Use these instructions to upgrade Oracle BI Enterprise Edition from 11.1.1.7.0 to 11.1.1.9.0.
Oracle recommends that you follow the standard Oracle BI Enterprise Edition (Oracle BI EE) documentation before using these instructions. See My Oracle Support document (ID 2022915.1) titled OBIEE 11g - How To Upgrade From OBIEE 11.1.1.7.0 To OBIEE 11.1.1.9.0.
To upgrade Oracle BI EE from 11.1.1.7.0 to 11.1.1.9.0:
Stop all WebLogic Servers, Node Manager, OPMN, and OPMN-managed system components that are part of all Oracle BI domains that use the Middleware Home that you must patch. Additionally, on Windows systems, stop the component that is called Oracle WebLogic NodeManager (name).
Back up the directories.
Disk1 directory under that directory and run the installer as follows:
[aime1@slc01aym Disk1]$ ./runInstaller -jreLoc $ORACLE_HOME/jdk -invPtrLoc $ORACLE_HOME/oraInst.loc where ORACLE_HOME = BI_ORACLE_HOME
MDS
BIPLATFORM
Switch to ORACLE_HOME/bin under <MiddlewareHome>
[aime1@slc01aym bin]$ pwd /scratch/ aime1/work/mw6047/Oracle_BI1/bin [aime1@slc01aym bin]$ ./psa
Start the Node Manager and Administration Server.
On UNIX: ORACLE_HOME/bin/config.sh On Windows: ORACLE_HOME\bin\config.bat
