| Oracle® Fusion Middleware Forms and Reports System Requirements and Specifications 11g Release 2 (11.1.2) |
![]() Previous |
E25460-01
March 2012
This document contains system and platform-specific information for Oracle Fusion Middleware Forms and Reports 11g Release 2 (11.1.2).
The following topics are covered in this document:
Section 1, "Finding Oracle Fusion Middleware Certification Information"
Section 2, "Oracle Fusion Middleware Memory and Space Requirements"
Section 4, "Configuration Requirements for Installing on a DHCP Host"
Section 6, "System Requirements for Windows Operating Systems"
If you are looking for latest certification information for current and previous releases, go to the Oracle Fusion Middleware Supported System Configurations page:
http://www.oracle.com/technetwork/middleware/ias/downloads/fusion-certification-100350.html
The various certification documents contain information related to supported 32-bit and 64-bit operating systems, databases, web servers, LDAP servers, adapters, IPv6, JDKs, and third-party products.
The certification document for 11g Release 2 (11.1.2) is called System Requirements and Supported Platforms for Oracle Forms and Reports 11g Release 2 (11.1.2.x) Certification Matrix.
This section contains the minimum memory and disk space requirements for Oracle Fusion Middleware products. The following topics are covered:
Section 2.2, "Oracle Forms and Reports Memory and Disk Space Requirements"
Section 2.3, "Using a 64-bit JDK with Oracle Fusion Middleware"
Section 2.4, "Oracle Identity Management Memory and Disk Space Requirements"
Unless otherwise noted, Table 1 lists the general minimum memory requirements for Oracle Fusion Middleware products. For the purposes of this document, "minimum available memory" is defined as the amount of physical memory (RAM) and swap memory combined.
This section describes the recommended hardware and system configuration requirements for Oracle Forms and Reports.
Note: On some Windows 32-bit operating systems, the available memory is limited to 3GB. For components that are certified on such systems, Oracle recommends using the/3GB switch, as specified in Microsoft Knowledge Base Article #291988.
For more information, see the certification information, as described in Section 1, "Finding Oracle Fusion Middleware Certification Information". |
Section 2.2.1, "Memory and Disk Space Requirements for Installing Oracle Forms and Reports"
Section 2.2.2, "Memory and Disk Space Requirements for Configuring Oracle Forms and Reports"
Table 2 lists the memory and disk space requirements for installing Oracle Forms and Reports.
Table 2 Memory and Disk Space Requirements for Installation
| Requirement | Value |
Physical Memory |
Expected minimum value is 922MB. |
Temp Space |
Must be greater than 270MB |
Swap Space |
Must be greater than 500MB |
Minimum Available Memory |
Must be greater than 1422MB (physical memory and swap space combined) |
Disk Space |
3600MB |
Table 2 lists the memory and disk space requirements for configuring Oracle Forms and Reports.
Table 3 Memory and Disk Space Requirements for Configuration
Physical Memory |
Temp Space |
Swap Space |
Disk Space |
Depends on your configuration mode:
If you are using a 64-bit JVM in your environment, ensure that all your Oracle Fusion Middleware components are using the 64-bit JVM. Also make sure that Oracle WebLogic Server is installed with the 64-bit JDK. You cannot mix components using a 32-bit JVM with those using a 64-bit JVM.
Refer to the System Requirements and Supported Platforms for Oracle Forms and Reports 11g Release 2 (11.1.2.x) Certification Matrix for information on the platforms that support a 64-bit JDK. This document is available on the Oracle Fusion Middleware Supported System Configurations page, as described in Section 1, "Finding Oracle Fusion Middleware Certification Information".
Oracle Forms and Reports can be protected by Oracle Identity Management as described in Oracle Fusion Middleware Installation Guide for Oracle Forms and Reports.
