Skip Headers
Oracle® Enterprise Manager Cloud Control Advanced Installation and Configuration Guide
12c Release 2 (12.1.0.2)
E24089-21
  Go To Table Of Contents
Contents
Go To Index
Index
Previous
Previous
Next
Next
8 Installing Shared Agent
This chapter describes how you can install a Shared Agent with the help of a central, shared Oracle home location of an existing Oracle Management Agent (Management Agent) that is installed on an NFS-mounted drive.
Overview
If you want to install additional Management Agents on hosts that share a mounted drive where a Management Agent is already installed, then the best option is to use the software binaries of the shared Oracle home from the mounted drive and configure the remote hosts to be managed by that Management Agent, thus capitalizing on the NFS visibility and saving hard disk space on the remote hosts.
The Management Agent that shares its software binaries, in this context, is called the Master Agent, and the one that is configured with an instance directory on the remote host is called the Shared Agents or NFS Agents.
You can install a Shared Agent in graphical or silent mode. In graphical mode, you use the Add Host Targets Wizard that is accessible from within the Enterprise Manager Cloud Control console. In silent mode, you use the AgentNFS.pl script.
The wizard and the script use the software binaries from the shared Oracle home and configure an instance directory on each of the destination hosts for storing configuration files such as emd.properties, targets.xml, log files, and so on.
  • Installing a Shared Agent on a host running on Microsoft Windows is not supported.
  • Unlike the Add Host Target Wizard, the AgentNFS.pl script must be run only from a destination host, and at a given time, only one Management Agent can be installed at a given time. Therefore, if you want to install only a few Management Agents, then use the AgentNFS.pl script.
Before You Begin
Before you begin, keep these points in mind:
Prerequisites
Before installing a Shared Agent, ensure that you meet the following prerequisites:
Table 8-1 Prerequisites for Installing Shared Agent
Requirement Description
Hardware Requirements
Ensure that you meet the hard disk space and physical memory requirements. For more information, see the chapter on hardware requirements in the Oracle Enterprise Manager Cloud Control Basic Installation Guide.
Destination Host Disk Space Requirements
Ensure that the Master Agent host has a minimum of 1 GB free hard disk space, and the Shared Agent host has a minimum of 1 MB free hard disk space.
Software Requirements
(Only for Graphical Mode)
(For Microsoft Windows) Ensure that you have installed Cygwin 1.7 on the destination host. For more information, see the chapter on installing Cygwin in the Oracle Enterprise Manager Cloud Control Basic Installation Guide.
Note: While running cygwin.bat in Microsoft Windows Server 2008 and Microsoft Windows Vista, ensure that you invoke it in administrator mode. To do this, right-click the cygwin.bat file and select Run as administrator.
Operating System Requirements
Ensure that you install the Management Agent only on certified operating systems as mentioned in the Enterprise Manager certification matrix available on My Oracle Support.
To access the Enterprise Manager certification matrix, follow the steps outlined in Oracle Enterprise Manager Cloud Control Basic Installation Guide.
For information about platforms receiving future support, refer to My Oracle Support note 793512.1.
Note: If you use Oracle Solaris 10, then ensure that you have update 9 or higher installed. To verify whether it is installed, run the following command:
cat /etc/release
You should see the output similar to the following. Here, s10s_u6 indicates that update 6, which is not a supported update level for installation, is installed.
Solaris 10 10/08 s10s_u6wos_07b SPARC
Package Requirements
Ensure that you install all the operating system-specific packages. For more information, see the chapter on package requirements in the Oracle Enterprise Manager Cloud Control Basic Installation Guide.
User and Operating System Group Requirement
Ensure that the destination host where you want to install the Management Agent has the appropriate users and operating system groups created.
For more information, see the chapter on creating operating system groups and users in the Oracle Enterprise Manager Cloud Control Basic Installation Guide.
Software Availability Requirements
Ensure that you already have Oracle Management Agent 12c installed as a Master Agent in a shared, mounted location.
Software Mount Requirements
Ensure that you mount the Master Agent software by running the following command on the Shared Agent host:
mount -t nfs -o ro <master_agent_host_name>:<agent_base_dir_of_master_agent> <agent_base_dir_of_shared_agent>
For example, run the following command:
mount -t nfs -o ro abc.oracle.com:/scratch/masterAgent /scratch/sharedAgent
Also, ensure that the Management Agent user has only read permissions on the mount location, that is, the agent base directory of the Master Agent.
