Oracle® Application Development Framework Developer's Guide
10g Release 3 (10.1.3) B25386-01 |
![]() Previous |
![]() Next |
You can create a data control from a TopLink sessions configuration file (sessions.xml), similarly to creating a data control from a TopLink map (see Section 19.5, "Using Multiple Maps with a TopLink Data Control").
Use the TopLink Data Control dialog (as shown in Figure 19-3), select TopLink Sessions Configuration, and then select the specific sessions configuration file (sessions.xml) and session.
To create a TopLink data control from a sessions configuration file (sessions.xml):
Right-click the sessions.xml file in the Navigator window and select Create Data Control.
On the TopLink Data Control dialog, select the TopLink Sessions Configuration option.
Figure 19-3 Creating a TopLink Data Control (from a Sessions Configuration)
Select the specific sessions configuration file (or create a new configuration) and session. You can create a data control for any mapped classes.
