Skip Headers
Oracle® Enterprise Manager Cloud Control Advanced Installation and Configuration Guide
12c Release 2 (12.1.0.2)
E24089-21
  Go To Table Of Contents
Contents
Go To Index
Index
Previous
Previous
Next
Next
2 Understanding the Basics
This chapter introduces you to some key concepts of Enterprise Manager Cloud Control, and describes some important aspects of installation that you must know before you proceed any further.
In particular, this chapter covers the following:
Understanding Installation Basics
This section describes the fundamental aspects of the installation process. In particular, this section covers the following:
What Different Installation Modes Can You Use?
You can install Enterprise Manager Cloud Control or any of its core components either in an interactive, graphical mode or in a silent mode.
Graphical Mode Graphical mode is the Graphical User Interface (GUI) method that involves usage of a Java-based installation wizard or a browser-based application that is built into and accessed from the Enterprise Manager Cloud Control console. This method is best suited for first-time installations because you are guided through the entire installation process and your installation details are captured using the interview screens.
Silent Mode Silent method involves usage of Oracle-supplied response files or scripts that capture all the information required for installation. This method is simpler and faster, but requires you to have some knowledge on the installation process so that you can provide your installation details in the response files without having to see the interview screens of the installation wizard.
In both these modes, you can perform a software-only installation. A Software-Only installation is an approach that enables you to install only the software binaries of Enterprise Manager Cloud Control or a Management Agent, that is, without any configuration to the installation. This is best suited when you want to install the software at one point and configure it later.
What Is Enterprise Manager Cloud Control Installation Wizard?
Enterprise Manager Cloud Control Installation Wizard is a Java-based wizard that helps you install or upgrade to Enterprise Manager Cloud Control in graphical mode. If you are installing Enterprise Manager Cloud Control or any of its core components for the first time, then Oracle strongly recommends you to use this installation wizard.
To invoke the installation wizard on UNIX platforms, run runInstaller. To invoke on Microsoft Windows platforms, run setup.exe.
Figure 2-1 describes the key elements of the installation wizard.
Figure 2-1 Enterprise Manager Cloud Control Installation Wizard
What Installation Types Are Offered by the Installation Wizard?
The Enterprise Manager Cloud Control Installation Wizard offers the following installation types:
Create a New Enterprise Manager System
This installation type enables you to install a new Enterprise Manager Cloud Control system with either simple or advanced configuration settings. For information about simple and advanced installation types, refer to Oracle Enterprise Manager Cloud Control Basic Installation Guide.
For information about what is installed for both simple and advanced installation types, refer to Oracle Enterprise Manager Cloud Control Basic Installation Guide.
Upgrade an Existing Enterprise Manager System
This installation type enables you to upgrade the following to Enterprise Manager Cloud Control 12c Release 2 (12.1.0.2):
  • Enterprise Manager Cloud Control 12c Release 1 (12.1.0.1)
  • Enterprise Manager 11g Grid Control Release 1 (11.1.0.1)
  • Enterprise Manager 10g Grid Control Release 5 (10.2.0.5)
For upgrading Enterprise Manager 10g Grid Control Release 5 (10.2.0.5) and Enterprise Manager 11g Grid Control Release 1 (11.1.0.1), you can select one of the following approaches. However, for upgrading Enterprise Manager Cloud Control 12c Release 1 (12.1.0.1), you can select only One System Upgrade approach.
  • One System Upgrade, enables you to upgrade to Enterprise Manager Cloud Control on the same host where your earlier release of Enterprise Manager is running. This approach also upgrades the Management Repository in the existing Oracle Database itself. Since the upgrade happens on the same host, there is a reasonable downtime involved.
  • Two System Upgrade, enables you to install Enterprise Manager Cloud Control on a host that is different from the host where your existing Enterprise Manager system is running. This approach does not upgrade the Management Repository in the existing Oracle Database, but upgrades the one in the backed up database, thus offering the scope for two Enterprise Manager systems to exist. Since a new Enterprise Manager system coexists with the old one, there is no or near zero downtime involved.
For more information on these upgrade options, see the Oracle Enterprise Manager Cloud Control Upgrade Guide.
Install Software Only
This installation type enables you to install only the software binaries of Enterprise Manager Cloud Control at one point, and configure it at a later point.
This approach helps you divide the installation process into two phases, mainly the installation phase and the configuration phase. Understandably, the installation phase takes less time compared to the configuration phase because the installation phase involves only copying of binaries.
For information about what is installed during the installation phase and what is configured during the configuration phase, refer to Overview.
What Is Oracle Configuration Manager?
With Enterprise Manager Cloud Control, you can choose to enable Oracle Configuration Manager. Alternatively, you can enable it after installing Enterprise Manager Cloud Control.
Oracle Configuration Manager automatically collects configuration information from your environment at regular intervals and uploads it to Oracle repository. This helps Oracle maintain up-to-date information about your environment, identify security vulnerabilities, quickly diagnose support issues, and offer better solutions consistently.
However, no business or personal information is collected and uploaded, except for local contact name in the event of transmission problems. Oracle guarantees that all the information collected will be kept strictly confidential and under no circumstances will this information be shared with any other party.
Oracle recommends that the host from where you are running the installation wizard have a connection to the Internet so that the configuration information can be automatically collected and uploaded to My Oracle Support.
If the host from where you are running the installation wizard has a connection to the Internet, then on the Oracle Configuration Manager screen of the installation wizard, enter the My Oracle Support user name (or e-mail address) and password.
Otherwise, enter only the e-mail address and leave the other fields blank. After you complete the installation, manually collect the configuration information and upload it to My Oracle Support. To understand how the configuration information can be manually collected and uploaded, see the steps outlined in Manually Collecting and Uploading Configuration Information.
If you want to enable it after installing Enterprise Manager Cloud Control, then see Enabling Oracle Configuration Manager After Installing Enterprise Manager Cloud Control.
