DameonThreadFacotry.
DaemonThreadFactory(String) - Constructor for class com.tangosol.util.DaemonThreadFactory
DatabaseFactory - Class in com.tangosol.io.bdb
Factory for Berkeley DB Environments and Databases.
DatabaseFactory(BerkeleyDBBinaryStoreManager) - Constructor for class com.tangosol.io.bdb.DatabaseFactory
Construct a DatabaseFactory for a given Berkeley DB Environment.
DatabaseFactory.EnvironmentHolder - Class in com.tangosol.io.bdb
Holder for Berkeley DB Environment and its Databases.
DatabaseFactory.EnvironmentHolder(BerkeleyDBBinaryStoreManager) - Constructor for class com.tangosol.io.bdb.DatabaseFactory.EnvironmentHolder
Construct a EnvironmentHolder for a given Berkeley DB Environment.
DatabaseFactory.EnvironmentHolder.DirectoryLock - Class in com.tangosol.io.bdb
Directory based lock.
DatabaseFactory.EnvironmentHolder.DirectoryLock(File, String) - Constructor for class com.tangosol.io.bdb.DatabaseFactory.EnvironmentHolder.DirectoryLock
Create a DirectoryLock which can be used to try to lock a directory.
DatabaseFactoryManager - Class in com.tangosol.io.bdb
A manager for Berkeley DB Database factories.
DatabaseFactoryManager() - Constructor for class com.tangosol.io.bdb.DatabaseFactoryManager
Construct a new DatabaseFactoryManager.
DatagramPacketOutputStream - Class in com.tangosol.net
Provides an OutputStream on top of a DatagramPacket.
DatagramPacketOutputStream(DatagramPacket) - Constructor for class com.tangosol.net.DatagramPacketOutputStream
DATE_FORMAT - Static variable in class com.tangosol.coherence.rest.DefaultKeyConverter
DateFormat instance that will be used to convert Date keys.
DateFormatAdapter - Class in com.tangosol.run.xml
A property adapter for formatting formatting and parsing dates in a locale-sensitive manner.
DateFormatAdapter(XmlBean.BeanInfo, Class, String, String, XmlElement) - Constructor for class com.tangosol.run.xml.DateFormatAdapter
Construct a DateFormatAdapter.
DateTimeAdapter - Class in com.tangosol.run.xml
A property adapter for the <xs:dateTime> format conforming to ISO 8601
DateTimeAdapter(XmlBean.BeanInfo, Class, String, String, XmlElement) - Constructor for class com.tangosol.run.xml.DateTimeAdapter
Construct a DateTimeAdapter.
deactivate() - Method in class com.tangosol.util.SafeHashMap.EntrySet.EntrySetIterator
Shut down the Iterator.
deactivate() - Method in class com.tangosol.util.SegmentedHashMap.EntrySet.EntrySetIterator
deactivatePage(SerializationPagedCache.WrapperBinaryStore) - Method in class com.tangosol.net.cache.SerializationPagedCache
Deactivate a page that is no longer active.
DebugDataOutputStream - Class in com.tangosol.io
This is an imitation DataOutputStream class that logs the output in a human-readable format for debugging purposes.
DebugDataOutputStream(OutputStream) - Constructor for class com.tangosol.io.DebugDataOutputStream
Construct a DebugDataOutputStream that will output to the specified Stream object.
DECO_CUSTOM - Static variable in interface com.tangosol.net.BackingMapManagerContext
The decoration id for a client specific (opaque) value information.
DECO_EXPIRY - Static variable in interface com.tangosol.net.BackingMapManagerContext
The decoration id for the value expiry information.
DECO_STORE - Static variable in interface com.tangosol.net.BackingMapManagerContext
The decoration id for the persistent state of the decorated value.
decode(char[]) - Static method in class com.tangosol.io.Base64InputStream
Decode the passed character data that was encoded using Base64 encoding.
decode(char[], boolean) - Static method in class com.tangosol.io.Base64InputStream
decode(char[], int, int) - Static method in class com.tangosol.io.Base64InputStream
decode(char[], int, int, boolean) - Static method in class com.tangosol.io.Base64InputStream
decode(char) - Static method in class com.tangosol.io.Base64InputStream
Decode one base64 alphabet character.
decode(PofReader, int) - Method in interface com.tangosol.io.pof.reflect.Codec
Deserialize an object from the provided PofReader.
decode(PofReader, int) - Method in class com.tangosol.io.pof.reflect.Codecs.DefaultCodec
decodeAttribute(String) - Static method in class com.tangosol.run.xml.XmlHelper
Decode an attribute value that was quoted.
decodeContent(String) - Static method in class com.tangosol.run.xml.XmlHelper
Decode an element's content value.
decodeCookie(HttpServletRequest) - Method in class com.tangosol.coherence.servlet.SessionHelper
Deprecated. Obtain a session ID from a request object by examining the cookies attached to the request.
decodeString(String) - Static method in class com.tangosol.run.xml.SimpleAdapter
Parse escaped string into a string.
decodeTinyInt(int) - Static method in class com.tangosol.io.pof.PofHelper
Decode an integer value from one of the reserved single-byte combined type and value indicators.
decodeUri(String) - Method in class com.tangosol.coherence.servlet.SessionHelper
Deprecated.
decodeUri(String) - Static method in class com.tangosol.run.xml.XmlHelper
Decode a System Identifier as per the XML 1.0 Specification 2nd ed section 4.2.2.
decodeUrl(HttpServletRequest) - Method in class com.tangosol.coherence.servlet.SessionHelper
Deprecated. Decodes the session ID from the URL represented by the passed request.
DecoratedBinaryDeltaCompressor - Class in com.tangosol.io
A DeltaCompressor implementation that works with decorated binary values.
DecoratedBinaryDeltaCompressor(DeltaCompressor) - Constructor for class com.tangosol.io.DecoratedBinaryDeltaCompressor
Construct a DecoratedBinaryDeltaCompressor.
DecorationOnlyDeltaCompressor - Class in com.tangosol.io
DecorationOnlyDeltaCompressor is a DeltaCompressor which optimizes for "decoration-only" updates.
DecorationOnlyDeltaCompressor() - Constructor for class com.tangosol.io.DecorationOnlyDeltaCompressor
decReferenceCount() - Method in class com.tangosol.coherence.servlet.RequestContext
Deprecated. Decrement the reference count.
decrement() - Method in class com.tangosol.util.ThreadGate.ThreadLocalCounter
Decrement the Long value of the ThreadLocalCounter for the current thread by one.
decrypt(SignedObject, Subject, Subject) - Method in interface com.tangosol.net.security.AccessController
Decrypt the specified SignedObject using the public credentials for a given encryptor Subject in a context represented by the decryptor Subject which is usually assosiated with the current thread.
decrypt(SignedObject, Subject, Subject) - Method in class com.tangosol.net.security.DefaultController
decrypt(SignedObject, PublicKey) - Method in class com.tangosol.net.security.DefaultController
Decrypt the specified SignedObject using the specified public key.
decryptPrivate(byte[]) - Method in class com.tangosol.net.security.AsymmetricEncryptionFilter
Deprecated. Decrypt the supplied data with the local private key.
dedupe() - Method in class com.tangosol.io.journal.AbstractJournalRM.CollectorDaemon
Give the in-memory radix key stores a chance to de-dupe their byte[] values, similar to the concept behind String's intern() method.
dedupe(byte[][]) - Method in class com.tangosol.io.journal.BackupJournalRM.FlashConsumer
This method may be invoked by the Journal implementation to request that any immutable byte arrays managed by the consumer be de-duplicated.
dedupe(byte[][]) - Method in class com.tangosol.io.journal.BackupJournalRM.RamConsumer
dedupe(byte[][]) - Method in interface com.tangosol.io.journal.Journal.JournalConsumer
dedupe(byte[][]) - Method in class com.tangosol.io.journal.JournalBinaryStore
dedupe(byte[][]) - Method in class com.tangosol.io.journal.RamJournalRM.FlashConsumer
DEFAULT_ADDRESS - Static variable in class com.tangosol.coherence.rest.server.AbstractHttpServer
Default HTTP server address.
DEFAULT_ALGORITHM - Static variable in class com.tangosol.net.security.SymmetricEncryptionFilter
Deprecated. Default cryptography algorithm
DEFAULT_BUF_SIZE - Static variable in class com.tangosol.io.MultiplexingWriteBufferPool
The default size of the smallest WriteBuffer.
DEFAULT_CACHE_CONFIG_PATH - Static variable in class com.tangosol.coherence.hibernate.CoherenceCacheProvider
The cache configuration file that defines Coherence caches for Hibernate
DEFAULT_CODEC - Static variable in class com.tangosol.io.pof.reflect.Codecs
A singleton instance of a Codecs.DefaultCodec
DEFAULT_CTXNAME - Static variable in class com.tangosol.coherence.servlet.SessionHelper
Deprecated. The default cache name for the ServletContext attribute map.
DEFAULT_EXPIRE - Static variable in class com.tangosol.net.cache.LocalCache
By default, the cache entries never expire.
DEFAULT_EXPIRE - Static variable in class com.tangosol.net.cache.OldCache
Deprecated. By default, the cache entries expire after one hour.
DEFAULT_FACTORY - Static variable in class com.tangosol.coherence.servlet.SessionHelper
Deprecated. The default class name for the SessionHelper factory implementation.
DEFAULT_FLUSH - Static variable in class com.tangosol.net.cache.OldCache
Deprecated. as of Coherence 3.5
DEFAULT_GROWTHRATE - Static variable in class com.tangosol.util.SafeHashMap
Using the default growth rate, the bucket array will grow by a factor of four.
DEFAULT_GROWTHRATE - Static variable in class com.tangosol.util.SegmentedHashMap
DEFAULT_HTTP_PORT - Static variable in class com.tangosol.net.management.MBeanConnector
Default HTTP port (8888).
DEFAULT_INITIALSIZE - Static variable in class com.tangosol.util.SafeHashMap
Default initial size provides a prime modulo and is large enough that resize is not immediate.
DEFAULT_INITIALSIZE - Static variable in class com.tangosol.util.SegmentedHashMap
DEFAULT_JITTER_THRESHOLD - Static variable in class com.tangosol.util.SafeClock
The default jitter threshold.
DEFAULT_KEY_LENGTH - Static variable in class com.tangosol.net.security.SymmetricEncryptionFilter
Deprecated. Default cryptography key length
DEFAULT_KEY_MASK - Variable in class com.tangosol.net.cache.LocalCache
The default key mask that ignores nothing.
DEFAULT_KEYSTORE_PATH - Static variable in class com.tangosol.net.security.AbstractEncryptionFilter
Deprecated. Default KeyStore path
DEFAULT_KEYSTORE_TYPE - Static variable in class com.tangosol.net.security.AbstractEncryptionFilter
Deprecated. Default KeyStore type
DEFAULT_KEYSTORE_TYPE - Static variable in class com.tangosol.net.security.SymmetricEncryptionFilter
Deprecated. Default KeyStore type.
DEFAULT_LIMIT - Static variable in class com.tangosol.io.AsyncBinaryStore
Default size limit for write-queued data.
DEFAULT_LOADFACTOR - Static variable in class com.tangosol.util.SafeHashMap
The default load factor is 100%, which means that the hash map will not resize until there is (on average) one entry in every bucket.
DEFAULT_LOADFACTOR - Static variable in class com.tangosol.util.SegmentedHashMap
DEFAULT_LOCK_LEASE_MILLIS - Static variable in class com.tangosol.coherence.hibernate.CoherenceCache
The default lock lease millis
DEFAULT_LOCK_OBTAIN_MILLIS - Static variable in class com.tangosol.coherence.hibernate.CoherenceCache
The default lock attempt millis
DEFAULT_MAX_LEVEL - Static variable in class com.tangosol.util.SafeSortedMap
The default limit on the index-level.
DEFAULT_MAX_SIZE - Static variable in class com.tangosol.io.nio.MappedBufferManager
Default maximum size for a memory mapped file.
DEFAULT_MAXLOADFACTOR - Static variable in class com.tangosol.io.nio.BinaryMap
Default value for the percentage of the modulo that the entry count must reach before going to the next bucket level.
DEFAULT_MGTNAME - Static variable in class com.tangosol.coherence.servlet.SessionHelper
Deprecated. The default cache name for the session management configuration data.
