| Oracle® Enterprise Manager Cloud Control Advanced Installation and Configuration Guide 12c Release 1 (12.1.0.1) E24089-15 |
![]() Previous |
![]() Next |
This chapter explains how you can install only the software binaries of Enterprise Manager Cloud Control at one point, and configure the installation at a later point. In particular, this chapter covers the following:
Note: Do NOT install the Enterprise Manager system on an OCFS file system. This file system is not supported. |
You can choose to install only the software binaries of Enterprise Manager Cloud Control at one point and configure it at a later point in time to work with an existing, certified Oracle Database. This approach enables you to divide the installation process into two phases, mainly the installation phase and the configuration phase. Understandably, the installation phase takes less time compared to the configuration phase because the installation phase involves only copying of binaries. This approach helps you plan your installation according to the time and priorities you have.
During the installation phase, you invoke the installer to create Oracle homes and install the following components in the middleware home:
Java Development Kit (JDK) 1.6 v24
Oracle WebLogic Server 11g Release 1 (10.3.5)
Oracle Management Service 12c
Oracle Management Agent 12c
Oracle JRF 11g Release (11.1.1.4.0), which includes oracle_common directory
Oracle Web Tier 11g Release (11.1.1.4.0), which includes Oracle_WT directory
Oracle Management Plug-Ins
Oracle Database Management Plug-In
Oracle Fusion Middleware Management Plug-In
Oracle My Oracle Support Management Plug-In
Oracle Exadata Management Plug-In
During the configuration phase, you invoke a configuration script to do the following:
Create an Oracle WebLogic domain called GCDomain. For this WebLogic Domain, a default user account, weblogic, is used as the administrative user. You can choose to change this, if you want, in the installer.
Create a Node Manager user account called nodemanager. A Node Manager enables you to start, shut down, or restart an Oracle WebLogic Server instance remotely, and is recommended for applications with high availability requirements.
Configure an Oracle Management Service Instance Base location (gc_inst) in the middleware home, for storing all configuration details related to Oracle Management Service 12c.
For example, if the middleware home is /u01/app/Oracle/Middleware/, then the instance base location is /u01/app/Oracle/Middleware/gc_inst.
Configures Oracle Management Repository in the existing, certified Oracle Database.
Runs the following configuration assistants to configure the installed or upgraded components:
Plugins Prerequisites Check
Repository Configuration
MDS Schema Configuration
OMS Configuration
Plugins Deployment and Configuration
Plugins Inventory Migration
Oracle Configuration Manager Repeater Configuration
Agent Configuration Assistant
Before you begin, keep these points in mind:
You must ensure that you have the latest Enterprise Manager Cloud Control software:
Ensure that you have the Enterprise Manager Cloud Control software released in February 2012 - Enterprise Manager Cloud Control 12c Release 1 (12.1.0.1) (With Bundle Patch 1). You can download it from the following URL:
http://www.oracle.com/technetwork/oem/enterprise-manager/downloads/index.html
If you had downloaded and installed the Enterprise Manager Cloud Control software released in October 2011, then apply the following patches, which are part of the Bundle Patch 1 released in February 2012, on the OMS and the Management Agent. In this case, you do not have to download the one released in February 2012.
On OMS, apply the patch 13242773.
On Management Agent, apply the patches 13242776, 13491785, 13550565, and 13550561.
To apply these patches, you can either read the My Oracle Support note 1395505.1 or the ReadMes packaged with the patches.
If you had downloaded the Enterprise Manager Cloud Control software released in October 2011, but not installed it yet, then discard that software and download the one released in February 2012 - Enterprise Manager Cloud Control 12c Release 1 (12.1.0.1) (With Bundle Patch 1. You can download it from the following URL:
Ensure that there are no white spaces in the name of the directory where you download and run the Enterprise Manager Cloud Control software from. For example, do not download and run the software from a directory titled Program Files because there is a white space between the two words of the directory name.
You can install Enterprise Manager Cloud Control using the installation wizard only on a single host, that is, locally on the server where the wizard is invoked. You cannot install on multiple or remote hosts.
To invoke the installation wizard on UNIX platforms, run runInstaller. To invoke on Microsoft Windows platforms, run setup.exe.
Enterprise Manager Cloud Control 12c can communicate only with Oracle Management Agent 12c, and not with any earlier release of the Management Agent.
You must not set the ORACLE_HOME and ORACLE_SID environment variables. You must ensure that the Oracle directories do NOT appear in the PATH.
Do not install on a symlink. If you do, then you will not be able to clone this OMS later.
The Enterprise Manager Cloud Control Installation Wizard installs Java Development Kit (JDK) 1.6 v24 and Oracle WebLogic Server 11g Release 1 (10.3.5), but only if they do not exist in your environment.
(Only for Graphical Mode) You must set the DISPLAY environment variable.
In bash terminal, run the following command:
export DISPLAY=<hostname>:<vnc port>.0
For example, export DISPLAY=example.com:1.0
In other terminals, run the following command:
setenv DISPLAY <hostname>:1.0
For example, setenv DISPLAY example.com:1.0
If Oracle WebLogic Server 11g Release 1 (10.3.5) does not exist and if you choose to manually install it, then ensure that you install it using JDK 1.6 v24+ (64-bit version for 64-bit platforms and 32-bit version for 32-bit platforms).
Download JDK 1.6 v24+ for your platform from the platform vendor's Web site. For example, download SUN JDK 1.6 v24+ for Linux platforms from Oracle Web site. Similarly, download the JDK for other platforms from other vendors' trusted Web sites.
If you already have JDK, then verify its version by navigating to the <JDK_Location>/bin directory and running the following command:
"./java -fullversion"
To verify whether it is a 32-bit or a 64-bit JDK, run the following command:
"file *"
JROCKIT is not supported.
If you want to manually install Oracle WebLogic Server 11g Release 1 (10.3.5) on Linux 64-bit platforms, first install the 64-bit JDK for your platform, and then download and use the wls1035_generic.jar file to install Oracle WebLogic Server.
For example,
<JDK home>/bin/java -d64 -jar <absolute_path _to_wls1035_generic.jar>
If you want to manually install Oracle WebLogic Server 11g Release 1 (10.3.5) on Linux 32-bit platforms, then download and use either the wls1035_linux32.bin file or the wls1035_generic.jar file.
For example,
<JDK home>/bin/java -jar <absolute_path _to_wls1035_generic.jar>
You must follow the instructions outlined in the Oracle Fusion Middleware Installation Guide for Oracle WebLogic Server to install Oracle WebLogic Server. The guide is available in the Fusion Middleware documentation library available at:
http://www.oracle.com/technetwork/middleware/weblogic/documentation/index.html
You must ensure that the Oracle WebLogic Server installation is a typical installation, and even if you choose to perform a custom installation, ensure that components chosen for custom installation are the same as the ones associated with a typical installation.
You must ensure that the user installing the WebLogic Server is the same as the one installing Enterprise Manager Cloud Control.
If you are installing Enterprise Manager Cloud Control in a middleware home that is on an NFS-mounted drive, then ensure that you maintain the lock file in a local file system and not in that NFS-mounted location. To do so, modify the lock file location in the httpd.conf file to map to a location on a local file system.
Stop the OMS:
<OMS_HOME>/bin/emctl stop oms -all
Open the following file:
Note: Oracle recommends you to take a backup of this file before editing it. |
<WEBTIER_INSTANCE_HOME>/config/OHS/ohs1/httpd.conf
Search for sections related to the modules mpm_prefork_module and mpm_worker_module. In both these sections, modify the value for the LockFile parameter so that the path leads to a location on the local file system.
