| Oracle® Enterprise Manager Configuration for Oracle Collaboration Suite 10g Release 1 (10.1.0.4) Part Number B13601-02 |
View PDF |
This chapter describes how to configure Enterprise Manager to manage the Web Conference component of Oracle Collaboration Suite Release 1 and Release 2.
See Chapter 4, "Configuring Real-Time Collaboration" for information on configuring Grid Control to manage Real-Time Collaboration components for Oracle Collaboration Suite 10g Release 1.This chapter contains the following sections
Web Conferencing is installed as a set of services distributed over hosts and databases. Monitoring Web Conferencing involves monitoring the Web Conferencing installations, the hosts on which the Web Conferencing software runs, the OC4J and HTTP instances, and the Web Application, which conducts transactions to run the various web conferencing test servlets.
Therefore, a Web Conferencing group target is created at the end of the process. This group target captures the important metrics of all the members of the group and also displays relevant charts all on one Web page. Web Conferencing targets consist of:
One Web Conferencing target for each Web Conferencing installation. It is usually defined on the host where Web Conferencing processes are running.
One Web Application for all the Web Conferencing installations. This Web Application will track all the URLs of all the Web Conferencing installations.
OC4J instances, HTTP servers, and hosts running on the same host as Web Conferencing are also part of the entire Web Conferencing group.
One Web Conferencing group target that groups together all the above mentioned targets and serves as a convenient starting point for monitoring Web Conferencing.
To create the Web Conferencing target:
Using the Grid Control Console, navigate to the Management Agent home page for the Management Agent that was installed on the Web Conferencing host.
In the Monitored Targets section of the page, select Real-Time Collaboration from the Add drop-down menu.
Enterprise Manager displays the property page for the selected target type. Provide the required information, as described in Table 16-1.
Click OK to create the target.
See Also:
"Adding Targets to be Monitored and Administered by Enterprise Manager" in the Enterprise Manager online helpTable 16-1 Web Conferencing Target Properties
| Property | Description |
The Oracle Home directory of the Web Conferencing component. |
The URL of the instance diagnostics page of the Web Conferencing target. The URL should be in the following format: http://<host>:<port>/imtapp/logs/system.jsp The URL can be a secure (HTTPS) or insecure (HTTP) URL. For example: https://webconfl2.oracle.com/imtapp/logs/system.jsp |
To monitor your Web Conferencing instances, you can create a Web Application target. Web Application targets can be monitored for availability and performance with Application Service Level Management transactions. You can also measure the response time of pages in your Web Applications using End-User Page Performance Monitoring.
See Also:
"About Application Performance Management" in the Enterprise Manager online helpTo create a Web Application target for your Web Conferencing components:
Using the Grid Control Console, navigate to the Agent home page for the Oracle Management Agent that was installed on the Web Conferencing host.
In the Monitored Targets section of the page, select Web Application from the Add drop-down menu and click Go.
Enterprise Manager displays the Create Web Application wizard, which guides you through the process of creating the Web Application.
On the Create Web Application: General page, enter the following URL in the Homepage URL field:
http://<host>:<port>/pls/portal
For example:
http://mgmthost42.acme.com:7777/pls/portal
Use the rest of the wizard to provide the rest of the information required for a Web Application target.
Click Help for more information about using the Create Web Application Target wizard.
Use the instructions in the online help to create some representative transactions to measure the availability and performance of the Web Application you just created.
For example, create a transaction that attends a test meeting. Create additional transactions that test the document and voice conversion features of Web Conferencing.
The following URL provides a good starting point for a transaction that tests the availability and performance of the Web Conferencing application:
http://<host>:<port>/imtapp/servlet/ImtTestServlet?mtgtest=true
This transaction works when Web Conferencing is configured but voice services are not.
See Also:
"Creating Transactions" in the Enterprise Manager online helpEnable End-User Page Performance Monitoring for the Web Application using the procedures for earlier versions of the Oracle Application Server described in "Configuring End-User Response Time Monitoring Using Earlier Versions of Oracle Application Server Web Cache" in Oracle Enterprise Manager Advanced Configuration for Oracle Enterprise Manager 10g Release 1 at:
http://www.oracle.com/technology/documentation/oem.html
Before you enable End-User Page Performance Monitoring to monitor your Oracle Collaboration Suite Web Application target, you must apply patch number 3040716 to the Oracle Application Server middle-tier instance. You can download this patch from OracleMetaLink:http://metalink.oracle.com/
After all the Web Conferencing targets are configured, you can create the Web Conferencing group target, which provides a custom user interface for managing your Oracle Collaboration Suite environment.
The Oracle Collaboration Suite Web Conferencing group home page contains the alerts table, followed by a table of rows of component targets and columns of key metrics. There is also a Performance tab where key metrics are charted for the Web Conferencing group.
To create the Web Conferencing group target:
Click the Targets tab in the Grid Control.
Click All Targets.
Select Collaboration Suite Component from the Add drop-down menu and click Go.
Enterprise Manager displays the Create Collaboration Suite Component page.
Select Web Conferencing from the Component Type drop-down menu.
Enter a name for the Web Conferencing group in the Name field.
For example, enter Web Conferencing Group.
Select the targets that you want to add to the group from the Available Targets list and add them to the Selected Targets list.
Be sure to add the following target types to the Web Conferencing group:
The host targets where the Web Conferencing servers reside
The Web Conferencing target you created in Section 16.2.
The Web Application target you created in Section 16.3.
The OracleAS Containers for J2EE (OC4J) and Oracle HTTP Server targets on the host
Click OK to create the group target.