DEFAULT_MIN_SIZE - Static variable in class com.tangosol.io.nio.MappedBufferManager
Default minimum size for a memory mapped file.
DEFAULT_MINLOADFACTOR - Static variable in class com.tangosol.io.nio.BinaryMap
Default value for the percentage of the next lower bucket level's modulo that the entry count must drop to before reverting to the next lower bucket level.
DEFAULT_PORT - Static variable in class com.tangosol.coherence.rest.server.AbstractHttpServer
Default HTTP server port.
DEFAULT_PROVIDER - Static variable in class com.tangosol.net.SocketProviderFactory
The factory's default SocketProvider.
DEFAULT_PRUNE - Static variable in class com.tangosol.net.cache.OldCache
Deprecated. By default, when the cache prunes, it reduces its entries by this percentage.
DEFAULT_RECYCLE_MAX - Static variable in class com.tangosol.util.RecyclingLinkedList
The default maximum number of Nodes to recycle.
DEFAULT_RESOURCE - Static variable in class com.tangosol.io.pof.ConfigurablePofContext
The name of the application resource that contains the default set of wire-format-to-object bindings.
DEFAULT_RMI_CONNECTION_PORT - Static variable in class com.tangosol.net.management.MBeanConnector
Default RMI connection port (3000).
DEFAULT_RMI_HOST - Static variable in class com.tangosol.net.management.MBeanConnector
Default RMI host (localhost).
DEFAULT_RMI_REGISTRY_PORT - Static variable in class com.tangosol.net.management.MBeanConnector
Default RMI registry port (9000).
DEFAULT_SIZE - Static variable in class com.tangosol.util.SimpleMapIndex.IndexCalculator
The default size of an entry used if the calculator is unable to calculate the size.
DEFAULT_SPAN - Static variable in class com.tangosol.util.SafeSortedMap
The default span value.
DEFAULT_TRANSFORMATION - Static variable in class com.tangosol.net.security.AsymmetricEncryptionFilter
Deprecated. Default transformation
DEFAULT_UNITS - Static variable in class com.tangosol.net.cache.LocalCache
By default, the cache size (in units) is infinite.
DEFAULT_UNITS - Static variable in class com.tangosol.net.cache.OldCache
Deprecated. By default, the cache size (in units).
DEFAULT_WAIT_MILLIS - Static variable in class com.tangosol.net.DefaultCacheServer
The default number of milliseconds between checks for service restart.
DefaultAggregatorFactory - Class in com.tangosol.coherence.rest.util.aggregator
The default implementation of AggregatorFactory.
DefaultAggregatorFactory(Class) - Constructor for class com.tangosol.coherence.rest.util.aggregator.DefaultAggregatorFactory
Construct a DefaultAggregatorFactory instance.
DefaultCacheDelegator - Class in com.tangosol.coherence.servlet
DefaultCacheDelegator() - Constructor for class com.tangosol.coherence.servlet.DefaultCacheDelegator
DefaultCacheFactoryBuilder - Class in com.tangosol.net
Implementation of CacheFactoryBuilder that maintains a single ConfigurableCacheFactory instance regardless of the requesting ClassLoader if a URI is not provided.
DefaultCacheFactoryBuilder() - Constructor for class com.tangosol.net.DefaultCacheFactoryBuilder
DefaultCacheServer - Class in com.tangosol.net
DefaultCacheServer is a simple command line facility that starts all services that are declared as requiring an "autostart" in the configurable factory XML descriptor.
DefaultCacheServer(DefaultConfigurableCacheFactory) - Constructor for class com.tangosol.net.DefaultCacheServer
Construct a DefaultCacheServer using the provided factory.
DefaultCacheServer.ShutdownProcess - Class in com.tangosol.net
ShutdownHook implementation.
DefaultCacheServer.ShutdownProcess() - Constructor for class com.tangosol.net.DefaultCacheServer.ShutdownProcess
DefaultConfigurableCacheFactory - Class in com.tangosol.net
DefaultConfigurableCacheFactory provides a facility to access caches declared in a "cache-config.dtd" compliant configuration file.
DefaultConfigurableCacheFactory() - Constructor for class com.tangosol.net.DefaultConfigurableCacheFactory
Construct a default DefaultConfigurableCacheFactory using the default configuration file name.
DefaultConfigurableCacheFactory(String) - Constructor for class com.tangosol.net.DefaultConfigurableCacheFactory
Construct a DefaultConfigurableCacheFactory using the specified path to a "cache-config.dtd" compliant configuration file or resource.
DefaultConfigurableCacheFactory(String, ClassLoader) - Constructor for class com.tangosol.net.DefaultConfigurableCacheFactory
DefaultConfigurableCacheFactory(XmlElement) - Constructor for class com.tangosol.net.DefaultConfigurableCacheFactory
Construct a DefaultConfigurableCacheFactory using the specified configuration XML.
DefaultConfigurableCacheFactory(XmlElement, ClassLoader) - Constructor for class com.tangosol.net.DefaultConfigurableCacheFactory
DefaultConfigurableCacheFactory.CacheInfo - Class in com.tangosol.net
CacheInfo is a placeholder for cache attributes retrieved during parsing the corresponding cache mapping element.
DefaultConfigurableCacheFactory.CacheInfo(String, String, Map) - Constructor for class com.tangosol.net.DefaultConfigurableCacheFactory.CacheInfo
Construct a CacheInfo object.
DefaultConfigurableCacheFactory.Manager - Class in com.tangosol.net
BackingMapManager implementation that uses the configuration XML to create the required backing maps and provides client access to those maps.
DefaultConfigurableCacheFactory.Manager() - Constructor for class com.tangosol.net.DefaultConfigurableCacheFactory.Manager
DefaultConfigurableCacheFactory.PartitionedBackingMapManager - Class in com.tangosol.net
BackingMapManager implementation used by PartitionAwareBackingMap(s) to lazily configure the enclosing PABM based on the configuration settings of the enclosed maps.
DefaultConfigurableCacheFactory.PartitionedBackingMapManager(DefaultConfigurableCacheFactory.CacheInfo, XmlElement, BackingMapManagerContext, ClassLoader) - Constructor for class com.tangosol.net.DefaultConfigurableCacheFactory.PartitionedBackingMapManager
DefaultConnectionFactory - Class in com.tangosol.coherence.transaction
Connection factory used to obtain a logical connection to a Coherence cache service.
DefaultConnectionFactory() - Constructor for class com.tangosol.coherence.transaction.DefaultConnectionFactory
Construct a connection factory.
DefaultConnectionFactory(String) - Constructor for class com.tangosol.coherence.transaction.DefaultConnectionFactory
Construct a connection factory based on the specified configuration.
DefaultController - Class in com.tangosol.net.security
The default implementation of the AccessController interface.
DefaultController(File, File) - Constructor for class com.tangosol.net.security.DefaultController
Construct DefaultController for the specified key store file and permissions description (XML) file.
DefaultHttpServer - Class in com.tangosol.coherence.rest.server
Implementation of HttpServer that uses Sun's lightweight HTTP server to handle requests.
DefaultHttpServer() - Constructor for class com.tangosol.coherence.rest.server.DefaultHttpServer
DefaultIdentityAsserter - Class in com.tangosol.net.security
The default implementation of the IdentityAsserter interface.
DefaultIdentityAsserter() - Constructor for class com.tangosol.net.security.DefaultIdentityAsserter
DefaultIdentityTransformer - Class in com.tangosol.net.security
The default implementation of the IdentityTransformer interface, which simply returns the Subject that is passed to it.
DefaultIdentityTransformer() - Constructor for class com.tangosol.net.security.DefaultIdentityTransformer
DefaultKeyAssociator - Class in com.tangosol.net.partition
A DefaultKeyAssociator provides key associations on behalf of keys that implement the KeyAssociation interface.
DefaultKeyAssociator() - Constructor for class com.tangosol.net.partition.DefaultKeyAssociator
DefaultKeyConverter - Class in com.tangosol.coherence.rest
Default implementation of KeyConverter for a given key class.
DefaultKeyConverter(Class) - Constructor for class com.tangosol.coherence.rest.DefaultKeyConverter
Construct a DefaultKeyConverter instance.
DefaultKeyPartitioningStrategy - Class in com.tangosol.net.partition
DefaultKeyPartitioningStrategy provides a simple strategy for assigning keys to partitions which is based on the hash code of keys in internal (serialized to Binary) form.
DefaultKeyPartitioningStrategy() - Constructor for class com.tangosol.net.partition.DefaultKeyPartitioningStrategy
DefaultProxyServiceLoadBalancer - Class in com.tangosol.net.proxy
Default ProxyServiceLoadBalancer implementation.
DefaultProxyServiceLoadBalancer() - Constructor for class com.tangosol.net.proxy.DefaultProxyServiceLoadBalancer
DefaultProxyServiceLoadBalancer(Comparator) - Constructor for class com.tangosol.net.proxy.DefaultProxyServiceLoadBalancer
Create a new DefaultProxyServiceLoadBalancer that will order ProxyServiceLoad objects using the specified Comparator.
DefaultResourceConfig - Class in com.tangosol.coherence.rest.server
An extension of com.sun.jersey.api.core.ScanningResourceConfig that registers the Coherence REST root resource and provider classes, in addition to user defined package names.
DefaultResourceConfig() - Constructor for class com.tangosol.coherence.rest.server.DefaultResourceConfig
DefaultResourceConfig(String[]) - Constructor for class com.tangosol.coherence.rest.server.DefaultResourceConfig
Construct an instance of ResourceConfig that initialize Coherence predefined properties and searches for root resource classes and providers in the specified packages.
DefaultRootResource - Class in com.tangosol.coherence.rest
Default root resource implementation.
DefaultRootResource() - Constructor for class com.tangosol.coherence.rest.DefaultRootResource
DefaultSerializer - Class in com.tangosol.io
A Serializer implementation that uses the ExternalizableHelper implementation for serialization and deserialization of objects.
DefaultSerializer() - Constructor for class com.tangosol.io.DefaultSerializer
DefaultSerializer(ClassLoader) - Constructor for class com.tangosol.io.DefaultSerializer
Construct a DefaultSerializer that will use the passed ClassLoader.
DelegatingWriteBuffer - Class in com.tangosol.io
A DelegatingWriteBuffer is a WriteBuffer that writes through to an underlying (or "containing") WriteBuffer.
DelegatingWriteBuffer(WriteBuffer, int, int) - Constructor for class com.tangosol.io.DelegatingWriteBuffer
Construct a DelegatingWriteBuffer that will delegate to the containing WriteBuffer.
DelegatingWriteBuffer.DelegatingBufferOutput - Class in com.tangosol.io
A BufferOutput implementation that delegates to a BufferOutput implementation, except that its offset range is shifted and limited.
DelegatingWriteBuffer.DelegatingBufferOutput(int) - Constructor for class com.tangosol.io.DelegatingWriteBuffer.DelegatingBufferOutput
Construct an AbstractBufferOutput that will begin writing at the start of the containing WriteBuffer.
delete() - Method in class com.tangosol.coherence.rest.EntryResource
Remove the entry.
delete() - Method in class com.tangosol.coherence.rest.EntrySetResource
Remove the entries.
delete(Object, Filter) - Method in interface com.tangosol.coherence.transaction.OptimisticNamedCache
Delete an existing value.
delete(Map.Entry) - Method in interface com.tangosol.util.MapIndex
Update this index in response to a remove operation on a cache.
delete(Map.Entry) - Method in class com.tangosol.util.SimpleMapIndex
DELETED - Static variable in class com.tangosol.io.AsyncBinaryStore
A special token that is used to signify a queued erase operation.
deleteInternal(Map.Entry) - Method in class com.tangosol.util.ConditionalIndex
deleteInternal(Map.Entry) - Method in class com.tangosol.util.SimpleMapIndex
deleteModel(AbstractHttpSessionCollection, AbstractHttpSessionModel) - Method in interface com.tangosol.coherence.servlet.CacheDelegator
Delete the session from the cluster cache.
deleteModel(AbstractHttpSessionCollection, AbstractHttpSessionModel) - Method in class com.tangosol.coherence.servlet.DefaultCacheDelegator
deleteModel(AbstractHttpSessionCollection, AbstractHttpSessionModel) - Method in class com.tangosol.coherence.servlet.SessionLocalBackingMapCacheDelegator
deleteModelFromLocalCaches(String, AbstractHttpSessionModel) - Method in class com.tangosol.coherence.servlet.AbstractHttpSessionCollection
Deprecated.
delink() - Method in class com.tangosol.util.SafeLinkedList.Node
Remove this Node from the List.
