Configuring Siebel eBusiness Applications > Configuring Screens and Views >
Managing Unused Screens
If you will not use a standard screen in your implementation, there are two approaches to managing unused screens:
- You can use the Responsibility Administration Screen to disassociate all views of the unused screen from the responsibilities your organization uses. This approach does not require you to recompile the .srf file. It also offers an easy upgrade path if you decide to show the screen or views later. At that time, no configuration or software upgrade is required; you need only to reassign the views to the relevant responsibility.
- You can also inactivate the screen using Siebel Tools. This approach re quires you to compile the .srf file. When you compile, the inactive screen will not be included in the .srf file.
