Deploying the Composite
To deploy the composite application:
  1. In the Application Navigator pane, right-click Project1 and select Deploy Project1.
    Figure 5-24 Deploying the Project
    Description of Figure 5-24 follows
    Description of "Figure 5-24 Deploying the Project"
  2. Select the Deploy to Application Server option and follow the instructions. Using this option, you can deploy the composite on the Application server after providing the details of the server.