To manually collect the configuration information, follow these steps:
  1. Navigate to the OMS home and run the following command:
    $<OMS_HOME>/ccr/bin/emCCR collect
    For Oracle Configuration Manager 10.2.7 and higher, the collected configuration information is stored in the /ccr/hosts/state/upload/ocmconfig.jar file. For lower versions of Oracle Configuration Manager, the collected configuration information is stored in the /ccr/state/upload/ocmconfig.jar file. When you run the same command next time, the ocmconfig.jar file gets overwritten with fresh data. Therefore, at any point, you will see only one ocmconfig.jar file.
  2. Upload the ocmconfig.jar file to a Service Request on My Oracle Support.
  3. Repeat Step (1) and Step (2) from the Management Agent home.
To enable Oracle Configuration Manager at a later point, do the folllowing:
  1. Set the environment variable ORACLE_CONFIG_HOME to the Oracle Management Service instance base directory. Oracle Management Service instance base is the directory where the configuration files of the OMS are created.
    • In bash terminal, run the following command:
      export ORACLE_CONFIG_HOME=<absolute_path_to_gc_inst>
    • In other terminals, run the following command:
      setenv ORACLE_CONFIG_HOME <absolute_path_to_gc_inst>
    For information about Oracle Management Service instance base directory, refer to What Is Oracle Management Service Instance Base Location?.
  2. From the OMS home, run the following command:
    $<OMS_HOME>/ccr/bin/setupCCR
What Are Software Updates?
This section describes the following:
What Is Auto Update?
Auto Update is a feature built in to the Enterprise Manager Cloud Control Installation Wizard. The feature appears as the Software Updates screen in the installer, and enables you to automatically download and deploy the latest recommended patches while installing or upgrading Enterprise Manager Cloud Control.
This way, you do not have to keep a manual check on the patches released by Oracle. All patches required by the installer for successful installation and upgrade are automatically detected and downloaded from My Oracle Support, and applied during the installation or upgrade, thus reducing the known issues and potential failures.
Oracle strongly recommends using this feature, and applying the software updates while the installation is in progress for the following reasons:
  • Keeping track of the availability of software updates at the time of installation is difficult
  • Keeping track of the patch numbers, and manually downloading them and applying them after installation is a cumbersome process
Automatically downloading and applying the software updates during installation saves time and effort, and ensures that you do not miss out on important software updates.
How Does Auto Update Feature Work?
The Auto Updates feature connects to My Oracle Support and first downloads patch 6069539. Patch 6069539 essentially consists of a file called patch.xml that the installer parses and creates a directory titled updates to download all the required updates. The updates directory has the following subdirectories:
  • updates/agent
    Contains patches related only to the central agent (Management Agent installed with the OMS).
  • updates/oms
    Contains patches related to the OMS.
  • updates/metadata
    Contains a subdirectory patch 6069539, inside which you will find the patch.xml that determines what all updates must be downloaded and on which Oracle home they must be applied.
What Types of Software Updates Are Downloaded and Applied?
The following are the different types of updates that can be applied using this feature:
  • OUI/Opatch Updates
    Includes the latest OUI/Opatch versions or their updates. If a new version of the installer is downloaded, then OUI is restarted and launched from the location where the latest version is downloaded.
  • Prerequisite Updates
    Includes new prerequisite check-related updates released in response to issues reported after a release of Enterprise Manager Cloud Control. This enables OUI to always run the latests set of prerequisite checks, thus resulting in a smoother installation or upgrade experience.
  • EM installer Updates
    Includes updates that fix OUI issues—essentially, Java code changes that most likely results in automatic restart of OUI after their application.
  • Interim Patch Updates
    Includes patches such as DST patches, performance-related patches, and so on. They are automatically detected, downloaded, and applied.
How Can You Download the Software Updates?
You can download the software updates in one of the following ways:
  • Download by User (Offline Mode): Use this option when you do not have Internet connectivity on the host where you are installing Enterprise Manager, to connect to My Oracle Support.
  • Automatic Download by Installation Wizard (Online Mode): Use this option when you have Internet connectivity to connect to My Oracle Support automatically using the Enterprise Manager Cloud Control Installation Wizard.
The following sections describe how you can download the software updates in offline and online modes.
  1. On a host that has Internet connectivity, invoke the Enterprise Manager Cloud Control Installation Wizard with the -downloadUpdates argument in the following way. This argument ensures that the installation wizard is invoked only for downloading the software updates.
    ./runInstaller -downloadUpdates
    Enterprise Manager Cloud Control Installation Wizard appears with only two screens, the titles of which appear on the left menu.
  2. On the Software Updates screen, enter the My Oracle Support account user name and password, and click Search for Updates. The installation wizard displays the Downloading Updates dialog, and downloads the software updates to /tmp/OraInstall<timestamp>/updates. Click Next.
    The installation wizard restarts itself, and this time, displays all the screens, the titles of which appear on the left menu. Exit the installation wizard because you have invoked it on this host only to download the softwareupdates, and not install the OMS.
  3. Copy the entire updates diectory to the host where you want to install the OMS.
  4. On the host where you want to install the OMS, invoke the installation wizard.
    • In Graphical Mode: On the Software Updates screen of the installation wizard, select Search for Updates, and then, select Local Directory. Enter the location where you copied the updates, and click Search for Updates. To search the computer and select the location, click Browse.
      For example, if you copied the entire updates directory to /u01/home/em/, then enter /u01/home/em/updates.
    • In Silent Mode: Invoke the installer passing the response file with the INSTALL_UPDATES_SELECTION parameter set to "staged", and the STAGE_LOCATION parameter set to the absolute path of the location where the updates are available.
    If you have a proxy server set up, then invoke the installation wizard passing the -showProxy argument. For example, if you are invoking in graphical mode, then invoke in the following way:
    <Software_Location>/runInstaller -showProxy
On a host that has Internet connectivity, invoke the Enterprise Manager Cloud Control Installation Wizard.