DELTA_TRUNCATE - Static variable in class com.tangosol.io.BinaryDeltaCompressor
A delta value that indicates an empty new value.
DeltaCompressor - Interface in com.tangosol.io
The DeltaCompressor interface provides the capability of comparing two in-memory buffers containing an old and a new value, and producing a result (called a "delta") that can be applied to the old value to create the new value.
DeltaSet - Class in com.tangosol.util
Implements a set which is based on another set, which is assumed to be immutable.
DeltaSet(Set) - Constructor for class com.tangosol.util.DeltaSet
Construct this set based on an existing set.
DeltaSet.DeltaIterator - Class in com.tangosol.util
Iterator for the contents of a delta set.
DeltaSet.DeltaIterator() - Constructor for class com.tangosol.util.DeltaSet.DeltaIterator
Construct an iterator for a delta set.
DEPARTING - Static variable in class com.tangosol.net.events.PartitionedServiceDispatcher.TransferEvent.Type
This PartitionedServiceDispatcher.TransferEvent is dispatched when a set of BinaryEntrys are being transferred from the current member.
Dequeue - Class in com.tangosol.util
Represents a double-ended queue (dequeue) of objects.
Dequeue() - Constructor for class com.tangosol.util.Dequeue
Constructs a dequeue.
Description - Interface in com.tangosol.net.management.annotation
The Description annotation allows a description to be specified for a method on an MBean, and for an MBean interface itself.
deserialize(ReadBuffer.BufferInput) - Method in class com.tangosol.io.DefaultSerializer
Deserialize an object from a ReadBuffer by reading its state using the specified BufferInput object.
deserialize(ReadBuffer.BufferInput) - Method in class com.tangosol.io.pof.ConfigurablePofContext
deserialize(PofReader) - Method in class com.tangosol.io.pof.EnumPofSerializer
Deserialize a user type instance from a POF stream by reading its state using the specified PofReader object.
deserialize(PofReader) - Method in class com.tangosol.io.pof.ExternalizableLitePofSerializer
deserialize(PofReader) - Method in class com.tangosol.io.pof.ExternalizablePofSerializer
deserialize(PofReader) - Method in class com.tangosol.io.pof.PofAnnotationSerializer
deserialize(PofReader) - Method in interface com.tangosol.io.pof.PofSerializer
deserialize(PofReader) - Method in class com.tangosol.io.pof.PortableObjectSerializer
deserialize(PofReader) - Method in class com.tangosol.io.pof.PrincipalPofSerializer
deserialize(PofReader) - Method in class com.tangosol.io.pof.SafeConfigurablePofContext.JavaPofSerializer
deserialize(PofReader) - Method in class com.tangosol.io.pof.SafeConfigurablePofContext.SafePofSerializer
deserialize(ReadBuffer.BufferInput) - Method in class com.tangosol.io.pof.SimplePofContext
deserialize(PofReader) - Method in class com.tangosol.io.pof.SubjectPofSerializer
deserialize(PofReader) - Method in class com.tangosol.io.pof.ThrowablePofSerializer
deserialize(PofReader) - Method in class com.tangosol.io.pof.XmlSerializablePofSerializer
deserialize(ReadBuffer.BufferInput) - Method in interface com.tangosol.io.Serializer
deserialize(ReadBuffer.BufferInput) - Method in class com.tangosol.util.NullImplementation.NullPofContext
deserializeValue(Binary) - Method in class com.tangosol.coherence.servlet.OptimizedHolder
Take the Binary form of the attribute value and turn it into the object value.
destroy() - Method in class com.tangosol.coherence.hibernate.CoherenceCache
Release local (JVM) resources associated with this cache.
destroy(String) - Method in class com.tangosol.coherence.servlet.AbstractHttpSessionCollection
Deprecated. Destroy the specified session.
destroy(String) - Method in interface com.tangosol.coherence.servlet.HttpSessionCollection
destroy() - Method in class com.tangosol.net.cache.ContinuousQueryCache
Release and destroy this instance of NamedCache.
destroy() - Method in class com.tangosol.net.cache.NearCache
destroy() - Method in class com.tangosol.net.cache.ReadonlyNamedCache
Should not be called.
destroy() - Method in class com.tangosol.net.cache.SerializationPagedCache.WrapperBinaryStore
Destroy the underlying BinaryStore.
destroy() - Method in class com.tangosol.net.cache.WrapperNamedCache
DESTROY - Static variable in class com.tangosol.net.ClusterPermission
Create action.
destroy() - Method in interface com.tangosol.net.NamedCache
destroy() - Method in class com.tangosol.util.ConverterCollections.ConverterNamedCache
destroy() - Method in class com.tangosol.util.ThreadGate
Destroy the thread gate.
destroyBinaryStore(BinaryStore) - Method in class com.tangosol.io.AsyncBinaryStoreManager
Lifecycle method: Destroy a BinaryStore previously created by this manager.
destroyBinaryStore(BinaryStore) - Method in class com.tangosol.io.bdb.BerkeleyDBBinaryStoreManager
destroyBinaryStore(BinaryStore) - Method in interface com.tangosol.io.BinaryStoreManager
destroyBinaryStore(BinaryStore) - Method in class com.tangosol.io.journal.AbstractJournalRM
destroyBinaryStore(BinaryStore) - Method in class com.tangosol.io.journal.BackupJournalRM
destroyBinaryStore(BinaryStore) - Method in class com.tangosol.io.nio.AbstractStoreManager
destroyBinaryStore(BinaryStore) - Method in class com.tangosol.net.cache.SerializationPagedCache
Destroy and unregister a BinaryStore object that was previously created using this cache's BinaryStoreManager by the createBinaryStore method.
destroyCache(NamedCache) - Static method in class com.tangosol.net.CacheFactory
Releases and destroys the specified NamedCache.
destroyCache(NamedCache) - Method in interface com.tangosol.net.CacheService
Release and destroy the specified cache.
destroyCache(NamedCache) - Method in interface com.tangosol.net.ConfigurableCacheFactory
destroyCache(NamedCache) - Method in class com.tangosol.net.DefaultConfigurableCacheFactory
destroyCache(NamedCache) - Method in class com.tangosol.net.WrapperCacheService
destroyIndex(Map) - Method in class com.tangosol.util.extractor.ConditionalExtractor
Destroy an existing index and remove it from the given map of indexes.
destroyIndex(Map) - Method in interface com.tangosol.util.extractor.IndexAwareExtractor
destroyLocalAttributesCache(String) - Method in class com.tangosol.coherence.servlet.AbstractHttpSessionCollection
Deprecated. Destroy the cache of local-only session attributes for the specified session ID.
destroyPartition(int) - Method in class com.tangosol.net.partition.ObservableSplittingBackingCache
Remove a partition from the PartitionAwareBackingMap.
destroyPartition(int) - Method in class com.tangosol.net.partition.ObservableSplittingBackingMap
destroyPartition(int) - Method in interface com.tangosol.net.partition.PartitionAwareBackingMap
destroyPartition(int) - Method in class com.tangosol.net.partition.PartitionSplittingBackingMap
destroyPartition(int) - Method in class com.tangosol.net.partition.ReadWriteSplittingBackingMap
DFT_BACKLOG_SIZE - Static variable in class com.tangosol.io.journal.FlashJournalRM
Default maximum backlog (16MB).
DFT_BLOCK_SIZE - Static variable in class com.tangosol.io.journal.FlashJournalRM
Default block size (256KB).
DFT_COLLECT_PCT - Static variable in class com.tangosol.io.journal.FlashJournalRM
Default collection factor (collect files that are 25% or less utilized).
DFT_COLLECT_PCT - Static variable in class com.tangosol.io.journal.RamJournalRM
Default collection factor (collect files that are 84% or less utilized).
DFT_FILE_SIZE - Static variable in class com.tangosol.io.journal.FlashJournalRM
Default size of a file (2GB).
DFT_FILE_SIZE - Static variable in class com.tangosol.io.journal.RamJournalRM
Default size of a "file" i.e. a buffer (2MB).
DFT_POOL_SIZE - Static variable in class com.tangosol.io.journal.FlashJournalRM
Default pool size (16MB).
DFT_POOL_SIZE - Static variable in class com.tangosol.io.journal.RamJournalRM
DFT_PURGE_DELAY_MILLIS - Static variable in class com.tangosol.io.journal.FlashJournalRM
Default delay until a tmp file is eligible for purging. 2 hours is the default.
DFT_TOTAL_SIZE - Static variable in class com.tangosol.io.journal.RamJournalRM
Default total size of RAM used (1GB).
DFT_VALUE_SIZE - Static variable in class com.tangosol.io.journal.RamJournalRM
Default maximum value size (16KB).
diffCollection(ReadBuffer.BufferInput, ReadBuffer.BufferInput, PofDeltaCompressor.ChangeTracker) - Method in class com.tangosol.io.pof.PofDeltaCompressor
Within the two passed POF streams, parse and compare an array or collection.
diffMap(ReadBuffer.BufferInput, ReadBuffer.BufferInput, PofDeltaCompressor.ChangeTracker) - Method in class com.tangosol.io.pof.PofDeltaCompressor
Within the two passed POF streams, parse and compare a Map of keys and values.
diffPackedInt(ReadBuffer.BufferInput, ReadBuffer.BufferInput, PofDeltaCompressor.ChangeTracker) - Method in class com.tangosol.io.pof.PofDeltaCompressor
Within the two passed POF streams, parse and compare a packed integer value.
diffPackedInts(ReadBuffer.BufferInput, ReadBuffer.BufferInput, PofDeltaCompressor.ChangeTracker, int) - Method in class com.tangosol.io.pof.PofDeltaCompressor
Within the two passed POF streams, parse and compare a series of packed integer values.
diffPackedLong(ReadBuffer.BufferInput, ReadBuffer.BufferInput, PofDeltaCompressor.ChangeTracker) - Method in class com.tangosol.io.pof.PofDeltaCompressor
Within the two passed POF streams, parse and compare a packed long integer value.
diffPackedLongs(ReadBuffer.BufferInput, ReadBuffer.BufferInput, PofDeltaCompressor.ChangeTracker, int) - Method in class com.tangosol.io.pof.PofDeltaCompressor
Within the two passed POF streams, parse and compare a series of packed long integer values.
diffSparseArray(ReadBuffer.BufferInput, ReadBuffer.BufferInput, PofDeltaCompressor.ChangeTracker) - Method in class com.tangosol.io.pof.PofDeltaCompressor
Within the two passed POF streams, parse and compare a sparse array.
diffTimeZone(ReadBuffer.BufferInput, ReadBuffer.BufferInput, PofDeltaCompressor.ChangeTracker) - Method in class com.tangosol.io.pof.PofDeltaCompressor
Within the two passed POF streams, parse and compare time zone information.
diffUniformCollection(ReadBuffer.BufferInput, ReadBuffer.BufferInput, PofDeltaCompressor.ChangeTracker) - Method in class com.tangosol.io.pof.PofDeltaCompressor
Within the two passed POF streams, parse and compare an array or collection of uniform types.
diffUniformKeysMap(ReadBuffer.BufferInput, ReadBuffer.BufferInput, PofDeltaCompressor.ChangeTracker) - Method in class com.tangosol.io.pof.PofDeltaCompressor
Within the two passed POF streams, parse and compare a Map of keys (of a uniform type) and values.
diffUniformMap(ReadBuffer.BufferInput, ReadBuffer.BufferInput, PofDeltaCompressor.ChangeTracker) - Method in class com.tangosol.io.pof.PofDeltaCompressor
Within the two passed POF streams, parse and compare a Map of keys and values, both of uniform types.
diffUniformSparseArray(ReadBuffer.BufferInput, ReadBuffer.BufferInput, PofDeltaCompressor.ChangeTracker) - Method in class com.tangosol.io.pof.PofDeltaCompressor
Within the two passed POF streams, parse and compare a sparse array of uniform types.
diffUniformValue(ReadBuffer.BufferInput, ReadBuffer.BufferInput, PofDeltaCompressor.ChangeTracker, int) - Method in class com.tangosol.io.pof.PofDeltaCompressor
Within the two passed POF streams, parse and compare a POF value of the specified type.
diffUserType(ReadBuffer.BufferInput, ReadBuffer.BufferInput, PofDeltaCompressor.ChangeTracker) - Method in class com.tangosol.io.pof.PofDeltaCompressor
Within the two passed POF streams, parse and compare a user type value.
diffValue(ReadBuffer.BufferInput, ReadBuffer.BufferInput, PofDeltaCompressor.ChangeTracker) - Method in class com.tangosol.io.pof.PofDeltaCompressor
Within the two passed POF streams, parse and compare a POF value.