<IfModule mpm_prefork_module> StartServers 5 MinSpareServers 5 MaxSpareServers 10 MaxClients 150 MaxRequestsPerChild 0 AcceptMutex fcntl LockFile "${ORACLE_INSTANCE}/diagnostics/logs/${COMPONENT_TYPE}/${COMPONENT_NAME}/http_lock" </IfModule> .... <IfModule mpm_worker_module> StartServers 2 MaxClients 150 MinSpareThreads 25 MaxSpareThreads 75 ThreadsPerChild 25 MaxRequestsPerChild 0 AcceptMutex fcntl LockFile "${ORACLE_INSTANCE}/diagnostics/logs/${COMPONENT_TYPE}/${COMPONENT_NAME}/http_lock" </IfModule>
Save the changes.
Restart the OMS:
<OMS_HOME>/bin/emctl start oms
You must ensure that the Oracle WebLogic Server 11g Release 1 (10.3.5) installed by the Enterprise Manager Cloud Control Installation Wizard or by you is dedicated for Enterprise Manager Cloud Control. You must not have any other Oracle Fusion Middleware product installed in that middleware home.
Enterprise Manager Cloud Control cannot coexist with any Oracle Fusion Middleware product in the same middleware home because the ORACLE_COMMON property is used by both the products.
(Only for Silent Mode) By default, the software updates cannot be applied during installation because the INSTALL_UPDATES_SELECTION variable in the response file is set to "skip". However, if you want to apply them during installation, then you can modify this variable as described in Editing Response File for Installing Software.
By default, the upload ports and console ports as described in What Ports Are Used for Installation? are used.
Oracle offers bug fixes for a product based on the Oracle Lifetime Support Policy. When the license period expires for a particular product, the support for bug fixes offered by Oracle also ends. For more information, see the Oracle Lifetime Support Policy available at:
http://www.oracle.com/support/library/brochure/lifetime-support-technology.pdf
When determining supportability and certification combinations for an Enterprise Manager Cloud Control installation, you must consider Enterprise Manager Cloud Control's framework components as well as the targets monitored by Enterprise Manager Cloud Control. Oracle recommends keeping your Cloud Control components and targets updated to the latest certified versions in order to receive code fixes without having to purchase an Extended Support license.
You must upgrade all existing EMCLI clients of the earlier release to 12c Release 1 so that they can work with Enterprise Manager Cloud Control. This means, you must discard the old one and set up a new one.
For information about setting up a new EMCLI client, see the Enterprise Manager Command Line Interface Download page within the Cloud Control console. To access that page, in Cloud Control, from the Setup menu, select My Preferences, and then, click Command Line Interface.
You can find the OMS and Management Agent entries in the /etc/oragchomelist file for all UNIX platforms except HPUNIX, HPia64, Solaris Sparc.
On HPUNIX, HPia64, Solaris Sparc platforms, the entries are present in /var/opt/oracle/oragchomelist.
As a prerequisite, you must have an existing Oracle Database to configure the Management Repository. This database can also have the Automatic Memory Management (AMM) feature enabled.
Meet the prerequisites described in the chapter on installing Enterprise Manager system that is available in the Oracle Enterprise Manager Cloud Control Basic Installation Guide.
This section describes the following:
This section explains how you can install only the software binaries of Enterprise Manager Cloud Control at one point in graphical mode, and configure the installation at a later point. In particular, this section covers the following:
To install only the software binaries of Enterprise Manager Cloud Control in graphical mode, follow these steps:
Note: Oracle recommends you to run the EM Prerequisite Kit before invoking the installer to ensure that you meet all the repository requirements beforehand. This helps you set up your Management Repository beforehand without starting the installation or upgrade process. For information on the kit, to understand how to run it, and to know about the prerequisite checks it runs, see Oracle Enterprise Manager Basic Installation Guide. |
Invoke the Enterprise Manager Cloud Control Installation Wizard
Invoke the installer as a user who belongs to the oinstall group you created. For information about creating operating system groups and users, see the Oracle Enterprise Manager Cloud Control Basic Installation Guide.
<Software_Location>/runInstaller [-invPtrLoc <absolute_path_to_oraInst.loc>]
Note: When you invokerunInstaller or setup.exe, if the Enterprise Manager Cloud Control Installation Wizard does not appear, then it is possible that you do not access to the /stage directory.
There is a classpath variable that the installation wizard computes for OPatch as |
Enter My Oracle Support Details
(Optional) On the My Oracle Support Details screen, enter your My Oracle Support credentials to enable Oracle Configuration Manager. If you do not want to enable Oracle Configuration Manager now, go to Step (3).
If the host from where you are running the installation wizard does not have a connection to the Internet, then enter only the e-mail address and leave the other fields blank. After you complete the installation, manually collect the configuration information and upload it to My Oracle Support.
Note: For information about manually collecting the configuration information and uploading it to My Oracle Support, see Manually Collecting and Uploading Configuration Information. |
Click Next.
Install Software Updates
On the Software Updates screen, select one of the following sources from where the software updates can be installed while the installation of the Enterprise Manager system is in progress. If you do not want to apply them now, then select Skip.
(Recommended) Select Search for Updates, and then, select Local Directory if you have already manually downloaded the software updates to an accessible local or remote location.
Enter the location where the updates are available, and click Search for Updates. To search the computer and select the location, click Browse. Once the search results appear with patch numbers and their details, click the patch number to view the ReadMe associated with that patch.
If the updates have been downloaded to the default location, then select or enter the full path to the scratch path location. For example, if the scratch path location is /scratch/OracleHomes and if the software updates are available in /scratch/OracleHomes/Updates, then enter /scratch/OracleHomes/Updates.
If the software updates have been downloaded to a custom location, then select or enter the full path to the custom location. For example, if the custom location is /scratch/john and if the software updates are available in /scratch/john/Updates, then enter /scratch/john/Updates.
Note: For more information about software updates, and how you can manually download them, see What Are Software Updates?. |
Select Search for Updates, and then, select My Oracle Support if you want the installer to connect to My Oracle Support and automatically download the updates from there.
Enter the My Oracle Support account user name and password, and click Search for Updates. Once the search results appear with patch numbers and their details, click the patch number to view the ReadMe associated with that patch
Note: If you choose to skip installing the software updates during installation by not providing the My Oracle Support credentials, you can always register the credentials later using the Enterprise Manager Cloud Control console and view the recommended security patches. To do so, in Cloud Control, from the Setup menu, select Security, and then, click Preferred Credentials. On the Preferred Credentials page, click Set MOS Credentials and register the credentials. |
Click Next.
If Enterprise Manager Cloud Control is the first Oracle product you are installing on the host that is running on UNIX operating system, then the Oracle Inventory screen appears. For details, see step (6). Otherwise, the Check Prerequisites screen appears. For details, see step (8).
If Enterprise Manager Cloud Control is the first Oracle product you are installing on the host that is running on Microsoft Windows operating system, then the Oracle Inventory screen does not appear. On Microsoft Windows, the following is the default inventory directory:
<system drive>\Program Files\Oracle\Inventory
Enter Oracle Inventory Details
On the Oracle Inventory screen, do the following. You will see this screen only if this turns out to be your first ever installation of an Oracle product on the host.
Enter the full path to a directory where the inventory files and directories can be placed.
Select the appropriate operating system group name that will own the Oracle inventory directories. The group that you select must have write permissions on the Oracle Inventory directories.
Click Next.
Check Prerequisites
On the Prerequisite Checks screen, check the status of the prerequisite checks run by the installation wizard, and verify whether your environment meets all the minimum requirements for a successful installation.
The installation wizard runs the prerequisite checks automatically when you come to this screen. It checks for the required operating system patches, operating system packages, and so on.
The status of the prerequisite check can be either Warning, Failed, or Succeeded.
If some checks result in Warning or Failed status, then investigate and correct the problems before you proceed with the installation. The screen provides details on why the prerequisites failed and how you can resolve them. After you correct the problems, return to this screen and click Rerun to check the prerequisites again.
Although Oracle recommends you to investigate and correct the problems, if you are compelled to proceed without resolving them, then select Ignore to ignore the warnings and failures.
