| Oracle® Enterprise Manager Oracle Fusion Middleware Metric Reference Manual 10g Release 5 (10.2.0.5.0) Part Number B25987-04 |
PDF · Mobi · ePub |
Oracle Enterprise Manager can be used to manage Oracle B2B Server. You can use the All Metrics page for an Oracle B2B Server target to view the metrics that have been collected for that target by the Oracle Management Agent.
This category contains the response metrics for Oracle B2B Server Engine.
This metric is intended for informational purposes only.
The following table shows how often the metric's value is collected and compared against the default thresholds. The 'Consecutive Number of Occurrences Preceding Notification' column indicates the consecutive number of times the comparison against thresholds should hold TRUE before an alert is generated.
Table 4-1 Metric Summary Table
| Target Version | Evaluation and Collection Frequency | Upload Frequency | Operator | Default Warning Threshold | Default Critical Threshold | Consecutive Number of Occurrences Preceding Notification | Alert Text |
All Versions |
Every Minute |
After Every Sample |
Not Defined |
1 |
1 |
Not Defined |
