Oracle® Application Development Framework Developer's Guide
10g Release 3 (10.1.3) B25386-01 |
![]() Previous |
![]() Next |
The data control class must be able to access the data source based on the metadata that was saved during design time. This class is instantiated by the createDataControl method in the data control definition class (see Section 20.4.7, "Creating an Instance of the Data Control").
This class needs to:
Extend the abstract class oracle.adf.model.AbstractImpl.
Implement one of the following data control interfaces:
Table 20-1 Data Control Interfaces
| Interface | When to Use |
Implement this interface if you do not need to demarcate the start and end of a request and if you do not need transactional support. |
Implement this interface if you need to demarcate the start and end of a request. This interface extends |
Implement this interface if you need transactional support. The interface requires you to implement the |
The abstract class oracle.adf.model.AbstractImpl is located in the JDEV_HOME/bc4j/lib/adfm.jar file.
The data control interfaces are located in the JDEV_HOME/bc4j/lib/adfbinding.jar file.
The following class outline for a data control class shows the methods you have to implement:
Example 20-23 Outline for a Data Control Class
import oracle.adf.model.adapter.AbstractImpl;
import oracle.binding.DataControl;
import java.util.HashMap;
public class SampleDataControl extends AbstractImpl implements ManagedDataControl
public boolean invokeOperation(java.util.Map map,
oracle.binding.OperationBinding action)
// you need to implement this method.
// see Section 20.5.4, "Implementing the invokeOperation Method".
public String getName()
// see Section 20.5.5, "Implementing the getName Method".
public void release(int flags)
// see Section 20.5.6, "Implementing the release Method".
public Object getDataProvider()
// see Section 20.5.7, "Implementing the getDataProvider Method".
Example 20-24 shows the complete source for the SampleDataControl class.
Example 20-24 Complete Source for the SampleDataControl Class
package oracle.adfinternal.model.adapter.sample;
import java.io.InputStream;
import java.util.ArrayList;
import java.util.Map;
import javax.naming.Context;
import oracle.binding.ManagedDataControl;
import oracle.binding.OperationInfo;
import oracle.adf.model.adapter.AdapterException;
import oracle.adf.model.adapter.dataformat.CSVHandler;
import oracle.adfinternal.model.adapter.url.SmartURL;
// Data control that represents a URL data source with CSV data format.
//URL to access the data source
private String mCSVUrl = null;
public SampleDataControl()
public SampleDataControl(String csvUrl)
mCSVUrl = csvUrl;
Context ctx = null;
try
// We are interested of method action binding only.
if (action == null)
return false;
OperationInfo method = action.getOperationInfo();
// No method defined, we are not interested.
if (method == null)
return false;
// Execute only when the adapter execute is invoked
if (METHOD_EXECUTE.equals(method.getOperationName()))
Object retVal = null;
if (mCSVUrl != null)
SmartURL su = new SmartURL(mCSVUrl);
InputStream isData = su.openStream();
CSVHandler csvHandler =
new CSVHandler(isData,true,"UTF-8",",","\"");
Map properties = new HashMap();
retVal = csvHandler.getResult(properties);
Map rootDataRow = new java.util.HashMap(2);
rootDataRow.put(SampleDCDef.RESULT_ACC_NAME, retVal);
ArrayList aRes = new ArrayList(2);
aRes.add(rootDataRow);
processResult(aRes.iterator(), map, action);
return true;
catch (AdapterException ae)
throw ae;
catch (Exception e)
throw new AdapterException(e);
return false;
* Perform request level initialization of the DataControl.
* @param requestCtx a HashMap representing request context.
public void beginRequest(HashMap requestCtx)
* perform request level cleanup of the DataControl.
public void endRequest(HashMap requestCtx)
* return false as resetState was deferred to endRequest processing
public boolean resetState()
return false;
* returns the name of the data control.
return mName;
* releases all references to the objects in the data provider layer
* Return the Business Service Object that this datacontrol is associated with.
return null;
You must implement the invokeOperation method in your data control class. The framework invokes this method when the user runs the view page.
This method is declared in the DataControl interface. The method has the following signature:
Example 20-25 invokeOperation Signature
public boolean invokeOperation(java.util.Map bindingContext, oracle.binding.OperationBinding action);
The bindingContext parameter contains the return values fetched from the data source. The keys for retrieving the values are generated by the framework. Typically you do not need to process the values unless you need to filter or transform them.
The action parameter specifies the method that generated the values. The method could be a method supported by the underlying service, as in the case of a web service. The framework calls the data control even for some built-in actions if the data control wants to override the default behavior. You can check this parameter to determine if you need to process the action or not. For data controls that represent data sources that do not expose methods, the framework creates an action AbstractImpl.METHOD_EXECUTE to the execute the query for a data control.
The method should return false if it does not handle an action.
In the simple CSV adapter, the invokeOperation method checks that the method is METHOD_EXECUTE before fetching the data. It invokes the CSVHandler class, which invokes the CSVParser class, to get the data from the CSV file.
Example 20-26 invokeOperation Method
Context ctx = null;
try
// We are interested in method action binding only.
if (action == null)
return false;
if (method == null)
return false;
new CSVHandler(isData, true, "UTF-8", ",", "\"");
return true;
throw ae;
catch (Exception e)
return false;
Note that invokeOperation calls the processResult method after fetching the data. See the next section for details.
invokeOperation should call processResult to provide updated values to the framework. The method puts the result into the binding context for the framework to pick up. The method has the following syntax:
Example 20-27 processResult Syntax
public void processResult(Object result, Map bindingContext, oracle.binding.OperationBinding action)
In the result parameter, specify the updated values.
In the bindingContext parameter, specify the binding context. This is typically the same binding context passed into the invokeOperation method.
In the action parameter, specify the operation. This is typically the same action value passed into the invokeOperation method.
Implement the getName method to return the name of the data control as used in a binding context.
This method is declared in the DataControl interface. It has the following signature:
In the simple CSV adapter, the method simply returns mName, which is a variable defined in the AbstractImpl class.
The framework calls the release method to release all references to the objects in the data provide layer.
The flags parameter indicate which references should be released:
REL_ALL_REFS: The data control should release all references to the view and model objects.
REL_DATA_REFS: The data control should release references to data provider objects.
REL_VIEW_REFS: The data control should release all references to view or UI layer objects.
In the simple CSV data control adapter, the release method is empty. However, if your data control uses a connection, it should close and release the connection in this method.