The memory and disk space requirements for Oracle Identity Management 11g Release 1 (11.1.1) can be found in Oracle Fusion Middleware System Requirements and Specifications for 11g Release 1 (11.1.1). This document can be found on the following page:
http://www.oracle.com/technetwork/middleware/ias/downloads/fusion-requirements-100147.html
This section contains prerequisite information for the Oracle Universal Installer (OUI). The requirements in this section must be met in order for the installer to start:
Section 3.3, "Spaces in Windows Directory Paths Are Not Supported"
Section 3.4, "Special Startup Requirements for Linux x86 or Linux x86-64 Operating Systems"
The environment variables on your system must be set as described in Table 4:
Table 4 Oracle Universal Installer Environment Variable Requirements
| Variable | Description |
Applies to: all configuration tools for all products on all platforms. This variable is automatically set by the configuration tool to the Oracle home from where the configuration tool is started. This is true even if the |
Applies to: all installers for all products on all platforms. For the Oracle Forms and Reports installer, this variable must not be set. For all other installers, there are no restrictions as to whether this variable is set or not set. |
Applies to: all installers for products with system components only on Windows operating systems. This variable is automatically set by the installer and prepended with NOTE: make sure this variable does not contain a reference to any other Oracle home directory. |
Applies to: all installers for products with system components only on HP-UX and HP-IA operating systems. This variable is automatically set by the installer and prepended with |
Applies to: all installers for products with system components only on AIX operating systems. This variable is automatically set by the installer and prepended with |
Applies to: all installers for products with system components only on Linux and Solaris operating systems. This variable is automatically set by the installer and prepended with NOTE: make sure this variable does not contain a reference to any other Oracle home directory. |
Applies to: all installers for all products on all platforms. If you are installing with a graphical user interface (GUI), this variable must be set to the monitor where you want the installer GUI to appear. Refer to your operating system documentation for specific instructions on how to do this, as procedures vary depending on your exact operating system. |
Applies to: all installers for all products on all platforms. Optional variable. If not set, then the default value is |
Applies to: all installers for all products on all platforms. For the Oracle Forms and Reports installer, these variables must not be set. For all other installers, there are no restrictions as to whether these variables are set or not set. |
The items in Table 5 are checked as the installer is being started:
Table 5 Oracle Universal Installer Startup Requirements
| Category | Accepted or Minimum Values |
Platforms |
For a complete list of supported platforms, refer to the System Requirements and Supported Platforms for Oracle Forms and Reports 11g Release 2 (11.1.2.x) Certification Matrix on the Oracle Fusion Middleware Supported System Configurations page, as described in Section 1, "Finding Oracle Fusion Middleware Certification Information". |
CPU Speed |
At least 300MHz |
Temp Space |
At least 270MB |
Swap Space |
At least 500MB |
Monitor |
At least 256 colors |
If you are running Oracle Universal Installer on a Windows operating system, make sure there are no spaces in the directory path that is specified as a parameter from the command line. For example, if you need to specify the location of a JRE from the command line, the following is not supported:
setup.exe -jreLoc C:\Program Files\Middleware\jdk160_27
Instead, you must shorten "C:\Program Files" to use the Windows short name "C:\Progra~1" as shown below:
setup.exe -jreLoc C:\Progra~1\Middleware\jdk160_27
If you are running Oracle Universal Installer on Linux x86 or Linux x86-64 operating systems, you must modify the value of the SHMMAX kernel parameter to avoid seeing errors generated by the Oracle Universal Installer. To do so:
Change the value of SHMMAX to 4294967295 by including the following line in /etc/sysctl.conf:
kernel.shmmax = 4294967295
Activate the new SHMMAX setting by running the command:
/sbin/sysctl -p
Start the Oracle Universal Installer and install your software.
If you are installing Oracle Forms and Reports on a DHCP host, you must follow the configuration steps in this section for your platform.
On Linux x86 operating systems, configure the host to resolve host names to the loopback IP address by modifying the /etc/hosts file to contain the following entries:
127.0.0.1 hostname.domainname hostname 127.0.0.1 localhost.localdomain localhost
After doing so, check that the hostname resolves to the loopback IP address by entering the following command:
/bin/ping hostname.domainname
On Windows systems, install a loopback adapter on the DHCP server (see Section 4.2.1, "Installing a Windows Loopback Adapter"). This assigns a local IP address to your computer.
After installing the adapter, add a line to the %SYSTEMROOT%\system32\drivers\etc\hosts file with the following format, immediately after the localhost line:
IP_address hostname.domainname hostname
Replace IP_address with the local IP address of the loopback adapter.
