Use these instructions to upgrade the Oracle Business Analytics Warehouse schema and data.
From BI APPS Release 11.1.1.10.2 onwards, there are only 2 upgrade Load plans irrespective of the source. However if you want to upgrade from the version prior to 11.1.1.10.1, you have to perform the upgrade to 11.1.1.10.1 by using the Upgrade BIApps 1111101 to 1111102 SDE and Upgrade BIApps 1111101 to 1111102 SIL upgrade procedures.