DirectBufferManager - Class in com.tangosol.io.nio
Manages a growable direct ByteBuffer.
DirectBufferManager(int, int) - Constructor for class com.tangosol.io.nio.DirectBufferManager
Construct a DirectBufferManager that supports a buffer of a certain initial and maximum size.
DirectStoreManager - Class in com.tangosol.io.nio
An implementation of BinaryStoreManager interface that uses BinaryMap objects built on the DirectBufferManager to provide BinaryStore objects.
DirectStoreManager(int, int) - Constructor for class com.tangosol.io.nio.DirectStoreManager
Construct a DirectStoreManager that uses BinaryMap objests built on the DirectBufferManager(s) with certain initial and maximum size.
disableServer(Member) - Method in class com.tangosol.coherence.commonj.WorkManager
Remove a Member from a list of active server nodes and terminate all work posted to that server.
discard() - Method in class com.tangosol.coherence.servlet.AbstractHttpSessionModel
Deprecated. When the session model is no longer usable, it is discarded.
discard() - Method in class com.tangosol.io.nio.BinaryMap.Block
Recycle the Block object, discarding any changes, resetting its contents and recycling the object.
discard() - Method in class com.tangosol.net.cache.OldCache.Entry
Deprecated. Called to inform the Entry that it is no longer used.
discard() - Method in class com.tangosol.util.RecyclingLinkedList.Node
Delink this Node and discard its value.
discard() - Method in class com.tangosol.util.SafeLinkedList.Node
dispatch(MapEvent) - Method in class com.tangosol.net.cache.ReadWriteBackingMap.InternalMapListener
Dispatch the event to the corresponding listeners.
dispatch(Listeners) - Method in class com.tangosol.net.MemberEvent
Dispatch this event to the specified listeners collection.
dispatch(EventListener[]) - Method in class com.tangosol.net.MemberEvent
Dispatch this event to the specified array of listeners.
dispatch(Listeners) - Method in class com.tangosol.util.MapEvent
dispatch(Listeners, boolean) - Method in class com.tangosol.util.MapEvent
dispatch(MapListener) - Method in class com.tangosol.util.MapEvent
Dispatch this event to the specified MapListener.
dispatch(Listeners) - Method in class com.tangosol.util.ServiceEvent
dispatch(EventListener[]) - Method in class com.tangosol.util.ServiceEvent
dispatchAttributeEvent(int, ServletContextAttributeEvent) - Method in class com.tangosol.coherence.servlet.SessionHelper
Deprecated. Dispatch a wrapped event to the application listeners.
dispatchEvent(CacheEvent) - Method in class com.tangosol.net.cache.AbstractSerializationCache
Dispatch the passed event.
dispatchEvent(MapEvent) - Method in class com.tangosol.net.cache.OldCache
Deprecated. Dispatch the passed event.
dispatchEvent(OverflowMap.Status, int, Object, Object, Object, boolean) - Method in class com.tangosol.net.cache.OverflowMap
Dispatch an event containing the passed event information.
dispatchEvent(OverflowMap.Status, MapEvent) - Method in class com.tangosol.net.cache.OverflowMap
dispatchEvent(MapEvent) - Method in class com.tangosol.util.ObservableHashMap
dispatchEvent(MapEvent) - Method in class com.tangosol.util.WrapperObservableMap
dispatchInternalAttributeEvent(int, ServletContextAttributeEvent) - Method in class com.tangosol.coherence.servlet.SessionHelper
dispatchPendingEvent(Object, int, Object, boolean) - Method in class com.tangosol.net.cache.AbstractSerializationCache
Dispatch an event that has not yet occurred, allowing the cache to potentially avoid reading of the "original value" information.
dispatchPendingEvent(Object, int, Object, boolean) - Method in class com.tangosol.util.WrapperObservableMap
Disposable - Interface in com.tangosol.util
The Disposable interface is used for life-cycle management of resources.
dispose() - Method in class com.tangosol.io.journal.AbstractJournalRM
dispose() - Method in class com.tangosol.io.journal.AbstractJournalRM.JournalFile
dispose() - Method in class com.tangosol.io.journal.AbstractJournalRM.JournalImpl
dispose() - Method in class com.tangosol.io.journal.BackupJournalRM
dispose() - Method in class com.tangosol.io.journal.BackupJournalRM.FlashConsumer
dispose() - Method in class com.tangosol.io.journal.BackupJournalRM.JournalImpl
dispose() - Method in class com.tangosol.io.journal.BackupJournalRM.RamConsumer
dispose() - Method in class com.tangosol.io.journal.FlashJournalRM.JournalFile
dispose() - Method in class com.tangosol.io.journal.JournalBinaryStore
dispose() - Method in class com.tangosol.io.journal.JournalService
Shut down and release the RAM, flash and backup Journal Resource Managers.
dispose() - Method in class com.tangosol.io.journal.RamJournalRM.FlashConsumer
dispose() - Method in class com.tangosol.io.journal.RamJournalRM.JournalFile
dispose() - Method in class com.tangosol.io.MultiBufferWriteBuffer
dispose() - Method in class com.tangosol.io.MultiplexingWriteBufferPool
dispose() - Method in class com.tangosol.io.nio.BinaryMapStore
DistinctValues - Class in com.tangosol.util.aggregator
Return the set of unique values extracted from a set of entries in a Map.
DistinctValues() - Constructor for class com.tangosol.util.aggregator.DistinctValues
Default constructor (necessary for the ExternalizableLite interface).
DistinctValues(ValueExtractor) - Constructor for class com.tangosol.util.aggregator.DistinctValues
Construct a DistinctValues aggregator.
DistinctValues(String) - Constructor for class com.tangosol.util.aggregator.DistinctValues
Construct an DistinctValues aggregator.
DISTRIBUTE - Static variable in interface com.tangosol.net.PartitionedService.PartitionedAction
Singleton action for partition distribution/backup.
DistributedCacheService - Interface in com.tangosol.net
A DistributedCacheService is a clustered cache service that partitions its data across cluster members that provide backing storage.
DistributionManager - Interface in com.tangosol.net.partition
A DistributionManager coordinates the distribution of partitions for a partitioned service.
doBalancePrimary(SimpleAssignmentStrategy.AnalysisContext, Member, PartitionSet, Member[]) - Method in class com.tangosol.net.partition.SimpleAssignmentStrategy
Do balancing transfers for primary distribution.
done() - Method in class com.tangosol.coherence.servlet.AbstractReapTask
Deprecated. Indicate that the reaping is done in this cycle.
DOUBLE_ARRAY_EMPTY - Static variable in class com.tangosol.io.pof.PofHelper
An empty array of doubles.
DoubleAverage - Class in com.tangosol.util.aggregator
Calculates an average for values of any numberic type extracted from a set of entries in a Map.
DoubleAverage() - Constructor for class com.tangosol.util.aggregator.DoubleAverage
DoubleAverage(ValueExtractor) - Constructor for class com.tangosol.util.aggregator.DoubleAverage
Construct a DoubleAverage aggregator.
DoubleAverage(String) - Constructor for class com.tangosol.util.aggregator.DoubleAverage
Construct an DoubleAverage object.
DoubleMax - Class in com.tangosol.util.aggregator
Calculates a maximum of numeric values extracted from a set of entries in a Map.
DoubleMax() - Constructor for class com.tangosol.util.aggregator.DoubleMax
DoubleMax(ValueExtractor) - Constructor for class com.tangosol.util.aggregator.DoubleMax
Construct a DoubleMax aggregator.
DoubleMax(String) - Constructor for class com.tangosol.util.aggregator.DoubleMax
DoubleMin - Class in com.tangosol.util.aggregator
Calculates a minimum of numeric values extracted from a set of entries in a Map.
DoubleMin() - Constructor for class com.tangosol.util.aggregator.DoubleMin
DoubleMin(ValueExtractor) - Constructor for class com.tangosol.util.aggregator.DoubleMin
Construct a DoubleMin aggregator.
DoubleMin(String) - Constructor for class com.tangosol.util.aggregator.DoubleMin
doubleRotate(AbstractSparseArray.Node, boolean) - Method in class com.tangosol.util.AbstractSparseArray
Double rotate a node in a given direction.
DoubleSum - Class in com.tangosol.util.aggregator
Sums up numeric values extracted from a set of entries in a Map.
DoubleSum() - Constructor for class com.tangosol.util.aggregator.DoubleSum
DoubleSum(ValueExtractor) - Constructor for class com.tangosol.util.aggregator.DoubleSum
Construct a DoubleSum aggregator.
DoubleSum(String) - Constructor for class com.tangosol.util.aggregator.DoubleSum
doubleValue() - Method in class com.tangosol.io.pof.RawQuad
Returns the value of the specified number as a double.
doWait(long) - Method in class com.tangosol.util.ThreadGate
Wait up to the specified number of milliseconds for notification.
dump() - Method in class com.tangosol.io.nio.BinaryMap
Debugging support: Dump the inner structures of the BinaryMap to stdout.
dump() - Method in class com.tangosol.util.CircularArrayList
Outputs information to standard output about representation for debugging purposes.
dump() - Method in class com.tangosol.util.SafeSortedMap
Return a human-readable description of this map's internal state.
DuplexingPofHandler - Class in com.tangosol.io.pof
An implementation of PofHandler that passes each call onto two different PofHandler objects.
DuplexingPofHandler(PofHandler, PofHandler) - Constructor for class com.tangosol.io.pof.DuplexingPofHandler
Construct a duplexing PofHandler that will pass on method calls to two different PofHandler objects.
E
E_ALL - Static variable in class com.tangosol.util.filter.MapEventFilter
This value indicates that all events should be evaluated.
E_DELETED - Static variable in class com.tangosol.util.filter.MapEventFilter
This value indicates that ENTRY_DELETED events should be evaluated.
E_INSERTED - Static variable in class com.tangosol.util.filter.MapEventFilter
This value indicates that ENTRY_INSERTED events should be evaluated.
E_KEYSET - Static variable in class com.tangosol.util.filter.MapEventFilter
This value indicates that all events that would affect the result of a QueryMap.keySet(com.tangosol.util.Filter) query should be evaluated.
E_UPDATED - Static variable in class com.tangosol.util.filter.MapEventFilter
This value indicates that ENTRY_UPDATED events should be evaluated.
E_UPDATED_ENTERED - Static variable in class com.tangosol.util.filter.MapEventFilter
This value indicates that ENTRY_UPDATED events should be evaluated, but only if filter evaluation is false for the old value and true for the new value.
E_UPDATED_LEFT - Static variable in class com.tangosol.util.filter.MapEventFilter
This value indicates that ENTRY_UPDATED events should be evaluated, but only if filter evaluation is true for the old value and false for the new value.
E_UPDATED_WITHIN - Static variable in class com.tangosol.util.filter.MapEventFilter
This value indicates that ENTRY_UPDATED events should be evaluated, but only if filter evaluation is true for both the old and the new value.
effectiveIndex(int) - Method in class com.tangosol.util.CircularArrayList
Calculate the effective index taking into account offsets and the circular nature of CircularArrayList.
elements() - Method in class com.tangosol.util.LiteSet
Returns an Enumerator over the elements in this Set.
elements() - Method in class com.tangosol.util.StringTable
Create an enumerator for the values in the table.
elements() - Method in class com.tangosol.util.Tree
Create an enumerator for the tree's values.
EMPTY - Static variable in class com.tangosol.io.Base64InputStream
Empty binary data.
EMPTY - Static variable in class com.tangosol.util.SimpleLongArray
Empty array of objects.
