Configuring Siebel eBusiness Applications > Editing Applet Layout > Editing List Columns Display Names and Control CaptionsYou can edit the Display Name property of list columns and the Caption property of controls directly in the Applet Layout Editor. When you type in a string, Siebel Tools searches for a symbolic string with a matching value in the Current String Value property. If an exact and unique match is found, the symbolic string is associated with the control or list column and the current string value is entered in the Display Name or Caption field. If no record is found, or there is not a unique match to a single symbolic string, an error is displayed that prompts you to enter a new symbolic string in the Object List Editor. You can also enter a value in the string override field in the Properties window. To be able to create new symbolic strings and enter string override values, you must be working with the ConstrainedMode parameter in the tools.cfg file set to FALSE. For more information about working with symbolic strings, string override fields, and the ConstrainedMode parameter, see Using Siebel Tools. To edit list column display names and control captions
| Configuring Siebel eBusiness Applications |