  • In Graphical Mode: On the Software Updates screen of the installation wizard, select Search for Updates, then select My Oracle Support. Enter the My Oracle Support account user name and password, and click Search for Updates. Once the search results appear with patch numbers and their details, click the patch number to view the ReadMe associated with that patch.
  • In Silent Mode: Invoke the installer passing the response file with the INSTALL_UPDATES_SELECTION parameter set to "download", and the MYORACLESUPPORT_USERNAME_FOR_SOFTWAREUPDATES and the MYORACLESUPPORT_PASSWORD_FOR_SOFTWAREUPDATES parameters set to your My Oracle Support credentials.
How Can You Identify What Patches Have Been Applied?
To identify what patches have been applied, run the following command from the OMS home or the Management Agent home. The output of this command lists all the applied patches.
<ORACLE_HOME>/OPatch/opatch lsinventory
What is a Deployment Size?
When you install Enterprise Manager Cloud Control with advanced configuration settings (Advanced installation type), you have an option of selecting the deployment size of your choice. This option is available in both graphical mode (Enterprise Manager Cloud Control Installation Wizard) and silent mode (response file).
The deployment size essentially indicates the number of targets you plan to monitor, the number Management Agents you plan to have, and the number of concurrent user sessions you plan have.
Table 2-1 describes each deployment size.
Table 2-1 Deployment Size
Deployment Size Targets Count Management Agents Count Concurrent User Session Count
Small
Up to 999
Up to 99
Up to 10
Medium
Between 1000 and 9999
Between 100 and 999
Between 10 and 24
Large
10,000 or more
1000 or more
Between 25 and 50
The prerequisite checks are run regardless of the selection you make, but the values to be set for the various parameters checked depend on the selection you make. For more information about these deployment sizes, and the database parameters set for each of them, refer to Chapter 11.
After installing Enterprise Manager Cloud Control with a particular deployment size, you can choose to increase or decrease the count of targets, Management Agents, or concurrent user sessions. However, if you do increase the count to a level that is not appropriate for the selected deployment size, then the performance might suffer. Under such circumstances, Oracle recommends you to modify the database parameters according to the desired deployment size, as described in Chapter 11.
What Is Add Host Target Wizard?
The Add Host Targets Wizard (Figure 2-2) is a GUI-rich application accessible from within the Cloud Control console, and used for installing Management Agents on unmanaged hosts and converting them to managed hosts in the Enterprise Manager system.
Using the Add Host Targets Wizard, you can do the following:
  • Install a fresh Management Agent
  • Clone an existing well-tested, pre-patched, and running Management Agent
  • Install a Management Agent from an existing, centrally shared Management Agent
Figure 2-2 Add Host Target Wizard
Although the Add Host Targets Wizard can be used for remotely installing one Management Agent, the wizard is best suited for mass-deployment of Management Agents, particularly while mass-deploying Management Agents of different releases on hosts of different platforms. The wizard gives you the flexibility to select hosts on which you want to install a Management Agent. This helps you when you want to install the Management Agent on several hosts, in one attempt.
What Is Add Management Service Deployment Procedure?
A deployment procedure is a procedure that contains a hierarchal sequence of provisioning or patching steps, where each step may contain a sequence of other steps. In other words, the workflow of all tasks that need to be performed for a particular life cycle management activity is encapsulated in a deployment procedure.
Enterprise Manager Cloud Control offers deployment procedures, and all of these can be accessed from within the Cloud Control console. One of the deployment procedures that falls within the context of Enterprise Manager Cloud Control installation is the Add Management Service deployment procedure.
The Add Management Service deployment procedure (Figure 2-3) helps you meet high-availability requirements by enabling you to install an additional OMS using an existing OMS that is running on an AdminServer host.
Figure 2-3 Add Management Service Deployment Procedure
In simple words, the Add Management Service deployment procedure enables you to install additional OMS instances in your environment. The deployment procedure clones an existing OMS and replicates its configuration to the destination host.
The earlier releases of Enterprise Manager offered this installation type from the Enterprise Manager Installation Wizard. However, for the Enterprise Manager Cloud Control release, this installation type is offered as a deployment procedure.
For more information about the deployment procedure, see the chapter on adding additional management service in the Oracle Enterprise Manager Cloud Control Basic Installation Guide.
What Ports Are Used for Installation?
This section describes the default ports that are honored while installing Enterprise Manager Cloud Control. In particular, this section covers the following:
What Default Ports Are Used?
The following are the default ports used for installation:
    Upload Port Console Port
    HTTP Port 4889
    If 4889 is not available, then the first available free port from the range 4889 to 4898 is selected.
    The first available free port from the range 7788 - 7798 is selected.
    HTTPS Port 1159
    If 1159 is not available, then the first available free port from the range 4899 to 4908 is selected.
    The first available free port from the range 7799 - 7809 is selected.
  • Oracle Management Agent
    The default upload port for Management Agent is 3872. The same port is used for both HTTP and HTTPS. If 3872 is not available, then the first available free port from the range 1830 to 1849 is selected.
  • Admin Server
    The default HTTPS port for Admin Server is 7101. If 7101 is not available, then the first available free port from the range 7101 to 7200 is selected.
  • Node Manager
    The default HTTPS port for Node Manager is 7401. If 7401 is not available, then the first available free port from the range 7401 to 7500 is selected.
  • Managed Server
    The default HTTP port for Managed Server is 7201. If 7201 is not available, then the first available free port from the range 7201 to 7300 is selected.
    The default HTTPS port for Managed Server is 7301. If 7310 is not available, then the first available free port from the range 7301 to 7400 is selected.
How Can You Customize Ports?
Enterprise Manager Cloud Control offers you the flexibility to use custom ports instead of default ports.
Customizing Ports While Installing Enterprise Manager Cloud Control
WARNING:
Do NOT set any port to a value lower than or equal to 1024. Ports up to 1024 are typically reserved for root users (super users). Therefore, make sure the port you customize is always set to a value greater than 1024.