/etc/hosts File Requirements
Ensure that the /etc/hosts file on the host has the IP address, the fully qualified name, and the short name in the following format:
172.16.0.0 example.com mypc
Destination Host Access Requirements
Ensure that the destination hosts are accessible from the host where the OMS is running.
Ensure that the destination host has read-only access to the software binaries of this Master Agent.
If the destination host and the host on which OMS is running belong to different network domains, then ensure that you update the /etc/hosts file on the destination host to add a line with the IP address of that host, the fully qualified name of that host, and the short name of the host.
For example, if the fully-qualified host name is example.com and the short name is mypc, then add the following line in the /etc/hosts file:
Destination Host Credential Requirements
Ensure that all the destination hosts running on the same operating system have the same set of credentials. For example, all the destination hosts running on Linux operating system must have the same set of credentials.
The wizard installs the Management Agent using the same user account. If you have hosts running on the same operating system but with different credentials, then have two different deployment sessions.
Destination Host Time Zone Requirements
Ensure that the time zones of the destination hosts have been set correctly. To verify the time zone of a destination host, log in to the OMS host, and run the following command:
ssh -l <install_user> <destination_host_name> /bin/sh -c 'echo $TZ'
If the time zone displayed is incorrect, log in to the destination host, and follow these steps:
  1. Run the following commands to set the time zone on the destination host:
    • For Korn shell:
      TZ=<value>
      export TZ
    • For Bourne shell or Bash shell:
      export TZ=<value>
    • For C shell:
      setenv TZ <value>
    For example, in the Bash shell, run the following command to set the time zone to America/New_York:
    export TZ='America/New_York'
    To set the time zone on a destination host that runs on Microsoft Windows, from the Start menu, select Control Panel. Click Date and Time, then select the Time Zone tab. Select your time zone from the displayed drop down list.
    To view a list of the time zones you can use, access the supportedtzs.lst file present in the <AGENT_HOME>/sysman/admin directory of the central agent (that is, the Management Agent installed on the OMS host).
    Note: If you are installing a Management Agent on a host that runs on Microsoft Windows Server 2003, and you encounter an error when you suse the Asia/Kolkata time zone, see the My Oracle Support note 1530571.1.
  2. Restart the SSH daemon.
    If the destination host runs on a UNIX based operating system, run the following command:
    sudo /etc/init.d/sshd restart
    If the destination host runs on a Microsoft Windows operating system, run the following commands:
    cygrunsrv -E sshd
    cygrunsrv -S sshd
  3. Verify whether the SSH server can access the TZ environment variable by logging in to the OMS host, and running the following command:
Note: If you had ignored a prerequisite check warning about wrong time zone settings during the Management Agent install, you must set the correct time zone on the destination hosts after installing the Management Agents. For information on setting time zones post install, refer After You Install.
(Only for Silent Mode)
Ensure that the host time zone has been set correctly. To verify the host time zone, run the following command:
echo $TZ
If the time zone displayed is incorrect, run the following commands, before running the agentDeploy.sh or agentDeploy.bat scripts, to set the correct time zone:
  • For Korn shell:
    TZ=<value>
    export TZ
    export TZ=<value>
  • For C shell:
    setenv TZ <value>
  • If you are installing a Management Agent on a host that runs on Microsoft Windows Server 2003, and you encounter an error when you use the Asia/Kolkata time zone, see the My Oracle Support note 1530571.1.
  • If you had ignored a prerequisite check warning about wrong time zone settings during the Management Agent install, you must set the correct time zone on the host after installing the Management Agent. For information on setting time zones post install, refer After You Install.
sudo/pbrun/sesu/su SSH Requirements
(Only for UNIX)
Ensure that you set the oracle.sysman.prov.agentpush.enablePty property to true in the $<OMS_HOME>/sysman/prov/agentpush/agentpush.properties file, if the privilege delegation tool you are using requires a pseudo terminal for remote command execution via SSH. Most privilege delegation tools such as pbrun, sesu, and su require a pseudo terminal for remote command execution, by default.