Instructions for removing the loopback adapter are provided in Section 4.2.2, "Removing a Windows Loopback Adapter"
To install a loopback adapter on Windows 2003 or Windows XP:
Open the Windows Control Panel.
Windows 2003: Select Start > Control Panel > Add Hardware.
Windows XP: Select Start > Control Panel, then double-click Add Hardware.
In the "Welcome" window, click Next.
In the "Is the hardware connected?" window, select Yes, I have already connected the hardware, then click Next.
In the "The following hardware is already installed on your computer" window, in the list of installed hardware, select Add a new hardware device, then click Next.
In the "The wizard can help you install other hardware" window, select Install the hardware that I manually select from a list, then click Next.
In the "From the list of hardware types, select the type of hardware you are installing" window, select Network adapters, then click Next.
In the "Select Network Adapter" window, make the following selections:
Manufacturer: Microsoft
Network Adapter: Microsoft Loopback Adapter
Click Next.
In the "The wizard is ready to install your hardware" window, click Next.
In the "Completing the Add Hardware Wizard" window, click Finish.
If you are using Windows 2003, restart your computer.
Right-click My Network Places on the desktop and choose Properties. This displays the Network Connections Control Panel.
Right-click the connection that was just created. This is usually named "Local Area Connection 2". Choose Properties.
On the "General" tab, select Internet Protocol (TCP/IP), then click Properties.
In the "Properties" dialog box, click Use the following IP address and do the following:
IP Address: Enter a non-routable IP for the loopback adapter. Oracle recommends the following non-routable addresses:
192.168.x.x (x is any value between 1 and 255) 10.10.10.10
Subnet mask: Enter 255.255.255.0.
Record the values you entered, which you will need later in this procedure.
Leave all other fields empty.
Click OK.
In the "Local Area Connection 2 Properties" dialog, click OK.
Close Network Connections.
Restart the computer.
To remove a loopback adapter on Windows 2003 or Windows XP:
Start the System Control panel.
Windows 2003: Select Start > Control Panel > System.
Windows XP: Select Start > Control Panel, then double-click System.
In the "Hardware" tab, click Device Manager.
In the "Device Manager" window, expand Network adapters. You should see Microsoft Loopback Adapter.
Right-click Microsoft Loopback Adapter and select Uninstall.
Click OK.
This section contains system requirement information for UNIX operating systems. The following topics are covered:
Section 5.1, "Supported UNIX Operating System Versions, Packages, and Patches"
Section 5.3, "Installing Oracle Identity Management on Solaris x86-64 Platforms"
Section 5.4, "Installing Oracle HTTP Server on Linux Operating Systems Requires NPTL"
Section 5.5, "Installing as a Non-Default User on UNIX Operating Systems"
Table 6 lists the platform, operating system, package, and patch information for UNIX operating systems that are either currently supported or were supported in a previous release.
In some cases, a particular platform may be de-supported for use with Oracle Fusion Middleware products. While this particular platform's requirements may remain in this document for legacy purposes, it would no longer be listed in the certification document and would no longer be considered a "certified" platform.
The System Requirements and Supported Platforms for Oracle Forms and Reports 11g Release 2 (11.1.2.x) Certification Matrix is located on the Oracle Fusion Middleware Supported System Configurations page, as described in Section 1, "Finding Oracle Fusion Middleware Certification Information".
All packages listed are minimum versions.
Table 6 Supported UNIX Operating Systems
| Platform | Operating System Version | Supported Packages | Operating System Patches |
Linux x86 |
Oracle Enterprise Linux 5.4 Red Hat Linux 5.4 |
gcc 4.1.0-28.4 gcc-c++ 4.1.0-28.4 setarch 1.6-1 sysstat 5.0.5-1 libstdc++ 4.1.0-28.4 libstdc++-devel 4.1.0-28.4 compat-libstdc++-296 2.96-132.7.2 compat-db 4.1.25-9 control-center 2.8.0-12 glibc-common 2.3.4-2.9 binutils 2.16.91.0.5-23.4 make 3.80-202.2 openmotif 2.2.3 openmotif22 2.2.3 libaio 0.3.106 libaio-devel 0.3.106 |
Linux x86 |
Oracle Enterprise Linux 4 Red Hat Linux 4 |
gcc 3.4.3-22.1 gcc-c++ 3.4.3-22.1 openmotif21 2.1.30-11.RHEL4.4 setarch 1.6-1 pdksh 5.2.14-30 sysstat 5.0.5-1 gnome-libs 1:1.4.1.2.90-44.1 libstdc++ 3.4.3-22.1 libstdc++-devel 3.4.3-22.1 compat-libstdc++-296 2.96-132.7.2 compat-db 4.1.25-9 control-center 2.8.0-12 glibc-common 2.3.4-2.9 binutils 2.15.92.0.2-13 make 1:3.80-5 xscreensaver 4.18-5.rhel4.2 openmotif 2.2.3 libaio 0.3.105 libaio-devel 0.3.105 |
Kernel 2.6.9 |
Linux x86 |
Oracle Enterprise Linux 5 Red Hat Linux 5 |
Kernel 2.6.18 |
Linux x86 |
SUSE 10 |
gcc 4.1.0-28.4 glibc-devel 2.4-31.2 gcc-c++ 4.1.0-28.4 libgcc 4.1.0-28.4 libstdc++-devel 4.1.0-28.4 libstdc++ 4.1.0-28.4 binutils 2.16.91.0.5-23 compat-libstdc++ 5.0.7-22.2 compat 2006.1.25-11.2 make 3.80-202.2 openmotif 2.2.3 openmotif21-libs 2.1.30 libaio 0.3.104 libaio-devel 0.3.104 |
Kernel 2.6.16.21 |
Linux x86 |
SUSE 11 |
binutils 2.19-11.28 gcc 4.3-62.198 gcc-c++ 4.3-62.198 glibc-devel 2.9-13.2 libgcc43 4.3.3_20081022-11.18 libstdc++43 4.3.3_20081022-11.18 libstdc++43-devel 4.3.3_20081022-11.18 libaio 0.3.104-140.22 libaio-devel 0.3.104-140.22 make 3.81-128.20 sysstat 8.1.5-7.8 openmotif 2.3.1-3.13 openmotif21-libs 2.1.30MLI4-143.9 openmotif22-libs 2.2.4-138.17 openmotif-libs 2.3.1-3.13 openmotif-devel 2.3.1-3.13 |
Kernel 2.6.27.19-5-default |
Linux x86-64 |
binutils 2.17.50.0.6 compat-libstdc++-33 3.2.3 (x86_64) compat-libstdc++-33 3.2.3 (i386 ) elfutils-libelf 0.125 elfutils-libelf-devel 0.125 gcc 4.1.1 gcc-c++ 4.1.1 glibc 2.5-12 (x86_64) glibc 2.5-12 (i686) glibc-common 2.5 glibc-devel 2.5 (x86_64) glibc-devel 2.5-12 (i386) libaio 0.3.106 (x86_64) libaio 0.3.106 (i386) libaio-devel 0.3.106 libgcc 4.1.1(x86_64) libgcc 4.1.1(i386) libstdc++ 4.1.1(x86_64) libstdc++ 4.1.1(i386) libstdc++-devel 4.1.1 make 3.81 sysstat 7.0.0 openmotif 2.2.3 openmotif22 2.2.3 |
2.6.18 |
Linux x86-64 |
binutils 2.15.92.0.2 compat-libstdc++-33 3.2.3(x86_64) compat-libstdc++-33 3.2.3 (i386) elfutils-libelf 0.97 elfutils-libelf-devel 0.97 gcc 3.4.5 gcc-c++ 3.4.5 glibc 2.3.4-2.19 (x86_64) glibc 2.3.4-2.19 (i686) glibc-common 2.3.4 glibc-devel 2.3.4(x86_64) glibc-devel 2.3.4 (i386) libaio 0.3.105 (x86_64) libaio 0.3.105 (i386) libaio-devel 0.3.105 libgcc 3.4.5 (x86_64) libgcc 3.4.5 (i386) libstdc++ 3.4.5 (x86_64) libstdc++ 3.4.5(i386) libstdc++-devel 3.4.5 make 3.80 sysstat 5.0.5 openmotif 2.2.3 openmotif21 2.1.30-11.RHEL4.4 |
