此映射脚本示例计算帐户和实体列,并为目标列分配值。还显示如何使用 fdmResult 映射更新当前行的其他列:
# Sample Jython Mapping Script. Script evaluates account and entity
# columns and assign value for the target column. In addition it
# also shows how to update the other columns of current row using
fdmResultMap
account = fdmRow.getString("ACCOUNT")
entity = fdmRow.getString("UD1")# Map based on account and dept column values
fdmResultMap["ATTR1"] = account + "-" + entity
if (account[0:2] == "71"):
fdmResult = "7110"
elif (account[0:2] == "72"):
fdmResult = "7210"
elif (account[0:2] == "77" and entity == "205"):
fdmResult = "7710"
fdmResultMap["AMOUNTX"] = 0
else:
fdmResult = "7310"
# Sample SQL script. Script uses SQL CASE statement to conditionally
# process assign value for the target column.
CASE
WHEN ACCOUNT LIKE '61%' AND ud1 = '205' THEN '6110'
WHEN ACCOUNT LIKE '61%' AND ud1 = '240' THEN '6120'
ELSE '6130'
END