Note: If you are using sudo as your privilege delegation tool, and you do not want to set the oracle.sysman.prov.agentpush.enablePty property to true, do one of the following:
  • Include Defaults visiblepw in the /etc/sudoers file, or enter the sudo command with the -S option for Privileged Delegation Setting on the Installation Details page.
    For information on how to access the Installation Details page, see Installing in Graphical Mode.
  • Comment out Defaults requiretty in the /etc/sudoers file.
sudo/pbrun/sesu/su Requirements (for Root User)
(Only for UNIX)
  • Ensure that the installing user has the privileges to invoke the id command and the agentdeployroot.sh script as root. Grant the privileges in the configuration file of your privilege delegation tool.
    For example, if you are using sudo as your privilege delegation tool, include the following in the /etc/sudoers file to grant the required privileges:
    oracle ALL=(root) /usr/bin/id, /home/oracle/agentinst/*/agentdeployroot.sh
    Here, oracle is the installing user, and /home/oracle/agentinst is the agent instance directory of the Shared Agent.
  • You do not require the following entry in the /etc/sudoers file for installing a Management Agent. However, the entry is required for performing provisioning and patching operations in Enterprise Manager. Therefore, if you are removing this entry before installing a Management Agent, then ensure that you bring back the entry after installing the Management Agent.
    (root)/oracle/product/oms12c/agent/agent_inst/bin/nmosudo
sudo/pbrun/sesu/su Requirements (for Locked Account User)
(Only for UNIX)
  • Ensure that the installing user has the privileges to invoke /bin/sh as the locked account user. Grant the privileges in the configuration file of your privilege delegation tool.
    login_user1 ALL=(oracle) /bin/sh
    Here, login_user1 is the SSH log in user, and oracle is the locked account and install user.
    If you do not want to grant privileges to the installing user to invoke /bin/sh as the locked account user, set the oracle.sysman.prov.agentpush.pdpShellOutEnabled property to false, and ensure that the installing user has the privileges to invoke id, chmod, cp, mkdir, rm, tar, emctl, perl, runInstaller, and unzip as the locked account user. Grant the privileges in the configuration file of your privilege delegation tool.
    login_user1 ALL=(oracle) /usr/bin/id, /bin/chmod, /bin/cp, /bin/mkdir, /bin/rm, /bin/tar, /home/oracle/agentinst/bin/emctl, /home/oracle/agentibd/core/12.1.0.2.0/perl/bin/perl, /home/oracle/agentibd/core/12.1.0.2.0/oui/bin/runInstaller, /home/oracle/agentibd/core/12.1.0.2.0/bin/unzip
    Here, login_user1 is the SSH log in user, oracle is the locked account and install user, /home/oracle/agentinst is the agent instance directory of the Shared Agent, and /home/oracle/agentibd is the agent base directory.
Temporary Directory Space Requirements
Ensure that you allocate 400 MB of space for a temporary directory where the executables can be copied.
By default, the temporary directory location set to the environment variable TMP or TEMP is honored. If both are set, then TEMP is honored. If none of them are set, then the following default values are honored: /tmp on UNIX hosts and c:\Temp on Microsoft Windows hosts.
Instance Directory Requirements
Ensure that the instance directory you enter is empty and has write permission.
Shared Oracle Home Requirements
Ensure that the Master Agent home is accessible from the destination host where you want to install the Shared Agent. Ensure that the Master Agent home is mounted with the setuid turned on.
Ensure that the Shared Agent has read-only access to the software binaries of this Master Agent.
PATH Environment Variable Requirements
On the destination host, ensure the following:
  • (For Microsoft Windows) Ensure that the Cygwin software location appears before other software locations in the PATH environment variable. After making it the first entry, restart the SSH daemon (sshd).
  • (For UNIX) On the destination host, ensure that the SCP binaries (for example, /usr/bin/scp) are in the PATH environment variable:
Path Validation Requirements
Validate the path to all command locations. For more information, see the appendix on validating command locations in the Oracle Enterprise Manager Cloud Control Basic Installation Guide.
CLASSPATH Environment Variable Requirements
If the value assigned to the CLASSPATH environment variable has white spaces in it, then ensure that you unset it. You can always reset the environment variable to the original value after the installation is complete.
Default SSH Port Requirements
Ensure that the SSH daemon is running on the default port (that is, 22) on all the destination hosts. To verify the port, run the following command:
netstat -anp | grep <port_no>
If the port is a non-default port, that is, any port other than 22, then update the SSH_PORT property in the following file that is present in the OMS home:
$<OMS_HOME>/oui/prov/resources/Paths.properties
Port Requirements
Ensure that the default ports described in What Default Ports Are Used? are free.
Installing User Requirements
  • Ensure that the user installing the Shared Agent is the same as the user who installed the Master Agent.
  • If the central inventory owner and the user installing the Management Agent are different, then ensure that they are part of the same group.
  • Ensure that the inventory owner and the group to which the owner belongs have read and write permissions on the inventory directory.
    For example, if the inventory owner is abc and the user installing the Management Agent is xyz, then ensure that abc and xyz belong to the same group, and they have read and write access to the inventory.
Central Inventory (oraInventory) Requirements
  • Ensure that you allocate 100 MB of space for the Central Inventory.
  • Ensure that the inventory directory is not in a shared file system.
  • The Shared Agent uses the inventory location mentioned in the oraInst.loc file, which is present in the <MASTER_AGENT_BASE DIR>/core/12.1.0.2.0/ directory. Ensure that the Shared Agent user has read and write permissions on this directory.
Agent User Account Permissions and Rights
(Only for Microsoft Windows)
(For Microsoft Windows) If you are installing the Management Agent on a Microsoft Windows-based operating system, then ensure that the agent user account has permissions and rights to perform the following:
  • Act as part of the operating system.
  • Adjust memory quotas for a process.
  • Replace process level token.
  • Log in as a batch job.
To verify whether the agent user has these rights, follow these steps:
  1. Launch the Local Security Policy.
    From the Start menu, click Settings and then select Control Panel. From the Control Panel window, select Administrative Tools, and from the Administrative Tools window, select Local Security Policy.
  2. In the Local Security Policy window, from the tree structure, expand Local Policies, and then expand User Rights Assignment.
Permissions for cmd.exe
(For Microsoft Windows) If you are installing the Management Agent on a Microsoft Windows-based operating system, then ensure that you grant the Cmd.exe program Read and Execute permissions for the user account that the batch job runs under. This is a restriction from Microsoft.
For more information on this restriction and to understand how you can grant these permissions, access the following URL to Microsoft Web site:
http://support.microsoft.com/kb/867466/en-us
Preinstallation/Postinstallation Scripts Requirements
Ensure that the preinstallation and postinstallation scripts that you want to run along with the installation are available either on the OMS host, destination hosts, or on a shared location accessible to the destination hosts.
Browser Requirements
  • Ensure that you use a certified browser as mentioned in the Enterprise Manager certification matrix available on My Oracle Support.
  • If you use Microsoft Internet Explorer 8 or 9, do the following:
    • Turn off the compatibility view mode. To do so, in Microsoft Internet Explorer, from the Tools menu, click Compatibility View to disable it if it is enabled. Also, click Compatibility View Settings and deregister the Enterprise Manager Cloud Control console URL.
    • Enable XMLHTTP. To do so, from the Tools menu, click Internet Options. Click the Advanced tab, and under the Security heading, select Enable native XMLHTTP support to enable it.
Installation Procedure
This section describes the following:
To install a Shared Agent in graphical mode, follow these steps:
  1. In Cloud Control, do one of the following:
    • From the Setup menu, select Add Targets, and then, click Auto Discovery Results. On the Auto Discovery Results page, select a host you want to monitor in Enterprise Manager Cloud Control, and click Promote.
    • From the Setup menu, select Add Target, and then, click Add Targets Manually. On the Add Targets Manually page, select Add Host Targets and click Add Host.
  2. On the Host and Platform page, do the following:
    1. Accept the default name assigned for this session or enter a unique name of your choice. The custom name you enter can be any intuitive name, and need not necessarily be in the same format as the default name. For example, add_host_operation_1
      A unique deployment activity name enables you to save the installation details specified in this deployment session and reuse them in the future without having to enter all the details all over again in the new session.
    2. Click Add to enter the fully qualified name and select the platform of the host on which you want to install the Management Agent.
      • Oracle recommends you to enter the fully qualified domain name of the host. For monitoring purpose, Enterprise Manager Cloud Control adds that host and the Management Agent with the exact name you enter here.
      • You must enter only one host name per row. Entering multiple host names separated by a comma is not supported.
      • You must ensure that the host name you enter does not have underscores.
      Alternatively, you can click either Load from File to add host names stored in a file, or Add Discovered Hosts to add host names from a list of hosts discovered by Enterprise Manager. For information on how the host name entries must appear in the host file, see Format of Host List File
      When you click Add Discovered Hosts and add hosts from a list of discovered hosts, the host's platform is automatically detected and displayed. The platform name is detected using a combination of factors, including hints received from automated discovery and the platform of the OMS host. This default platform name is a suggestion, so Oracle strongly recommends you to verify the platform details before proceeding to the next step.
      As the Shared Agent can be installed only if the source host and the destination host are running on the same platform, set the platform for the first host in the first row of the table and from the Platform list, select Same for All Hosts. This will ensure that the platform name you selected for the first host is also set for the rest of the hosts in the table.
      If you are installing a Management Agent on a host that is running on a platform different from the OMS host platform, then ensure that the Management Agent software for that platform is available in Oracle Software Library (Software Library). If the Management Agent software for the required platform is not available in Software Library, acquire and apply the software using the Self Update console.
      To access the Self Update Console, from the Setup menu, select Extensibility, then select Self Update. To acquire the latest Management Agent software, click Agent Software, select the required software, then click Download.
      For more information on how to acquire and apply the Management Agent software for a platform using the Self Update console, see Oracle Enterprise Manager Cloud Control Basic Installation Guide.
    3. Click Next.
  3. On the Installation Details page, do the following:
    1. In the Deployment Type section, select Add Host to Shared Agent. Then, for Select Target, click the torch icon and select the Management Agent that is shared and mounted. This location must be visible on all remote hosts.
      Figure 8-1 describes this step.
      Figure 8-1 Installing a Shared Agent
      Description of Figure 8-1 follows
      Description of "Figure 8-1 Installing a Shared Agent"
    2. From the table, select the first row that indicates the hosts grouped by their common platform name.
    3. In the Installation Details section, provide the installation details common to the hosts selected in Step 3 (b). For Oracle Home, validate or enter the location of the shared Management Agent home. Ensure that this location is accessible from all the destination hosts.
    4. For Instance Directory, enter the absolute path to a directory where all Management Agent-related configuration files can be stored. Ensure that the directory has write permission.
      For example, /usr/home/software/oracle/agentHome/agent_inst
      If the path you enter does not exist, the application creates a directory at the specified path, and stores all the Management Agent-related configuration files there.
    5. From Named Credential list, select an appropriate profile whose credentials can be used for setting up the SSH connectivity between the OMS and the remote hosts, and for installing a Management Agent on each of the remote hosts.
      • If you do not have a credential profile, or if you have one but do not see it in the Named Credential list, then click the plus icon against this list. In the Create New Named Credential window, enter the credentials and store them with an appropriate profile name so that it can be selected and used for installing the Management Agents. Also set the run privilege if you want to switch over from the Named Credential you are creating, to another user who has the privileges to perform the installation.
      • If the plus icon is disabled against this list, then you do not have the privileges to create a profile with credentials. In this case, contact your administrator and either request him/her to grant you the privileges to create a new profile or request him/her to create a profile and grant you the access to view it in the Named Credential list.
      • If you have manually set up SSH public key authentication between the OMS and the remote hosts, then you may not have a password for your user account. In this case, create a named credential with a dummy password. Do NOT leave the password field blank.
    6. For Privileged Delegation Setting, validate the Privilege Delegation setting to be used for running the root scripts. By default, it is set to the Privilege Delegation setting configured in Enterprise Manager Cloud Control.
      For example, you can specify one of the following for the Privileged Delegation Setting field:
      /usr/bin/sudo -u %RUNAS% %COMMAND%
      /usr/bin/sesu - %RUNAS% -c "%COMMAND%"
      /usr/bin/pbrun %PROFILE% -u %RUNAS% %COMMAND%
      /usr/bin/su - %RUNAS% -c "%COMMAND%"
      If you leave the Privileged Delegation Setting field blank, the root scripts will not be run by the wizard; you will have to run them manually after the installation. For information about running them manually, see After You Install.
      This setting will also be used for performing the installation as the user set in the Run As attribute of the selected Named Credential if you had set the user while creating that Named Credential.
      In the Privilege Delegation setting, the %RUNAS% is honored as the root user for running the root scripts and as the user set in the Run As attribute of the Named Credential for performing the installation.
    7. For Port, accept the default port (3872) that is assigned for the Management Agent to communicate, or enter a port of your choice.
      The custom port you enter must not be busy. If you are not sure, you can leave it blank. Enterprise Manager Cloud Control automatically assigns the first available free port within the range of 1830 - 1849.
    8. (Optional) In the Optional Details section, enter the absolute path to an accessible location where the preinstallation and postinstallation scripts you want to run are available. Note that only one preinstallation or one postinstallation script can be specified.
      If you want to run the script as root, then select Run as Root. If the script is on the host where OMS is running and is not on the host where you want to install the Management Agent, then select Script on OMS. In this case, the script will be copied from the OMS host to the destination hosts, and then run on the destination hosts.
    9. (Optional) For Additional Parameters, enter a whitespace-separate list of additional parameters that you want to pass during the installation. For a complete list of supported additional parameters, see Table 8-2.
      For example, if you want to provide the inventory pointer location file, then enter -invPtrLoc followed by the absolute path to the file location. However, this parameter is supported only on UNIX platforms, and not on Microsoft Windows platforms.
    10. Repeat Step 3 (b) to Step 3 (h) for every other row you have in the table.
    11. Click Next.
  4. On the Review page, review the details you have provided and if you are satisfied with the details, then click Deploy Agent to install the Management Agent.
    If you want to modify the details, then click Back repeatedly to reach the page where you want to make the changes.
    When you click Deploy Agent and submit the deployment session, you are automatically taken to the Add Host Status page that enables you to monitor the progress of the deployment session.
If you restart the destination host after installing a Shared Agent, and the Shared Agent does not start up automatically, restore the mount, and start the Shared Agent manually by running the following commands on the host:
$<INSTANCE_HOME>/bin/emctl start agent
Supported Additional Parameters
Table 8-2 lists the additional parameters supported for installing a Shared Agent in graphical mode.
Table 8-2 Supported Additional Parameters
Parameter Description
EM_STAGE_DIR
Enter the absolute path to a custom location that can be created as a temporary Provisioning Advisor Framework (PAF) staging directory.
By default, every time you install a Management Agent, a PAF staging directory is created for copying the Software Library entities related to the deployment procedures. By default, this location is the scratch path location (/tmp). The location is used only for provisioning activities—entities are copied for a deployment procedure, and then, deleted once the deployment procedure ends.
If you want to override this location with a custom location, you can pass this option and enter a custom location.
For example,
EM_STAGE_DIR=/home/john/software/oracle/pafdir
b_startAgent=false
Specify this parameter if you do not want the Management Agent to start automatically once it is installed and configured.
If you do not specify this parameter, the Management Agent starts automatically once it is installed and configured.
b_secureAgent=false
Specify this parameter if you do not want the Management Agent to be secured after the install.
If you specify this parameter, ensure that you also specify the OMS HTTP port, using the EM_UPLOAD_PORT parameter.
For example, b_secureAgent=false EM_UPLOAD_PORT=4899
If you do not specify this parameter, the Management Agent is secured automatically after the install.
Installing in Silent Mode
To install a Shared Agent in silent mode, follow these steps:
  1. Create a response file titled AgentNFS.rsp as described in Table 8-3.
    The response file you create can have any name, and not necessarily AgentNFS.rsp. For easy understanding, this chapter uses the name AgentNFS.rsp. Also, instead of creating a response file, you can choose to pass the arguments explicitly while invoking the script. However, Oracle recommends that you create a response file and capture the information there.
  2. Invoke the script from the Master Agent home, which is visible as a shared location, and pass the response file.
    $<AGENT_HOME>/perl/bin/perl <AGENT_HOME>/sysman/install/AgentNFS.pl -responseFile=<absolute_path_to_response_file>
    For example,
    /scratch/agent_base_dir/core/12.1.0.2.0/perl/bin/perl /scratch/agent_base_dir/core/12.1.0.2.0/sysman/install/AgentNFS.pl -responseFile=/home/john/AgentNFS.rsp
    • Instead of creating a response file, you can choose to pass all the arguments explicitly while invoking the script. In this case, invoke the script in the following way:
      $<AGENT_HOME>/perl/bin/perl <AGENT_HOME>/sysman/install/AgentNFS.pl AGENT_INSTANCE_HOME=<absolute_path_to_instance_dir> ORACLE_HOME=<absolute_path_to_master_agent_oracle_home> <parameter1>=<value1> <parameter2>=<value2> <parameter3>=<value3>...