Kernel 2.6.9 |
Linux x86-64 |
binutils 2.17.50.0.6 compat-libstdc++-33 3.2.3 (x86_64) compat-libstdc++-33 3.2.3 (i386) elfutils-libelf 0.125 elfutils-libelf-devel 0.125 gcc 4.1.1 gcc-c++ 4.1.1 glibc 2.5-12 (x86_64) glibc 2.5-12 (i686) glibc-common 2.5 glibc-devel 2.5 (x86_64) glibc-devel 2.5-12 (i386) libaio 0.3.106 (x86_64) libaio 0.3.106 (i386) libaio-devel 0.3.106 libgcc 4.1.1 (x86_64) libgcc 4.1.1(i386) libstdc++ 4.1.1 (x86_64) libstdc++ 4.1.1 (i386) libstdc++-devel 4.1.1 make 3.81 sysstat 7.0.0 openmotif 2.2.3 openmotif22 2.2.3 |
Kernel 2.6.18 |
Linux x86-64 |
SUSE 10 |
binutils 2.16.91.0.5 compat-libstdc++ 5.0.7-22.2 gcc 4.1.0 gcc-c++ 4.1.0 glibc 2.4-31.2 glibc-32bit 2.4-31.2 glibc-devel 2.4 glibc-devel-32bit 2.4 libaio 0.3.104 libaio-devel 0.3.104 libelf 0.8.5 libgcc 4.1.0 libstdc++ 4.1.0 libstdc++-devel 4.1.0 make 3.80 sysstat 6.0.2 openmotif 2.2.3 openmotif21-libs 2.1.30 |
Kernel 2.6.16.21 |
Linux x86-64 |
SUSE 11 |
binutils 2.19-11.28 gcc 4.3-62.198 gcc-c++ 4.3-62.198 gcc-32bit-4.3 glibc 2.9-13.2 glibc-32bit 2.9-13.2 glibc-devel 2.9 glibc-devel-32bit 2.9-13.2 ksh-93t libaio-32bit-0.3.104 libaio 0.3.104-140.22 libaio-devel 0.3.104-140.22 libgcc43 4.3.3_20081022 libstdc++33-3.3.3 libstdc++33-32bit-3.3.3 libstdc++-devel-4.3 libstdc++43 4.3.3_20081022-11.18 libstdc++43-devel 4.3.3_20081022-11.18 make 3.81 sysstat 8.1.5-7.8 openmotif22 2.2.3 openmotif 2.2.3 |
Solaris SPARC64 |
Solaris 9 |
SUNWarc SUNWbtool SUNWhea SUNWlibC SUNWlibm SUNWlibms SUNWsprot SUNWtoo SUNWi1of SUNWi1cs SUNWi15cs SUNWxwfnt SUNWsprox SUNWmfrun Motif: 2.1.0 |
118558-22 112874-39 |
Solaris SPARC64 |
Solaris 10 |
SUNWarc SUNWbtool SUNWhea SUNWlibC SUNWlibm SUNWlibms SUNWsprot SUNWtoo SUNWi1of SUNWi1cs SUNWi15cs SUNWxwfnt SUNWmfrun Motif: 2.1.0 |
127111-02 137111-04 |
Solaris x86-64 |
Solaris 9 |
SUNWarc SUNWbtool SUNWhea SUNWlibC SUNWlibm SUNWlibms SUNWsprot SUNWtoo SUNWi1of SUNWi1cs SUNWi15cs SUNWxwfnt SUNWsprox Motif: 2.1.0 |
Solaris x86-64 |
Solaris 10 |
SUNWarc SUNWbtool SUNWhea SUNWlibC SUNWlibm SUNWlibms SUNWsprot SUNWtoo SUNWi1of SUNWi1cs SUNWi15cs SUNWxwfnt Motif: 2.1.0 |
HP-UX Itanium |
HP-UX 11i v2 (11.23) |
package value: B3394BA version 2.1.0 |
PHCO_35524 HCO_36673 PHKL_35029 PHKL_35478 PHSS_35978 PHSS_35979 PHSS_37201 |
HP-UX Itanium |
HP-UX 11i v3 (11.31) |
PHKL_36248 PHKL_36249 PHSS_37202 PHSS_37501 PHCO_38050 PHSS_38139 |
HP-UX PA-RISC |
PHCO_35524 PHCO_36673 PHKL_35029 PHKL_35478 PHKL_35767 PHKL_36853 PHSS_35101 PHSS_35102 PHSS_35103 PHSS_35176 PHSS_35978 PHSS_35979 PHSS_37201 |
HP-UX PA-RISC |
PHKL_36248 PHKL_36249 PHSS_37202 PHSS_37501 PHCO_38050 |
AIX |
6100-02 |
X11.motif.lib 2.1.30 |
AIX |
5300-08 |
In addition to the requirements detailed in Table 6, the Open File Limit should also be checked. The minimum Open File Limit should be 4096.
