Configuring Siebel eBusiness Applications > Configuring Multi-Value Group and Association Applets > Understanding How MVGs are Implemented > About the Multi-Value LinkThe multi-value link object definition is a child of the originating business component. It identifies the link that provides the field values from the multi-value group business component. The multi-value link in the originating or joined (in the case of an indirect multi-value link) business component has the following important properties:
NOTE: An indirect multi-value link may be used in place of a conventional multi-value link when there is an existing link object definition which would be appropriate for use in a multi-value link, but the originating business component is different from the master business component. If there is a Join object definition that joins the desired master business component to the master business component of the link, the existing link can be used in the multi-value link. For more information about multi-value links, see About Multi-Value Links. |
| Configuring Siebel eBusiness Applications |
