Configuring Siebel eBusiness Applications > Configuring the Customer Dashboard >
Changing the Background Color and Border of the Customer Dashboard
You can change the background color and border color properties in the main.css file, which is located in PUBLIC\ Language_Code \FILES\ directory of your Siebel installation, where language code represents the three-letter code for your installation language pack. To modify the background color or border
- Locate the main.css file in the
PUBLIC\ Language_Code \FILES\ directory of your Siebel installation.
- Open the file with Notepad or other editor.
- Find the following section and modify the values for dashbrdBorder and dashbrdBack as necessary.
/*Dashboard Definitions*/
.dashbrdBorder {background-color:#999999;}
.dashbrdBack {background-color:#f0f0f0;}
NOTE: in the example above, #999999 is medium grey and #f0f0f0 is light grey.