The following examples are for Linux operating systems. Equivalent commands should be followed for other UNIX operating systems.
You can see how many files are open with the following command:
/usr/sbin/lsof | wc -l
To check your open file limits, use the commands below.
For C-shell:
limit descriptors
For Bash:
ulimit -n
To change the open file limits, login as root and edit the /etc/security/limits.conf file. Look for the following two lines:
* soft nofile 2048 * hard nofile 2048
Change the values from 2048 to 4096, then reboot the machine.
If you are installing Oracle Identity Management on a Solaris x86-64 platform, you must patch all software versions to the most recent version before you configure a domain. Below is a recommended installation procedure; refer to the product documentation (Oracle Fusion Middleware Installation Guide for Oracle Identity Management) for more details.
Install the most recent version of Oracle WebLogic Server.
If necessary, run Repository Creation Utility (RCU) to create the database schemas.
Perform a software-only installation (do not configure a domain) of the Release 11.1.1.2.0 software.
Patch the software to the latest version with the Patch Set Installer.
Run the configuration tool to configure a domain.
If you are installing Oracle HTTP Server on a Linux operating system, the operating system needs to set Native POSIX Threads Library (NPTL) as the default threads-implementation. To check for this, run the following command:
getconf GNU_LIBPTHREAD_VERSION
The expected results should be "NPTL 2.3.4". Failing to have NPTL can result in unexpected behavior for the Oracle HTTP Server, especially if the Multi-Processing Module (MPM) is the Worker MPM.
On UNIX operating systems, the installation of Fusion Middleware products is owned and controlled as a known user (for example, "oracle"). The file permissions associated with this installation are configured to ensure the highest level of security possible, which by default are 700 (meaning all files are owned and accessible by the owner only).
Changing the default permissions settings will reduce the security of the installation and possibly your system. Therefore, making such a change is not recommended. If access to particular files or executables is required by other users, the UNIX sudo command (or other similar command) should be considered in lieu of changing file permissions.
Refer to your UNIX operating system Administrator's Guide or contact your operating system vendor if you need further assistance.
On Solaris operating systems, the prerequisite patches that are applied in the global zone can be considered applied in the non-global zones. There is only one kernel running on the system, and all zones must be at the same patch level with respect to the kernel and other Solaris system components. Kernel patches can only be applied from the global zone, and they affect the global and all non-global zones equally.
To check if a kernel patch is applied in the global zone, use the following command:
showrev -p | grep patch_number
For example, to check if patch 137111-04 is applied:
showrev -p | grep 137111
This section contains the following:
Section 6.2, "Installing 32-Bit Oracle Forms and Reports on 64-Bit Windows Operating Systems"
Section 6.3, "Enabling User Account Control (UAC) on Windows Operating Systems"
Section 6.4, "Required Installation Privileges on Windows Operating Systems"
Refer to the System Requirements and Supported Platforms for Oracle Forms and Reports 11g Release 2 (11.1.2.x) Certification Matrix for the latest information on certified Windows operating systems. See Section 1, "Finding Oracle Fusion Middleware Certification Information" for a link to this document.
If you are installing the 32-bit version of Oracle Forms and Reports onto a 64-bit Windows operating system, the Oracle WebLogic Server on your system must also use a supported 32-bit JDK (either the one included with the installer or another supported 32-bit JDK). If Oracle WebLogic Server uses a 64-bit JDK, some patches may not be installed properly by the Oracle Forms and Reports installer.
On Microsoft Windows operating systems, you must enable User Account Control (UAC) so that the correct permissions are applied to the cwallet.sso file.
