Configuring Siebel eBusiness Applications > Configuring Screens and Views > Defining Sequence for Screen View ObjectsYou define the sequence in which views and groups of views (categories) appear in the user interface using the Screen View Sequence Editor. This is a visual design tool that allows you to see the hierarchy of screen view records at each level of navigation. It displays the hierarchy in a tree format and allows you to move individual screen views or groups of screen views to different positions in the sequence. However, you cannot move an item out of its current category or hierarchical level. If you do not define the sequence of screen views, the Siebel Web Engine will order them alphabetically. The Sequence property displays a numerical code to indicate the sequence of a Screen View in the hierarchy. This field is updated when you open the Screen View Editor, make changes, and then choose File > Save. In the Object List Editor, you can sort on the Sequence column to see the hierarchy that will be displayed at run time. Note that if there is a null value for the Sequence property, SWE will render that Screen View as the last item in the sequence. NOTE: Screen View sequence does not affect how views appear in Site Map. Views appear in Site Map in alphabetical order below the screen name. To define the display order of Screen View objects
| Configuring Siebel eBusiness Applications |
