Configuring Siebel eBusiness Applications > Configuring EIM Interfaces > About EIM Object Types > User Key Column Object TypeUser key columns can be either attributes or foreign keys. In most cases these are the columns in the user key index (usually the index with a suffix of _U1), with the exception of the CONFLICT_ID column. |
| Configuring Siebel eBusiness Applications |
