Este exemplo mostra como enviar uma regra de carregamento de dados por meio de um script.
This sample Jython script provides code related to custom scripts. All the messages being logged (meaning printed) are visible in the process lLog Level profile.
# Log the beginning of the script, at the INFO level
fdmAPI.logInfo("======================================================================")
fdmAPI.logInfo("Custom Script: Begin")
fdmAPI.logInfo("======================================================================")# Log the target application name from the context, at the DEBUG level
fdmAPI.logDebug("Target App Name = " + fdmContext["TARGETAPPNAME"])# Log the script name from the context at the DEBUG level
fdmAPI.logDebug("Custom Script name = " + fdmContext["SCRIPTFILE"])# Get all script parameters and log their names and values at the DEBUG level
fdmAPI.logDebug("Custom script parameter values by name: begin")
fdmAPI.logDebug("The value of parameter CUSTOM_LOCATION is = " + fdmAPI.getCustomScriptParameterValue("CUSTOM_LOCATION"))
fdmAPI.logDebug("The value of parameter CUSTOM_YEAR is = " + fdmAPI.getCustomScriptParameterValue("CUSTOM_YEAR"))
fdmAPI.logDebug("Custom script parameter values by name: end")# Example submitting a data rule
import os
import subprocess
os.chdir("C:/Oracle/Middleware/user_projects/epmsystem1/FinancialDataQuality")
myScriptName = "C:/Oracle/Middleware/user_projects/epmsystem1/FinancialDataQuality/loaddata.bat"
command = '%s "%s" "%s" "%s" "%s" "%s" "%s" "%s" "%s" "%s" "%s" "%s"' % (myScriptName, "admin", "password", "SRESBA1_DR1", "Y", "N", "STORE_DATA", "SNAPSHOT", "N", "Jan-2003", "Jan-2003", "ASYNC")
fdmAPI.logDebug("Submitting a data rule via a script using the following command: " + command)
retcode = subprocess.Popen(command)
fdmAPI.logDebug("Data rule submitted fine.")# Close the connection and log the end of the script, at INFO level
fdmAPI.closeConnection()
fdmAPI.logInfo("Custom Script: end")
A saída do script personalizado executado é:
2013-09-25 08:12:26,080 INFO [AIF]: ==========================================================================
2013-09-25 08:12:26,081 INFO [AIF]: Custom Script: Begin
2013-09-25 08:12:26,082 INFO [AIF]: ==========================================================================
2013-09-25 08:12:26,083 DEBUG [AIF]: Target App Name = SRESBA1
2013-09-25 08:12:26,084 DEBUG [AIF]: Custom Script name = SRCustomScript1.py
2013-09-25 08:12:26,087 DEBUG [AIF]: CUSTOM_LOCATION = 1
2013-09-25 08:12:26,087 DEBUG [AIF]: CUSTOM_YEAR = 2013
2013-09-25 08:12:26,088 DEBUG [AIF]: Custom script parameter values by name: begin
2013-09-25 08:12:26,091 DEBUG [AIF]: The value of parameter CUSTOM_LOCATION is = 1
2013-09-25 08:12:26,093 DEBUG [AIF]: The value of parameter CUSTOM_YEAR is = 2013
2013-09-25 08:12:26,094 DEBUG [AIF]: Custom script parameter values by name: end
2013-09-25 08:12:26,535 DEBUG [AIF]: Submitting a data rule via a script using the following command: C:/Oracle/Middleware/user_projects/epmsystem1/FinancialDataQuality/loaddata.bat "admin" "****" "SRESBA1_DR1" "Y" "N" "STORE_DATA" "SNAPSHOT" "N" "Jan-2003" "Jan-2003" "ASYNC"
2013-09-25 08:12:26,596 DEBUG [AIF]: Data rule submitted fine.
2013-09-25 08:12:26,635 INFO [AIF]: ==========================================================================
2013-09-25 08:12:26,636 INFO [AIF]: Custom Script: end
2013-09-25 08:12:26,637 INFO [AIF]: ==========================================================================
