FolderExistsRenvoie True si un dossier spécifié existe. Renvoie False dans le cas contraire.
Syntaxe
object.FolderExists(folderspec)
Arguments :
FileSystemObject.Les exemples suivants illustrent l'utilisation de la méthode FileExists.
Exemple 1 :
Function CheckFolderExistence(fldr)
Dim fso, msg
Set fso = CreateObject("Scripting.FileSystemObject")
If fso.FolderExists(fldr) Then
msg = fldr & " exists."
Else
msg = fldr & " doesn't exist."
End If
CheckFolderExistence = msg
End Function
' Usage
Dim folderPath
folderPath = "C:\1"
bExists = CheckFolderExistence(folderPath)
'bExists now holds C:\1 exists. if the folder exists, else It will have C:\1 doesn’t exists.