  • If you are installing Enterprise Manager Cloud Control (advanced installation) in graphical mode, that is, using the Enterprise Manager Cloud Control Installation Wizard, then you can use the Port Configuration Details screen to enter custom ports. You can also import a staticports.ini file that already captures the custom ports.
  • If you are installing Enterprise Manager Cloud Control in silent mode, that is, using the installation procedures described in Part II, then update the staticports.ini file with suitable custom ports.
    The staticports.ini file is available at the following location of the software kit (DVD, downloaded software, and so on):
    <software_kit>/response/staticports.ini
Customizing HTTP/HTTPS Console and Upload Ports After Installing Enterprise Manager Cloud Control
WARNING:
If you want to change the HTTP/HTTPS console ports and upload ports after installing Enterprise Manager Cloud Control, then follow these steps:
  1. Stop the OMS:
    $<OMS_HOME>/bin/emctl stop oms -all
  2. Update the emgc properties with HTTP and HTTPS ports as described in Table 2-2. Specify the values for parameters <http_upload_new>, <https_upload_new>, <http_console_new>, and <https_console_new>):
    Table 2-2 Updating EMOMS Properties with HTTP and HTTPS Ports
    Port/Property Type Command to Run
    HTTP Upload Port
    <OMS_Home>/bin/emctl set property -name oracle.sysman.emSDK.svlt.ConsoleServerPort -value <http_upload_new>
    HTTPS Upload Port
    <OMS_Home>/bin/emctl set property -name oracle.sysman.emSDK.svlt.ConsoleServerHTTPSPort -value <https_upload_new>
    HTTP Console Port
    <OMS_Home>/bin/emctl set property -name oracle.sysman.emSDK.svlt.EMConsoleServerPort -value <http_console_new>
    HTTPS Console Port
    <OMS_Home>/bin/emctl set property -name oracle.sysman.emSDK.svlt.EMConsoleServerHTTPSPort -value <https_console_new>
  3. Back up the following file:
    $<OMS_INSTANCE_HOME>/emgc.properties
    After backing up the file, open the original emgc.properties file, and specify the new port numbers for the following parameters:
    EM_UPLOAD_HTTP_PORT=<http_upload_new>
    EM_UPLOAD_HTTPS_PORT=<https_upload_new>
    EM_CONSOLE_HTTP_PORT=<http_console_new>
    EM_CONSOLE_HTTPS_PORT=<https_console_new>
  4. Back up the files httpd.conf, ssl.conf, and httpd_em.conf from the following location:
    $<WEBTIER_INSTANCE_HOME>/config/OHS/ohs#/
    After backing up the files, open the original files, and specify the new port numbers:
    • In httpd.conf file, in the Listen directive, replace <http_console_orig> with <http_console_new>.
    • In ssl.conf file, in the Listen directive, replace <https_console_orig> with <https_console_new>.
    • In httpd_em.conf file, in the Listen and VirtualHost directive, replace <http_upload_orig> with <http_upload_new>, and <https_upload_orig> with <https_upload_new>, respectively.
  5. Start the OMS, and verify its status:
    $<OMS_HOME>/bin/emctl start oms
    $<OMS_HOME>/bin/emctl status oms -details
  6. If the OMS is configured with any Server Load Balance (SLB), then update the ports in the SLB pools, monitors, and so on.
  7. If the OMS is configured for SSO or OAM, then re-run the SSO or OAM configuration.
  8. Back up the following file:
    $<AGENT_INSTANCE_HOME>/sysman/config/emd.properties
    Back up the emd.properties file from all Management Agents that are communicating with the OMS.
    After backing up the file, open the original emd.properties file, and verify the URL mentioned in REPOSITORY_URL. If the URL is an HTTPS URL, then change the port number to <https_upload_new>. If the URL is an HTTP URL, then change the port number to <http_upload_new>.
  9. If there are any EM CLI instances set up on the ports you have changed, then set up those instances again. To do so, from each EM CLI instance, run the command emcli setup or emcli status, and note the EM URL that appears.
    If you have changed that port number, run the following command:
    emcli setup -url=http(s)://<host>:<new_port#>/em -dir=<dir>....
What Precautions You Must Take While Customizing Port Numbers?
While updating the staticports.ini file, you must be extremely careful because an error in the file can cause the installation wizard to use default ports without displaying any warning. Therefore, before updating the staticports.ini file, check for these points:
  • Do NOT set any port to a value lower than or equal to 1024. Ports up to 1024 are typically reserved for root users (super users). Therefore, make sure the port you customize is always set to a value greater than 1024.
  • If a port is already being used by a component or any other application, do not enter that port (used port) in the staticports.ini file. If you do, then the related configuration assistant also fails.
  • If you have entered the same port for more than one component, then the installation displays an error after the prerequisite checks phase. You must rectify this error before proceeding with the installation.
  • If you have syntax errors in the staticports.ini file (for example, if you omitted the equal (=) character for a line), then the installation wizard ignores the line. For the components specified on such lines, the installation wizard assigns the default ports. The installation wizard does not display a warning for lines with syntax errors.
  • If you misspell a component name, then the installation wizard assigns the default port for the component. Names of components in the file are case-sensitive. The installation wizard does not display a warning for lines with unrecognized names.
  • If you enter a nonnumeric value for the port number, then the installation wizard ignores the line and assigns the default port number for the component. It does this without displaying any warning.
  • If you misspell the parameter on the command line, then the installation wizard does not display a warning. It continues and assigns default ports to all components.
  • If you enter a relative path to the staticports.ini file (for example, ./staticports.ini) in the command line, then the installation wizard does not find the file. It continues without displaying a warning and it assigns default ports to all components. You must enter a full path to the staticports.ini file.
What Data Files Are Created While Configuring Oracle Management Repository?