      For example,
      /scratch/agent_base_dir/core/12.1.0.2.0/perl/bin/perl /scratch/agent_base_dir/core/12.1.0.2.0/sysman/install/AgentNFS.pl AGENT_INSTANCE_HOME=/home/john/agent_inst ORACLE_HOME=/scratch/agent_base_dir/core/12.1.0.2.0 AGENT_PORT=1832 AGENT_REGISTRATION_PASSWORD=welcome b_startAgent=TRUE
    • If the Master Agent was installed using the Add Host Targets Wizard, then ensure that you pass the following arguments with these values:
      AGENT_REGISTRATION_PASSWORD=<password>
      b_startAgent=TRUE
    • Do NOT pass the -invPtrLoc argument because, by default, the location <AGENT_HOME>/oraInst.loc is honored, where <AGENT_HOME> is the Master Agent. Also ensure that the Oracle Inventory directory, to which the inventory file points, is not in a shared location.
    • If you restart the destination host after installing a Shared Agent, and the Shared Agent does not start up automatically, restore the mount, and start the Shared Agent manually by running the following commands:
      mount -t nfs -o ro <master_agent_host_name>:<master_agent_base_dir> <shared_agent_base_dir>
  3. When prompted to run the root.sh script, run it from the instance directory of the Management Agent:
    <AGENT_INSTANCE_HOME>/root.sh
    If you are not a root user, then use SUDO to change to a root user. For example, run the following command:
    /usr/local/bin/sudo /scratch/OracleHomes/agent_inst/root.sh
  4. Repeat Step (1) to Step (3) on the remaining hosts where you want to install the Shared Agent.
Creating a Response File
For silently installing a Shared Agent, you must invoke the AgentNFS.pl script and pass a response file that captures all the required information. Table 8-3 describes the various parameters you must include in the response file.
Table 8-3 Creating a Response File for Installing Oracle Management Agent Using the AgentNFS.pl Script
ORACLE_HOME
Specify the absolute path to the Master Agent home, which is shared and visible on the destination host.
For example, /scratch/agent_base_dir/core/12.1.0.2.0
AGENT_PORT
(Optional) Enter the port on which the Shared Agent process should be started. You can enter any free port between 1830 and 1849. The same port is used for both HTTP and HTTPS.
For example, 1832
AGENT_INSTANCE_HOME
Specify the absolute path to a location on the destination host where you want to store all Management Agent-related configuration files.
For example, /home/john/agent_inst
b_startAgent
Set it to TRUE so that the Shared Agent is started automatically once it is installed and configured.
Note: If the Master Agent was installed using the Add Host Targets Wizard, then you must pass this parameter.
ORACLE_HOSTNAME
(Optional) (Only for Installation on Virtual Hosts) Specify the virtual host name where you are installing the Shared Agent.
Enter a password for registering new Management Agents that join the Enterprise Manager system.
By default, the communication between the OMS and the Management Agents is secured and locked. Any new Management Agents that join the Enterprise Manager system must be authenticated before they become part of the system. The password you enter here will be used for authenticating those new Management Agents.
For example, Wel456come
After You Install
After you install a Shared Agent, follow these steps:
  1. (Only for Graphical Mode) Verify the installation on the Add Host Status page. Review the progress made on each of the phases of the deployment operation — Initialization, Remote Prerequisite Check, and Agent Deployment.
    In the Add Host Targets Wizard, after you click Deploy Agent to install one or more Management Agents, you are automatically taken to the Add Host Status page.
    If you want to view the details or track the progress of all the deployment sessions, then from the Setup menu, select Add Target, and then, click Add Targets Manually. On the Add Targets Manually page, select Add Host Targets and click Add Host Results.
    If a particular phase fails or ends up with a warning, then review the details provided for each phase in the Agent Deployment Details section, and do one of the following:
    • Ignore the warning or failure, and continue with the session if you prefer.
