Write rules that infer relationships and entities
Rules that infer relationships and entities can be useful for grouping entity instances in order to refer to the group as a whole in your rules and use the standard entity functions in a more powerful way. For example, you could:
Further examples are provided under Worked Examples below.
What do you want to do?
Infer membership of a relationship
Infer existence of entities to satisfy the relationship
See worked examples
The syntax to use to infer that existing entity instances are members of a relationship is:
Note that membership rules must be written in the positive form. That is, it is not possible to infer that an entity is not a member of a relationship.
All subsequent rule levels for this conclusion must have the source entity and the target entity in its reasoning scope. The relationship used must be defined as a many-to-many relationship type in the properties file for the project. (See Define a relationship for more information.)
In the example rule below, a membership statement is used to conclude membership of the inferred relationship 'the parent’s school-aged children'.
the child is a member of the parent’s school-aged children if
the child is of school age
Notes /Limitations
  1. A relationship conclusion can only ever be the top line of a rule. If the syntax is used anywhere else in a rule, then it will be treated as a membership statement (see Use relationship membership as a rule input).
  2. An inferred relationship will be partially known if the rule used to infer it returns unknown for any of the potential target entity instances.
  3. An inferred relationship will be partially known if its target entity is not complete.
  4. Combining manually created relationships with inferred relationships is not allowed.
  5. Combining inferred relationships with temporal values is not supported.
  6. A relationship must only be inferred in its primary direction.
You can also write a rule that creates entity instances to become members of a relationship.
The syntax to use to infer that entity instances should be created (or deleted) as members of a relationship is:
or in table form (where multiple instances are needed):
Relationship
<identifying value> Condition
The identifying value can either be a fixed value ("spouse") or a variable (the tax year) which is then used as the identifying attribute for the entity instances created.
At runtime, the engine will evaluate each rule in the above form, evaluate the condition(s) and will create an instance for any condition that is true, and destroy any instance for which no condition returns true.
For example, assuming you have the following data model:
Example 1: Creating a single instance
Writing the rule:
the locations ("Main office") exists
will create a single instance of the entity "the location" which is a member of the containment relationship "the locations". The instance will have "Main office" as the value of the identifying attribute.
Example 2: Creating multiple instances using a rule table
Writing the rule:
the locations
"Main office" the assessment date >= 2009-10-01
"Warehouse" the assessment date >= 2000-01-15
"Factory" the assessment date >= 2000-01-15
will create instances of the entity "the location" (depending on the assessment date), which are members of the containment relationship "the locations". These instances will have "Main office", "Warehouse" and "Factory" as the value of their identifying attributes.
Example 3: Creating multiple instances from a single entity level-attribute
Writing the rule:
the location in which the employee works (the employee’s local office) exists
will create an instance of the location entity for each unique value of "the employee’s local office". These instances will be members of the relationship "the location in which the employee works" and have the value of the employee’s local office as the value of the identifying attribute.
Notes /Limitations
  1. Combining manually created instances with inferred instances is not allowed.
  2. Combining inferred entity instances with temporal values is not supported.
  3. Only a single attribute of the entity instance can be inferred as a part of the entity rule. For example, the type of benefit ("unemployment benefit") can be set but the amount of the benefit would have to be set via a separate rule.
  4. Inferred entity instances may not contain base level attributes.
  5. A relationship that participates in an inferred entity instance rule is considered to be an inferred relationship. This means that an inferred relationship rule cannot be used to prove the same relationship used in an inferred entity instance rule.
See worked examples
The following example rulebases installed with Oracle Policy Modeling demonstrate the inferred entity instance functionality. For how to view these rulebases, see Open an example rulebase.
See also:
