Oracle® Application Development Framework Developer's Guide
10g Release 3 (10.1.3) B25386-01 |
![]() Previous |
![]() Next |
By default, when compiling TopLink classes, JDeveloper uses JDK 1.5 generic collection types for relationships. This will causes errors if you compile your project using a different JDK version (such as 1.4).
Before generating TopLink mappings you must change the default JSEE library for your project. In the Default Project Properties Dialog – Libraries page, click Change to select a new J2SE definition for the project. On the Manage Libraries Dialog – Edit J2SE Definitions Page (see Figure 19-6), select a (or create a new) J2SE definition to use.
