迁移定义文件示例
在迁移定义文件中,用于 Oracle Hyperion Shared Services 的产品代码为 HUB。
注:
如果在迁移定义文件中使用的语法不正确,会显示 ‘Incorrect format of MDF file’ 错误。
示例 J-1 导出至文件系统
<?xml version="1.0" encoding="UTF-8" ?>
<Package>
   <LOCALE>en_US</LOCALE>
   <User name="" password="" />
   <Task>
      <Source type="Application" product="HUB" project="Foundation" application="Shared Services" />
      <Target type="FileSystem" filePath="/HSS-Shared Services" />
      <Artifact recursive="false" parentPath="/Native Directory" pattern="Users" />
   </Task>
   <Task>
      <Source type="Application" product="HUB" project="Foundation" application="Deployment Metadata" />
      <Target type="FileSystem" filePath="/HSS-Deployment Metadata" />
      <Artifact recursive="false" parentPath="/Shared Services Registry" pattern="Properties" />
   </Task>
</Package>
示例 J-2 从文件系统导入
<Package>
   <Task>
      <Source type="FileSystem" filePath="/HSS-Shared Services" />
      <Target type="Application" product="HUB" project="Foundation" application="Shared Services" />
   </Task>
   <Task>
      <Source type="FileSystem" filePath="/HSS-Deployment Metadata" />
      <Target type="Application" product="HUB" project="Foundation" application="Deployment Metadata" />
   </Task>
</Package>