To enable UAC:
Run secpol.msc from the command prompt.
Select Security Settings > Local Policies > Security Options.
Set the User Account Control:Run all Administrator in Admin Approval Mode option to enabled.
Restart the host.
Restart the servers.
In order to install Oracle Forms and Reports or use the Oracle Forms and Reports Builders after installation, the operating system user must have Windows "Administrator" privileges.
Although the current user may have Windows "Administrator" privileges, if they are not the installation owner, the Windows UAC settings may need to be relaxed.
Oracle Forms and Reports 11g Release 2 (11.1.2) is released and tested with Oracle WebLogic Server 11gR1 (10.3.5). Oracle WebLogic Server can be obtained from the following URL:
http://www.oracle.com/technetwork/middleware/weblogic/downloads/
Refer to the System Requirements and Supported Platforms for Oracle Forms and Reports 11g Release 2 (11.1.2.x) Certification Matrix to see if there are additional versions of Oracle WebLogic Server that can be used with your version of Oracle Forms and Reports. This document is available in the Oracle Fusion Middleware Supported System Configurations page, as described in Section 1, "Finding Oracle Fusion Middleware Certification Information".
For information about Oracle's commitment to accessibility, visit the Oracle Accessibility Program website at http://www.oracle.com/pls/topic/lookup?ctx=acc&id=docacc.
Access to Oracle Support
Oracle customers have access to electronic support through My Oracle Support. For information, visit http://www.oracle.com/pls/topic/lookup?ctx=acc&id=info or visit http://www.oracle.com/pls/topic/lookup?ctx=acc&id=trs if you are hearing impaired.
Copyright © 2012 Oracle and/or its affiliates. All rights reserved.
This software and related documentation are provided under a license agreement containing restrictions on use and disclosure and are protected by intellectual property laws. Except as expressly permitted in your license agreement or allowed by law, you may not use, copy, reproduce, translate, broadcast, modify, license, transmit, distribute, exhibit, perform, publish, or display any part, in any form, or by any means. Reverse engineering, disassembly, or decompilation of this software, unless required by law for interoperability, is prohibited.
The information contained herein is subject to change without notice and is not warranted to be error-free. If you find any errors, please report them to us in writing.
If this is software or related documentation that is delivered to the U.S. Government or anyone licensing it on behalf of the U.S. Government, the following notice is applicable:
U.S. GOVERNMENT RIGHTS Programs, software, databases, and related documentation and technical data delivered to U.S. Government customers are "commercial computer software" or "commercial technical data" pursuant to the applicable Federal Acquisition Regulation and agency-specific supplemental regulations. As such, the use, duplication, disclosure, modification, and adaptation shall be subject to the restrictions and license terms set forth in the applicable Government contract, and, to the extent applicable by the terms of the Government contract, the additional rights set forth in FAR 52.227-19, Commercial Computer Software License (December 2007). Oracle America, Inc., 500 Oracle Parkway, Redwood City, CA 94065.
This software or hardware is developed for general use in a variety of information management applications. It is not developed or intended for use in any inherently dangerous applications, including applications that may create a risk of personal injury. If you use this software or hardware in dangerous applications, then you shall be responsible to take all appropriate fail-safe, backup, redundancy, and other measures to ensure its safe use. Oracle Corporation and its affiliates disclaim any liability for any damages caused by use of this software or hardware in dangerous applications.
Oracle and Java are registered trademarks of Oracle and/or its affiliates. Other names may be trademarks of their respective owners.
Intel and Intel Xeon are trademarks or registered trademarks of Intel Corporation. All SPARC trademarks are used under license and are trademarks or registered trademarks of SPARC International, Inc. AMD, Opteron, the AMD logo, and the AMD Opteron logo are trademarks or registered trademarks of Advanced Micro Devices. UNIX is a registered trademark of The Open Group.
This software or hardware and documentation may provide access to or information on content, products, and services from third parties. Oracle Corporation and its affiliates are not responsible for and expressly disclaim all warranties of any kind with respect to third-party content, products, and services. Oracle Corporation and its affiliates will not be responsible for any loss, costs, or damages incurred due to your access to or use of third-party content, products, or services.
