Oracle® Application Development Framework Developer's Guide
10g Release 3 (10.1.3) B25386-01 |
![]() Previous |
![]() Next |
You need to add the following libraries to your project in order to build your adapter:
In the Project Properties dialog in JDeveloper, select Libraries on the left side.
Click Add Library on the right side and add the following libraries:
JSR-227 API
ADF Model Generic Runtime
Oracle XML Parser v2
Click Add Jar/Directory on the right side and add the following libraries:
JDEV_HOME/ide/lib/ide.jar
JDEV_HOME/ide/lib/javatools.jar
JDEV_HOME/bc4j/jlib/dc-adapter.jar
