Configuring Siebel eBusiness Applications > Specialized Behavior Supported by Web Templates > About Search and Find in SWE Templates > Search Result Tag: <swe:srchResultField>Purpose: Represents a result field object. Usage: This tag can be called only within the context of the srchResultFieldList and encloses the following tag: |
| Configuring Siebel eBusiness Applications |