The following are the data files created while configuring Oracle Management Repository:
mgmt.dbf Stores information about the monitored targets, their metrics, and so on.
mgmt_ecm_depot1.dbf Stores configuration information collected from the monitored targets.
mgmt_ad4j.dbf Stores monitoring data related to JVM Diagnostics and Application Dependency Performance (ADP).
How Do You Delete Data Files?
To delete the data files, you must drop the SYSMAN/MDS schema. To do so, run the following command from the OMS home.
$<OMS_HOME>/sysman/admin/emdrep/bin/RepManager <repository_database_host> <repository_database_port> <repository_database_sid> -action dropall -dbUser <repository_database_user> -dbPassword <repository_database_password> -dbRole <repository_database_user_role> -mwHome <middleware_home> -mwOraHome <oms_home> -oracleHome <oms_home>
  • For Microsoft Windows, invoke RepManager.bat.
  • If you are dropping the schemas that belong to a 10g Release 2 (10.2.x.x) Management Repository, then run previous command without these arguments:
    -mwHome <middleware_home> -mwOraHome <middleware_ora_home> -oracleHome <OMS_HOME>
After dropping the schema, manually delete the database files mgmt.dbf and mgmt_ecm_depot1.dbf.
You can find these files by running the following command as SYS:
SELECT FILE_NAME FROM DBA_DATA_FILES WHERE UPPER (TABLESPACE_NAME) LIKE 'MGMT%';
Table 2-3 describes the -action options that are supported by the different versions of RepManager.
Table 2-3 RepManager Support for -action dropall Command
RepManager Version Command Supported
RepManager 12.1
  • -action dropall
    Drops SYSMAN, SYSMAN_MDS, APM, OPSS, EMRUNTIME, and SYSMAN_RO.
  • -action drop
    Drops only SYSMAN.
RepManager 11.1
  • -action dropall
    Drops only SYSMAN and SYSMAN_MDS.
  • -action drop
    Drops only SYSMAN.
RepManager 10.2.0.5
-action drop
Drops only SYSMAN.
Understanding Oracle WebLogic Server Requirement
Enterprise Manager Cloud Control requires Oracle WebLogic Server 11g Release 1 (10.3.5) and Java Development Kit 1.6 v24+.
If Oracle WebLogic Server 11g Release 1 (10.3.5) and Java Development Kit 1.6 v24+ are NOT already installed in your environment, then the installation wizard automatically installs them for you while installing a new Enterprise Manager Cloud Control.
This section describes some important aspects related to Oracle WebLogic Server that you must know before you install Enterprise Manager Cloud Control.
How Do I Verify Whether Oracle WebLogic Server Is Installed?
To verify whether Oracle WebLogic Server is installed, check the following file in the Oracle WebLogic Server home:
$<WLS_HOME>/logs/log.txt
The following is the sample output of the log.txt file:
release  10.3.5.0 [Added]
    |_____Common Infrastructure Engineering 7.1.0.0 [Added]
    |    |_____Uninstall [Added]
    |    |_____Patch Client [Added]
    |    |_____Patch Attachment Facility [Added]
    |    |_____Clone Facility [Added]
    |_____WebLogic Server 10.3.5.0 [Added]
    |    |_____Core Application Server [Added]
    |    |_____Administration Console [Added]
    |    |_____Configuration Wizard and Upgrade Framework [Added]
    |    |_____Web 2.0 HTTP Pub-Sub Server [Added]
    |    |_____WebLogic SCA [Added]
    |    |_____WebLogic JDBC Drivers [Added]
    |    |_____Third Party JDBC Drivers [Added]
    |    |_____WebLogic Server Clients [Added]
    |    |_____WebLogic Web Server Plugins [Added]
    |    |_____UDDI and Xquery Support [Added]
    |    |_____Server Examples [Added]
    |    |_____Evaluation Database [Added]
    |    |_____Workshop Code Completion Support [Added]
    |_____Oracle Configuration Manager 10.3.3.1 [Added]
    |    |_____Data Collector [Added]
    |_____Oracle Coherence 3.6.0.3 [Not Installed]
         |_____Coherence Product Files [Not Installed]
         |_____Coherence Examples [Not Installed]
Is Oracle WebLogic Server Cluster Supported?
Oracle WebLogic Server cluster consists of Oracle WebLogic Servers running simultaneously and working together to provide increased scalability and reliability. A cluster appears to be a single Oracle WebLogic Server instance. The server instances that constitute a cluster can run on the same host, or be located on different hosts.
You can install Enterprise Manager Cloud Control on an Oracle WebLogic Server Cluster, however, you cannot take advantage of the cluster configurations.
If Oracle WebLogic Server Already Exists, Is the Existing Domain Used?
If Oracle WebLogic Server already exists, then the existing domain is NOT used. Instead, the Enterprise Manager Cloud Control Installation Wizard creates a new domain and deploys the Enterprise Manager Cloud Control software to it.
When and Why Do You Need Oracle WebLogic Server Credentials?
While installing or upgrading to Enterprise Manager Cloud Control, you are prompted to enter the Oracle WebLogic Server credentials (user name and password). The credentials are used for creating the WebLogic domain and other associated components such as the Admin Server, the managed server, and the node manager.
The WebLogic user name is the default user name that will be used as the administrative user for the WebLogic Domain. By default, the user name is weblogic. And the WebLogic password is the password for this default administrative user account.
When and Why Do You Need Node Manager Credentials?
While installing or upgrading to Enterprise Manager Cloud Control, you are prompted to enter the Node Manager password for the default Node Manager user account, which is nodemanager. The password is used for configuring the Node Manager. A Node Manager enables you to start, shut down, or restart an Oracle WebLogic Server instance remotely, and is recommended for applications with high availability requirements.
How Do You Find Admin Server Port After Installing Enterprise Manager?
To find the Admin Server port, view the value set for the AS_HTTPS_PORT parameter in the emgc.properties file. This file is available in the Oracle Management Service Instance Base location.
For example,
/DATA/oracle/Middleware/gc_inst/em/EMGC_OMS1/emgc.properties
How Do You Verify Whether Admin Server Is Running?
