Configuring Siebel eBusiness Applications > Editing Applet Layout >
Aligning Controls in a Grid Layout
Grid layout allows you to align controls relative to each other. To align controls
- Navigate to the applet you want to edit, right-click, and then choose Edit Web Layout.
- In the Mode field of Web Controls toolbar, choose the applet mode that you want to edit.
- In the Layout Canvas, hold down the Shift key, and then click the controls you want to align.
The last item selected is the one to which all other items will be aligned.
- Perform the following tasks as necessary:
Align the left side of controls. |
Align the center of controls vertically. |
Align the right side of controls. |
Align the top edge of controls. |
Align the middle of controls horizontally |
Align the bottom edge of controls |
- Choose File > Save.
