A Oracle Help and JavaHelp File Formats
This appendix describes the Oracle Help file formats based on the JavaHelp specification. Oracle Help extends the JavaHelp file definitions to support additional features.
This appendix includes the following sections:
These conventions apply to the following tables:
  • In the Element column, child elements are indented under parent elements.
  • The items in the Attribute column are attributes of the element listed directly above the attribute(s).
  • In the Origin column, "JH" refers to the JavaHelp 1.0 file format specification. "OH" refers to Oracle Help. Oracle's extensions to JavaHelp were originally developed for Oracle Help for Java (OHJ). However, most of the formats now apply to both OHJ and Oracle Help for the Web (OHW). Therefore, "OH" alone is used.
  • In the Supported By column, "OH" refers both to OHJ and OHW.
A.1 Helpset File
For more information about this file, see Section 5.2, "Helpset File".
Table A-1 Helpset Elements
Element Attribute Origin Supported By
<helpset>
JH
OH & JH - Differences as shown below
xml:lang
JH
JH only
version
JH
JH only
<title>
JH
OH & JH
<maps>
JH
OH & JH
<homeID>
JH
JH & OH (in some circumstances)
<mapref>
JH
location
JH
OH & JH
class
OH
OH only
<wintype>
OH
OH only
default
OH
OH only
<name>
OH
OH only
<height>
OH
OH only
<width>
OH
OH only
<x>
OH
OH only
<y>
OH
OH only
<textfg>
OH
OH only
<linkfg>
OH
OH only
<bg>
OH
OH only
<title>
OH
OH only
<toolbar>
OH
OH only
<links>
OH
OH only
<linkref>
OH
OH only
location
OH
OH only
<view>
JH
<name>
JH
JH only
<label>
JH
OH & JH
OH
OH only
<title>
OH
OH only
OH
OH only (TOC view only)
<type>
JH
OH & JH
<data>
JH
class
OH
OH only
engine
JH
OH & JH
<subhelpset>
OH
OH only
location
OH
OH only
class
OH
OH only
A.2 Map File
For more information about this file, see Section 5.3, "Map Files".
Table A-2 Map File Elements
<map>
JH
xml:lang
JH
JH only
version
JH
JH only
<mapID>
JH
Differences as listed below
target
JH
OH & JH
url
JH
OH & JH
wintype
OH
OH only
xml:lang
JH
JH only
A.3 Table of Contents File
For more information about this file, see Section 6.2, "Table of Contents File".
Table A-3 Table of Contents Elements
<toc>
JH
xml:lang
JH
JH only
version
JH
JH only
<tocitem>
JH
target
JH
OH & JH
text
JH
OH & JH
JH
OH & JH
xml:lang
JH
JH only
A.4 Index File
For more information about this file, see Section 6.4, "Index File".
Table A-4 Index File Elements
<index>
JH
xml:lang
JH
JH only
version
JH
JH only
<indexitem>
JH
target
JH
OH & JH
text
JH
OH & JH
<indexentry>
OH
OH only
target
OH
OH only
text
OH
OH only
A.5 Search Index File
This file is unique to Oracle Help. For more information, see Section 6.5, "Search Index File".
A.6 Link File
This file is unique to Oracle Help. For more information, see Section 6.6, "Link File".
A.7 OHW Configuration File
This file is unique to Oracle Help. For more information, see Chapter 8, "Oracle Help for the Web Configuration File".
