KeysRenvoie un tableau contenant toutes les clés existantes dans un objet Dictionary.
Syntaxe
object.Keys( )
Arguments
object : requis. Toujours le nom d'un objet Dictionary.
Remarques
Les exemples de code suivants illustrent l'utilisation de la méthode Keys :
Exemple 1 :
Function DicDemo
Dim a, d, i, s ' Create some variables.
Set d = CreateObject("Scripting.Dictionary")
' Add some keys and items.
d.Add "a", "Athens"
d.Add "b", "Belgrade"
d.Add "c", "Cairo"
' Get the keys.
a = d.Keys
' Iterate the array
For i = 0 To d.Count - 1
s = s & a(i) ' Create return string
Next
DicDemo = s
End Function
' Usage
Dim result
result = DicDemo
' Output: a b c
Exemple 2 :
Function DicKeysWithItems
d.Add "x", "Xenon"
d.Add "y", "Yttrium"
d.Add "z", "Zirconium"
' Get the keys.
a = d.Keys
' Iterate the array
s = s & "Key: " & a(i) & ", Item: " & d.Item(a(i))
Next
DicKeysWithItems = s
End Function
' Usage
Dim result
result = DicKeysWithItems
' Output: Key: x, Item: Xenon Key: y, Item: Yttrium Key: z, Item: Zirconium
Exemple 3 :
Function CheckAndRemoveKey(keyToRemove)
d.Add "m", "Moscow"
d.Add "t", "Tokyo"
d.Add "n", "New York"
' Check and remove key
If d.Exists(keyToRemove) Then
d.Remove(keyToRemove)
s = "Key '" & keyToRemove & "' removed."
Else
s = "Key '" & keyToRemove & "' not found."
End If
' Get the remaining keys.
a = d.Keys
s = s & "Remaining Key: " & a(i)
Next
CheckAndRemoveKey = s
End Function
' Usage
Dim result
result = CheckAndRemoveKey("t")
' Output: Key 't' removed. Remaining Key: m Remaining Key: n
