Configuring Siebel eBusiness Applications > Configuring Applets > About the Role of Applet ModesApplets modes determine how a given applet is rendered at run time. Applets can be rendered in one or more modes. Each mode is associated with a Web template. Applet modes are defined as part of the Applet Web Template object type (child of applet) and are used when editing layouts in the Applet Layout Editor. The modes used most often are:
You define modes when you create applets or when you configure applet layouts. The default mode is defined as a property on the View Web Template Item object type. Related topics |
| Configuring Siebel eBusiness Applications |