      • You can choose to proceed with the deployment of Management Agents only on those remote hosts that have successfully cleared the checks, and you can ignore the ones that have Warning or Failed status. To do so, click Continue and select Continue, Ignoring Failed Hosts.
      • You can choose to proceed with the deployment of Management Agents on all the hosts, including the ones that have Warning or Failed status. To do so, click Continue and select Continue, All Hosts.
    • Fix the problem by reviewing the error description carefully, understanding its cause, and taking action as recommended by Oracle.
      • You can choose to retry the deployment of Management Agents with the same installation details. To do so, click Retry and select Retry Using Same Inputs.
      • You can retry the deployment of Management Agents with modified installation details. To do so, click Retry and select Update Inputs and Retry.
  2. Verify the installation:
    1. Navigate to the Shared Agent instance home and run the following command to see a message that confirms that the Management Agent is up and running:
      $<AGENT_INSTANCE_HOME>/bin/emctl status agent
      If the status of the Management Agent is down for some reason, then manually start the Management Agent by running the following command from its Oracle home:
      $<AGENT_INSTANCE_HOME>/bin/emctl start agent
    2. Navigate to the Shared Agent home and run the following command to see a message that confirms that EMD upload completed successfully:
      $<AGENT_INSTANCE_HOME>/bin/emctl upload
  3. (Only for Graphical Mode) If you have restrictive Privilege Delegation Provider (PDP) configuration settings, enter the location of nmosudo in your PDP configuration file.
    Enterprise Manager supports PDPs such as SUDO and PowerBroker that enable administrators to restrict certain users from running certain commands.
    In Enterprise Manager Cloud Control 12c Release 2 (12.1.0.2), nmosudo is located in the sbin directory, which is in the agent base directory. For example, <AGENT_BASE_DIRECTORY>/sbin/nmosudo. In Enterprise Manager Cloud Control 12c Release 1 (12.1.0.1) [with or without Bundle Patch 1], nmosudo is located in the agent instance directory. For example, <AGENT_INSTANCE_DIRECTORY>/bin/nmosudo.
    Therefore, when you install an Enterprise Manager Cloud Control 12c Release 2 (12.1.0.2) Management Agent, you must modify your PDP configuration file to update the new location of nmosudo.
    For example, if you use SUDO as your PDP, the configuration file for SUDO is typically /etc/sudoers. In this file, update the following entry with the new location to nmosudo.
    sudouser ALL : oracle /eminstall/basedir/sbin/nmosudo *
  4. (Only for UNIX Operating Systems) If you had ignored the prerequisite check warning about not having root privileges, SUDO binaries, or SUDO privileges, then manually run the following scripts as a root user from each of the hosts where the cloning was done. If you do not have SUDO privileges, then request your Administrator who has the privileges to run these scripts.
    • If this is the first Oracle product you just cloned on the host, then run the oraInstroot.sh script from the inventory location specified in the oraInst.loc file that is available in the Management Agent home.
      For example, if the inventory location specified in the oraInst.loc file is $HOME/oraInventory, then run the following command:
      $HOME/oraInventory/oraInstRoot.sh
      /usr/bin/sudo $HOME/oraInventory/oraInstRoot.sh
    • Run the root.sh script from the Management Agent home:
      $<AGENT_HOME>/root.sh
      /usr/bin/sudo $<AGENT_HOME>/root.sh
  5. If you had ignored a prerequisite check warning about wrong time zone settings, run the following command and follow the steps it displays:
    $<AGENT_INSTANCE_HOME>/bin/emctl resetTZ agent
  6. By default, the host and the Shared Agent get automatically added to the Enterprise Manager Cloud Control console for monitoring. None of the targets running on that host get automatically discovered and monitored.
    To monitor the other targets, you need to add them to Enterprise Manager Cloud Control either using the Auto Discovery Results page, the Add Targets Manually page, or the discovery wizards offered for the targets you want to monitor.
    For information about discovering targets in Enterprise Manager Cloud Control, refer to the chapter on adding targets in the Oracle Enterprise Manager Cloud Control Administrator's Guide.
If Oracle Management Agents 12c Release 1 or 2 (12.1.0.x ) hang frequently or do not respond on Solaris 9ux and 10ux operating systems, then refer to document ID 1427773.1 on My Oracle Support.
