Configuring Siebel eBusiness Applications > Configuring Screens and Views >
Creating Views using the Object List Editor
You can use the Object List Editor to manually create a new view object. However, it is recommended that you use the New View Wizard because the Wizard prompts you for all necessary information and configures dependent objects for you. To define a view in the Object List Editor
- From the Object Explorer, select View.
The Object List Editor opens.
- Choose Edit > New Record to add a new view object definition.
- Set the following properties for the new view record:
- In the Object List Editor, select the record, and then right-click and choose Edit Web Layout.
The Select Template dialog box appears.
- Select a view template and click Next.
The Applet dialog box appears.
- Select the applets you want to appear on the view and then click Next.
- Review your selections and then click Finish.
For information about configuring visibility, see Security Guide for Siebel eBusiness Applications.
For more information about the New View Wizard, see Creating Views Using the View Wizard.
