Configuring Siebel eBusiness Applications > Configuring Special Purpose Controls >
Configuring Fields to Use Web Content Assets
Any business component can take advantage of Web Content Assets to add fields that are rendered as HTML content. For example, you can use display static HTML messages to your end users in the Partner Relationship Manager application, or represent a Product Description as HTML content. This section describes the steps for configuring this functionality, using the Partner Message business component as an example. To configure fields to use Web Content Assets
- In Siebel Tools navigate to the Partner Message business component.
- Navigate to the Message field and set the Pick List to ContentBase Asset Hierarchical PickList.
- Query for Partner Message List Applet.
- Navigate to the list column named Message Body and set the Pick Applet property to ContentBase Asset Hierarchical PickList.
- Query for Partner Message Entry Form Applet.
- Navigate to the control name Message Body Preview and set the Field Retrieval Type property to Service.
- Navigate to the Control User Props for this control and add a Control User Prop with the name Field Retrieval Service and the value ContentBase - Asset Publish Service.
- Query for Partner Message Form Applet (SCW).
- Navigate to the control named MessageBody and set the Field Retrieval Type property to Service.
- Navigate to the Control User Props child object for this control and add a control user property with the name Field Retrieval Service and the value
- Compile your changes to an .srf file and test.
