Configuring Siebel eBusiness Applications > Editing Applet Layout >
Spacing Controls in a Grid Layout
Grid layout allows you to control the horizontal and vertical spacing of controls relative to each other. To change the space between controls
- Navigate to the applet you want to edit, right-click, and then choose Edit Web Layout.
- In the Mode field of Web Controls toolbar, choose the applet mode that you want to edit.
- In the Layout Canvas, hold down the Shift key, and then click the controls whose spacing you want to modify.
The last item selected is the one that is used as the basis for the spacing.
- Perform the following tasks as necessary:
Make horizontal spacing equal |
Increase horizontal spacing |
Decrease horizontal spacing |
Remove horizontal spacing |
Make vertical spacing equal |
Increase vertical spacing |
Decrease vertical spacing |
Remove vertical spacing |
- Choose File > Save.