However, all package requirements must be met or fixed before proceeding any further. Otherwise, the installation might fail.
Click Next.
Select Installation Type
On the Install Types screen, do the following:
Select Install software only.
Validate or enter the middleware home where you want to install the OMS and other core components.
Click Next.
Select Plug-Ins
On the Select Plug-Ins screen, select the optional plug-ins you want to install from the software kit while installing the Enterprise Manager system. The screen lists the mandatory plug-ins as well as the optional plug-ins. The grayed rows indicate the mandatory plug-ins that will be installed.
Note: During installation, if you want to install a plug-in that is not available in the software kit, then refer to the point about installing additional plug-ins in Using Advanced Installer Options. |
Click Next.
Review and Install
On the Review screen, review the details you provided for the selected installation type.
If you want to change the details, click Back repeatedly until you reach the screen where you want to make the changes.
After you verify the details, if you are satisfied, click Install to begin the installation process.
On the Install Progress screen, view the overall progress (in percentage) of the installation.
On the Finish screen, you should see information pertaining to the installation of Enterprise Manager. Review the information and click Close to exit the installation wizard.
The following are some additional, advanced options you can pass while invoking the installer:
If you want to install on a host that has multiple host names (for example, virtual hosts), then pass the ORACLE_HOSTNAME argument while invoking the installer. Ensure that the host name you enter does not have underscores.
For example,
./runInstaller ORACLE_HOSTNAME=example.com
If you want to set the Central Inventory, then pass the -invPtrLoc parameter. This parameter considers the path to a location where the inventory pointer file (oraInst.loc) is available. However, this parameter is supported only on UNIX platforms, and not on Microsoft Windows platforms.
For example,
./runInstaller -invPtrLoc /scratch/OracleHomes/oraInst.loc -silent -responseFile <absolute_path_response_file>
If you want to install some plug-ins that are not in the software kit, then follow these steps:
Manually download the plug-ins from the Enterprise Manager Download page on OTN, and store them in an accessible location.
http://www.oracle.com/technetwork/oem/grid-control/downloads/oem-upgrade-console-502238.html
Invoke the installer with the following option, and pass the location where the plug-ins you want to install are available:
./runInstaller -pluginLocation <absolute_path_to_plugin_software_location>
The Select Plug-In screen of the installation wizard displays a list of plug-ins available in the software kit as well as the plug-ins available in this custom location. You can choose the ones you want to install.
(For UNIX Only) After you install the software binaries of Enterprise Manager Cloud Control, log in as a root user in a new terminal and run the allroot.sh ( or allroot.bat on Microsoft Windows) script from the OMS home:
$<OMS_HOME>/allroot.sh
To configure Enterprise Manager Cloud Control, follow these steps:
Invoke the installation wizard as a user who belongs to the oinstall group you created. For information about creating operating system groups and users, see the Oracle Enterprise Manager Cloud Control Basic Installation Guide.
$<MIDDLEWARE_HOME>/oms/sysman/install/ConfigureGC.sh [-invPtrLoc <absolute_path_to_oraInst.loc>]
In the installation wizard, on the Install Types screen, select Create a New Enterprise Manager System.
Click Next.
Enter WebLogic Server Configuration Details
On the WebLogic Server Configuration Details screen, enter the credentials for the WebLogic Server user account and the Node Manager user account, and validate the path to the Oracle Management Service instance base location.
Note: Ensure that your password contains at least 8 characters without any spaces, begins with a letter, and includes at least one numeric value. |
By default, the WebLogic Domain name is GCDomain, and the Node Manager name is nodemanager. These are non-editable fields. The installer uses this information for creating Oracle WebLogic Domain and other associated components such as the admin server, the managed server, and the node manager.
By default, the Oracle Management Service instance base location is gc_inst, which is created in the middleware home for storing all configuration details related to the OMS.
Click Next.
Enter Database Connection Details
On the Database Connection Details screen, enter the fully qualified name of the host where the existing database resides, the database's listener port and its service name or system ID (SID), and the SYS user account's password.
