Siebel Assignment Manager Administration Guide > Advanced Assignment Manager Configuration >
Assigning Child Accounts Based on Parent's Primary Address
A common business requirement involves the configuration of Assignment Manager to assign child accounts based on the primary account's address. This configuration is completed through Siebel Tools using the following procedure. To assign child account objects based on the parent's primary address
- In the Object Explorer, select the Workflow Policy object, and click the Account record.
- Expand the Workflow Policy object in the Object Explorer, and select the Workflow Policy Components object.
- Create two new workflow policy components, Parent Account and Parent Account Address, with the following properties:
Parent Account |
Parent Account Address |
Source Table Name: |
S_ORG_EXT |
S_ADDR_ORG |
Source Column Name: |
ROW_ID |
ROW_ID |
Target Component Name: |
Account |
Parent Account |
Target Column Name: |
PAR_OU_ID |
PR_ADDR_ID |
- While the new Parent Account Address record is selected, expand the Workflow Policy Component object, and click the Workflow Policy Component Column object.
- Create a new record with the following properties:
Alias |
Parent Account State |
- In the Object Explorer, select the Assignment Attributes object, and create a new record with the following properties:
Data Type: |
Varchar |
Pick List: |
PickList State |
Pick Field: |
Value |
- While the new assignment attribute Parent Account State is selected, expand the Assignment Attributes object, and click the Assignment Attributes Column object.
Assignment Object |
Account |
Workflow Object: |
Account |
Workflow Component: |
Workflow Component Column: |
Sequence: |
1 |
- In the Object Explorer, select the Assignment Criteria object and create a new record with the following properties:
Display Name |
Use Expertise |
FALSE |
- While the new assignment criteria Parent Account State is selected, expand the Assignment Criteria object and click the Assignment Criteria Attribute object; create a new record with the following properties:
Assignment Attribute: |
Store Column: |
1 |
Display Sequence: |
1 |
Display Name: |
After the configurations are complete, the project must be checked into the server, and various server administration procedures must be run. To update your deployment with these new configurations, see Updating Your Assignment Manager Deployment with New Configurations. For more information on compiling projects, see Using Siebel Tools. For information on distributing the siebel.srf file, see Siebel Anywhere Administration Guide. An assignment rule can now be created that assigns child accounts based on the parent's primary address. NOTE: Make sure the child account has a value in the PAR_OU_ID column pointing to a parent account that has the primary address.