To install an additional OMS, the Admin Server that is used by the first OMS must be up and running. To verify whether the Admin Server is running, access the Admin Server console using the following URL:
https://host:port/console
Here, host and port are values specified in the EM_INSTANCE_HOST and AS_HTTPS_PORT parameters, respectively, in the emgc.properties file. This properties file is available in the following location, that is, in the OMS home (first OMS) that was initially installed:
$<MIDDLEWARE_HOME>/gc_inst/em/EMGC_OMS1/emgc.properties
How Do You Start Admin Server?
You can start the Admin Server by running the following command. Although the command is used essentially to start the OMS, the command in turn starts the Admin Server on which that OMS is running. So run this command even if you know that the OMS is already running.
emctl start oms
Understanding Installation Directories
This section describes the installation directories that need to be entered while installing Enterprise Manager Cloud Control or any of its core components. In particular, this section covers the following:
What Is Oracle Inventory Directory?
If Enterprise Manager Cloud Control is the first Oracle product that you are installing, then the Enterprise Manager Cloud Control Installation Wizard prompts you to enter an inventory directory (also called the oraInventory directory).
This inventory directory is used by the installation wizard to place all the installer files and directories on the host. The installation wizard automatically sets up subdirectories for each Oracle product to contain the inventory data.
You can enter the oraInventory directory in two ways:
  • While installing Enterprise Manager Cloud Control using the installation wizard, you can enter the oraInventory directory in the Oracle Inventory screen. When you enter it in this screen, you must also select the appropriate operating system group name that will own the oraInventory directories. The group you select must have write permission on the oraInventory directories.
  • While installing Enterprise Manager Cloud Control in silent mode, that is, without using the installation wizard, you can enter the oraInventory directory using the -invPtrLoc parameter. This parameter considers the path to a location where the inventory pointer file (oraInst.loc) is available. However, this parameter is supported only on UNIX platforms, and not on Microsoft Windows platforms.
    For example
    ./runInstaller -invPtrLoc /scratch/OracleHomes/oraInst.loc
Ensure that the oraInventory directory is not in a shared location. If it is, change it to a non-shared location.
If you already have an Oracle product installed on the host, then the installation wizard uses the existing oraInventory directory that was created while installing that Oracle product. Ensure that you have write permission on that directory. To do so, run the installer as the same operating system user as the one who installed the other Oracle product.
The oraInventory directory is different from Installation Directory. For information about Installation Directory, see What Is Oracle Middleware Home?.
While installing or upgrading to Enterprise Manager Cloud Control, you are required to enter the Oracle Middleware home.
Oracle Middleware home (Middleware home) is the parent directory that has the Oracle WebLogic Server home, the Java Development Kit, the Web tier instance files, one or more Oracle homes, the OMS instance base directory, and other relevant files. This is where the OMS and the plug-ins are deployed.
For example,
/u01/app/Oracle/Middleware
If you are installing or upgrading to Enterprise Manager Cloud Control, then:
  • If Oracle WebLogic Server 11g Release 1 (10.3.5) and Java Development Kit 1.6 v24+ are already installed in your environment, then the installation wizard automatically detects them and displays the absolute path to the Middleware home where they are installed.
    In this case, validate the Middleware home that is detected and displayed by default. If the location is incorrect, then enter the path to the correct location. Ensure that the Middleware home you select or enter is a Middleware home that does not have any Oracle homes for the OMS and the Management Agent.
  • If Oracle WebLogic Server 11g Release 1 (10.3.5) and Java Development Kit 1.6 v24+ are NOT already installed in your environment, then the installation wizard automatically installs them for you while installing Enterprise Manager Cloud Control.
    In this case, enter the absolute path to a directory where you want to have them installed. Ensure that the directory you enter does not contain any files or subdirectories.
    For example,
    /u01/app/Oracle/Middleware/
Oracle Middleware home is different from Oracle Home of OMS or Management Agent. For information about Oracle Home, see What Is Oracle Home?.
While installing Enterprise Manager Cloud Control, you are required to enter the Oracle Management Service Instance Base Location.
Oracle Management Service Instance Base Location is a directory (gc_inst) inside the Middleware home where the configuration files of the OMS are stored.
The installation wizard uses its built-in algorithm to identify this location, and displays it for you to validate. If the Middleware home is /u01/app/Oracle/Middleware/, then by default, the following is the Oracle Management Service Instance Base Location:
/u01/app/Oracle/Middleware/gc_inst
You can either accept the default location or specify another location that has write permission.
For information about Oracle Middleware home, see What Is Oracle Middleware Home?.
Oracle Home or Oracle home is the directory where the OMS, the Management Agent, and the plug-ins are installed. Table 2-4 lists the default Oracle homes are created.
Table 2-4 Oracle Homes of OMS, Management Management Plug-ins
Component Default Oracle Home Sample Location
$<MIDDLEWARE_HOME>/oms
/u01/app/Oracle/Middleware/oms
$<AGENT_BASE_DIR>/core/12.1.0.2.0
/u01/app/Oracle/agent/core/12.1.0.2.0
Plug-in (OMS-specific plug-ins)
$<MIDDLEWARE_HOME>/plugins/<pluginID_Version>
/u01/app/Oracle/software/plugins/oracle.sysman.db.agent.plugin_12.1.0.2.0
Plug-in (agent-specific plug-ins)
$<AGENT_BASE_DIR>/plugins
/u01/app/Oracle/agent/plugins
Oracle Home is different from OraInventory. For information about OraInventory directory, see What Is Oracle Inventory Directory?.
What Is Agent Base Directory?
While installing Enterprise Manager Cloud Control and a standalone Management Agent using the Add Host Targets Wizard, you are required to enter an installation base directory, which is essentially the agent base directory.
Agent Base Directory is a directory outside the Oracle Mdidleware Home, where the Management Agent home is created.
