Configuring Siebel eBusiness Applications > Configuring Applets > About Applet Controls and List ColumnsControls and list columns are child objects of the applet object type. Controls implement user interface elements, such as text boxes, check boxes, and buttons. In form applets, controls also implement fields. In list applets, list columns implement fields. You define controls and list columns for new applets using the New Applet Wizard. For existing applets, you add, remove, and modify controls and list columns using the Applet Layout Editor. For more information, see Adding Existing Controls and List Columns to Applet Layouts and Adding New Controls and List Columns to Applet Layouts. List columns, and have a corresponding object type (List Column). Data entry in a list applet is performed in the cells that are at the intersections of rows and list columns. Cells in different list columns can function in different ways, depending on the properties of their list columns. Some examples of cell behavior based on list column properties are:
There are many types of controls, as defined by the HTML Type property of the control or list column object, including Text Area, CheckBox, MiniButtons, ActiveX Controls, and Links. The following topics in this section describe the various types of controls. For a complete list of Control and List Column properties, see Object Types Reference. |
| Configuring Siebel eBusiness Applications |
