Bookshelf Home | Contents | Index | PDF | ![]() ![]() |
Configuring Siebel eBusiness Applications > Configuring Special Purpose Applets > About Recursive TreesIn a recursive tree, all levels in the hierarchy are of the same object type. For example, the Account Explorer Applet consists of a tree applet in which the only node is for the Account business component, and subaccounts appear beneath accounts which have them. Recursive trees are provided in standard Siebel applications for accounts, activities, campaigns, opportunities, positions, and various other business components in which records can have subrecords. Almost any number of levels of subrecords are possible in a recursive tree. For a recursive tree to be implemented, the business component used must contain a pointer to the record of the same type at the next level up in the hierarchy. In the accounts tree example, the Account business component has a Parent Account Id field which points to its parent account. A Link object definition must exist that references this field in its Destination Field property. In the accounts example, this link is Account/Account. A recursive tree is implemented with a tree object definition to which only one tree node object definition is attached. In the Tree Node object definition, the following special properties are set:
Configuring Siebel eBusiness Applications |
