事件脚本示例
此事件脚本示例会在数据加载执行期间更新 table_xyz 表:
# Sample to update table_xyz table during data load rule execution
query = "UPDATE table_xyz SET accountx = 'SCRIPT_' || account WHERE loadid = ? and accountx is NULL"
params = [ fdmContext["LOADID"] ]
print fdmAPI.executeDML(query, params, False)
fdmAPI.commitTransaction()
# Sample to import data from a custom SQL source and upload into FDMEE
# open interface table. This script should be called in BefImport Event.
# This is alternate to the FDMEE integration import script.
import java.sql as sql
batchName = "Batch_" + str(fdmContext["LOCNAME"])
insertStmt = """
INSERT INTO AIF_OPEN_INTERFACE (
   BATCH_NAME
  ,COL01
  ,COL02
  ,AMOUNT
  ,DESC1
) VALUES (
sourceConn = sql.DriverManager.getConnection("jdbcUrl", "user", "password");
# Limiting number of rows to 5 during the test runs.
selectStmt = "SELECT * FROM orders WHERE rownum < 6"
stmt = sourceConn.prepareStatement(selectStmt)
stmtRS = stmt.executeQuery()
while(stmtRS.next()):
  params = [ batchName, stmtRS.getBigDecimal("Customer_Id"),
             stmtRS.getString("Ship_Country"),
             stmtRS.getBigDecimal("Freight"), stmtRS.getString("Ship_Name") ]
  fdmAPI.executeDML(insertStmt, params, False)
stmtRS.close()
stmt.close()
sourceConn.close()
# Sample to send email messages using Jython SMTP library
import smtplib
sender = "from@gmail.com"
receivers = "to@gmail.com"
message = """ This is a test e-mail message.
              This is a test e-mail message.  """
try:
  smtpServer = smtplib.SMTP('smtp.gmail.com:587')
  smtpServer.starttls()
  smtpServer.login("user", "password")
  smtpServer.sendmail(sender, receivers, message)
  print "Successfully sent email"
  smtpServer.quit()
except Exception, e:
  print "Error: unable to send email: " + str(e)
注:
请参阅位于以下链接的联机 Jython 文档,其中解释了 Jython 异常以及在您的脚本中捕获异常时使用的语法:有关使用 Jython 中的异常处理机制的信息,请参阅异常处理和调试。
此注释适用于所有脚本类型。
