Siebel Assignment Manager Administration Guide > Advanced Assignment Manager Configuration > Process of Configuring Assignment Objects for Team Scoring > Extending an Object's Base Table for Team ScoringBefore configuring an assignment object for team scoring, make sure the object has the necessary columns in its database table. This task is a step in Process of Configuring Assignment Objects for Team Scoring. NOTE: You must review the sections on extension tables and columns in Configuring Siebel Business Applications before completing this procedure. To extend an object's base table for team scoring
NOTE: There are specific considerations depending on the platform you are using. For more information about this, see the note in Step 7 of the procedure in Extending an Assignment Object's Base Table for Availability-Based Assignment. After the necessary base table columns are in place, you can configure the assignment object for team scoring. |
| Siebel Assignment Manager Administration Guide |