EMPTY_ARRAY - Static variable in class com.tangosol.util.CopyOnWriteLongArray
An empty placeholder array.
EMPTY_BYTE_ARRAY - Static variable in class com.tangosol.net.security.BlockCipherInputStream
Initial value for m_abBlockClear
EMPTY_BYTES - Static variable in class com.tangosol.io.MultiByteArrayInputStream
Empty array of bytes.
ENABLED - Static variable in class com.tangosol.net.security.Security
Indicates if security is enabled by the operational configuration.
enableReference() - Method in class com.tangosol.io.pof.PofBufferWriter
Ensure that reference support (necessary for cyclic dependencies) is enabled.
enableReference() - Method in class com.tangosol.io.pof.PofBufferWriter.UserTypeWriter
encode(byte[]) - Static method in class com.tangosol.io.Base64OutputStream
Encode the passed binary data using Base64 encoding.
encode(byte[], boolean) - Static method in class com.tangosol.io.Base64OutputStream
encode(byte[], int, int, boolean) - Static method in class com.tangosol.io.Base64OutputStream
encode(PofWriter, int, Object) - Method in interface com.tangosol.io.pof.reflect.Codec
Serialize an object using the provided PofWriter.
encode(PofWriter, int, Object) - Method in class com.tangosol.io.pof.reflect.Codecs.AbstractCodec
encodeAttribute(String, char) - Static method in class com.tangosol.run.xml.XmlHelper
Encode an attribute value so that it can be quoted and made part of a valid and well formed XML document.
encodeContent(String, boolean) - Static method in class com.tangosol.run.xml.XmlHelper
Encode an element's content value so that it can be made part of a valid and well formed XML document.
encodeCookie(HttpServletRequest, HttpServletResponse, String, boolean) - Method in class com.tangosol.coherence.servlet.SessionHelper
Deprecated. Encode a session ID into a cookie and attach it to the response object.
encodeGeneration(int, int) - Static method in class com.tangosol.io.MultiplexingWriteBufferPool
Return the buffer allocation size for a given generation.
encodeInitParams(XmlElement, XmlElement) - Static method in class com.tangosol.run.xml.XmlHelper
Encode the supplied xmlConfig XmlElement as a series of init-param elements.
encodePosition(int) - Method in class com.tangosol.io.pof.WritingPofHandler
Called for each and every value going into the POF stream, in case the value needs its position to be encoded into the stream.
encodeString(String) - Static method in class com.tangosol.run.xml.SimpleAdapter
encodeTicket(int, long, int) - Method in class com.tangosol.io.journal.AbstractJournalRM
Encode a file number, offset and length into a "ticket".
encodeTicket(ByteSequence) - Method in class com.tangosol.io.journal.AbstractJournalRM
Encode a Binary into a "ticket".
encodeTicket(int, long, int) - Method in class com.tangosol.io.journal.FlashJournalRM
encodeTicket(int, long, int) - Method in class com.tangosol.io.journal.RamJournalRM
encodeTinyInt(int) - Static method in class com.tangosol.io.pof.PofHelper
Encode an integer value into one of the reserved single-byte combined type and value indicators.
encodeUri(String) - Static method in class com.tangosol.run.xml.XmlHelper
Encode a System Identifier as per the XML 1.0 Specification second edition, section 4.2.2.
encodeUrl(String, HttpServletRequest) - Method in class com.tangosol.coherence.servlet.SessionHelper
Deprecated. Encodes the specified URL by including the session ID in it, or, if encoding is not needed, returns the URL unchanged.
encodeUrl(String, String) - Method in class com.tangosol.coherence.servlet.SessionHelper
Deprecated. Encodes the specified URL by including the given session ID in it.
encrypt(Object, Subject) - Method in interface com.tangosol.net.security.AccessController
Encrypt the specified object using the private credentials for the given Subject (encryptor), which is usually assosiated with the current thread.
encrypt(Object, Subject) - Method in class com.tangosol.net.security.DefaultController
encrypt(Serializable, PrivateKey) - Method in class com.tangosol.net.security.DefaultController
Encrypt the specified object using the specified private key.
encryptPrivate(byte[], Member) - Method in class com.tangosol.net.security.AsymmetricEncryptionFilter
Deprecated. Encrypt the supplied data for privacy using the supplied Member's public key.
end() - Method in class com.tangosol.io.pof.LoggingPofHandler
End a complex data structure.
endBulkKeyProcess(Object[], SimpleOverflowMap.Status[]) - Method in class com.tangosol.net.cache.SimpleOverflowMap
Finish the processing of any number of keys.
endComplexValue() - Method in class com.tangosol.io.pof.AbstractPofHandler
Signifies the termination of the current complex value.
endComplexValue() - Method in class com.tangosol.io.pof.DuplexingPofHandler
endComplexValue() - Method in class com.tangosol.io.pof.LoggingPofHandler
endComplexValue() - Method in interface com.tangosol.io.pof.PofHandler
endComplexValue() - Method in class com.tangosol.io.pof.ValidatingPofHandler
endComplexValue() - Method in class com.tangosol.io.pof.WritingPofHandler
endComplexValue() - Method in class com.tangosol.util.NullImplementation.NullPofHandler
endKeyProcess(Object, OverflowMap.Status) - Method in class com.tangosol.net.cache.OverflowMap
Finish the processing of a single key.
endKeyProcess(Object, SimpleOverflowMap.Status) - Method in class com.tangosol.net.cache.SimpleOverflowMap
endMapProcess() - Method in class com.tangosol.net.cache.OverflowMap
Release exclusive access for the OverflowMap.
endMapProcess() - Method in class com.tangosol.net.cache.SimpleOverflowMap
endProperty(int) - Method in class com.tangosol.io.pof.PofBufferWriter
Signifies the termination of the current POF property.
endProperty(int) - Method in class com.tangosol.io.pof.PofBufferWriter.UserTypeWriter
endsWith(Binary) - Method in class com.tangosol.util.Binary
Tests if this Binary object ends with the specified suffix.
engineGetTrustManagers() - Method in class com.tangosol.net.security.PeerX509TrustManagerFactory
Return one trust manager for each type of trust material.
engineInit(KeyStore) - Method in class com.tangosol.net.security.PeerX509TrustManagerFactory
Initialize this factory with a source of certificate authorities and related trust material.
engineInit(ManagerFactoryParameters) - Method in class com.tangosol.net.security.PeerX509TrustManagerFactory
Initialize this factory with a source of provider-specific key material.
enlist(TransactionMap, Object) - Method in class com.tangosol.run.jca.SimpleValidator
Enlist the resource with the specified transaction.
enlist(TransactionMap, Object) - Method in interface com.tangosol.util.TransactionMap.Validator
enqueue(Binary) - Method in class com.tangosol.io.journal.AbstractJournalRM.JournalFile
Enqueue a Binary value to be written to this file, returning a ticket, or return 0L if this file is full and the append has to occur to a new file.
enqueue(Binary) - Method in class com.tangosol.io.journal.FlashJournalRM.JournalFile
enqueue(Binary) - Method in class com.tangosol.io.journal.RamJournalRM.JournalFile
enqueueBuffer(FlashJournalRM.JournalFile, FlashJournalRM.Buffer, int) - Method in class com.tangosol.io.journal.FlashJournalRM.WriterDaemon
Notify the writer thread that a buffer needs to be written.
ensureAdded() - Method in class com.tangosol.util.DeltaSet
Get a mutable set of items that were added to the delta set.
ensureAttributeSerializationFailureMap() - Method in class com.tangosol.coherence.servlet.MonolithicHttpSessionModel
Deprecated. Ensure that the map of attributes that cannot be written exists, creating it if necessary, and return it.
ensureBackupJournalRM() - Method in class com.tangosol.io.journal.JournalService
Ensure there is a configured BackupJournalRM.
ensureBackupJournalRM(Cluster) - Method in class com.tangosol.net.DefaultConfigurableCacheFactory
Ensure the BackupJournalRM is configured and started.
ensureBigDecimal(Number) - Static method in class com.tangosol.util.aggregator.AbstractBigDecimalAggregator
Ensure the specified Number is a BigDecimal value or convert it into a new BigDecimal object.
ensureBuffer(Socket) - Method in class com.tangosol.net.LoadBalancer.SocketHandler
Return the existing buffer, if there is one, or create one to use for reading from the passed socket.
ensureBufferOutput(int) - Method in class com.tangosol.io.MultiBufferWriteBuffer
Obtain the internal MultiBufferOutput, creating it if necessary.
ensureCache(MapEvent) - Method in class com.tangosol.net.cache.AbstractEvictionPolicy
Return the ConfigurableCacheMap that uses this eviction policy.
ensureCache(String, ClassLoader) - Method in interface com.tangosol.net.CacheService
Obtain a NamedCache interface that provides a view of resources shared among members of a cluster.
ensureCache(String, ClassLoader) - Method in interface com.tangosol.net.ConfigurableCacheFactory
Ensure a cache for the given name using the corresponding XML configuration.
ensureCache(String, ClassLoader) - Method in class com.tangosol.net.DefaultConfigurableCacheFactory
ensureCache(DefaultConfigurableCacheFactory.CacheInfo, XmlElement, ClassLoader) - Method in class com.tangosol.net.DefaultConfigurableCacheFactory
Obtain the NamedCache reference for the cache service defined by the specified scheme.
ensureCache(String, ClassLoader) - Method in class com.tangosol.net.WrapperCacheService
ensureCapacity(int) - Method in class com.tangosol.util.CircularArrayList
Increase the capacity of this list instance, if necessary, to ensure that it can hold at least the specified number of elements.
ensureCluster() - Method in class com.tangosol.coherence.servlet.SessionHelper
Deprecated. Ensure the coherence cluster.
ensureCluster() - Static method in class com.tangosol.net.CacheFactory
Obtain a Cluster object running Coherence services.
ensureCompactness() - Method in class com.tangosol.util.CircularArrayList
Ensure the representation of this list is appropriatly compact by shrinking if necessary.
ensureConfigCCFMap(ClassLoader) - Method in class com.tangosol.net.ScopedCacheFactoryBuilder
Ensure that a map from URI to ConfigurableCacheFactory for the specified loader exists (creating it if necessary).
ensureConfigurationCache() - Method in class com.tangosol.coherence.servlet.SessionHelper
Deprecated. Get the NamedCache used to store configuration and management information for the session management implementation if it exists, otherwise create it.
ensureConnection(SocketAddress) - Method in class com.tangosol.net.TcpDatagramSocket.Impl
Obtain a Connection for the specified address.
ensureConverted(Converter) - Method in class com.tangosol.util.filter.InKeySetFilter
Ensure that the underlying keys are converted using the specified converter.
ensureCurrentJournalFile() - Method in class com.tangosol.io.journal.AbstractJournalRM
Obtain the current JournalFile that is being appended to, creating a new one if necessary.
ensureCurrentJournalFile() - Method in class com.tangosol.io.journal.FlashJournalRM
ensureData() - Method in class com.tangosol.net.security.BlockCipherInputStream
Ensure that there is some data available for read, blocking on the wrapped stream if necessary.
ensureDelegate() - Method in class com.tangosol.net.WrapperSocketProvider
Return the delegate SocketProvider, creating one if necessary.
ensureEffectiveIndex(int) - Method in class com.tangosol.util.CircularArrayList
After range checking Calculate the effective index while taking into account the offsets and the circular nature of the list.
ensureElement(String) - Method in class com.tangosol.run.xml.SimpleElement
Ensure that a child element exists.
ensureElement(String) - Method in interface com.tangosol.run.xml.XmlElement
ensureElement(XmlElement, String) - Static method in class com.tangosol.run.xml.XmlHelper
ensureEraseBundler(int) - Method in class com.tangosol.net.cache.ReadWriteBackingMap.StoreWrapper
Configure the bundler for the "erase" operations.
ensureEventQueue() - Method in class com.tangosol.net.cache.ContinuousQueryCache
Obtain the existing event queue or create one if none exists.
ensureFactory(BerkeleyDBBinaryStoreManager) - Method in class com.tangosol.io.bdb.DatabaseFactoryManager
Find, or if needed create a DatabaseFactory for the specified manager.
ensureFlashJournalRM() - Method in class com.tangosol.io.journal.JournalService
Ensure there is a configured FlashJournalRM.