For example, if the agent base directory is /u01/app/Oracle/agent, then the Management Agent home is created as /u01/app/Oracle/agent/core/12.1.0.2.0.
What is Agent Instance Directory?
Agent Instance Directory is a directory (agent_inst) created for storing all Management Agent-related configuration files.
Agent Instance Directory is created inside the agent base directory.
For example, if the agent base directory is /u01/app/Oracle/agent, then by default, the following is the agent instance directory:
/u01/app/Oracle/agent/agent_inst
What Is /TMP C:\Temp Directory Used For?
When you invoke the Enterprise Manager Cloud Control Installation Wizard, it automatically copies some executable files and link files to a temporary directory on the host.
For example, the default /tmp directory on UNIX hosts, and C:\Temp on Microsoft Windows hosts.
If the host is set to run cron jobs along with many other processes that may be running periodically, then these jobs attempt to clean up the default temporary directory, thereby deleting some files and causing the installation wizard to fail.
If there are any cron jobs or processes that are automatically run on the hosts to clean up the temporary directories, then ensure that you set the TMP or TEMP environment variable to a location that is different from the default location. Ensure that the non-default location you set is secure on the hard drive, that is, the non-default location is a location where cleanup jobs are not run. Also ensure that you have write permissions on this alternative directory.
This must be done before you run the installer to invoke the Enterprise Manager Cloud Control Installation Wizard. (For UNIX operating systems, you invoke runInstaller, and for Microsoft Windows, you invoke setup.exe).
Specifying an alternative temporary directory location is not mandatory, and is required only if any cron jobs are set on the computers to clean up the /tmp directory.
Understanding Configuration Assistants
This section describes the postinstallation activities that are performed by the installation wizard. In particular, this section covers the following:
What Are Configuration Assistants?
While installing or upgrading to Enterprise Manager Cloud Control in either GUI mode (using the installation wizard) or silent mode (using a response file), a set of configuration assistants are run at the end of the installation process to configure the installed or upgraded components. Your installation or upgrade process is complete only after all the components are configured using these configuration assistants.
Even when you perform a software-only installation of Enterprise Manager, when you run the ConfigureGC.sh script to configure the installation, the configuration assistants are internally run. (On Microsoft Windows, run the ConfigureGC.bat script.)
What Configuration Assistants Are Run by the Installation Wizard?
This section lists the configuration assistants run by the installation wizard for the different installation types.
Configuration Assistants Run While Installing a New Enterprise Manager
The following are the configuration assistants that are run while installing a new Enterprise Manager, that is, when you select Create a new Enterprise Manager System in the installation wizard.
  • Plug-ins Prerequisites Check Configuration Assistant
  • Repository Configuration Assistant
    If you use a database instance that was created with a preconfigured Management Repository using the database templates offered by Oracle, then Repository Out-of-Box Configuration Assistant is run instead of Repository Configuration Assistant.
  • MDS Schema Configuration Assistant
  • OMS Configuration Assistant
  • Plug-ins Deployment and Configuration Assistant
  • Start Oracle Management Service Configuration Assistant
  • Oracle Configuration Manager for OMS Configuration Assistant
  • Agent Configuration Assistant
Configuration Assistants Run While Upgrading an Existing Enterprise Manager
The following are the configuration assistants that are run while upgrading an existing Enterprise Manager, that is, when you select Upgrade an existing Enterprise Manager System in the installation wizard.
1-System Upgrade Approach
  • Repository Upgrade Configuration Assistant
  • Plug-ins Inventory Migration Configuration Assistant
In addition, while upgrading 12c Release 1 (12.1.0.1) to 12c Release 2 (12.1.0.2), the following are run:
  • Stopping APM Engines Configuration Assistant
  • Stop Admin Server Configuration Assistant
Agent Configuration Assistant is not run because the Management Agent is not upgraded as it is either predeployed by the Enterprise Manager 12c Upgrade Console (for 10.2.0.5 or 11.1 Management Agents) or upgraded using the Upgrade Agents Console (for 12.1.0.1 Management Agents).
2-System Upgrade Approach
1-System Upgrade Approach on a Different Host
Configuration Assistants Run While Upgrading an Additional Oracle Management Service
The following are the configuration assistants that are run while upgrading an additional OMS, that is, when you select Upgrade an existing Enterprise Manager System, then select an additional OMS in the installation wizard.
The Agent Configuration Assistant is not run because the Management Agent is not upgraded as it is either predeployed by the Enterprise Manager 12c Upgrade Console (for 10.2.0.5 or 11.1 Management Agents) or upgraded using the Upgrade Agents Console (for 12.1.0.1 Management Agents).
What Do You Do When Configuration Assistants Fail?
If an optional configuration assistant fails, then the installation wizard ignores the failure and runs to the next configuration assistant automatically. However, if a mandatory configuration assistant fails, then the installation wizard stops the installation process. In this case, you are expected to resolve the issue and rerun the configuration assistant.
For information about the log files to review when a configuration assistant fails, and the actions to be taken to resolve the issue, see Appendix H.
Understanding Prerequisite Checks
Every time you install Enterprise Manager Cloud Control using the installation wizard, a set of prerequisite checks are run to verify if the environment meets the minimum requirements for a successful installation. The installation wizard checks for a variety of things including required operating system patches, operating system packages, kernel parameters, and so on.
The following sections describe these prerequisite checks. In particular, this section covers the following:
What Prerequisite Checks Are Run by Default?
The following are the default prerequisite checks that are run for different installation types—Creating a New Enterprise Manager System and Upgrading an Existing Enterprise Manager System:
  • Prerequisite check for verifying whether the installation is being done on a certified operating system.
  • Prerequisite check for verifying whether all the certified packages and libraries have been installed.
  • Prerequisite check for verifying whether the glibc package has been installed. (Not applicable for Management Agent installation)
  • Prerequisite check for verifying whether there is sufficient disk space in the temp directory. (Not applicable for Management Agent installation)
  • Prerequisite check for verifying whether there is sufficient disk space in the inventory directory.