The installer uses this information to connect to the existing, certified Oracle Database for creating the SYSMAN schema. SYSMAN schema holds most of the relational data used in managing Enterprise Manager Cloud Control.
Note: If any repository-related prerequisite check fails, then run the check manually. For instructions, see the appendix on EM Prerequisite Kit in the Oracle Enterprise Manager Cloud Control Basic Installation Guide. |
Click Next.
Note: If you are connecting to an Oracle RAC database, and if you have entered the virtual host name of one of its nodes, then the installation wizard prompts you with a Connection String dialog and requests you to update the connect string with information about the other nodes that are part of the cluster. Update the connect string and click OK. If you want to test the connection, click Test Connection.If your Oracle RAC database is configured with Single Client Access Name (SCAN) listener, then you can enter a connection string using the SCAN listener. Oracle Real Application Cluster (Oracle RAC) nodes are referred to by their virtual IP (vip) names. The service_name parameter is used instead of the system identifier (SID) in connect_data mode, and failover is turned on. For more information, refer to Oracle Database Net Services Administrator's Guide. |
Enter Repository Configuration Details
On the Repository Configuration Details screen, do the following:
For SYSMAN Password, enter a password for creating the SYSMAN user account. The SYSMAN user account is used for creating the SYSMAN schema, which holds most of the relational data used in managing Enterprise Manager Cloud Control. SYSMAN is also the super administrator for Enterprise Manager Cloud Control.
For Registration Password, enter a password for registering the new Management Agents that join the Enterprise Manager system.
For Management Tablespace, enter the absolute path to the location where the data file for management tablespace (mgmt.dbf) can be stored. The installer uses this information for storing data about the monitored targets, their metrics, and so on. Ensure that the specified path leads up to the file name.
For example, /u01/oracle/prod/oradata/mgmt.dbf
For Configuration Data Tablespace, enter the absolute path to the location where the data file for configuration data tablespace (mgmt_ecm_depot1.dbf) can be stored. This is required for storing configuration information collected from the monitored targets. Ensure that the specified path leads up to the file name.
For example, /u01/oracle/prod/oradata/mgmt_ecm_depot1.dbf
For JVM Diagnostics Data Tablespace, enter the absolute path to a location where the data file for JVM Diagnostics data tablespace (mgmt_ad4j.dbf) can be stored. Ensure that the specified path leads up to the file name. Enterprise Manager Cloud Control requires this data file to store monitoring data related to JVM Diagnostics and Application Dependency Performance (ADP).
For example, /u01/oracle/prod/oradata/mgmt_ad4j.dbf
Note: If you are configuring the Management Repository on a database that uses Oracle Automatic Storage Management (Oracle ASM) for storage, then when you enter the data file location, only the disk group is used for creating the tablespaces. For example, if you specify+DATA/a.dbf, then only +DATA is used for creating the tablespaces on Oracle ASM, and the exact location of the data file on the disk group is decided by Oracle Managed Files. |
Click Next.
Customize Ports
On the Port Configuration Details screen, customize the ports to be used for various components.
You can enter a free custom port that is either within or outside the port range recommended by Oracle.
To verify if a port is free, run the following command:
On Unix:
netstat -anp | grep <port no>
On Microsoft Windows:
netstat -an|findstr <port_no>
However, the custom port must be greater than 1024 and lesser than 65535. Alternatively, if you already have the ports predefined in a staticports.ini file and if you want to use those ports, then click Import staticports.ini file and select the file.
Note: If thestaticports.ini file is passed during installation, then by default, the ports defined in the staticports.ini file are displayed. Otherwise, the first available port from the recommended range is displayed. |
Click Next.
Review and Install
After you verify the details, if you are satisfied, click Configure to begin the installation process.
Track the Progress
End the Installation
The following are some additional, advanced options you can pass while invoking the configureGC.sh script (or configureGC.bat on Microsoft Windows):
By default, GCDomain is the default name used for creating the WebLogic Domain. To override this and use a custom WebLogic Domain name, invoke the script with the WLS_DOMAIN_NAME option, and enter a unique custom name.