ensureFlashJournalRM(Cluster) - Method in class com.tangosol.net.DefaultConfigurableCacheFactory
Ensure the FlashJournalRM is configured and started.
ensureGetBundler(int) - Method in class com.tangosol.net.cache.BundlingNamedCache
Configure the bundler for the "get" operations.
ensureGlobalName(String) - Method in interface com.tangosol.net.management.Registry
Convert the passed MBean name to a global name if necessary.
ensureHttpSession(String) - Method in class com.tangosol.coherence.servlet.SessionHelper
Deprecated. Get the HttpSession object for the specified ID.
ensureIndexMap() - Method in class com.tangosol.net.cache.ContinuousQueryCache
Ensure that the map of indexes maintained by this cache exists.
ensureInitialized() - Method in class com.tangosol.coherence.hibernate.HibernateCacheLoader
Called by all API-implementing methods for lazy initialization.
ensureInitialized() - Method in class com.tangosol.io.pof.ConfigurablePofContext
Fully initialize the ConfigurablePofContext if it has not already been initialized.
ensureInputStream() - Method in class com.tangosol.io.WrapperInputStream
Return the underlying InputStream.
ensureInternalBinary() - Method in class com.tangosol.coherence.servlet.OptimizedHolder
Obtain the non-null internally managed binary value.
ensureInternalBinary() - Method in class com.tangosol.coherence.servlet.SplittableHolder
ensureInternalIterator() - Method in class com.tangosol.net.CompositeAddressProvider
Create (if necessary) and return the default iterator.
ensureInternalListener() - Method in class com.tangosol.util.WrapperObservableMap
Obtain the internal MapListener, creating one if necessary.
ensureInvalidationStrategy() - Method in class com.tangosol.net.cache.CachingMap
Ensure that a strategy has been chosen and that any appropriate global listeners have been registered.
ensureInvocationService() - Method in class com.tangosol.coherence.weblogic.PortalCacheProvider
Obtain the Coherence InvocationService used by the CacheProvider, initializing it if it hasn't already been initialized.
ensureIterator() - Method in class com.tangosol.net.RefreshableAddressProvider
Return the cache iterator.
ensureJournalService(Cluster) - Method in class com.tangosol.net.DefaultConfigurableCacheFactory
Ensure the JournalService is registered as a cluster resource.
ensureListener(MapIndex) - Static method in class com.tangosol.util.InvocableMapHelper
Ensure a MapListener for the given index.
ensureLoadBundler(int) - Method in class com.tangosol.net.cache.ReadWriteBackingMap.StoreWrapper
Configure the bundler for the "load" operations.
ensureLoadFactor(SegmentedHashMap.Segment) - Method in class com.tangosol.util.SegmentedHashMap
Check whether or not the specified segment is overloaded and if so, grow the bucket array (which suggests with high probability that the per-segment load will decrease).
ensureLocalAttributesCache(String) - Method in class com.tangosol.coherence.servlet.AbstractHttpSessionCollection
Deprecated. Get the cache of local-only session attributes for the specified session ID.
ensureLocalCache() - Method in class com.tangosol.coherence.weblogic.PortalCacheProvider.CacheImpl
Return the LocalCache of non-serializable entries, creating it first if necessary.
ensureMap() - Method in class com.tangosol.util.aggregator.ReducerAggregator
Return a map that can be used to store reduced values, creating it if one has not already been created.
ensureMapListenerSupport() - Method in class com.tangosol.util.WrapperObservableMap
Obtain the MapListenerSupport, creating it if necessary.
ensureMutable() - Method in class com.tangosol.run.xml.XmlBean
Make sure that this XML bean is mutable.
ensureNamespace(XmlElement, String, String) - Static method in class com.tangosol.run.xml.XmlHelper
Ensure the existence of the Namespace declaration attribute in a context of the specified XmlElement.
ensureOutputStream() - Method in class com.tangosol.io.WrapperOutputStream
Return the underlying OutputStream.
ensureProvider(XmlElement) - Method in class com.tangosol.net.SocketProviderFactory
Return an instance of the specified provider, creating it if necessary.
ensurePutBundler(int) - Method in class com.tangosol.net.cache.BundlingNamedCache
Configure the bundler for the "put" operations.
ensureQueueDaemon() - Method in class com.tangosol.io.AsyncBinaryStore
Obtain the QueueDaemon, if one already exists; otherwise, create and start one.
ensureRamJournalRM() - Method in class com.tangosol.io.journal.JournalService
Ensure there is a configured RAMJournalRM.
ensureRAMJournalRM(Cluster) - Method in class com.tangosol.net.DefaultConfigurableCacheFactory
Ensure the RamJournalRM is configured and started.
ensureReadOnly() - Method in class com.tangosol.run.xml.XmlBean
Make sure that this value is read-only (immutable).
ensureReferenceRegistry() - Method in class com.tangosol.io.pof.PofBufferReader
Obtain the registry for identity-reference pairs, creating it if necessary.
ensureRegistration() - Static method in class com.tangosol.net.security.SecurityProvider
Ensure that an instance of this provider has been registered with the system.
ensureRemoveBundler(int) - Method in class com.tangosol.net.cache.BundlingNamedCache
Configure the bundler for the "remove" operations.
ensureRemoved() - Method in class com.tangosol.util.DeltaSet
Get a mutable set of items that were removed from the delta set.
ensureRemoved() - Method in class com.tangosol.util.SubSet
Get a mutable set of items that are removed in the subset.
ensureResults() - Method in class com.tangosol.net.cache.AbstractBinaryEntryBundler.Bundle
Obtain results of the bundled requests.
ensureResults() - Method in class com.tangosol.net.cache.AbstractBundler.Bundle
ensureResults(boolean) - Method in class com.tangosol.net.cache.AbstractBundler.Bundle
Obtain results of the bundled requests or ensure that the results have already been retrieved.
ensureResults() - Method in class com.tangosol.net.cache.AbstractEntryBundler.Bundle
ensureResults() - Method in class com.tangosol.net.cache.AbstractKeyBundler.Bundle
ensureRetained() - Method in class com.tangosol.util.SubSet
Get a mutable set of items that are retained in the subset.
ensureSecurityException(Throwable) - Static method in class com.tangosol.net.security.AbstractEncryptionFilter
Deprecated. Convert the passed exception to a SecurityException if necessary.
ensureSecurityException(Throwable, String) - Static method in class com.tangosol.net.security.AbstractEncryptionFilter
ensureService(String, String) - Method in interface com.tangosol.net.Cluster
Obtains a Service object for the specified service name and type.
ensureService(String) - Method in interface com.tangosol.net.ConfigurableCacheFactory
Ensure a service for the given name using the corresponding XML configuration.
ensureService(String) - Method in class com.tangosol.net.DefaultConfigurableCacheFactory
ensureService(XmlElement) - Method in class com.tangosol.net.DefaultConfigurableCacheFactory
Ensure the service for the specified scheme.
ensureServiceInternal(XmlElement) - Method in class com.tangosol.net.DefaultConfigurableCacheFactory
ensureServletContextAttributeCache() - Method in class com.tangosol.coherence.servlet.SessionHelper
Deprecated. Get the clustered attribute map if it exists, otherwise create it (if the ServletContext is supposed to be clustered).
ensureSessionHelper(ServletContext) - Static method in class com.tangosol.coherence.servlet.SessionHelper
Deprecated. Find the existing (or create new) Coherence SessionHelper that will act as a coordinator to manage the creation and lookup of container objects, fake container objects (the Coherence implementation of the Servlet spec interfaces), and helper classes (such as the SessionHelper itself, the servlet model collection, etc.).
ensureSessionWorkerDaemon() - Method in class com.tangosol.coherence.servlet.SessionHelper
Deprecated. Get the daemon thread that is used for scheduled tasks, creating it if necessary.
ensureSet(Set) - Method in class com.tangosol.net.ConfigurableQuorumPolicy.ClusterQuorumPolicy
Return the specified set, or an empty set if null.
ensureSet() - Method in class com.tangosol.util.aggregator.DistinctValues
Return a set that can be used to store distinct values, creating it if one has not already been created.
ensureSingletonMBean(String) - Static method in class com.tangosol.net.management.MBeanHelper
Ensure that there is an instance of a local MBean of the specified type registered with the default MBeansServer.
ensureSocketException(IOException) - Static method in class com.tangosol.net.TcpDatagramSocket.Impl
Convert an IOException into a SocketException.
ensureStep(Filter) - Method in interface com.tangosol.util.QueryRecord.PartialResult.ExplainStep
Ensure an inner nested explain step for the given filter.
ensureStep(Filter) - Method in interface com.tangosol.util.QueryRecord.PartialResult.TraceStep
Ensure an inner nested trace step for the given filter.
ensureStep(Filter) - Method in class com.tangosol.util.SimpleQueryRecord.PartialResult.ExplainStep
ensureStep(Filter) - Method in class com.tangosol.util.SimpleQueryRecord.PartialResult.TraceStep
ensureStoreBundler(int) - Method in class com.tangosol.net.cache.ReadWriteBackingMap.StoreWrapper
Configure the bundler for the "store" operations.
ensureSynchronized(boolean) - Method in class com.tangosol.net.cache.ContinuousQueryCache
Ensure that the ContinuousQueryCache listeners have been registered and its content synchronized with the underlying NamedCache.
ensureSynthetic() - Method in class com.tangosol.net.cache.LocalCache.KeyMask
Ensure that the synthetic operation flag is set.
ensureType(Object, int, PofContext) - Static method in class com.tangosol.io.pof.reflect.PofReflectionHelper
Validate that the supplied object is compatible with the specified type.
ensureType(int) - Method in class com.tangosol.run.xml.SimpleValue
Change the type of the internal representation of the XmlValue.
ensureUpdatedPartitions() - Method in class com.tangosol.net.partition.SimpleAssignmentStrategy.AnalysisContext
Ensure and return the set of updated partitions.
ensureWrappedServletContext(ServletContext) - Static method in class com.tangosol.coherence.servlet.SessionHelper
Deprecated. Make sure that there is a ServletContext wrapper for the specified servlet context for this application, creating one if necessary.
enter(String, boolean) - Method in class com.tangosol.coherence.servlet.AbstractHttpSessionCollection
Deprecated. Obtain any necessary ownership for the specified session.
enter(String, boolean, boolean) - Method in class com.tangosol.coherence.servlet.AbstractHttpSessionCollection
enter() - Method in class com.tangosol.coherence.servlet.AbstractHttpSessionModel
Deprecated. Increment the usage count of the session by this thread.
enter(String, boolean) - Method in interface com.tangosol.coherence.servlet.HttpSessionCollection
enter(String, boolean, boolean) - Method in interface com.tangosol.coherence.servlet.HttpSessionCollection
enter(long) - Method in interface com.tangosol.util.Gate
Enter the gate.
enter(long) - Method in class com.tangosol.util.ThreadGate
Enter the gate.
enter(long) - Method in class com.tangosol.util.ThreadGateLite
Enter the gate.
enter(long) - Method in class com.tangosol.util.WrapperReentrantGate
Enter the gate.
enterSession(String) - Method in class com.tangosol.coherence.servlet.SessionHelper
enterWriteAttributes() - Method in class com.tangosol.coherence.servlet.MonolithicHttpSessionModel
Deprecated. Specify that the attributes are now being written.
ENTRY - Static variable in class com.tangosol.io.nio.BinaryMap.Block
State of a block that holds an Entry object's data.
ENTRY_DELETED - Static variable in class com.tangosol.net.cache.OverflowMap
This event indicates that an entry has been removed from the map.
ENTRY_DELETED - Static variable in class com.tangosol.net.cache.SimpleOverflowMap
ENTRY_DELETED - Static variable in class com.tangosol.util.MapEvent
ENTRY_INSERTED - Static variable in class com.tangosol.net.cache.OverflowMap
This event indicates that an entry has been added to the map.
ENTRY_INSERTED - Static variable in class com.tangosol.net.cache.SimpleOverflowMap
ENTRY_INSERTED - Static variable in class com.tangosol.util.MapEvent
ENTRY_TO_KEY_CONVERTER - Static variable in class com.tangosol.util.InvocableMapHelper
Trivial Entry-to-Key converter.
ENTRY_UPDATED - Static variable in class com.tangosol.net.cache.OverflowMap
This event indicates that an entry has been updated in the map.
