8 Oracle RightNow Adapter Use Cases
This chapter provides a walkthrough of the Oracle RightNow adapter use cases.
Each of the following use cases describes how you can use the Oracle RightNow adapter to perform activities that integrate from SOA Suite with the Oracle RightNow Cx.
For information on the common operations that you perform before following the steps in each of these use cases, see Performing Common JDeveloper Configuration Steps.
The Oracle RightNow adapter enables you to perform the following:
