Configuring Siebel eBusiness Applications > Overview of Configuring Siebel Applications > Other Ways to Customize Application Behavior > State ModelThe state model provides a data-driven method for extending workflow control based on the status of an object such as a service request or a product defect. A state model is the blueprint of acceptable states and state transitions that the state machine enforces. The state machine then makes sure that these objects go through the desired process defined in the state model. A state machine is an engine that enforces the transitions between states for an object during its lifetime. A state represents the status of an object, such as Open, Closed, or Pending. The state represents where the object is in its lifetime. The state can also control whether or not the data of that object can be modified. For example, a service request that is in a Closed state may be considered frozen, such that its attributes cannot be modified. A state transition defines the allowable migration of an object from one state to the next. For instance, a service request that has been closed but must be re-opened may go from the Closed state to an Open state, and may go from Open to Pending, but may not transition directly from Closed to Pending. The allowable migration of a service request from Closed to Open, or Open to Pending, represents defined state transitions. State Model is administered through the Siebel Business Process Designer on the Siebel client. For more information on accessing and using the State Model views, see Siebel Business Process Designer Administration Guide. |
Configuring Siebel eBusiness Applications |