For example, if you want to use the custom name EMDomain, then run the following command:
$<MIDDLEWARE_HOME>/oms/sysman/install/ConfigureGC.sh WLS_DOMAIN_NAME=EMDomain
After the configuration ends successfully, the OMS and the Management Agent start automatically. If you do not want them to start automatically, then invoke the script with START_OMS and b_startAgent options, and set them to TRUE or FALSE depending on what you want to control.
For example, if you do not want the Management Agent to start automatically, then run the following command:
$<MIDDLEWARE_HOME>/oms/sysman/install/ConfigureGC.sh START_OMS=TRUE b_startAgent=FALSE
To understand the limitations involved with this advanced option, see Understanding the Limitations.
Perform the post-install steps as described in the chapter on installing Enterprise Manager system that is available in the Oracle Enterprise Manager Cloud Control Basic Installation Guide.
This section explains how you can install only the software binaries of Enterprise Manager Cloud Control at one point in silent mode, and configure the installation at a later point. In particular, this section covers the following:
To install only the software binaries of Enterprise Manager Cloud Control in silent mode, follow these steps:
Copy the following response file to an accessible location on your local host:
<Software_Location>/response/software_only.rsp
In this command, <Software_Location> refers to either the DVD or the location where you have downloaded software kit.
Edit the response file and enter appropriate values for the variables described in Table 4-1.
If this is the first Oracle product you are installing on the host, then run the following command:
./runInstaller -silent -responseFile <absolute_path>/software_only.rsp [-invPtrLoc <absolute_path_to_oraInst.loc>]
Otherwise, run the following command:
Table 4-1 describes what variables you must edit and how you must edit them in the new_install.rsp response file for installing the software binaries.
Table 4-1 Editing Response File for Installing Enterprise Manager Software
| Parameter | Description |
UNIX_GROUP_NAME |
Enter the name of the UNIX group you belong to. For example, Note: This parameter is supported only on UNIX platforms, and not on Microsoft Windows platforms. |
INVENTORY_LOCATION |
Enter the absolute path to the Central Inventory. For example, Note: This parameter is supported only on UNIX platforms, and not on Microsoft Windows platforms. |
SECURITY_UPDATES_VIA_MYORACLESUPPORT |
DECLINE_SECURITY_UPDATES |
INSTALL_UPDATES_SELECTION |
By default, this variable is set to
ORACLE_MIDDLEWARE_HOME_LOCATION |
Enter the location where you want the installer to install Oracle WebLogic Server 11g Release 1 (10.3.5) and Java Development Kit 1.6 v24. For example, Ensure that the middleware location has write permission to create the Oracle homes for OMS and Management Agent. If you have already installed them manually, then enter the location where you have installed them. For more information about this location, see What Is Oracle Middleware Home?. Note: Ensure that the middleware home you enter here is used only for Enterprise Manager Cloud Control. Ensure that no other Oracle Fusion Middleware products or components are installed in the same middleware home. |
PLUGIN_SELECTION |
By default, mandatory plug-ins such as Oracle Database Management Plug-In, Oracle Fusion Middleware Management Plug-In, Oracle My Oracle Support Management Plug-In, and Oracle Exadata Management Plug-In get automatically installed with the Enterprise Manager system. However, if you want to install any of the other optional plug-ins that are available in the software kit (DVD or downloaded software), then enter the names of those plug-ins for this variable. For example,
If you want to install any plug-in that is not available in the software kit, then do the following:
(For UNIX Only) After you install the software binaries of Enterprise Manager Cloud Control, log in as a root user in a new terminal and run the allroot.sh script (or allroot.bat on Microsoft Windows) from the OMS home:
To configure the software binaries of Enterprise Manager Cloud Control, follow these steps:
Copy the following response file to an accessible location on the host where you copied the software binaries of Enterprise Manager Cloud Control:
<Software_Location>/response/new_install.rsp
Edit the response file and enter appropriate values for the variables described in Table 4-2.