  • Prerequisite check for verifying whether there is write permission in the inventory directory.(Not applicable for OMS installation)
  • Prerequisite check for verifying whether the software is compatible with the current operating system.
  • Prerequisite check for verifying whether there is sufficient physical memory.
  • Prerequisite check for verifying the required ulimit value. (Not applicable for Management Agent installation)
  • Prerequisite check for verifying the host name.
  • Prerequisite check for verifying whether the LD_ASSUME_KERNEL environment variable is set. (Not applicable for Management Agent installation)
  • Prerequisite check for verifying whether proper timezone is set.
  • Prerequisite check for verifying whether there is 4 GB of swap space. (Not applicable for Management Agent installation)
How Can You Run Prerequisite Checks in Standalone Mode?
You can run the prerequisite checks in standalone mode before invoking the installation wizard. This helps you identify and resolve issues that might otherwise cause the installation to fail.
Table 2-5 shows the commands you need to run to run the prerequisite checks in standalone mode:
Table 2-5 Running Prerequisite Checks in Standalone Mode
Installation Type Command
  • Create a New Enterprise Manager System
  • Upgrade an Existing Enterprise Manager System
  • Install Software Only
<Software_Location>/install/runInstaller -prereqchecker PREREQ_CONFIG_LOCATION=<Software_Location>/stage/prereq -entryPoint "oracle.sysman.top.oms_Core" -prereqLogLoc <absolute_path_to_log_location> -silent -waitForCompletion
On Microsoft Windows, replace /runInstaller with setup.exe. Also, <Software_Location> mentioned in the commands in Table 2-5 refer to the location where the Enterprise Manager software is available. For example, DVD. If you have downloaded the software from Oracle Technology Network (OTN), then enter the absolute path to that downloaded location.
Understanding Limitations of Enterprise Manager Cloud Control
This section describes the limitations you might face while using Enterprise Manager Cloud Control. In particular, this section covers the following:
Can You Access Unlicensed Components?
Although the installation media in your media pack contain many Oracle components, you are permitted to use only those components for which you have purchased licenses. Oracle Support Service does not provide support for components for which licenses have not been purchased.
For more information, access the Enterprise Manager documentation library at the following URL and view the Oracle Enterprise Manager Licensing Information Guide:
http://www.oracle.com/technetwork/indexes/documentation/index.html
What Are the Limitations with DHCP-Enabled Machines?
Do NOT run the OMS on a computer that is DHCP enabled. Oracle strongly suggests that you use a static host name or IP address assigned on the network for Enterprise Manager Cloud Control components to function properly.
For more information, refer to My Oracle Support Note 428665.1 at:
https://support.oracle.com/
Understanding Startup Scripts
By default, Enterprise Manager Cloud Control offers a startup script called gcstartup with every installation of OMS and Management Agent. The startup script ensures that the OMS and the Management Agent are started automatically every time their hosts are rebooted, thereby relieving you of the manual effort.
Where Is the Startup Script Stored?
The startup script is present in the following location of the OMS host and the Management Agent host:
/etc/init.d/gcstartup
What Does the Startup Script Invoke?
On the OMS host, the startup script invokes the following file to start up the OMS when its host is rebooted:
$<OMS_HOME>/install/unix/scripts/omsstup
Similarly, on the Management Agent host, the startup script invokes the following file to start up the Management Agent when its host is rebooted:
$<AGENT_HOME>/install/unix/scripts/agentstup
How Do I Stop the Startup Script from Starting the OMS or the Management Agent?
If you do not want the startup script to start the OMS and the Management Agent when their hosts are rebooted, then remove the omsstup file and the agentstup file from the respective hosts.
Can the Startup Script Start an OMS or a Management Agent on a Remote Host?
The startup script is specific to the host on which an OMS or a Management Agent is installed. Therefore, the startup script cannot start an OMS or a Management Agent on a remote host.
Is the Startup Script Available for All Operating Systems?
While the startup script exists on UNIX operating systems, there is no such script for Microsoft Windows operating systems. However, on Microsoft Windows, the startup functionality is offered by the inherent Windows Service that is available within the Microsoft Windows framework.
Understanding Other Miscellaneous Concepts
This section covers miscellaneous concepts related to the installation of Enterprise Manager Cloud Control. In particular, this section covers the following:
What Is a Host List File?
While using the Add Host Targets Wizard, you can enter the hosts on which you want to install Oracle Management Agent, in two ways — you can either enter the host name or the IP address, or select an external file that contains a list of hosts mentioned.
If you choose to select an external file, then ensure that the file contains only the host name (Example 2-1), or the host name followed by the platform name (Example 2-2).
Example 2-1 External File with Only the Host Names
host1.example.com
host2.example.com
Example 2-2 External File with the Host Names and Platform Names
host1.example.com linux
host2.example.com aix
What Scripts Are Run During the Installation Process?
At least once during or after the installation of Enterprise Manager Cloud Control or Management Agent, you are prompted to log in as a root user and run oraInstRoot.sh, allroot.sh, or root.sh. You must log in as a root user because the scripts edit files in the /etc directory and create files in the local bin directory (/usr/local/bin, by default).
After every installation, a check is performed to identify the Central Inventory (oraInventory) directory. The Central Inventory directory is a directory that is automatically created by the installation wizard when an Oracle product is installed on a host for the very first time.
Ensure that the central inventory location you specify must NOT be on a shared file system. If it is already on a shared file system, then switch over to a non-shared file system.
  • If you have NOT installed an Oracle product before on the host, then run the oraInstRoot.sh script from the Central Inventory:
    $Home/oraInventory/oraInstRoot.sh
    The oraInstRoot.sh script is run to create the oraInst.loc file. The oraInst.loc file contains the Central Inventory location.
  • However, if you already have an Oracle product on the host, then run allroot.sh script from the OMS home:
    <OMS_HOME>/allroot.sh