ENTRY_UPDATED - Static variable in class com.tangosol.net.cache.SimpleOverflowMap
ENTRY_UPDATED - Static variable in class com.tangosol.util.MapEvent
EntryAwareComparator - Interface in com.tangosol.util.comparator
EntryAwareComparator is an extension to the Comparator interface that allows the EntryComparator to know whether the underlying comparator expects to compare the corresponding Entries' keys or values.
EntryComparator - Class in com.tangosol.util.comparator
Comparator implementation used to compare map entries.
EntryComparator() - Constructor for class com.tangosol.util.comparator.EntryComparator
Default constructor (for ExternalizableLite and PortableObject).
EntryComparator(Comparator) - Constructor for class com.tangosol.util.comparator.EntryComparator
Construct an EntryComparator to compare entries' values using the provided Comparator object.
EntryComparator(Comparator, int) - Constructor for class com.tangosol.util.comparator.EntryComparator
Construct an EntryComparator to compare entries using the provided Comparator object according to the specified comparison style.
entryDeleted(MapEvent) - Method in class com.tangosol.net.cache.AbstractEvictionPolicy
Invoked when a map entry has been removed.
entryDeleted(MapEvent) - Method in class com.tangosol.net.cache.CachingMap.FrontMapListener
entryDeleted(MapEvent) - Method in class com.tangosol.net.cache.LocalCache.InternalListener
entryDeleted(MapEvent) - Method in class com.tangosol.net.cache.ReadWriteBackingMap.InternalMapListener
entryDeleted(MapEvent) - Method in class com.tangosol.net.cache.SeppukuMapListener
entryDeleted(MapEvent) - Method in class com.tangosol.net.cache.VersionedNearCache.VersionCacheListener
Deprecated. Invoked when a map entry has been removed.
entryDeleted(MapEvent) - Method in class com.tangosol.util.AbstractMapListener
entryDeleted(MapEvent) - Method in class com.tangosol.util.ConverterCollections.ConverterMapListener
entryDeleted(MapEvent) - Method in class com.tangosol.util.InvocableMapHelper.IndexAdapter
entryDeleted(MapEvent) - Method in interface com.tangosol.util.MapListener
entryDeleted(MapEvent) - Method in class com.tangosol.util.MapListenerSupport.WrapperSynchronousListener
entryDeleted(MapEvent) - Method in class com.tangosol.util.MultiplexingMapListener
EntryExtractor - Class in com.tangosol.util.extractor
The EntryExtractor is a base abstract class for special purpose custom ValueExtractor implementations.
EntryExtractor() - Constructor for class com.tangosol.util.extractor.EntryExtractor
Default constructor (for backward compatibilty).
EntryExtractor(int) - Constructor for class com.tangosol.util.extractor.EntryExtractor
Construct an EntryExtractor based on the entry extraction target.
EntryFilter - Interface in com.tangosol.util.filter
EntryFilter provides an extension to Filter for those cases in which both a key and a value may be necessary to evaluate the conditional inclusion of a particular object.
entryFromBucket(SegmentedHashMap.Entry[], int) - Static method in class com.tangosol.util.SegmentedHashMap
Return the first non-synthetic Entry object contained by in the specified bucket.
entryInserted(MapEvent) - Method in class com.tangosol.net.cache.AbstractEvictionPolicy
Invoked when a map entry has been inserted.
entryInserted(MapEvent) - Method in class com.tangosol.net.cache.LocalCache.InternalListener
entryInserted(MapEvent) - Method in class com.tangosol.net.cache.ReadWriteBackingMap.InternalMapListener
entryInserted(MapEvent) - Method in class com.tangosol.net.cache.SeppukuMapListener
entryInserted(MapEvent) - Method in class com.tangosol.util.AbstractMapListener
entryInserted(MapEvent) - Method in class com.tangosol.util.ConverterCollections.ConverterMapListener
entryInserted(MapEvent) - Method in class com.tangosol.util.InvocableMapHelper.IndexAdapter
entryInserted(MapEvent) - Method in interface com.tangosol.util.MapListener
entryInserted(MapEvent) - Method in class com.tangosol.util.MapListenerSupport.WrapperSynchronousListener
entryInserted(MapEvent) - Method in class com.tangosol.util.MultiplexingMapListener
EntryResource - Class in com.tangosol.coherence.rest
REST resource representing a single cache entry.
EntryResource(NamedCache, Object, Class, MarshallerRegistry) - Constructor for class com.tangosol.coherence.rest.EntryResource
Construct EntryResource.
entrySet() - Method in class com.tangosol.coherence.weblogic.PortalCacheProvider.CacheImpl
Returns a Set view of the mappings contained in this cache.
entrySet() - Method in class com.tangosol.io.nio.BinaryMap
Returns a set view of the mappings contained in this map.
entrySet() - Method in class com.tangosol.io.pof.PofHelper.ReadableEntrySetMap
entrySet() - Method in class com.tangosol.io.pof.PofHelper.WriteableEntrySetMap
entrySet() - Method in class com.tangosol.net.cache.CachingMap
Obtain an set view of the mappings contained in this map.
entrySet(Filter) - Method in class com.tangosol.net.cache.ContinuousQueryCache
Return a set view of the entries contained in this map that satisfy the criteria expressed by the filter.
entrySet(Filter, Comparator) - Method in class com.tangosol.net.cache.ContinuousQueryCache
entrySet(Filter) - Method in class com.tangosol.net.cache.NearCache
entrySet(Filter, Comparator) - Method in class com.tangosol.net.cache.NearCache
entrySet() - Method in class com.tangosol.net.cache.ReadWriteBackingMap
Returns an set view of the mappings contained in this map.
entrySet(Filter) - Method in class com.tangosol.net.cache.WrapperNamedCache
entrySet(Filter, Comparator) - Method in class com.tangosol.net.cache.WrapperNamedCache
entrySet() - Method in class com.tangosol.run.xml.SimpleElement.AttributeMap
entrySet() - Method in class com.tangosol.util.AbstractKeyBasedMap
entrySet() - Method in class com.tangosol.util.ChainedMap
entrySet() - Method in class com.tangosol.util.ConverterCollections.ConverterMap
entrySet(Filter) - Method in class com.tangosol.util.ConverterCollections.ConverterNamedCache
entrySet(Filter, Comparator) - Method in class com.tangosol.util.ConverterCollections.ConverterNamedCache
entrySet(Filter) - Method in class com.tangosol.util.ConverterCollections.ConverterQueryMap
entrySet(Filter, Comparator) - Method in class com.tangosol.util.ConverterCollections.ConverterQueryMap
entrySet() - Method in class com.tangosol.util.EntrySetMap
entrySet() - Method in class com.tangosol.util.LiteMap
entrySet() - Method in class com.tangosol.util.NullImplementation.NullMap
entrySet(Filter) - Method in interface com.tangosol.util.QueryMap
entrySet(Filter, Comparator) - Method in interface com.tangosol.util.QueryMap
entrySet() - Method in class com.tangosol.util.RestrictedCollections.RestrictedMap
entrySet() - Method in class com.tangosol.util.SafeHashMap
entrySet() - Method in class com.tangosol.util.SafeSortedMap
entrySet() - Method in class com.tangosol.util.SafeSortedMap.ViewMap
entrySet() - Method in class com.tangosol.util.SegmentedHashMap
entrySet() - Method in class com.tangosol.util.WrapperCollections.AbstractWrapperMap
entrySet() - Method in class com.tangosol.util.WrapperCollections.ConcurrentWrapperMap
EntrySetMap - Class in com.tangosol.util
A trivial Map implementation that is based on a specified set of entries.
EntrySetMap(Set) - Constructor for class com.tangosol.util.EntrySetMap
EntrySetResource - Class in com.tangosol.coherence.rest
REST resource representing a set of cache entries.
EntrySetResource(NamedCache, Set, Class) - Constructor for class com.tangosol.coherence.rest.EntrySetResource
Construct an EntrySetResource.
entryTouched(ConfigurableCacheMap.Entry) - Method in interface com.tangosol.net.cache.ConfigurableCacheMap.EvictionPolicy
This method is called by the cache to indicate that an entry has been touched.
entryTouched(ConfigurableCacheMap.Entry) - Method in class com.tangosol.net.cache.OldCache.InternalEvictionPolicy
Deprecated. This method is called by the cache to indicate that an entry has been touched.
entryTouched(ConfigurableCacheMap.Entry) - Method in class com.tangosol.net.cache.SerializationCache.InternalEvictionPolicy
entryUpdated(MapEvent) - Method in class com.tangosol.net.cache.AbstractEvictionPolicy
Invoked when a map entry has been updated.
entryUpdated(ConfigurableCacheMap.Entry) - Method in class com.tangosol.net.cache.AbstractEvictionPolicy
This method is called to indicate that an entry has been either inserted or updated.
entryUpdated(MapEvent) - Method in class com.tangosol.net.cache.LocalCache.InternalListener
entryUpdated(MapEvent) - Method in class com.tangosol.net.cache.ReadWriteBackingMap.InternalMapListener
entryUpdated(MapEvent) - Method in class com.tangosol.net.cache.SeppukuMapListener
entryUpdated(MapEvent) - Method in class com.tangosol.net.cache.VersionedNearCache.VersionCacheListener
Deprecated. Invoked when a map entry has been updated.
entryUpdated(MapEvent) - Method in class com.tangosol.util.AbstractMapListener
entryUpdated(MapEvent) - Method in class com.tangosol.util.ConverterCollections.ConverterMapListener
entryUpdated(MapEvent) - Method in class com.tangosol.util.InvocableMapHelper.IndexAdapter
entryUpdated(MapEvent) - Method in interface com.tangosol.util.MapListener
entryUpdated(MapEvent) - Method in class com.tangosol.util.MapListenerSupport.WrapperSynchronousListener
entryUpdated(MapEvent) - Method in class com.tangosol.util.MultiplexingMapListener
EnumerationIterator - Class in com.tangosol.util
Provide a implementation of an Iterator based on data from an Enumeration.
EnumerationIterator(Enumeration) - Constructor for class com.tangosol.util.EnumerationIterator
Construct the Iterator based on an Enumeration.
EnumPofSerializer - Class in com.tangosol.io.pof
PofSerializer implementation that can be used to serialize all enum values.
EnumPofSerializer() - Constructor for class com.tangosol.io.pof.EnumPofSerializer
ENVIRONMENT_NAME_PREFIX - Static variable in class com.tangosol.io.bdb.DatabaseFactory.EnvironmentHolder
Prefix for temporary environment names.
equals(Object) - Method in class com.tangosol.coherence.commonj.WorkManager.WorkHolder
Compare this WorkItem with the specified object for equality.
equals(Object) - Method in class com.tangosol.coherence.transaction.ConnectionSpecImpl
Indicates whether some other object is "equal to" this one.
equals(Object) - Method in class com.tangosol.io.AbstractByteArrayReadBuffer
Compare two ReadBuffer objects for equality.
equals(Object) - Method in class com.tangosol.io.AbstractReadBuffer
equals(Object) - Method in class com.tangosol.io.bdb.BerkeleyDBBinaryStoreManager
Compares two BerkeleyDBBinaryStoreManagers for equality.
equals(Object) - Method in class com.tangosol.io.pof.PofPrincipal
Compares this Principal to the specified object.
equals(Object) - Method in class com.tangosol.io.pof.RawDate
Compare this object with another for equality.
equals(Object) - Method in class com.tangosol.io.pof.RawDateTime
equals(Object) - Method in class com.tangosol.io.pof.RawDayTimeInterval
equals(Object) - Method in class com.tangosol.io.pof.RawQuad
equals(Object) - Method in class com.tangosol.io.pof.RawTime
equals(Object) - Method in class com.tangosol.io.pof.RawTimeInterval
equals(Object) - Method in class com.tangosol.io.pof.RawYearMonthInterval
equals(Object) - Method in class com.tangosol.io.pof.reflect.SimplePofPath
Compare the SimplePofPath with another object to determine equality.
equals(Object) - Method in interface com.tangosol.io.ReadBuffer
equals(Object) - Method in interface com.tangosol.net.AddressProvider
AddressProvider instances are considered equivalent iff they consistently produce the same resulting set of addresses.
equals(Object) - Method in class com.tangosol.net.cache.BackingMapBinaryEntry
Compares the specified object with this entry for equality.
equals(Object) - Method in class com.tangosol.net.cache.ContinuousQueryCache.EventRouter
Compare the EventRouter with another object to determine equality.
equals(Object) - Method in class com.tangosol.net.cache.ReadWriteBackingMap
Compares the specified object with this map for equality.
equals(Object) - Method in class com.tangosol.net.cache.SimpleOverflowMap.HashcodeComparator
equals(Object) - Method in class com.tangosol.net.ClusterPermission
Checks two Permission objects for equality.
equals(Object) - Method in class com.tangosol.net.CompositeAddressProvider
equals(Object) - Method in class com.tangosol.net.CompositeAddressProvider.SingleProvider
equals(Object) - Method in class com.tangosol.net.ConfigurableAddressProvider.AddressHolder
Return true iff this AddressHolder is equal to the specified Object.