Configure the software binaries by invoking the ConfigureGC.sh script (or ConfigureGC.bat on Microsoft Windows) passing the response you edited in the previous step:
$<MIDDLEWARE_HOME>/oms/sysman/install/ConfigureGC.sh -silent -responseFile <absolute_path>/new_install.rsp [-invPtrLoc <absolute_path_to_inventory_directory>]
Table 4-2 describes what variables you must edit and how you must edit them in the new_install.rsp file for configuring the software binaries.
Table 4-2 Editing Response File for Configuring Enterprise Manager Software
WLS_ADMIN_SERVER_USERNAME |
By default, |
WLS_ADMIN_SERVER_PASSWORD |
Enter a password for the WebLogic user account. Ensure that your password contains at least 8 characters without any spaces, begins with a letter, and includes at least one numeric value. |
WLS_ADMIN_SERVER_CONFIRM_PASSWORD |
Confirm the password for the WebLogic user account. |
NODE_MANAGER_PASSWORD |
By default, Ensure that your password contains at least 8 characters without any spaces, begins with a letter, and includes at least one numeric value. |
NODE_MANAGER_CONFIRM_PASSWORD |
Confirm the password for the node manager user account. |
ORACLE_INSTANCE_HOME_LOCATION |
By default, Whether you accept the default directory or enter a custom one, by default, the directory is created under the parent directory of the middleware home. For example, if the middleware home is For more information about this location, see What Is Oracle Management Service Instance Base Location?. |
DATABASE_HOSTNAME |
Enter the fully qualified name of the host where the existing database resides. Ensure that the host name does not have underscores. For example, If you are connecting to an Oracle RAC Database, and if the nodes have virtual host names, then enter the virtual host name of one of its nodes. The connection to the database is established with a connect string that is formed using only this virtual host name, and the installation ends successfully. However, if you want to update the connect string with other nodes of the cluster, then after the installation, run the following command:
If your Oracle RAC database is configured with Single Client Access Name (SCAN) listener, then you can enter a connection string using the SCAN listener. |
LISTENER_PORT |
Enter the listener port to connect to the existing database. For example, |
SERVICENAME_OR_SID |
Enter the service name or the system ID (SID) of the existing database. For example, |
SYS_PASSWORD |
Enter the SYS user account's password. |
SYSMAN_PASSWORD |
Enter a password for creating a SYSMAN user account. This password is used to create the SYSMAN user, which is the primary owner of the Management Repository schema. Ensure that your password contains at least 8 characters without any spaces, begins with a letter, and includes at least one numeric value. |
SYSMAN_CONFIRM_PASSWORD |
Confirm the SYSMAN user account's password. |
MANAGEMENT_TABLESPACE_LOCATION |
Enter the absolute path to the location where the data file for management tablespace ( For example:
Enterprise Manager Cloud Control requires this data file to store information about the monitored targets, their metrics, and so on. Essentially, everything else other than configuration data, software library data, and audit data. |
CONFIGURATION_DATA_TABLESPACE_LOCATION |
Enter the absolute path to the location where the data file for configuration data tablespace ( For example, Enterprise Manager Cloud Control requires this data file to store configuration information collected from the monitored targets. |
JVM_DIAGNOSTICS_TABLESPACE_LOCATION |
Enter the absolute path to a location where the data file for JVM Diagnostics data tablespace ( For example, Enterprise Manager Cloud Control requires this data file to store monitoring data related to JVM Diagnostics and Application Dependency Performance (ADP). |
AGENT_REGISTRATION_PASSWORD |
Enter a password to secure the communication between the OMS and the Management Agents. Note that you have to provide the same registration password for securing your Management Agents. |
AGENT_REGISTRATION_CONFIRM_PASSWORD |
Confirm the agent registration password. |
STATIC_PORTS_FILE |
By default, ports described in What Ports Are Used for Installation? are honored. If you want to accept the default ports, then leave this field blank. If you want to use custom ports, then enter the absolute path to the |