AddressProvider instances should compare to be equals() iff they should be expected to consistently produce the same resulting set of addresses.
equals(Object) - Method in class com.tangosol.net.management.ObjectNameExcludeFilter
Compare the ObjectNameExcludeFilter with another object to determine equality.
equals(Object) - Method in class com.tangosol.net.partition.Ownership
equals(Object) - Method in class com.tangosol.net.partition.PartitionSet
equals(Object) - Method in class com.tangosol.net.partition.SimplePartitionKey
equals(Object) - Method in class com.tangosol.net.RefreshableAddressProvider
equals(Object) - Method in class com.tangosol.net.security.SimpleHandler
Compare this principal to the specified object.
equals(Object) - Method in class com.tangosol.run.xml.SimpleDocument
Compare this XML document and all of its contained information with another XML document for equality.
equals(Object) - Method in class com.tangosol.run.xml.SimpleElement.AttributeMap
Compare this XML element and all of its contained information with another XML element for equality.
equals(Object) - Method in class com.tangosol.run.xml.SimpleValue
Compare this XML value with another XML value for equality.
equals(Object) - Method in class com.tangosol.run.xml.XmlBean
Determine if this value object is equal to the passed value object.
equals(Object) - Method in interface com.tangosol.run.xml.XmlDocument
equals(Object) - Method in interface com.tangosol.run.xml.XmlElement
equals(Object) - Method in interface com.tangosol.run.xml.XmlValue
equals(Object) - Method in class com.tangosol.util.AbstractByteSequence
equals(Object) - Method in class com.tangosol.util.AbstractKeyBasedMap
equals(Object) - Method in class com.tangosol.util.AbstractLongArray
Test for LongArray equality.
equals(Object) - Method in class com.tangosol.util.aggregator.AbstractAggregator
Compares this object with another object for equality.
equals(Object) - Method in class com.tangosol.util.aggregator.CompositeAggregator
Compare the CompositeAggregator with another object to determine equality.
equals(Object) - Method in class com.tangosol.util.aggregator.GroupAggregator
Compare the GroupAggregator with another object to determine equality.
equals(Object) - Method in class com.tangosol.util.Binary
Compares this Binary object with another object for equality.
equals(byte[], int, byte[], int, int) - Static method in class com.tangosol.util.Binary
Compare two binary regions, testing for equality.
equals(Object) - Method in class com.tangosol.util.CacheCollator
Compares the equality of two Collators.
equals(Object) - Method in class com.tangosol.util.ClassFilter
Compare the ClassFilter with another object to determine equality.
equals(Object) - Method in class com.tangosol.util.comparator.ChainedComparator
Determine if two ChainedComparator objects are equal.
equals(Object) - Method in class com.tangosol.util.comparator.EntryComparator
Determine if two EntryComparator objects are equal.
equals(Object) - Method in class com.tangosol.util.comparator.InverseComparator
Compare the InverseComparator with another object to determine equality.
equals(Object) - Method in class com.tangosol.util.comparator.SafeComparator
Determine if two comparators are equal.
equals(Object) - Method in class com.tangosol.util.CompositeKey
equals(Object) - Method in class com.tangosol.util.ConditionalIndex
Compares the specified object with this index for equality.
equals(Object) - Method in class com.tangosol.util.ConverterCollections.AbstractConverterEntry
equals(Object) - Method in class com.tangosol.util.ConverterCollections.ConverterCollection
Compares the specified object with this collection for equality.
equals(Object) - Method in class com.tangosol.util.ConverterCollections.ConverterEntrySet
equals(Object) - Method in class com.tangosol.util.ConverterCollections.ConverterList
equals(Object) - Method in class com.tangosol.util.ConverterCollections.ConverterMap
equals(Object) - Method in class com.tangosol.util.ConverterCollections.ConverterMapListener
Compare the ConverterMapListener with another object to determine equality.
equals(Object) - Method in class com.tangosol.util.ConverterCollections.ConverterSet
equals(Object) - Method in class com.tangosol.util.extractor.AbstractCompositeExtractor
Compare the AbstractCompositeExtractor with another object to determine equality.
equals(Object) - Method in class com.tangosol.util.extractor.ConditionalExtractor
Compare the ValueExtractor with another object to determine equality.
equals(Object) - Method in class com.tangosol.util.extractor.IdentityExtractor
Compare the IdentityExtractor with another object to determine equality.
equals(Object) - Method in class com.tangosol.util.extractor.KeyExtractor
Compare the KeyExtractor with another object to determine equality.
equals(Object) - Method in class com.tangosol.util.extractor.PofExtractor
Compare the PofExtractor with another object to determine equality.
equals(Object) - Method in class com.tangosol.util.extractor.PofUpdater
Compare the PofUpdater with another object to determine equality.
equals(Object) - Method in class com.tangosol.util.extractor.ReflectionExtractor
Compare the ReflectionExtractor with another object to determine equality.
equals(Object) - Method in class com.tangosol.util.extractor.ReflectionUpdater
Compare the ReflectionUpdater with another object to determine equality.
equals(Object) - Method in class com.tangosol.util.filter.AlwaysFilter
Compare the AlwaysFilter with another object to determine equality.
equals(Object) - Method in class com.tangosol.util.filter.ArrayFilter
Compare the ArrayFilter with another object to determine equality.
equals(Object) - Method in class com.tangosol.util.filter.ComparisonFilter
Compare the ComparisonFilter with another object to determine equality.
equals(Object) - Method in class com.tangosol.util.filter.FilterTrigger
Compare the FilterTrigger with another object to determine equality.
equals(Object) - Method in class com.tangosol.util.filter.KeyAssociatedFilter
Compare the KeyAssociatedFilter with another object to determine equality.
equals(Object) - Method in class com.tangosol.util.filter.MapEventFilter
Compare the MapEventFilter with another object to determine equality.
equals(Object) - Method in class com.tangosol.util.filter.MapEventTransformerFilter
Compare the MapEventTransformerFilter with another object to determine equality.
equals(Object) - Method in class com.tangosol.util.filter.NeverFilter
Compare the NeverFilter with another object to determine equality.
equals(Object) - Method in class com.tangosol.util.filter.NotFilter
Compare the NotFilter with another object to determine equality.
equals(Object) - Method in class com.tangosol.util.filter.PartitionedFilter
Compare the PartitionedFilter with another object to determine equality.
equals(Object) - Method in class com.tangosol.util.filter.PresentFilter
Compare the PresentFilter with another object to determine equality.
equals(Object) - Method in class com.tangosol.util.filter.ValueChangeEventFilter
Compare the ValueChangeEventFilter with another object to determine equality.
equals(Object) - Method in class com.tangosol.util.ImmutableArrayList
Compare this Collection / List / Set / SortedSet with some other Object and determine if the caller would believe this Object to equal that other Object.
equals(Object) - Method in class com.tangosol.util.ImmutableArrayList.ListView
equals(Object) - Method in class com.tangosol.util.ImmutableArrayList.SetView
equals(Object) - Method in class com.tangosol.util.ImmutableArrayList.SortedSetView
equals(Object) - Method in class com.tangosol.util.ImmutableMultiList
Compare this Collection / List / Set with some other Object and determine if the caller would believe this Object to equal that other Object.
equals(Object) - Method in class com.tangosol.util.ImmutableMultiList.ListView
Compares the specified object with this list for equality.
equals(Object) - Method in class com.tangosol.util.ImmutableMultiList.SetView
Compares the specified object with this set for equality.
equals(Object) - Method in class com.tangosol.util.InflatableCollection
equals(Object) - Method in class com.tangosol.util.InflatableList
equals(Object) - Method in class com.tangosol.util.InvocableMapHelper.IndexAdapter
Compare this IndexMapListener with another object for equality.
equals(Object) - Method in class com.tangosol.util.InvocableMapHelper.SimpleEntry
Compare this SimpleEntry with another object for equality.
equals(Object) - Method in interface com.tangosol.util.LongArray
equals(Object) - Method in class com.tangosol.util.MapListenerSupport.WrapperSynchronousListener
Compare the WrapperSynchronousListener with another object to determine equality.
equals(Object) - Method in class com.tangosol.util.NullFilter
Compare the NullFilter with another object to determine equality.
equals(Object) - Method in class com.tangosol.util.NullImplementation.NullFlatRegistry
equals(Object) - Method in class com.tangosol.util.NullImplementation.NullMap
equals(Object) - Method in class com.tangosol.util.NullImplementation.NullSet
equals(Object) - Method in class com.tangosol.util.NullImplementation.NullValueExtractor
equals(Object) - Method in class com.tangosol.util.processor.CompositeProcessor
Compare the ConditionalProcessor with another object to determine equality.
equals(Object) - Method in class com.tangosol.util.processor.ConditionalProcessor
equals(Object) - Method in class com.tangosol.util.processor.ConditionalPut
Compare the ConditionalPut with another object to determine equality.
equals(Object) - Method in class com.tangosol.util.processor.ConditionalPutAll
Compare the ConditionalPutAll with another object to determine equality.
equals(Object) - Method in class com.tangosol.util.processor.ConditionalRemove
Compare the ConditionalRemove with another object to determine equality.
equals(Object) - Method in class com.tangosol.util.processor.ExtractorProcessor
Compare the ExtractorProcessor with another object to determine equality.
equals(Object) - Method in class com.tangosol.util.processor.PreloadRequest
Compare the PreloadRequest with another object to determine equality.
equals(Object) - Method in class com.tangosol.util.processor.PropertyManipulator
Compare the PropertyManipulator with another object to determine equality.
equals(Object) - Method in class com.tangosol.util.processor.PropertyProcessor
Compare the PropertyProcessor with another object to determine equality.
equals(Object) - Method in class com.tangosol.util.processor.UpdaterProcessor
Compare the UpdaterProcessor with another object to determine equality.
equals(Object) - Method in class com.tangosol.util.processor.VersionedPut
Compare the VersionedPut with another object to determine equality.
equals(Object) - Method in class com.tangosol.util.processor.VersionedPutAll
Compare the VersionedPutAll with another object to determine equality.
equals(Object) - Method in class com.tangosol.util.RestrictedCollections.RestrictedCollection
equals(Object) - Method in class com.tangosol.util.RestrictedCollections.RestrictedEntrySet
equals(Object) - Method in class com.tangosol.util.RestrictedCollections.RestrictedEntrySet.RestrictedEntry
equals(Object) - Method in class com.tangosol.util.RestrictedCollections.RestrictedEntrySet.RestrictedIterator
Compares the specified object with this Iterator for equality.
equals(Object) - Method in class com.tangosol.util.RestrictedCollections.RestrictedMap
equals(Object) - Method in class com.tangosol.util.SafeHashMap.Entry
equals(Object) - Method in class com.tangosol.util.SafeLinkedList.Node
Compare this Node with an object for equality.
equals(Object) - Method in class com.tangosol.util.SafeSortedMap.EntryNode.MapEntry
equals(Object) - Method in class com.tangosol.util.SegmentedHashMap.Entry
equals(Object) - Method in class com.tangosol.util.SimpleMapEntry
equals(Object) - Method in class com.tangosol.util.SimpleMapIndex
equals(Object) - Method in class com.tangosol.util.SimpleQueryRecord.PartialResult.IndexLookupRecord
equals(Object) - Method in class com.tangosol.util.StringTable
Test for equality of two string tables.
equals(Object) - Method in class com.tangosol.util.SubList
equals(Object) - Method in class com.tangosol.util.transformer.
